View Full Version : LT1 Based Engine Tech
- Which headers should I buy???Please help!
- Car won't Start
- where to get gasket for 52mm TB
- where to buy nittos?
- LT1 Scanmaster code ?
- Blower for LT1?
- Speedometer
- Voltage problems
- odd noise from the rear....
- Need Torque Specs for cam install
- T56 Rebuild Questions?
- Driveshaft
- Camshaft bolt Stripped?? help please
- Roots Type Blower for LT1s?
- LT4 KM quick question
- Jounce bumpers tough install?
- In the middle of optispark swap and have a question?
- Can Toluene cause white smoke from exhaust
- injectors
- brake problem..help!
- 93 knock sensor
- Baer Track Kit, fit on Enkie Winn 17 " Wheels
- Any ideas? - Wipers move up windshield instead of down...
- slp shorty headers for '94 Z28
- engine fire and oil leak
- what to clean the throttle body with???
- What will I get out of a 160 degree thermostat?
- Exhaust Question...
- Aiming TA headlights
- Good Deal?...What you guys think?
- Aeromotive or Holly Fuel pressure REG?
- whats the best thing to buy with 400$
- What A Bad Clicking Morning
- Swithced source for DRL, WHERE?
- FLPs passed emissions
- rpm capability
- i got a 52mm tb
- what the hell is this thing
- Trying to make FAQ, what questions?
- Replacement Fog Lights for T/A Help!
- Header Bolts
- will a lt4 pp/mcloed disk hold 340rwhp
- tranny filter in m6
- Muffler option on duals?
- Questions about headers
- a/c problem?
- Need help with drivetrain
- need help a.s.a.p
- Tranny bein goofy
- Questions for anyone who has rebuilt an LT1
- link for head porting?
- headlights
- How to put in a 94 A4 shifter into a 96 6 speed camaro
- What do you think it will run?
- OD stumble is it common
- Whats the thread size on the factory T-56 shifter?
- How do i remove the parking brake handle on a 4th gen?
- Lights and Wipers, simple questions, please contribute your thoughts
- 383 or 396 stroker
- intermittant stumble
- Engine balancing info...some PRE-questions!!
- SVO 24# injectors
- Batt. Dying, and Tranny ?
- RPO Codes???
- WTB 30# injectors
- Where can I find Tie Rods!!!???
- holy smoke!!!!
- WHAT THE HELL!!! charging system issue
- Anyone with Jet Hot LT's come in please, have a question
- Fluid Changing Question
- shop labor?
- lightweight parts
- Car surges under light throttle
- Whats your opinion on a 2400 stall
- Timing cover
- Winter mods complete, Heads/GM847 cam/RT catback
- Video of 305vs305
- Got my sfc's installed today (andy's auto)
- replacing lock cylinder??
- Air Filters
- Exhaust Question
- Smoke T/A?
- Thinkin about a rebuild, but need info
- if i need my clutch replaced, what do i need?
- Centerline Warriors
- If you were to build a BUDGET 355 forged long block, what would your choices be??
- P0300 code deleted on OBD2 why is this?
- For electronics guys --->
- Alright...What's the deal with 98+ SS spoliers on LT1 cars...
- Stock replacement hi flow fuel filter?
- P.O.S. CSI water pumped died...
- My turn signals work intermittently...
- disconnecting fuel lines to replace fuel injectors?
- Finish LS1 brakes, think i have a air leak, need help
- Can you still get a blue/silver Paxton FPR??
- Help Me KILL My CAT!!.....Converter that is
- What Mods will help me get the most ......
- Spring/Shock combo?
- Mis-Shifted how bad did i hurt it?
- loading video
- New flywheel or resurface the old???
- TEA heads
- where and how to check for vacuum leaks?
- plug wire arcing
- ****in' air pockets
- checking power to the fuel pump
- I can't find the right size bolt?
- SLP Loudmouth
- What price can I get for Chrome LT1 rims "salad shooters"
- Distinguishing between a '97 Z28 and SS
- Troubleshooting optispark?
- tires?
- High RPM miss-SOLVED
- track results
- Clutch install next weekend, do I need anything else???
- Does this work?????
- casting numbers?
- exhaust tip question
- Options for a shortblock stock/355/383
- fuel pump relay - where is it
- Cams for LT1s
- Hawker or Dynabatt users?
- o2 sensor locations
- Cam Surge Bad?
- I keep smelling gas inside the car.......?
- SLP Line Lock ?
- Anyone running a harwood cowl hood and made it fuctional??
- 97 z28 - Problems with throwout bearing? help please!
- Not happy with Jason Chromer..
- Need cam retaining plate part number...
- Help!!! HELP!!! A/C died!!!
- Brake Help please
- Question: Cut outs on a 96 SS
- What 2 do with O2
- blowing horn fuses when i use my lighter
- Should we use low octane fuel ?
- Why use a Adjustable Fuel Reg?
- anyone use hayes clutch disk/centerforce pp
- abs inop light flashing???
- Please help me pick a cam!!!
- stock exhaust pipe size??
- high rpms through every gear
- TireS???????
- No Lockout for Reverse with new M6??
- oil leak fix
- MSD Part / injector number
- ques. on adjusting the clutch linkage
- BBk chrome headers
- HELP: reinstalling crank and rods
- Converting from 4L60E to 700R4
- Insulator under hood
- Thoughts, Ideas, Coments, Concerns...head pics inside..
- Quick Question -> MAC Headers
- Is there a safe way to pressure wash the engine bay
- How do I REALLY flush the rad?
- 160 degree thermostat controversy?
- Not just another opti question
- Help me out here! A.I.R. issues
- dowel pin ?s
- Do I need an installation kit? (loudmouth)
- Reuse 2 month old head gaskets?
- obd1 cable and pay pal
- Draglite sizes?
- TB bypass
- IDLE-2K STUMBLE w/ a twist....NO ANSWERS
- How do you get the console out of a '95???
- problems with longtube install
- Hypertech Users info NEEDED
- Running rich/lean
- What are my options for after market timing chains
- Shift Points?
- Can an LS1 cat back fir a 93-95 single cat car?
- Whats the best RVT to use?
- Ac
- Alot of OIL stains please help
- To run Freescan or similar software, can I use a desktop PC?
- Quest for 11's with bolt-ons, runs into a wall..
- What driveshaft loop
- Just got my Pro 5.0 and I have some questions....
- Regular Wires
- 18" How fat?
- Low Oil Light after replacement of unit.
- head porting materials
- balancing motor after rebuilt
- Bleeding Brakes 96 Z *ABS Traction Cont * ????
- forged crank or not?
- Next mod: headers... need some advice!
- Opti problems
- abs question
- LS1 WS6 Front Sway Bar 32mm?
- tech line products
- Which coolant level sensor do i need? anyone w/ p/n?? 94Z
- idle
- Price to change muffler
- reverse solenoid install
- Optima Red Top owners please?
- I have some cool ideas for a power inverter!!
- Collapsed lifter?
- How much HP /w this 383
- Need an electric CSI waterpump with core?
- Why would the car shift normal in 3rd and not in OD??
- New Mods on: STB/SFC/Corners/Corsa!
- How do I get ahold of Llyod Elliot?
- Installing Hooker LT's . Any helpful hints is appreciated
- Ok, getting kinda frustrated...still have driveline vibration>
- 97 Y-Pipe ??
- Question about A/C blower motors...
- Just install new Borla
- Running Rich, Where to start?
- Squeaking alternator pulley
- Removable rear glass theory!
- where can i buy just the fuel pump for my 96SS
- Which of these tires would you buy?
- Dynatech LTs, Are Over-The-valvecover Wires needed???
- Sumitomo HTR+ tires?
- Where can I get a manuel or book on porting heads?
- LT1 Edit, PCMforless, or Dyno tune for LT4 Hotcam tune?????
- LT4 head gasket boost compression?
- car is running like crap
- final question (I swear) before I do the LS1 brake upgrade
- performance gains to be had with MARCH pulley set?
- Need quick answer...ordering parts now!
- Newbie Questions
- Heavy miss at WOT
- Car died on highway
- I'm putting on exstended studs. Need part number
- sometimes car is quick, sometimes car is slow!!
- Funky Noise Inside!!!!1!!
- Anyway to retain the CPS with a double roller?
- Headers??
- fog light
- Difference between 700R4 and TH400?
- How to get rear calipers off?
- power steering leak
- Quick header question
- edelbrock exhaust any good?
- Anyone running long tubes, catless ypipe and borla exhaust
- Help Me Chose Guys! Brakes Set-up!
- LT1 air intake silencer
- Best LOW budget cat back
- Anyone with Hooker shorties...help needed
- Exhaust piston to valve clearance problems :-(
- Mac headers, 224/230 cam and stock heads...
- Upgrade and questions, please help
- Honda ATF in 6 Speeds
- Edelbrock LT1 Heads...
- Stiff Stick!!!
- Long Tubes
- Parking lights flip flop to be make them brighter?
- Thanks Rob (Shoebox)
