View Full Version : LT1 Based Engine Tech
- BMR TrakPak
- Whats a good muffler
- o2 sensor locations
- My window is stuck....
- cost of auto tranny rebuild?
- Got her in
- LCA terminology
- 4 anyone interested in SLP LT4 clutch....inside
- Thrush Mufflers
- 350 rwhp
- Which LCA's
- Cooling Fan operation-Technical question
- Hoping to have prob fixed 2morrow
- bad miss/stumble above 4000 rpm
- PCMFORLESS questions...
- LT1 in a 1998 GMC Jimmy
- What kind of Tach to get??
- removing passanger front o2 sensor
- can i use seafoam then autorx?
- weight diff. formula/TA
- M6/4.10 users...inside please.
- A4 guys...quick question..how do you shift outa parK?
- Sound clip of my heads/cam XE 236/242/112 with open headers!!!
- Cc305 Cam
- SLP Loudmouth
- Fuel injector questions for 383???
- EXHAUST RATTLES!! (Borla)
- O2 Sensor wire question!
- Where can I get a genx1 and genx2 wet kit?
- will these 3:73's fit?
- How big are the combustion chambers on LT1 heads?
- Quick mass air ?
- Electrical problem help please
- new engine setup...what do you think..
- Lt4 Km
- what causes code 154?????
- msd question
- Endurex Lifters
- Was thinking of losing the Borla for something more "Exotic", any suggestions??
- Firebird on front bumper of TA...I need one!
- TH400 and a Gear Vendor.
- couple q's
- Help
- TRANS Fluids for a m6
- MAF vs. BBK??
- Anyone who has ever done a shifter for an A4 inside...
- How are O2's connected?
- Need bolt sizes (Shoebox?)
- I Might Be The Coolest Guy Ever....
- Looking for muffler between an ultra flo and bullet (loudness)
- anyone w/SS with 17" wheels
- It wasn't the alternator......Now what???
- PCV valve replacement
- Buget Heads and Cam?
- who has the best price for fuel pumps
- anyone see goodyear F1 GS-D3 tires in action
- Found your RPM stumble
- LT4 Clutch Identification
- Diagnostics...Codes...????
- Thoughts on cam and help with motor... Solid roller 244/244 .611/.611 112lsa
- advice anyone?
- All 1994-95 must see!!!!! Easy way to fix C.A.G.S!!!! FREE!!!!
- tranny/clutch problem
- Need Engine Building Tips/Advice
- need bolts... please help
- is this 2 much 2 pay for a lt1 30th camaro?
- Got slp clutch do I need new flywheel ?
- what push rods and lifters are good?
- Fuel line connections
- What is this, and what is it's purpose?
- Hub install tool - make my own?
- Y-Pipe to Headers bolts!!!
- Those with True Duels: inside please
- 97 LT1 4LE Trans Bolts is there a Removal Trick?
- Need help w/ my wheels/tires
- Difference between X and H pipe?
- HELP! Installing Airfoil!
- Quick, easy question about taking off calipers
- HP gain from Hot cam with stock manifolds
- FX5 Shocks?
- QUICK! PB Blaster OK?
- How to find year and V.I.N on an M6???
- Bleeding my brakes.. Need to make sure im doing it right.
- Is this car worth fixing?
- 700r4 question
- Tranny flush?
- how do i remove back seats?
- Cab the EGR valve be removed all together???
- A4 guys with 4.10s
- Dumping my steed, gettin a Z28.
- 3.73 Gears question
- jackhammer noise from rear after clutch ... wheel hop?
- Starting the car in the morning
- What Bolt-ons am I missing?
- help with setup
- 93z bad miss and stalls
- Steering Stereo Lights Out
- Cant Make A Churp 1st into 2nd
- Changing Diff Fluid
- Getting LT4 Hocam, Do i need LT4 TIming Chain?
- jet hot lt headers vs straight plugs
- Why won't my rear window defrost stay on longer than 30 secs?
- Spark Plug Wire Routing
- surging at idle
- Clutch Chatter
- After 4+ years, I finally did what should be the first mod
- Posi Rear
- how do you take the vents out
- High Flow cats...
- Installing HOT Cam, how much more trouble to pull heads??
- Vibrations...
- Use GM fuel filter?
- cc305 vs. cc306
- Regaining momentum after 1st
- HEAD and CAM LT1 OR buy LS1 Car?? HElp me decide
- lt1 edit vs hypertech
- autorx or seafoam???
- Living with the low speed stumble.
- Z06 85mm MAF
- shifter for an A4...
- New to the z28 and need help
- PCM question
- Just put in my headers..
- How do I rig a switch to manually lock my TC?
- low coolant sensor
- How hard would it be to convert LT1 to carb?
- Thanks a million combo motorsports
- Cam and lifters?
- Can I beat...
- back to the 99+ fuel tank swap = anyone actually done it?
- Fan switch write up??
- Eibach pro kit, hows the ride?
- First runs of the season
- times question
- why am i getting like 200-230 miles per tank?
- Stock Motor Mounts, how much HP can they handle with an A4?
- roller rocker arms
- Trans gurus --->T56 conversion almost complete, have some important questions
- LT1 swap
- My Stumble fix...High RPM
- Holy Mother of all evils, I stripped a banjo bolt hole!!!!
- best transmission for 525 hp?
- Cc305 Vs. Hotcam
- Pictures inside.... Help me ID this BBK throttle body
- Broke manifold bolt. How bad would it leak w/o it?
- Best Heads/cam Combo?
- Solid roller question
- How much rubber.....
- Would you LT1 owners be interested in a PCM "Repair" kit?
- New to manuals got a question
- cc305 and emissions
- random tech catback or cutout??
- Excessive Motorsports Heads Poll?
- Anyone get their FLPs slip fitted?
- 2 quick mod questions...
- Unplugging MAF and car dies?
- Oil Change intervals after cam install?
- SLP CAI owners...
- yet another cutout question
- True LT1 Cam Specs
- How much water?
- 3.4 to 5.7
- Rod and main cap torque
- Rad Hoses
- obd1 or odb2
- Mass Air
- Does exhaust touching underbody=false knock??
- Borla install
- Vacuum for cc306?
- How hard is it to rebuild a 4l60e tranny?
- OK new problem
- Quick Valvespring ??
- pulley - airpump, problem????
- Dead Clutch can you ID these ?
- using anti-freeze but not leaking
- need advice to PCM
- Need Help Fast! Hydraulic Clutch Lines
- where to buy street twin?
- Gauges pods
- Removing A/C question
- with slp take out torsen zexal...do you add the additive???
- Need some part numbers
- Bad power stearing pump??
- shoebox; yet another hub ?
- AC help.. evap temp sensor
- new way to plug w/p drive hole that looks good
- Cut outs ons the y pipe?
- Dyno numbers in! w/355 heads and cam
- oil pan for 383 stroker?
- Bleeding after TB bypass
- Any Experience With JET Shift-Plus???
- accel 375+
- Converter advise is welcome
- New Magnaflow Sound Clips
- Help! 98+ls1 injectors in an lt1?
- Poll: True Duels
- rocker adjustment w/out timing cover removal
- Bolt tighing order for LT1 heads
- Tranny rebuild by LT1Dave any good?
- Edelbrock TES headers any good?
- LT1 scanmaster hookup ?
- K&N FIPK filter probs
- could i keep with an LS1??
- How hard is it for you guys to shift at high MPH
- Coolant Guage Sensor?
- HELP PLEASE!! oil leaking out like water after heads/cam
- Shoebox--how to hook up Autometer Tach
- improperly installed balancer - can this cause a problem?
- trouble codes
- roller rockers
- Over the cover wires w/ BBK headers?
- engine assembly lube=cam lube?
- Thoughts on Aluminum Flywheels?
- need help understanding the reading on some sensors
- Co-Worker just bought a 2003 Cobra...need mods...
- Someone Backed into me. Busted front corners
- Knock Sensor Test
- What Is Cam Surge?
- Has anyone seen a Camaro like this before??
- Starter dead?
- pics of fuel pressure gauge fitting
- Internally balanced 355 LT1 what flexplate to use
- before applying gaskets...
- Need part # for impala head gasket...
- Best place to buy OEM parts from?
- Tuning experts please help on idle issue?
- Headlight Help!
- RWHP gains from Elec. Waterpump and 160 thermostat???
- howmany of you removed your rad to change the opti?
- lt4 intake
- SFC or LS1 brake up grade?
- tranny work and clutch install
- Choose your Parts Stores accordingly
- Making the ride nicer
- Relocation brackets=Lowered??
- Can a knock module cause the check engine light to come on?
- First couple of mods???
- Which Header Bolts?
- no power in OD on the freeway, experts inside pls
- M6 Tranny Fluid?
- need help ASAP
- Installing Headers - Checklist...
- 383 motor won't crank properly
- Howling In Rear
- pushrod length
- Will these valve cover breathers work?
- Wiring Harness Question(LT1 in a thirgen)
- tire suggestions
- Coating Headers
- tranny mount sound-a-like
