View Full Version : LT1 Based Engine Tech
- Y-Pipe selection..Input needed!
- Making its official CZ28 Début: The Ultimate LT1 Header Information/Survey Page!!
- Why is my rough idle gone with Air on.
- Part # for Ashtray cover
- Quick Question MAC Exhaust
- finally car fixed
- Stock Shifter??
- 93 tranny problem
- Somethings Turning ON/OFF????
- Anything to gain by ditching flowmaster for LM
- Not tech but q about price of 95 TA
- using ram air hood as intake cooler?
- Fried heater hose
- Help, need to disable starter kill on alarm
- Vortec Heads?
- STB - which one?
- Tranny bearings and rebuilding t56....anyone do this?
- As&m Headers & Oil Cooler?
- EGR valve location
- Corsa exhaust
- Do I need to reset PCM after installing new TPS?
- Long Tubes ???
- clutch issue...
- Jet Hot 2000
- Part# for the rubber that surrounds hatch window??
- Need advice on Auto Security Devices
- shim flywheel?
- Rwhp Poll Does This Suck
- Moroso Cai
- Stock Cam Vig 3000 owners ? about manors
- 275/40-18 tire work on a Corvette 18x10.5?
- IAT - Unplug or relocate (already did a search)
- what all will these wheels fit on???
- Can it be fixed?
- Car running rough....need advice.
- Keep Ram Air or Not???????
- What mod to do next?
- LT4 Hot Cam...What more do i need?
- overkill? slp shorties not cats and cutout what do u think ? sounds awesome
- Coated Headers
- Subframe measurements
- What is this? EGR??
- Moroso Racing Oil Pump Question?????
- Hydra rev kit, Stock Springs?
- How much Hp will this exhaust add to my car
- Got all wet. How long does limp home mode last?
- Will a '97 T/A inst. cluster work in a '95 T/A?
- Aluminum d/s problems still!??!??
- build a 383 yourself, is it possible?
- Brake Rotors
- Any pics of your Lowered Longtubed Fbody??
- Air/Fuel ratio monitor
- any1 no a good website for engine rebuild kits?
- A\M electric fuel P.gauge
- Hooker muffler?
- MAF question
- LT1 vs LS1 drive shaft
- Hurst vs. Pro 5.0 vs. B&M
- How much should I desensitize my KS on my 93?
- Bleeding the heater core lines..
- Idle Question..
- Buying a new car, how many miles do LT1s last?
- Open exhaust/burned valves ??
- Borla Headers???
- Removing vapor canister and rerouting lines
- Do you know where my oil leak may be coming from??
- ZZ-9, ZZ-9x, Hot cam????
- good converter?
- BBk Pulley??? worth the$ from jegs
- 4L60E -> TH350 Conversion Information
- Green Coolant Vs. Orange
- Nitrous question
- new motor pics
- Might be buying Impalla LT1. Blue smoke = intake leak?
- Hey Everyone...Help me out....what to get next?
- Another tranny bites the dust
- How will a BMR Trak Pack benifit me?
- Throttle Body Bypass???
- SLP STB Install problem
- stock ignition coil
- header coatings????????
- Two very stupid questions...
- Guys with small cams, how do you like them. under 224/230 please
- Anyone Who has removed their fuel tank, inside please!
- SLP Y-pipe with random tech cat question....
- LS1 brakes question
- low rpm hesitation
- Need a part #...
- HP and Rocker arms
- Gmpartsdirect.com part number question
- Stall questions...
- What the heck? Oil pressure drop on easy stop?
- Dyno #'s
- bad wheel hop when i turn right?
- I did a search and still can't find.... What 1.6 RR fit under STOCK valve covers???
- Anyone have info. on the Mcleod Adjustable Clutch Master Cylinder?
- 1.6 pro-mags and stock valve covers? what do i have to do?
- stock heads flow numbers?
- oil pressure and trans fluid
- tranny problem, anyone know if I need a rebuild?
- peg leg or posi
- white face gauges
- blower doesn't always work? help
- should i buy this?
- is there a way to test the opti once its removed
- Best Tuning software?
- In the process of M6 conversion. HELP ME
- Help please, cant get back on stupid heater hose clamps
- Do 93's have a knock module??
- DMS or BMR which lowering spring do you recomend??
- What Performance Parts Should I Buy?
- Maf Sensor
- Pulling auto trans. HELP
- Does anyone think it will matter....
- no CAT=more hp??
- Sweet Thunder after cutout install!!!
- Proper pushrods to use with XE grinds
- quick question about LT4 Hot cam, stock lt1 springs, 1.5 rockers
- valve spring help
- low rpm surge solved, was a $30 part
- moody LT1....any ideas?
- C5 LT1 LS1 Braided brake lines. Is there a difference in size, length, compatibility?
- headers
- EGR Simulator
- tire speed ratings
- Turn signal doesnt work
- horsepower level with these mods..
- ignition switch melts!
- Couple o' Questions
- Where to mount BTM?
- Anyone know the CFM rates for High flow cats vs muflers
- Need options on H/C combo
- LS1 air lid on LT1
- new member estimated RWHP and RWTQ
- cam install
- pcm map
- Bose speaker ?s
- Cat Question
- TPIS Long Tube headers/ or mid length headers
- What do you guys think of these Accel ignition parts?
- how easy is to swap a lt4?
- stock vs aftermarket shifter m6?
- Quick MAF question
- 700E Mega Raptor is on order :)
- how do i remove 4th gen transam foglight ?
- Torque Converter Lockout
- opti spark
- Help!!! Need Pictures of Intake Plumbing
- Help!!! Need Vacuum Diagrams
- Possible Cam Install Error--help!!!
- Full Pillar???
- getting EGR and AIR programmed out? removing AIR pump?
- Gears!!!
- What Cam for ATI 6 PSI????
- Flowmaster Should I Keep It Or Not===>
- Mac Headers underneath pictures Anyone have?????
- cooling fan problem
- Electrical problem
- LT4 intake gaskets pn?
- Do LT1 head gaskets last, should I change with cam install
- Problem with the engine
- 355 OBD1 T/A Doesnt like closed loop??
- Parting out 94 Z28 hard top
- 93 Z28 6 Speed
- What should I do next? opinions please
- The best head/cam combo
- Ceramic Coat or Paint
- Any suggestions on replacement clutches?
- broken m6 shifter boot..please help
- Egr Solenoid
- Dual electric cut outs
- COST of lt4 hot cam kit install?
- Cloyes Timing Chain Part #
- Is upgradinig to a ported intake manifold worth it?
- How hot should a bone stock 97 A4 Z run???
- What brand of 1.6 rr's, where at, how much.
- Gas in oil?
- Electric cut out websites?
- Airfoil
- NEED INFO on Reliability of Stroker motors
- The rest of my True Dual **videos** inside
- Spark Plug Problem
- **Y-pipe**
- How to get Ignition coil off bracket ?!?!
- questions about cat backs
- Got my cutout in the mail today!
- converting to power windows Need help?
- MSD 6A Where do I put it?
- Test n/m
- miss or cutting out and icm?
- Car is smoking but its not coolant?
- Rear End Woes Help Please!!!!
- Heads have been ported now what machine work is needed?
- if i add alt pulley to compensate for ud pulley wont it basically cross it out
- gasket part #s?
- reverse lockout or cags
- Recomendations on what size valves to use on my LT1 Ported Heads...
- Hybrid Opti
- Lobe Seperation ??
- Dipstick won't go back in, can I cut off most of the tube that goes into block??
- mac's on 97 dual cats?
- Help !!!Keep Burning Plug wires
- I need advice on tires
- Doors won't stay LOCKED
- Oil Pump ???
- New Guy here Got a few Questions
- Hal or billstien
- Y-Pipe Leaking Fluid!!!!
- Need Prices and Locations, of parts that i need for the 383 project
- Wiring help?
- www.wotelectronics.com = good customer service
- A simple question
- McLeod going in on Sat, couple of questions...
- Whats the smallest I can fit on 17x11?
- What happened to the Hurst rachet shifter?
- Lifters needed for LT4 hotcam kit
- Still a rough idle!!
- Hooker Headers
- proted heads for cc305 swap?
- Powerless windows on my door
- Would this set up be worth it?
- my dyno results
- Too loud for local smokeys ?
- Can someone verify some part numbers???
- BAD Cat!......or NOT?
- Stage 1 or 2 clutch
- Flashing lights
- roll cage, when it it time?
- Just recieved new Revised Canton oil pan..
- Can you put the engine in with hooker LT's bolted on???
- Pro 5.0 install
- 4.10 gear owners step inside!!!
- Anyone with pics of underdrive pulley?
- How can you tell which head gasket is leaking?
- Part No. Required for GM remote button pad.
- ? sbout tuning in combo
- horrible gas mileage...fouled plugs...
- Removing Rear shocks
- need some help
- The correct way to set valve lash with Hotcam kit?
- Could misadjusment of rockers cause pinging?
- How will I do vs. 2003 350Z?
- Tranny Install
- Can anyone teach me about castings/intake runner CC?
- What channel ABS does my car have?
- New Meziere water pump and housing
- JETHOT LTs Install questions?
- Need help...looking for Headers
- Will a Spohn Torque Arm clear my True Duals?
- 355 buildup with stock crank?
