View Full Version : LT1 Based Engine Tech
- aftermarket muffler fitting in stock setup??
- Cheapest price for a 94 Opti?
- Motor Swap!!
- Safety issues and body alignment regarding removed bumper supports + rollcage
- anyone build their own sub frame connectors?
- shifting question
- Iridium spark plugs worth it?
- Help Quick, I think its a bent 3/4 fork
- SS Ram Airbox question
- Gutted cats on a lT1, and exhaust question??
- can i have my car vavumme tested?
- Where can I buy a new 4L60E A4 transmission
- Should I mod my Hawk???
- Moroso CAI
- LT4KM Worth it?
- VFN hood... bolt-on or pin-on?
- Tire Size Question
- K&N factory replacement filter
- LT4KM where can i get this and how do i instal it?
- broke a stud off the ypipe...what now?
- Replacement filters for SLP CAI?
- How far off will my spedo be?
- washed engine, now it will not start!
- EGR code
- How about these Mods?
- Some advice needed (programming, future mods)
- confused :( (rear brakes)
- Stupid PCM question...
- What do you think of my set-up???
- Manual Fan Switch
- LT1 wont start while cranking, but pops after letting off key?
- LT1 Engine Damage Pics (rods specifically) needed
- Clutch Install, Question
- VATS and EGR
- Cheap Upgrades
- I think my reverse lockout solenoid is out...
- used lt1
- squeaking brakes!!
- LCA Bolts?
- Finding oil round base of Throttle body
- !Air Conditioning
- what does ttt mean on the sales board?
- Part # for heated O2 sensors
- Trans Mount on A4
- Stuck in 4th gear
- Lowest profile 16" tires for 4th gen Camaro?
- Blinker short circuit
- when to change o2's?
- Valve Cover Gasket Leaks after !EGR
- EGR Question...I searched first :-)
- Just changed Evap canister...Still have gas smell!!!
- Beware Of Inspection, Listen To This Bs!!!
- ZZ409 cam, LT headers, Hooker Catback...HOw will this sound
- What color is the OEM opti in 94's?
- reading obd1
- Single Cat Header Conversion Questions??
- Does anyone have a new web address or e-mail for SPEC (Star) Clutches???
- help.......just bought 1.6rr's
- Number Cast onto Block??
- hp gain with hooker LT and cat back
- Car Popping When I first Start It.
- enter all electical masters
- Does anybody make this any more?
- now why cant u have true duals coming out the back?
- My trans is making noise
- Convertible Top Cleaning?
- what is wrong?
- overheat at idle 94Z28
- Healthy Place for rev limit
- ebay does it again
- new intake idea
- 383 dyno numbers?
- 1998 Lexus SC400 vs. Z28 M6
- CAI makes a huge diff.
- Want to be atleast in the 13's need help
- Grinding 2nd gear, WHY?
- Help I'm stumpped!!!
- o2 and fuel filter
- What can I use to plug the holes on my headers?
- Jet Hot LTs are done!! Pics if you want em!
- Heat sink compound for ign. contrl. mod.
- Newbie coolant question...
- the cheapest place to buy longrubes.
- Is This Safe?
- Cyberdyne boost gauge... how to install!!
- What tire pressure for skinnies?
- How to....
- hard to start after fuel pump install
- Intake valve closing point of LT4 hotcam
- are RR hard to install?
- cooler plugs for 11to1 compresion?
- Replacing C-Clip in Rear End
- opti O-ring seal, is it needed, ASAP!!
- help me appraise this car
- new headers & y-pipe
- possible exhaust leak. Muffler upgrade Options?
- Post Storage Maitenance Questions
- Idler Pulley Noise?
- price to change power steering pump
- need walbro fuel pump info
- manifold porting
- LCA Relocation Brackets worth it?
- Power loss 'caused by bad Opti
- need help ASAP!!!
- oil leak puestion
- Fixing head gasket, need part numbers for all gaskets needed..
- L88 rat motor question?
- Help!! Help!!! Help!!!
- Waterpump replacement
- Need help...
- fuse problem
- SHOEBOX gotta question for ya...
- oil pressure gauge question
- Ngk Iridium Spark Plugs For Camaro
- How do you know when your master cylinder or booster is bad? help
- Cai
- 300 RWHP possible with stock cam and stock heads?
- My filter came off of my FIPK, please HELP!!!
- gear change
- anti lock inop
- first day at track with 94z
- Trunk Measurements
- Thread size?
- VERY bad day at dyno
- Gen II LT1 block...help ASAP!!
- Getting fuel lines off
- What do you think about those SFC?
- u-joint question
- ran a 13.8 today...
- 90/10 Camaro Struts??????
- rocker arm install, crank turns which way??
- Anyone ever see a optispark blow up internally?
- Popping, Misfiring in 95z
- Installing hooker LT's , Having problem's installing around Vortech T-trim
- Need help getting catback apart..
- Asap!! Please Help Quick!!!!
- should my alignment be THIS far out after LS1 brake upgrade?
- my car shakes some
- May have the wrong part number....
- how do your springs feel (sportline, pro kit, drag launch, etc.)
- Vorteh elbow
- need advice on my car
- My horn doesnt work...
- i have traction control can i remove the box under the hood?
- where to buy front wheel bearings?
- Pro 5.0 w/shortstick
- 1st gear problem in t56. WTF????
- SLP Ultra Z Intake
- Sub-frame damage, who fixes it?
- Removal Of Entire Dash (97Z28)
- Anyone change steering wheel?
- Tranny cooler lines. Need part numbers
- I'm ready to start fuggin smo....
- Roller rockers
- Where can I get a air bag setup for the rear?
- opti installed.
- General Maintenence
- couple of tech questions I could use some input on...
- Needing Help On Rebuilding The Engine
- what can cause the tranny solenoid to burn/fail?? no 3rd & 4th gear..
- do I need to clearance the T/C for cloyes?
- Tickling noise on acceleration
- Problems with the Stereo
- Disappearing coolent problem....solved.
- Anyone know how to install brake pads?
- DynaTech Long Tubes Installation Problem, Factory Oil Cooler, HELP!
- stock rim size for 94z?
- Which works better, Ram Air, or a CAI?
- what bolts to use when replacing lca and panhard bar?
- seafoamed last night and now have engine code p0113 what do i do?
- Rear End Help
- People with MAster cylinder problem(clutch)
- where can i find a oilpump drive on a sunday?(today)
- Problem Solved...look Inside
- Shifters
- Opti part number....
- Installed tranny cooler, walk through and commentary inside.
- Interesting Optispark experience - anyone else ever seen this?
- Lt1 Question
- Disabling the progressive door locks.
- Who used an S-10 Converter
- t56 swap ? ignition switch on col.
- question about hooking up a tack
- AFR head gasket question
- 97 spec. Ed. conv. boot?
- Moroso Cai Cleaning
- hatch latch
- shift light
- bmr track pack
- simple question on a-4 cars
- Hesitation Frustration
- Cost to mod my car????
- What are best performance springs.
- When does size matter ?
- Saving Up For a LT1!
- Sparkplugs Ever heard of these?
- how do u install an electronic air/fuel gauge??
- Who makes the most NA horsepower with an LT1?
- low coolant light
- Odd problem...
- alternator relocation
- Opti Spark ???
- Tune Up Help
- still considering the 700R4 to TH400 swap in the 93 Z
- 700r4 conversion
- Possible brake prob???
- Car Problems: Chapter 12493
- DS vibe?
- Just got my first runs in at the track!
- Xenon Headlights for 4th Gen??
- head swap question?
- Dif between SS & Z28
- firebird clear corners
- Power limitation on stock internals?
- CC306 cam
- LT1 questions
- LT-1 computer wiring harness. Pin to plug
- Ive been thinking.......
- 6 month project list... what am I missing?
- Dont know where to hoses go, can anyone help?
- set base line
- Spark Plugs and Wires
- stock fuel filter
- What is a CAM
- Hosepower Gain
- Opti/Trouble Code Questions
- Headers
- 60 foot times better stock then with $1400 worth of mods!
- Is a XE 230/236 "too big" for non-ported heads?
- Clicking noise coming from front of engine
- Cam recommendation from Comp Cams
- Not your typical driveshaft question...
- Anyone know the part numbers of these door parts?
- Dead number 1 & 8 cylinder?
- Who is the "MR KNOWLAGE" when it comes to factory stereo units? Monsoon or not?
- need cylinder volume
- any tricks to remove a stubborn bleeder screw?
- Headlights Kill Battery...wth
- Strange prob with electrical fans
- Cutout or CAI?
- car missing help
- 93-97 fittings offset
- exhuast header bolt locations
- Front Lights replacement
- Anybody use X-1R oil additive?
- Help! Fuel pressure Guage
- Optispark???!?!?!?!?!?!?!?!?
- Tranny mount part number and question
- 98+ SS spoiler on a 95 - which resistor
