View Full Version : LT1 Based Engine Tech
- Scanmaster work on 1993 Z28s?
- Aftrmarket Starter Install Question
- fuel pump?
- Engine opinions needed!
- MSD Plug Wires?
- remove cat??
- What kind of rear wheel are we seeing in 383's?
- alarm/starter kill bypass
- Question on unplugging my MAF.........
- Suspension....
- Combo Motorsports Package
- Head flow numbers... Finally! (AFR's done by Race Prep)
- new to me 93 z28
- Will 26" ET Streets fit? Lowered
- Bad cold starts
- HELP! Car wont start after garaged for winter.
- 6speed swap problems
- 5 speed LT1 in '93????
- how is this sound to you?
- LT1 Computer & Wiring quesiton
- header gasket
- FINALLY got my 3.73's installed!!!!!
- Differential question
- Size Dimensions for LT1 Intake Manifold
- Test the PCV valve?
- Quick CC305 question
- File named .... z28exhaust.mpeg
- ANYone put a cutout ON the cat?
- heads/cam/headers project ?'s
- Hotcam or CC306? RWHP difference?
- Fan Switch ?'s...93 A4
- Show me your clips (of exhaust sounds)
- Shocks?
- bad battery?
- what did you pay for your Hot Cam kit?
- Strange or Moser 12 bolts???
- 1996 ss question???
- Hot Cam Question-read this!!
- Question?
- OVC Wires?
- are 2 12in long bullet mufflers enough for my true duals?? Or should i buy more??
- CMotorsports Spring Set Impressions
- set off codes
- GM 1.6 Roller Rockers?????????
- A4 kick down two gear on the freeway????
- is my advance right??
- I think my opticrap went bad again
- Cooling system OVERHAULED, still running hot
- Anything To Be Gained By Putting 3" Catback On A Stock LT1?
- TB bypass on a 97
- walbro pump/fuel pump return hose not on?
- bosch platinum +4s and nitrous
- !egr and!air
- Production Numbers and RPO Codes
- Deleting of rear 02s hurt/help performance?
- What Could This Be ???
- A couples of weird sounds from down under
- Things to look out for
- MAF home-porting success rate
- MAF question
- cooling question
- Gains from Longtubes on a stock motor
- M6 Gear Ratios
- lt1 swap
- installing LT1 from the top
- What all factory cd players will work in a 93 firebird?
- Man Just Cut Cats Off Aawesome! Got Question
- installing ASP Pulley
- I think my shocks are gone
- Need some info
- Flexplate Question
- directions for ZEX install please!!!
- Engine Dies and Dealer can't find problem
- Car won't start, need help diagnosing the problem.
- PCMforLess trouble again, file not found?
- 383 pre-built?........or build it myself?
- Good alternator or starters out there??
- air pump???
- ProForm Roller Rockers?
- stock 10 bolt is it series 3?
- guys need quick help here please,xcelerator muffler?
- Do I need to get O-ring gasket from SLP?
- Thinking of doing a heads and cam setup.
- Highest compress ratio w/ 92 octane
- dynomax cat back
- What is the fastest cam swap time???
- Car up and died on me...
- T-56 guys please help
- where to find???????
- just run
- Cheapest Hookers
- 10-bolt vs. 12-bolt
- Disabled air/egr w/95 opti
- Magnaflow hi flow cat
- new member exaust questions. Please help!
- Does this sound right?
- Part No. for black Lug Nut caps.
- Low RPM Stumble - Possible Fix?
- Longtube Header Install
- Need A Dyno Graph with the cc305 installed?
- Just got Myself a Multimeter
- Change gasket?
- '95 differences: Calif vs. the rest?
- CSI WP for 97 z28 ????
- Lloyd Elliot
- Hooker Shorty Install / Gasket Problem
- 30th Anniversary Stripe Question
- Will a 5speed center console work in our cars
- milling question
- Rear 02 sensors
- what exactly is top end and bottom end power when talking about cams??
- Could EGR cause this?
- Help...I'm new with valves and P&P....
- 15/8 to 13/4 header gain?
- Keep hotcam, or go for the 306?? (convince me)
- LT5 Swap
- 93 T/A - Wont shift into 2nd gear under WOT, bangs rev limiter
- what is this hose??
- Tranny noise
- car wont idle
- Will a CC305 pass emissions?
- Egr Hard?
- 305 vs. 306 race!
- ANYONE W/edelbrock shorties In here ASAP please
- Head cam combo for 383 guys
- porting help advice
- Best Way to build up LT1 Heads
- pn# for auto dipstick?
- Trans help PLEASE
- 1st gear block
- best heads for a 396?
- lots of miles,,smoking??????
- Resale Value
- Oh #*%^!!
- Custom Y-pipe
- A testament to the tenacity of a LT1
- Tired Valve springs robbing HP?
- CC306 need help and answers.
- MOTOR HP #'s
- ASAP! Need help on identifying this GM cam
- How much does custom tuning cost
- Baddest Setup
- How to get the plug out of head for Jet Fan switch install???
- csi waterpump question
- hypertech
- What stall should i go with?
- Going with Dynomax Super Turbos on The True Duals
- Bigger Valves: Worth it?
- How much for a system with eight oxygen sensors?
- What is a " wide band 02 sensor " ??????
- Any one with a 12 Bolt Moser please Read
- All people using 3/8 rocker studs???pls!
- Guys with 3.73's or 4.10's
- Weight savings with T56 over 4L60E?
- Pushrod direction ??
- interesting roller rocker problem!
- Help, my car isnt doing so well!!
- Tire Rotation
- Serious Questions on CC306 and XE 230/236 cams please help
- was quoted 1100.00 for cam install does this sound right i hope not
- GET IN HERE LT1 engine builders
- 3.73's OR 1.6rr
- Anyway to adjust kickdown on A4, besides PCM.
- bad opti or bad injector
- Need an opinion
- ***What is SLPs Email Address***
- Is this a good deal for a T56 conversion
- ??tranny swap??
- O2 bungs or no?
- Engine Misfire Code
- what could happen if??....
- Ignition Coil compatability
- What else do I need?
- SLP take off differential
- Looking to buy this car. Can someone do a carfax please?
- Nittos and Rear Ends. Am I gonna break somethin?
- Loose driveshaft splines
- Cheap optispark.
- Shifter won't lock, car keeps rolling!
- 96 Z A4 no selector for 1st.
- Linear rate springs.
- Best cam for my car???
- Possible to get fuel lines wrong?
- Header Question?
- Help With Line Lock!!!
- Taller V-Covers With ALL 1.6s????
- XE cams
- Pinging heard after cam/head work
- Got Loudmouth On....HOT DANG!!!
- Throttle body cleaning?
- Opti Spark, "Modified Cam Gear"??
- Question about my y-pipe and starter
- Rear axle brake lines, are they pre-bent from the dealership ???
- how much better is a 355
- Has anyone tried the Tazzo Performance Computer?
- Suspension question please help!
- Argh! Someone help me! I think I may have bent a valve!
- OEM shock life? cold weather weird noise?
- do LT1's loose power?
- Motor "Blubbering"
- Please help! Best shorties and cat back for 1997 WS6
- Best Non Synthetic Tranny Fluid
- Is it Possible?
- Need help finding the Trans-am emblems that are on both doors
- Exhaust leak..diferences of opinion
- How to launch with a stall?
- fog light??
- Pcm
- Car will Only run with the coolant fan fuse pulled !! WTF ???
- Dissapointing dyno results
- PCMforless...what to do?
- New Gears/Wheels, Speedo off, what Speed with 3.73 @ 3000 RPM
- Center Console
- Air pump inline valve question
- Emissions?
- Link bolt - Stab bar to low control arm
- Good exhaust shop in Orange County
- service.gm.com ???
- SLP / YANK 2800 Stall Torque Converter Myth?
- Exaust leaks
- CC 306 and stock tuning?
- Good deal? help plz
- roll bar need help!!!
- I just got my Qwik Stick.
- Blew tranny, do i need new tc?
- Greetings!
- Timing question
- New Valves?
- belt squeak w/ no wear, o2 sensors, and high temp rubber
- **** The T_bypass
- problem?????
- Switched +12V Connection
- FLP LT's-Good or Bad?
- Guys W/BMR Tubular Kmember...Whats involved???
- OK...frmula thinks that frmula is getting raped.. how much you pay for pf25 ac del.
- Help this future F-body owner out VOTE!
- Vibration in 3rd gear of 700R4
- Knock knock....whos there???
- LT1 Scanmaster
- Converter guys inside please!
- part # for head bolts
- window motors
- where to get vortec elbow
- anyone wanna tell me exactly where the intake studs/bolts go??
- strange belt noise
- New clutch installed now bad vibration!!help
- VERY slow acceleration and O2 Sim Q's
- changing oil every 4000 miles with semi synthetic??
- transmission seal part #
- Are there any good shops in CT to do performance work?
