View Full Version : LT1 Based Engine Tech
- intake milling
- Royal Purple
- 96 z28 no start
- What is this mod? PCV/Intake
- OBD1 Code Scanner (16 pin terminal)
- Fuel leaking from Evap System??
- jeff s
- Help with shutting off after opti change and idiot mistake .
- Delete AIR, Leave EGR In Place - Emissions Question
- aftermarket remanufactured opti installed
- Best Spark plugs?
- High Idle Issue
- Electric Meziere waterpump noise
- Advice about no spark probably opti ?
- canton valve covers work with 96 ss ram airbox??!!!
- Valve seal help
- Need help 1996 camaro lt1 cranks but won't start!
- Over heating after brand new rebuild.HELLLLP!!
- Possible tune problem with new cam.
- Tune and Injector Size Help
- LT1 switched to LS2 Coils, should I change the sparkplugs?
- HELP with LT1 Headers Please
- stroker rod and piston selection opinions
- 1996 Firebird WS6 performance build on a budget.
- Help!!! Electronic/ fuel troubles!!!
- Need a reference pic please!
- Lt4 vette exhaust manifolds on lt1 camaro?
- you bypass the pass key
- cc503 cam question please help
- rocker arm help
- scan files
- Is there a fuel relay in a 1994 z28
- Suggestions for a upgrade path
- Help please! noise and weak crank
- Car back together, quieter exhaust options?
- Another lt1 shorty header discussion. White lightning?
- getting an a4 lt1,used to own m6, questions!
- Stock piston rods
- negative batt cable grounding point broken
- Fuel line dust coovers
- Rocker Arm Suggestions
- No start - Looking for suggestions
- loose wiring?
- bad starter
- Composite valve covers & shaft rockers
- water pump drive gear
- LTCC problem
- rebuilding lt1
- cam and e85 help
- I modified my air foil, what do you think ?
- 95z28
- intake manifold bolt
- Theft control module
- Bad opti?
- Long Start Please Help!!!!!!
- Issue with rpm fluctuations wot
- Does Holley TB Air Foil Block PCV passage ?
- Luck getting Discontinued OEM Parts
- evap solenoid
- Fuel pump primes but no pressure on crank
- Broken pushrod in 1995 Z28.
- 94Z no start, fuel press solid
- Question on crank snout?
- Anyone clean the MAP sensor 95Z28
- Any new fixes for a broken ear? OUCH!
- new opti, have spark and fuel
- Flexplate Cover Bolt Size
- Overboard
- Shaft Rockers
- Remove Air Pump 95 Z28
- P0172, p0175
- snap on scanner
- 93 lt1 z28
- oil pressure sender
- 1996 z28 stalling
- 96 Loud ticking noise and overheat
- New to LT1's
- Putting 94 Camaro LT1 motor in a 70 Camaro
- Frustrating overheating issue in 1993 Z28
- 96 camaro hesitates
- The infamous LT1 intake leak
- another misfire and idle surge
- 94 lt1 mail order tune
- Low RPM Miss. None or Very Little Miss at WOT
- Ltcc conversion benefits?
- Engine Identification
- Injector I.D
- locked out pcm
- Heads and cam build
- 383 stroker questions
- LT1 Water Problems
- 96 lt1 wet NOS question.
- I think my optispark just packed it in
- main and rod bearing replacement
- Preference on Cold Air Intakes
- 96 Camaro LT1 high fuel pressure
- oil dipstick tube
- 9495 scan
- banjo bolts
- oil pan gasket
- Ran out of fuel, now hard to start.
- 195 degree thermostat
- coolant temp switch
- open loop mode?
- How to: Remove EVAP/carbon/vapor canister and replace purge valve with pics
- Horrible gas mileage
- bleeding coolant
- 94lt1 oil pan pick-up
- 94 lt1
- Could someone please HELP?!
- LT1 Virgin needs Help !
- Low oil sending unit
- Need help on some lt1 engine building
- Piston Compression Question!
- 396 Engine rebuild Help pls...
- 94 z28 sold sold sold
- New Lsx pcm conversion
- I have a crank shaft question.....
- Optispark Front Cover Oil Seal Question
- 389 teardown findings
- 95 Formula LT1 Low Coolant light
- help im lost
- 1993 Camaro z28 LT1 6 speed
- Need help choosing injectors LT1 383 build
- VP MS109 Fuel
- 94 Camaro Starting Issue
- New Belt New tensioner and pulley belt still squeaky
- Rev limiter and reported rpm
- Will a bbody Lt1 drop into an Fbody with the fbody harness?
- Gambling on Opti replacement?
- z28 backfire ???
- 1995 Formula Starting Problem
- Mysterious symptoms? Head gasket?
- 93 Camaro z28, 6 speed - Performance Chip
- Camaro guys unite
- Wrap Stainless Headers?
- Have a lifter question please!
- Shift linkage help
- 93/94 Optispark disassembly for repair
- fuel injectors
- Length of starter bolts
- 1.6 RR pre-load adjustment questions
- Intake manifold gasket, anybody have this?
- 94 z28 got a ? HELP :/
- Lt1 Header Opinions
- 94 z28 water pump & opti ? help :/
- Hoping for Suggestions
- help diagnosing problem
- 1994 Camaro lt1
- 94z28 catalytic converter & muffler?? ideas
- my money pit
- Which 4L60E transmission for a 1995 Z28?
- 94 Formula shut down issue.
- Dash lights flickering!!
- 1997 z28 Camaro cranks n cranks no start!!
- Bad eBay opti or what???
- 383 lt1 swap
- Computer Stolen
- Array of Problems on "New" '95 Camaro Z28
- Key turn won't start!!!!!
- 94 z28 spectre vs k&n ??
- no start, smoke coming from upper part of column
- Error codes help
- At my wits end!!!!!!
- LT1 T56 Drag Racing Clutch
- Idle/maf issue
- 94 Firebird Formula - Dies (Need HELP!!)
- 94 Z28 Automatic transmission - engine stall - No codes present
- L98, LTx, or LSx, simplest to install on '87 IROC?
- ScanMaster LT1
- 1.7 RR''s + Supporting Parts
- OBD1 PCM for 1997 LT1?
- 94 z28 M6 issues
- 1994 pcm in 1995 lt1
- MIL light out...Fans come on! (FYI)
- LT1 Cam
- DTC 26: Quad driver Fault questions
- Car intermittent start, Weak/no noid light
- Differential gears
- 93 formula LT1 starts and sputters
- comp cams 1.6 rr's
- 94z28 Hypertech Power Programmer III????
- OBDI trouble code issue
- 1994 z28 lt1 engine sucks air inlet hose
- 94 z28 48mm vs 52mm tb &air foil & tb bypass &maf
- Back again Code 18 question
- Upgrade injectors and intake?
- Trickflow/Edlebrock LT1 heads
- LT1 just starts and shuts down
- High Idle fixed
- 97 Z28 hot battery no power
- New clutch - Getting trans back on
- Ohm value of temp sending unit 95 LT1
- 1994 z28 shuts off while driving
- Homemade Cold Air Induction for '93 LT1
- '94 Z28 Stalls!
- Possible Cam Upgrade?
- Rusty spark plugs (with pics)
- Transmission issue
- Fan kick on temperatures?
- LT1 Alternator wiring plug. question
- What is this???
- Removing steel plug from aluminum LT1 heads
- Missing and sputtering with data log
- holy mother of broken
- 94 z28 best exhaust & headers for your $$$$$
- shifting problems after installing a stall converter
- 94 z28 stock 0-60 ??
- Vibration @ ~2500-3k rpms
- In search of a Dyno Tuner in Central FL
- Car shuts off randomly...Any thoughts?
- LT-1 to L31 swap.
- Cam for 93 LT1
- Do I need to change the oil pump
- Hot weather issue
- Feed back on Dyno Don's headers
- low dyno numbers..
- Missing pushrod?
- 93z28 flooding
- 94 z28 camaro lt1 300 hp ?? info
- LTCC Install Instructions
- Fan problems
- Plz help 93 z28
- Intermittent accessory power issue
- 94 z28 noise driving me crazy ?
- 94 LT1 opti issues- won't rev, new opti
- Help with engine miss please
- 1994 z28 camaro smog?? & stock breather ???
- LT1 starting problem
- 1994 z28 tune up lt1 ?? why Chevy why
- Code 27?
- 1994 z28 strange problems
- 94 z28 update ? help
- Help/Car stumbling running rough
- How much is the stock lt1 flywheel offset weight?
- 94 z28 coolant sensor leaking??help
- 95 z28 Randomly dies and wont crank
- Lt1 ovreheating need help
- new z28 owner :) lt1 ?
- Does steampipe steam?
- Intake explosion and white smoke
- 97 z28 will not restart
- injectors
- Opinions on early LT1 timing chain
- Car dies when in gear
- Catalytic converter
- Car Wont Start Help!
- 1995 Z28 LT1 Idle Problem
- 1997 camaro z28 injector cycle problem
- Black smoke, won't stay running
