View Full Version : LT1 Based Engine Tech
- Anyone here using 350TH
- Quick ?
- pete jackson gears ??
- Quick help, Simple spark plug and spark knock questions
- what's the different between TH400, 4L60 and 4L60E??
- Transmission failure
- Are stock 3.42's enough for cc306??
- slp/yank stall?
- Cost for head work?
- links to a converter install
- Anyone ever research rebuilds?? 350, 355, 383??
- ? on CarFax results I have
- Brake Pads, Hawk or EBC Green stuff
- Paging - Mark w/ the Blue 94Z
- Exhaust Manifold Query
- Grotyohann headers?
- 383 Stroker Question
- would bigger t-body/ported intake reduce/eliminate cam surge w/ big cam?
- Suspension: Help me lower this freakin car!!!!!!
- Anyone T/A's out there that did something stupid like me and break there antenna???
- What is your oil pressure at idle?
- want to blow some money
- Any easy places to route the wiring for a dual DMH cutout?
- Question Regarding OBDI Swap
- What to do with O2's
- rate these bolt ons
- Need Cam Help
- Curious about CAGS skip shift
- Performance sites
- Cloyes installation ?????
- XE time/hp guesses
- Started went out AGAIN!!!
- Question on Corvette servo on the A4
- Anything wrong with changing oil every 1k miles?
- confirm for me how trap speed calculated
- Okay, I need help with this...
- Rattles??
- Mercron tranny fluid?
- First long tube install!
- whats all needed for 396???
- *HELP* LT1 to LS1 rear axle swap question
- Power Steering Fluid?
- Buying a 95 TA
- Wat else should I replace??
- What makes OIL get so BLACK???
- 95' Camaro Z28
- is it bad if lifter retainer is on backwards??
- bent Chassis
- '93 Guys....What cam do you use?
- Question on code P0430 and how to fix it
- I need suspension help
- What are the components that make up the "BOTTOM END"
- Flexplate for TH400 setup?
- Back together... Now a noise on input shaft.
- Adjustable PHR and LCAs...why?
- antiseize or thread sealant on intake manifold bolts???
- CC305>>> times??
- Rear End advice
- XE 230-236 Clearance?
- Anyone know the part number for a OBDII O2 sensor
- Which AFR's for my motor?
- need some help from the gear heads
- An idea for passing emissions.
- Just a quick note for all you "i want xx.xx sec timeslip guys"
- help please
- 9 inch Ford rear-end
- These good flow #s?
- B & M or Trans Go shift kit
- waterpump is taking a dump...what to buy?
- Paging Shoebox! testing info needed for DI Low Res code
- BMR Finally Installed
- Last Night Black Smoke... Now Stall!!!! Ahhh Whats Happinging To My Baby?
- Could I hit 12s?
- heddman headers ????????
- What gains can I expect from these mods?
- LT4 intake Q's
- Pcm4less
- Best place for Tranny overhaul kit?
- Holley is the BEST TB out there!
- GNC Stage 2s...HP?
- O2 Sensors OBDII to OBDI conversion
- Which brand of headers are the best?
- how often do you reset valve lash?
- WHAT STYLE o2 sims are used on a 96z flat or square connecter?
- Correct Driveshaft length?
- Your thoughts....3in or 2.5in true duals???
- Jim Pace Lt4 hot kit
- some adivce please
- how to tighten fan belt???
- Where to put MSD box!?
- Is my car running right?
- Timing sets and covers
- Injector Options
- any body using a catco cat?
- Headers and Cat-Back
- Mass Air Flow Sensor Questions
- Pan rails w/Canton Pan
- Do these 1/4mi times sound normal?
- Exhausted issue
- looking for parts
- Open vs. Closed Loop on Hotcam car
- Longer install: Heads or cam?
- Gear Suggestion??
- Strange ticking after IM leak fix & OVC wire install
- shaking in the car
- hypertech programmming
- what size???
- Gas mileage???
- car stumble on the freeway, around 2000 RPM under light throttle, only when in OD
- Any H-pipe true dual owners??
- Anyone tried the BOSCH O2 sensors
- removing catalytic converter
- Car wont stay running
- MaGnAfLoW C/B Owners
- Simple Exhaust Tip ?
- diff between 93-95 & 96-97
- Loud Tick that increases with RPM
- Comp LT-1 Xtreme Energy Cam
- LT4 hot cam kit Q's!!!
- First Hotcam results
- what kind of oil for rear?
- Anyone Using after-market Auto Shifter
- LT1edit and laptop Beginner Questions!
- Taylor OVC = Valvetrain Noise???
- 3.73 Vs. 4.10
- lt4 heads ?
- Replacing airbags and dash, Any hints, help?
- many probs...still new and need help
- 160 thermo temp?
- Edelbrock Catback - Any Good???
- Headers for a 94
- Engine Temp
- Code 1371?
- Star Clutch
- LOTS of Parts needed for a 93 z28 LT1
- TransGo question
- car spinning 1 wheel
- Dyno Results!!!!
- Blinker not working.
- Zoom Clutch
- Those with BMR Relocation Brackets...
- autolite plug wires
- Cam and Tq vert questions
- LS1 brakes, Is this everything?
- 3.73's, 6 speed, gas mileage?
- If LM is only 3" pipes and resinator then...
- LT1 Ram air stuff from SLP
- Th400
- no question here guys
- what now
- did any camaros come with the LT4???
- LT4 heads: Post your #s
- popping sound from front left wheel
- Cai 93 Z
- Ever Tried the Tornado?
- Temperature Gauge
- anyone with MSD 6AL on 94-97
- Ever used....
- Weight of an SS catback?
- Lock nuts for Lt4 crane 1.6rr
- I got a quick OBD1 doesn't like big stall TC question.
- TransGo
- ABS INOP light wont go away, please help
- What is CAM SURGE?
- TCI Converters
- Transmission Performance button
- Help!!!
- help please, LS1 brakes on ebay..i must be out bid!!
- Hypothetical: What would be involved in retrofitting SFI onto a MFI LT1?
- Loud squeaking sound
- rksports
- LT4 knock module
- Speedo Drive Gear
- Please help me ease my nerves!! i know black smoke means unburned fuel but...
- CC305 question
- Engine Temperature
- wolf craft weld in cage ???'s
- Guys using a cat on there Hooker LT's have some ?'s
- And another cam question!!!
- Morgan Motorsports?
- Long lugnut covers for ARP wheel stud users
- Quick Question abuot !EGR
- Are MAC headers 1 5/8 or 1 3/4???
- Fuel pump/pressure related...
- intake manifold leak
- Octane Calc?
- Spark plug wire
- Gas mileage with Hotcam
- Serious head choice opinions need for my 383
- Anyone install Accel Fuel Pressure Gauge?
- A4 and TORQUE CONVERTER PROBLEMS
- MY 2003 GOALS am I aiming to high?
- So whats the deal with cutouts
- local GM dealer will not make good on air pump recall unless i have a campaign #
- TSB's?
- Where to Get SPEC clutch?
- Valve seal part number?
- removing cloyes double roller
- seized plug took out some threads.. help
- Harmonic Balancer
- What gear do I have
- accell or msd ignition box
- A few problems I need more help with
- How much for a T/A hatch?
- why would you buy a fuel press reg cause dont the computer make it useless
- Could I have a vacuum leak only during decel?
- Block drain plug on passenger side??
- MSD BTM Ignition question
- Shiftlight Install
- M6 guys with 3.73's...please take a look!!
- Impala SS header Q?
- pics of my new car
- Radiator help please...
- Holley Throttle Body Issues???
- fuel rail question
- To all FLORIDA Camaro Owners
- When Does Your Clutch Engage?
- PLEASE help with heads!!
- Putting '02 10 bolt in my 95, it will work right??
- Interior Lights
- A way to test a coil?
- HELP gpoing itno gear is hard, reverse is near impossible
- Which way is up for Impy Head Gaskets?
- supercharger
- advice for replacing egr valve
- Moser 12 bolt axel seals question. work in progress
- Pro 5.0 Shifter Question (Already Have one)...
- Excellent Flowing LT1 heads
- Headers, Headers, Headers - Come give us your opinion!
- Question about stall conveter.
- What are The best spark plugs and wires for Z28???
- Switched
- oil change
- After how many miles tranny fluid need to be replaced?
- Cheap stuff to do..
- 97 T/A to 98 T/A conversion anyone where to start and where to get the parts?!
- Need FSB end link measurements
- Cheapest full length headers?
- Guys w/ LTs please read/help.
- Stock-headed CC305 - New Best - Video
- Loud noise from drivetrain
- Fuel Pressure ????
- I need some clutch install tips...
- Shoebox's Coolant Diagram
- What year springs are these?
- How much transmission fluid do I need to refill my car? 700R4 help
- How much for a Valve job and spring machining
- too much thread sealant help!!
- Window Motor
- Nitto 555 Drag radial or BFG KD drag radial?
