View Full Version : LT1 Based Engine Tech
- schredor valve
- '93 experts inside
- in midde of mac header install.. y-pipe won't fit!!
- Car Craft dyno tests LT1 bolt ons....
- Injector size
- aluminum drive shafts
- how do i fix my y pipe???
- Ignition Switch be causing Code 46?
- 236/242 with a 383?
- traction problems
- air pump
- changing front shocks
- Magnaflow
- WTF? this can't be good!!!!
- Timing Chain Heavy Duty ?
- I think i found the limit of a stock rotating assm.
- NGK TR55 question
- cags!!!!????94z?
- need help ASAP!! valve spring removal
- Magnaflow/Hooker Catback
- What bolts do we use?
- 1.7 rockers=bigger cam replacement?
- headlights (right bright on all the time)
- Best Torque Arm?
- Corsa GTR tips
- Please help! How do I run 94-95 headers on a 97???
- performence rebuild
- Part numbers for 1LE foglight delete
- Mac headers, please help!
- LT1 rocker suggestions
- Deep trans pan pricing?
- swapping ls1 in place of lt1???
- Paging: Injuneer D.S. Question???
- Incremental increase of Bolt ons??
- LS1 injectors
- ABS Q. switching to 8.5" rear
- Headlight Replacement Question
- battery light appears for a second sometimes?
- Someone please tell me what this hose is for!
- headers????LT or shorties
- BBK Headers
- gm part number????
- taking off rear shocks and the nut keeps spinning
- Ticking rear suspension
- longtube or shortys? for 1/4 time
- Any downside to LT1 Xtreme 224/236 nitrous cam with stock heads?
- Those running skinnies up front please come in....
- Most Common Error Codes/ SES causes
- Where is the tach terminal
- Removing dipstick. Need to drain oil?
- Rebuild... am I missing anything?
- HELP! Removing passenger side header
- made big mistake messed all my needles up when i did my white face guages please help
- Someone explain to me what roller rockers are
- Exhaust + Emissions ?s
- 4L60E to 700R4 swap
- Someone told me you can remove the thermostat?? Is this true???
- offroad y pipe
- cc305 w/nitrous
- gauges
- Currently doing heads/cam...few questions
- Need Advice Building an LT1 383 w/6" Rods
- Hey Fellas, I need a couple of DIY guides for my spring upgrades
- 4l60e Removal
- injector question
- Key to check codes on 94?
- Big Time troubles here, please help
- Where to get Ram Air scoop
- SES light on 94 T/A - how to read?
- T-56 fluid question
- will these springs work with my cam?
- How much more HP can I squeeze?
- Blower Cam Installed
- need to pull engine
- quick question
- Moroso plug wires
- gas fumes
- Need help, car keeps dieing!
- Parts Catalogs
- Help with car, got 4 codes when car stalled!
- What part of the cruise control system is most prone to failure?
- Custom exhaust, anyone do something similar?
- Car Revs slow, What to check?
- 1 O2 Not Working Other is Way Rich, How to Fix?
- Front License Plate install
- what headers should i go with(help)
- Need help buying my Z28...
- Help Quick Guys - Radiator Problems!!
- Replacement Starter?
- aftermarket fuel pump
- nitrous works jet sizes
- 93 speedo and rear gear questions
- stock cam question, just need opinions...
- Low Oil Press.
- I Dont Think My Fans are Coming On
- Front air dam
- Injectors sequence?
- What Rims Look Good On A 93-97 Camaro Body Stlye
- Cutouts
- Fuel Lines for LT1 swap in thirdgen
- Wheel & Radio questions!!
- What does the Shiny metal (computer) box under the dash do?
- tranny help
- What battery is the best?
- Good deal or what?
- DTC 18, and 46.....HELP!!!
- Think I Found My Pinging Problem!!!!!!!!!
- Eibach SportLines
- TPS Voltage?
- Car dead on freeway, help! We have the codes.
- How many LT1 F-bodies produced?
- need help with mallory 685: please!
- How long does it take computer to learn changes made the car?
- hope this is not the opti.....(Hesitation at hot water temp)
- Hotcam driveablity charecteristics?
- Is it just me, or is this a little high.
- One of my injectors is missing an O-ring!!
- HELP!! (TPS-Car not shifting)
- making a coil wire, pls help
- Can a decent 4th Gen. Camaro be had for $5k?
- Can a bad IAC act like a vacuum leak?
- PM rod bolts
- Help me make a decision on what wheels and tires to buy for the track..
- what should i do next...1k
- LT1 heads
- New Cam Caused Fuel Pressure To Go Up?
- MAF Sensor/Throttle Body
- Relax, it's different kind of cam question.
- Does this sound like a starter to you? (Please help!!!)
- Thinking about a 396 Motor ?????'s
- Mufflex 4" exhaust
- LT1 vs LS1 w/= HP
- My 1/8th times
- calaberation after installing white face guages
- Fuelpump question???
- Can someone explain what is involved in balancing a flywheel...
- lt1 year questions...
- Borla Exhuast Setup
- ported heads please give opinions (pics inside)
- What Solved Your <2000 RPM hesitation?
- Little help here
- Disconnecting fuel lines
- Over the valve cover wire kits question
- TPS question, optimal voltage ???
- where can I buy a 3" to make a custom exhaust?
- Project G Machine
- Heat shield
- Where can I find a stock clutch disk for a good price?
- power antenna problem
- 2Q? lt4 valvecovers, and changing valve springs
- MAF Wiring Help!
- No turn signals?!?!!?!?!?!?
- Anyone else have problems with S.P.E.C. Clutches?
- First mod to do for an auto...
- NEED info..cars been in storage..water where and not where is should be?? any ideas.
- Getting Real Hot...Advice??
- What does a LT1 need to out run LS1's?
- Liquid Wrench
- Need Help Fast
- Tires
- Repairing the LT1 intake leak, some questions.
- Shop guy taking me for a ride?
- Brakes
- Coolant
- ALL LT4 CAM kit guys in here!!!
- opti is going out i think!!!!
- Any thing else needed w/ 1LE !AC
- Upgrade piping with cutout or not?
- Gears!!! Which is Stronger Series 2 or 3 Carrier
- Head Gaskets
- Oil pump needle fluctuates
- 35th ann rims
- Anybody Else's Car Sit Really Funny?????
- cheap tires
- Anyone with desktop dyno inside please.
- Need help with partnumbers/advice...
- auto to manual
- Rubber Shifter Boot P/N?
- Help!! QA-1/Hal Users Inside Please!!
- Heads/Cam package questions???
- Need Help on Buying Suspension Parts
- Free Shift Kit Mod,yea Thats Right Free...
- Why is this causing rough idle?
- Need immediate help guys...... inside please Long ... Sorry:(
- what about tires?
- New Oil pan gasket?
- Lou's short stick worth the $?
- Buddy needs help...
- !maf and SES lights for pre-cat O2's
- Next mod session, what should I get now?? spend my money!
- ABS doesn't work
- passing CA emissions
- combination motorsports owner's name?
- Freeway driving and downshifting question: transmission people inside!
- What is wrong with my Z28??
- TR55's or TR6's w/ .....
- cutouts and back pressure
- ?'s about 355 build.
- calling all with AUTOMETER N2O GAUGE IN A-pillad pod
- Opti SPark Elimination Options
- Carb vs Fuel injection
- Timeslip within, do these #s seem good for my mods?
- Be careful on roll cage install
- best muffler to go with
- Stock Exaust
- Blown head Gasket
- Spark Plugs
- Need Cam Info.
- how to spend $1500 and tire choice
- Fuel Line in TB?
- Rocker Arm Stud Question
- got this for my birthday...
- Which pilot bushing? The solid , or the one with bearings in the center
- What causes backfire - Too lean or too fat?
- Flowmaster or Loudmouth?
- CAI or SS Hood with airbox??
- How do I get these bellhousing bolts off?(auto)
- yet another...lt4 hot cam question
- Please Help!!!
- CAI question, am I dreaming????
- What should I do about a TB gasket?
- 1LE elbow??
- Long tube header part numbers...
- Cam suggestion
- Has anyone tried both an H-pipe and X-pipe at the same time?
- Intake Manifold Leak and Split LTtrims
- What is stock fuel press at idle and full throttle?
- LT4 Intake
- Storing LT1/T56 without fluids?
- Average Oil Pressure ?
- Is this CAM to much? Opinions Please
- Brain Fart
- This rust on the cylinder walls anything to worry about?
- How high can I rev This Motor?
- What size belt for underdrive pulleys?
- Quick question....
- !EGR & !AIR on OBDII and no SES . ..
- Bolt size in motor mounts??. ..
- What Do You Think about this?
- What catback or muffler to buy?
- need a resistance reading quick
- SLP/LT4 Clutch vs. Spec Stage III owners
- Getting Hot
- Q's About Which Tranny To Go With?????
- Any adjustment on door hinges or catch mech.
- Emergancy: Fuel Injectors, Info before buy!!!
- Headlight solution ?
- Do I have an F-1 Z28??
- Cooling issues...
- What will sound better, Longtubes with 2OTL w/cat or without cat?
