View Full Version : LT1 Based Engine Tech
- where do i jack at, there is a spot
- Just ordered vigilante now i have a question
- how much coolant needed?
- Weird problem with rear hatch
- Could someone host my dyno sheet from DynoJet yesterday?
- Any fix for left turn rearend squeal?
- Important Timing Question
- Combination Motorsports
- Problem with wipers, Need your help!
- What Headers used with Lowering springs
- 2.73's or 3.23's???????
- throttle body question???
- It's always one problem after another...need some advice
- Your opinion on a cam set-up. Which ever gets the most votes for I will do that cam!
- Please list all items needed for a cam swap...
- glove box codes
- Current status on my car (Also need oil pres sensor part#).
- Trans Am Door Emblem Part # ?
- Look at these heads, what do you think?
- High stall shift problem
- Those of you Firebird/TA owners with headlight issues, inside here..
- Port and Polished???
- How much for a LT1 to take a LS1
- LT4 Hot Cam Install
- Rear Wheel (In Honda)
- broken manifold bolt!!!!!
- Anyone with cam and stock heads trapping 110mph+ with stock 3.42's??
- SES Problem
- writeup for A/C removal
- Of EGR, Air Pump....
- TDC for #1 cyl: timing marks aligned??
- Yet Another Question on my Car Problem
- antyhing else needed?
- to crank engine without starting..... only remove coil plug??
- What parts are required for OBDI conversion
- Paging Mindgame
- Coolant in my oil!!!
- Removing hatch plastic/vinyl
- LS1 vs. LT1
- timing set install???
- coolant
- 396 cubes?
- Hot Cam idle speed
- very desperate, out of ideas. PLEASE!!!
- may be dumb but why 327cid???
- Cutouts
- SLP Loudmouth....
- cut out or straight pipe
- Last ditch effort....cd player power advice please!!!
- Dyno and Track Results 230/236
- lt1 stumblems after resetting computer???
- air pump removal?
- Valve Lash to tight??????
- header install...egr question..
- Trey thinks theres something wrong with my car
- Anyone have the XE 230/236 cam? Questions asked...
- Which muffler??
- IL inside
- 97 SS: What does she put down?
- Headliner
- A/C compressor delete belt size?
- MAC headers installation
- 1993 Trans AM need info
- Dyno Results
- Problems with wax!!!! HELP!!!
- Is it possible to get drivers side header in w/o removing the oil filter?
- Sound or power
- Okay guys your Fav. Plugs...I think Im changing them soon so need 8
- best prices on AFR?
- Who has used a billet core cam on a LT1?
- Opti bad or the sending unit before it?
- Check engine light flashing.. what's up?
- What size fuse to run with MSD ignition??
- Plugs?
- Who has a definite fix for the PARKING BRAKE RATTLE???
- Ngk Tr55 ??
- roller rocker/ valve spring install
- Air Dam!
- Raytech Solid Pinion Spacer?
- Amount of gas used during WOT?
- Anyone running Hoosier Pro Street Radials
- supercharging a stroker
- New times. Comments?
- Please email me all your Dynocharts and Track times with aftermarket cams!!!
- Fuel Saver Pro
- Need Experienced Opinions ASAP !!!
- Need new Brakes
- changing fuel pump today, one question......
- Demand Identify Camshaft
- Going to Dyno
- Need Urgent HELP, crank hub is stuck on bad!!!
- brakes after hotcam?
- Throttle linkage cover PN
- Header Wrap
- legal headers
- High idle after relashing valves...vacuum leak?
- Borla sound? how to generate it?
- Guys who run skinnes up front everyday?
- 95 A4 Flywheel
- Tranny temp guage problem..can ya help me?
- Rounded off lugnut
- My Header and Dual Exhaust Design...
- Need help ASAP, is this Toulene pure/"virgin"?
- P0100/p0103 1997 Z/28 Threw Codes
- Is it possible to use just a cloyes chain?
- What extras do i need for a cam swap?
- Lightweight Flywheels.. question on streetability
- Guideplate height differences....is there really an advantage?
- Magnaflow outflow 2OTL???
- Changed the plug/wires now won't start
- lt1 question
- slp dual dual or GMMG?
- Bad PCV Valve > Oil in Intake
- fuel lines need help fast????
- Ok Ok Now What Do You Have To Say About 4.10s In The Snow
- Answer to starting problems!
- OBD I and OBD II
- Valvetrain rebuild/work and 1.6 rr
- Oil on a plug...Low Oil Presssure?? Whats going on!?
- Bose Cd player cost
- Fuel pump harness 96 Z
- placement of bullet mufflers?
- Give me some idea's
- People who like to look at pictures
- hard to start
- correct speed on gauges?
- Can opti just suddenly die??!
- rear end whining
- 2-series posi in 3-series rearend?
- Quick question: Wiring harness and ECM?
- Fuel Problem-Despirately Need Help
- why are FLP headers so expensive?
- Those that have purchased GM water pump and opti o-rings seals
- Speaker Size?
- The notorious LT1 water pump
- Lowering CR on stock LT1 head
- Where to get set screws for roller rockers?
- Fix annoying popping sound with borla
- rear-battery troubles!!
- Anyone ever break a LPE ds?
- First Dyno Reults! DynoJet!
- Elec water pump conversion question
- How the heck do I do a coolant flush?
- Grrrr...scoggin-dickey problems
- Air bags.....
- Open,Closed Loop, and TP sensor questions
- Borla with Mecham tips, will tone or purr differ?
- Quick! Wiper blades!
- is my solenoid going bad or my tranny is getting ready to blow up??
- Will these rims fit???
- Gears 4.10 or 3.73?
- will 95 hooker headers fit on a 96 camaro?
- 2200 stall + A4 + BFG drag radials: should I worry about rear end??
- My car is trying to overheat when I leave it running....
- Curious happenings with hydraulic lifters...need insight please
- Fuel Line disconnect tool??
- Lower price on LS1 brake kit...
- test pipe
- csi wiring que
- Thin Cats
- Help!! Throwing cdes 41, 42, and 51
- Help Me Please
- help my tranny is slipping
- WTF...tranny mount?
- Electric WP
- tiny exhaust leak on collector of AS&M y-pipe, is it hurting me?
- car value
- Shoebox do you have an exploded view of..
- removing alternator
- part list cam/heads
- My LT1 sounds like a sewing machine
- Hard to start issue
- CS-144 or Dual Rectifier Alternator
- Fuel Pump Problems--help needed
- Need some pic of welded or bolted sfc...Thanks
- car feels weak
- Z28 Reliability, Show My Dad
- Rough Idle HELP!!!!!
- Spring cleaning
- Question about the GM 847 cam
- Anybody know the length of the bolts needed for Spohn TA?
- can a 98 Z28 and 94 Firehawk swap rears?
- Is it bad to go big with injectors?
- Is something wrong with my car?
- stupid car won't let me win and not racing
- Where to install water temp. sender for Autometer water temp gauge?
- new injectors?
- 1995 95 with OBD II
- DID they make a 16x8 Firehawk rims?????
- cat back install -please come in!!!
- need sam smith's # for new opti
- Will these tires fit a 93-97 Camaro
- Gear Swap
- Starting on my heads/cam swap later today, here are the details!!
- help with Low Traction light
- Strut/Shock tower thread size
- Anybody have long tubes and a single cat?
- Engine Problem? ... help needed
- How difficult is changing the rear main seal?
- How much HP will I make?
- Decent Price?
- Whats the widest drag radial I can run on pro star 15?
- fuel pressure gauge
- can i use stock rockers with this??
- cam shaft choosing
- z28 lt1 or corvette lt1
- XE 224/230 112lsa??
- lights on dash
- Makeing first gear selectable on a 2.73 car
- Got my car today
- Flowmaster vs Edlebrock exhaust.
- installing log tube headers
- Custom catback?
- USED SLP install (with primary already welded)
- important cam ? need to know tonight
- Part number for shorter belt BBk pulley
- Car won't crank (sometimes)
- MidWest Torque Converter?
- Long tubes and dual cats
- Plug access on edelbrock shorties?
- track testing the hypertech
- Hypertech programmer changed....
- looking for pics of SLP line lock..
- When to adjust rockers??
- quick capacity ?
- o2 sensors keep failing
- SES Light in Caprice
- Hooker long tubes Left #1 primary
- Knock Sensor relocation
- torque converter question
- How much horsepower do you think I will have?
- tranny/computer?
- Fans do not turn on... and headlights are on when not supposed to.
- Can't separate T-56 from Bellhousing...
- MAS Can i Take it off
- Lifters
- theoretical question about painting stuff
- Finished oil pan gasket today, but now bigger problem
- 1le trany mount
- Mod opinions please....
- What kind of oil is best?
- Procedure/techiques for adjusting Spohn torque arm?
- One more optispark question?
- Cc305 Vs Hotcam
- Intake Manifold ? About Anodizing
- what is the advantage of an...
- Cat back
- Who makes the best intake gaskets for LT4 heads?
- 4th Gen rack and pinion
- My Tips for those installing shocks, knuckles and brakes
