View Full Version : LT1 Based Engine Tech
- fuel pressure q's
- cracked EVAP vacuum hose grouped with Fuel lines
- Best set of heads for hotcam?
- Attention: Anyone who purchased from "All-Ignition"
- 2 Problems...
- Run fuel pump with engine off?
- A.I.R. Fittings
- Is this oil pump any good??
- anyone ever use this oil pan?
- runs rough under a load
- LT1 Top End noises and misses
- lt1 help
- Should I change my 145,000 mile lifters?
- Car is Running Bad
- Cam qustion help
- fuel problems...code 55
- Arp shaft question!
- First Startup Video - AI 226/234 Cam Package
- MadZ28 Tune
- weird running issues
- NapaAutoParts Flywheel, good or bad?
- Whatever happened to these guys?
- Timing chain broke....
- I am in desperate need of help. Please
- How to check the Fuel Pressure
- opinions on headers?
- Just, installed 4.10's, Madz28 tune & MSD Coil
- Will 95 lt1 fit in 96 camaro??????
- Removing balancer on an automatic car?
- adjusting LT1 rockers
- Where do these pig tails connect to from wire harness? PICS
- Neep help with cam
- Stalling randomly/stumble idle.
- Going carbed
- lt1 engines mostly metric or standard?
- Tips and Suggestions needed ASAP
- new motor question
- Need help (speedometer problem)
- IRON heads!!!!
- Still got an Oil Leak!!!
- WooHoo! Passed smog in CA!
- Motor not turning over smothly?!
- Easiest Big Block Engine Swap?
- How Much Fill on an LT Block?
- next mod ideas
- Engine Problem
- what should i do next?
- Budget minded 383
- Need Help, thermostat housing.
- LT1 Help Please
- fan switch install prob. 95z
- lt1 problems
- Its So Frustrating I Dont Kno Whats Wrong..
- Lt1 tunning programs?
- How to bypass all accessories except alt.
- Next Modification.
- hotcam with stock springs?
- My engine quits on me
- Camshaft imperfections?
- Unplugged connector?
- Gtech my car today
- shift light?
- still leaking oil...
- Thread sealant?
- Oil pump drive gear question
- lifters
- Difference betw. Tune up vs Dyno Tune
- Optispark.. wrong way?
- New Stroker Motor Startup. WHite smoke NEED HELP!!
- Lt4 Hotcam ?
- Cam Bearing Gouge
- GMPP LT4 Hot Cam kit-Expected gains in a 95 LT1?
- Fuel pressure Bleed down
- HELP ME!!!! Engine code P0336
- Help On Wiring (pics Included)
- Need Help To Figure Out Whats Wrong
- Need Help To Figure Out Whats Wrong..
- Strange LT1 Tach problem- works until 4200rpm, then goes to zero
- LE packages & setups..gone?
- OBD2 Engine and OBD1 Computer
- REBUILD CLUB: Proper initiation rites
- Hot motor slow starting
- How long until computer re-learns settings?
- weird glitch?
- cylinder heads are hot
- Cam Swap, Suggestions?
- Codes 16,36?
- Hotcam Checklist? v.2
- oil seals for timing cover
- Help Please - Fuel leak at the end of fuel rail
- AFR Hydra-rev kit part #
- Motor Blew What To Do???!!!
- Opti O rings?
- Oil psi drops to 5 psi under hard braking - help
- Wheres the Cheapest Place to buy LT Pacesetters?
- Need PN for opti harness for a 93!!
- One Polylock Keeps Backing Off
- Deleting Cruise and Airbags Question
- Which pig tail is this?
- Sewing machine sound w/ 1.6 rockers
- Barebones cam swap...
- Blow by
- 383 build for next year!
- Stock Timing
- LT1's place in history and future
- 1988 5.7l 350
- LT1 harness Question
- Guess on gains . . . ?
- 1994 z28 hollowed cat now won't start????
- low rpm bog only when its hot
- 383 dyno results
- Backfire question....after heavy accel....
- ignition misfires
- Rebuilding Z - Soliciting Opinions
- Please advise on LE2 valvetrain
- Engine removal question
- Camaro not Starting again!!! HELP
- Burnt valve question
- 10.847 @ 126.08 staight off the trailer first pass of the year
- Rod questions for 383
- Hypertech programmer
- Can anyone help with this one ???
- How to take measurements on engine block?
- Can LE3 heads be used on stock shortblock?
- BLM issues, pulling hair out and need help!!!
- Part numbers for Vacuum Hoses?
- Induction Flow?
- CC503 Road Trip MPG
- Probe Industries Kits
- 1995 Z28 cooling fans
- Valve Train Weight?
- 95 Z28
- eng. still has a prob.
- HotCam Kit for 383???
- fusebox help
- Possibe exhaust leak! I hope!
- GM High-Tech Perf tests the Edelbrock LT1 intake
- Emission Help
- backfire helppp!!!
- seat pressure and stock valves
- I think it's the opti
- Spark plug?
- Wet EGR valve
- water pump
- differences between LT1 and Lt4 mani?
- Engine shaking between 45mph-55mph @ 1250rpms????
- Hitting up the dyno
- Increasing displacement questions?
- 300rwhp and 325 rwhp?
- Tune? or something else?
- CC306?? Cam identification
- AFR 195 Comp Eliminators
- valve spring recommendations?
- Wiring Help Needed
- ram air kits
- Water pump drive shaft q...
- EGR shows 6.3 or 12.5 percect
- breaking up over 5K (non opti problem)
- Ground Problem
- Is our flywheel and coil springs/rear springs made from ac delco?
- Could I achieve 400rwhp with this setup?
- whats up with thses cams?
- Oil dipstick bolt
- LT4 heads?
- How do my cam bearings look? PIC
- uh oh, forgot to put this back on!!!
- supercharged 355?
- one cylinder misfiring randomly
- Will this be a good cam for me?
- a couple of exhaust questions?
- IAC question ..
- Stumble after MAC header install
- 94 LT motor in 96 Z28
- Starter Or ignition switch problem?
- Lt1 Loud Knock Won't Start Banging
- LT1 starting issues - opti/timing belt...i need a car please help!
- Plugs
- Here's a thought:
- noid test.....very dim flash
- downsizing cam ..
- Where can I find Instructions for Hypertech III?
- fel-pro rear main seal/gasket set (BS40520)
- 1.6 rocker install
- Hotcam Checklist?
- Afr 195cc comp. Emissions legal?
- Hung up on timing cover removal
- air pump questions
- 42lb injectors
- No run LT1
- Ajusting rockers lt4 hotcam - help
- 2 Questions: Finding TDC without removing front cover & ring orientation
- lt4 hot cam - valvetrain is very loud
- Can I use different plug wires?
- Way too loud! Time for muffler change.. Recomendations??
- head gaskets
- Another LT1 missfire but gone worse... need help
- exact specs
- One side of engine having lean issues
- no spark from opti.........
- CC503 Cam Surge?
- Opinion On This Roller Rocker Install Walkthrough?
- glowing cats
- leaky valve covers, which gaskets?
- Charging/Electrical problems
- Car died on me on the road cranks but no start?
- Preload
- ses light
- got some money
- Running Rich???
- Bad water pump and opti
- Redline question
- air pump
- LT1 WS6 air boxes....
- ls7 lifters in a lt1
- Advanced charging issue
- ultra z
- Cam Parts
- Fan issues. reversed wiring?
- Looking for someone who tunes LT1's in Colorado
- i need help
- problem with my ol lt1 running??? pics inside
- Which specific sensors are "ignored" when engine is in open loop?
- which CAI?
- missing hose/line
- Blue Smoke Out Exhaust
- wierd clicking sound comming from engine
- Sigh...LT1 Valve Cover options....
- Looking for loss power
- g7 hypertech chip
- LS7 Lifters Individual Partnumber
- Can anyone look over my logs?
- Throttle bodies
- LT1 Ac Delco Reman Engine
- Nothing but problems
- What do you think I broke? Ran W/O Alt. Harness
- 97 ss lt1 won't fire for nothing!!
- Thermostat?
- Starting a 383 build
- opinions please
- individual coils
- main cap stud questions
- Question for Shoebox or Injuneer...Part #'s
- balancer bolt
- Impala Gaskets?
- Stuttering / Missing
- 383 stroker---making a thumping noise-- *vid*--please help
- Car trouble starting! HELP!
- Engine knock, with video
- how to tell...
- compression ratio vs. octane?
