View Full Version : LT1 Based Engine Tech
- Removing Rivits off old Ignition coil mount
- putting Ice bags on my intake
- wow...item on ebay
- Low MPH???
- fuel pressure regulator
- HELP! What Type Of Sealant To Use On Gas Line/Finttings??
- 436 rwhp/418 tq. ... shootin' for high tens on motor!
- New engine, what oil to start off with
- Cheapest place to get Loudmouth?
- Do air foils work?
- Motor
- PLEASE help me figure out why my car is running bad!!!!!
- Dyno2000 file
- How much coolant is needed to fill the system?
- screaching noise coming from my mufflers
- Should the reserve coolant tank be filled?
- Anyone use the Hurst th350 conversion kit?
- Vibration at highway speeds
- Where is the best place to get some good shocks
- How much coolant to put in LT1 cooling system?
- People with the K&N FIPK
- Firing Order
- Looking for a location on a LT1
- Electric fuel pressure gauge install??? What do I need?
- Anyone melted their stock corner markers?
- Synthetic Oil
- Shifter with th400
- Can I have the MAF programmed out.
- ls1 fuel tanks in an lt1 car
- AC trouble and under drive pulley...
- How do I do a complete coolant flush?
- LS1 brake upgrade???????
- Do the LT4 valve cover have to be modified to fit?
- Help After Hotcam Install
- anyone port their throttle bodies?
- Gas smell
- Cat delete
- crack in the radiator
- FLP Level 4 Trans & 3600 stall
- Dyno graph interpretation please
- 160 deg theromostat intall?
- ZZ-9 on stock motor?
- What gears? need advice.
- Pro 5.0 install
- Should I get a bigger TB?
- Hooker LT question about O2's!!!
- Stock.. Paint or Powder?
- put 1.6 rr on, need help
- Having a hard time getting the balancer hub off, any suggestions?
- Flushing Heater Core??
- guys with over 75,000 on the clock what oil you runnin
- Which shocks.. kyb agx or bilsteins?
- 383 in Califronia... Well it pass smog???
- Broke HARD...never heard of this happening before
- anyone converted a LT1 to carb? what kinda HP is made vs FI
- About to change thermostat. ????'s
- LT1 To 383 Stroker
- What Are Signs of a Bad Injector?
- 1.6 rr?
- 16x7 rim, what backspace?
- Rough idle and poor gas milage
- Distributor Help!!
- Need Some Expert Trans Advice
- v6-lt1 conversion help please
- Anyone use the Crane Cam 210/224?
- Help from those that do thier own bodywork!
- Any Dif performance wise???
- anyone help!
- Cracked Radiator ???
- Newbie has some ignition questions
- How many F-bodies built in a year
- guide plate ?
- A4 maximum HorsePower handling?
- engine rebuild
- Whinny fuel pump noise when gas gets low
- cheapest place to get a 700R4 for a 93 Z?
- OPEN Vs 3.0" Vs 2.5"
- Let's all play name this piece. Attention Shoebox you'll probally know!
- Driving on slightly bent rim
- 93 Exhaust manifold Air tube thread size?
- Custom Headlights?
- 335/45/17 tires out back... will they fit?
- B4 I get an off-road pipe,.. i have a police ??
- Need to move ABS module, have a few Q's.
- quik ?, what way does brake bleeder face?
- Really need help guys!
- How tough is the LT1?
- what to get
- 4.10's to much for an A4?
- Replacing O2 Sensors....
- Is there a cam in this thing?
- Dual -> Single Cat Conversion...
- Is there a way to disable the SES light?
- Problems bolting a stock LT1 intake to AFR 220s
- is this normal?(gas consumption question)
- Car smells like coolant after driving a while
- SES Light, Hesitation, Car Shuts Off
- Going on a trip: Oil change time
- ticking sound coming from front of car, seems to get faster with higher rpm
- battery hold down brackets?
- Oil dipstick install with LT's
- What years have the same timing chain and cover as 97?
- install on bmr struttower brace???
- Wiring directions for CSI WP?
- shifter knob size
- What shifter did you use with your TH350?
- Holley TB question
- Serpentine belt with UD pulleys??
- Canton Oil Pan Problems..??
- Power Steering Pulley Removal
- Anyone know 'test light' voltage?
- Broken timing chain....a couple of questions
- Cut-out location with hooker catback
- Problems With EVAP
- Should I Reinstall Jounce Jumpers?
- thoughts/sound clips on selding muffler directly to Y-pipe?
- need good comp ratio suggestion for 93 oct
- rev limiter
- Hooker lt's y pipe nightmare
- JET-Hot I'm calling you out
- driveshaft length
- Mass Air..96 caprice to 97 Formula?
- lateral G's
- Difference Between 12" and 18" Bullets
- Oil Leak..Still can't track it down!
- Heater Core ?
- DTC 43 - Help me !
- Blew a fuse while scanning it??
- A4 to T-56 conversion?
- gears
- header bolts
- clutch bits in filter
- stall
- Error Code 29 AIR pump LT1
- More than1 way 2 gut a cat?
- I messed something up w/ TBbypass!
- Will a rattling ypipe give false knock?
- So what's the secret to working with valve spring keepers?
- ses woes
- Please help....car is running like crap.
- Its good to be back!
- oil pressure when the car is dead cold??
- Argument needs settling on torque converter
- Stock Fuel pressure?
- limited slip ?
- Say What?!?
- Cruise Control Help
- How much work will 500 bucks get me?
- how much hours of labour to change cams in my car?
- Injector DC
- Where to buy bare LT4 heads??
- Are those connecting rods any good for LT1?
- LT1 performance manual
- Will I be the only 218 224???
- Ok guys, need help bad...opti or fuel related???
- Cost of 96 Formula?
- Any way in He!! to make a 383 LT1 OBD-2 pass emissions? Or would I be SOL?
- quick 3.73 question
- Help! Keep blowing fuse.
- I CAN'T REMEMBER being THIS PISSED for awhile now, guys help me out with your comment
- Exhuast questions
- Moroso Vs. SLP?
- need opinions
- any interest in some polished intake manifolds.
- X Pipe question
- what is wrong?
- Shoebox
- Need Help Quick!! Can't pull hub.
- 93/94-95 headers???
- why is my car idleing too high??
- lower balljoint falls out arm
- 85 Vette ET?
- Part # for 1LE Tranny mount???
- What gears do I have?
- Buying new car
- Bigger TB: Is it time?
- how much are o2 sensors?
- Which 3.73 to get?
- Mufflex y-pipe users and 3" cat-back people inside please.
- C5 brake upgrade post oppinions
- 2.5 true duals v/s goin through X-pipe
- Fan Switch/PCMforless......
- kinda funny
- Window Rattle
- injector size?
- What is needed to replace EVAP canister+EVAP purge valve
- I f"ed up
- Egr Block Off Plate Part # ???
- supermo26
- AC Delco PF25 oil filter not available? PLus a ? about serpentine belt
- Locktite on motor mount bolts?
- MAC AIR fitting. Please help
- vortech elbow
- How to get the most out of the Lt1
- valve covers
- Help me find this tread or give me the answer, 1/4 mile related
- Hookers or MACS?
- Running way rich, how do I fix?
- Cloyes Timing Set
- Will part # 1284 Felpro intake gasket work with Lt4 intake?
- Spinning tires?
- How High Compression w/93 gas, and ? about Dart heads
- LT1 Rebuild Kit?
- Crank and Cam dots lined up = TDC Cylinder #1??
- Trying to check compression and...no crank
- HEEELLLLPPPP!!! WTF is wrong with my car??? (Tranny related)
- Dual Exhaust
- Engine shake?
- What can I expect now?
- help with cam decision
- I got some problems.....please help
- Best aftermarket radiator?
- How much power do T-56's handle?
- What is a 58mm tb worth over a 52mm?
- What kind of RTV to use, if any??
- 4.000 crank in LT1
- manual fan switch ? and cut out
- i'm getting knock retard!!!
- EGR solenoid wiring question
- Please!!need Help Now!
- inside "dome" lights stay on when headlights are on
- Drag racing an automatic Z28
- Trans Help...anyone??
- possible coolant flow issue?
- Why Wont My Car Go Into A Gear :-(
- Urgent Need Trans Help Asap......
- Hey Guys Need Some Help Please
- Need help hooking up to ground better?
- Will this Power Steering Cooler fit my car???
- Where can i find a 160 stat?????
- Shims under engine mounts
- PLEASE HELP!!! car runs like crap after it is warm....
- Running MSD 6al with Stock Platinum Plugs
- sintered metal exhaust donuts reusable?
- need an estimate on how long to install cam, heads etc
- Which gears to get?
- head porting disscussion: lt1 castings
- Power brakes wont work w/ cc305 ?? ( so i was told)
- NIce clunk, when i turn the car off...Clip inside..
- long tubes
- Free Mods/Pretty Cheap Mods
- List some brake pad suggestions with prices and feedback please!
- 4l60e-->Th350 Quick Speedo Question
- Super Quick Question!!!
- 94 to 95 vented opti switch?
- Stutter
- Thermostat
- '93 and an adjustable fuel pressure regulator?
- TB bypass=?HP
- What else should i do?
