View Full Version : LT1 Based Engine Tech
- NE1...SLP Suspension Kit worth it???
- Warning: Bad Deal With Advanced Induction
- True dual part numbers
- Can I Use The XE224/230 Cam With.....
- loudmouth/hooker lt's
- anyone get detonation after header install?
- Will 02sims off of a 2002 work on a 97T/A???
- Slave cylinder upgrade??
- cc-305 and cc-306 sound files please!!
- Difference in cc305 and extreme 224/230?
- oil pan leak
- Gear Ratio?? I am lost What is the Formula?
- Mod help
- Header install, q's about what else do do at the same time
- smokin
- Need help
- what else could it be.......? [Car won't stay charged...]
- obdII timing cover
- Is a SHIFT KIT worth it if you've already raised the line pressure?
- Where to put cut out?
- Help please....
- swirl meter, tumble fixture and port flow analyzer, do they realy work?
- Need help quick....
- Exhaust Help...Need to MAKE up MIND!!!
- gears?
- what is louder, ultra flow or hooker?
- What should I run with Corsa exhaust!?!
- Throttle not opening all the way, 93 TV cable related
- yank torque thruster with 2.73's?
- CC305, What kind of Headwork??
- What catalogs are available?
- Weird headlight problem; causing voltage gauge to dance
- slp header install
- 11 Degrees Of Knock At WOT!
- problem with parking brake light...alwys on, i am stumped
- Questions froma poor man.....
- gutted cat?
- tb bypass
- Another question about removing heads...
- Few questions here, please help!
- how bad is it not to change the PVC valve?
- 94 Camaro Z28 Ss(clone) For Sale In Minnesota
- NITROUS or HEADERS for next mod??
- rusty wire???
- lt1 94 z28 clicking when trying to start
- First impressions of my z28
- what happens when the TPS sensor is bad?
- Anyone have pics of stroker clearancing
- JB Weld on exhaust manifold ?
- optispark
- Wheel Alignment after LS1 Brake Upgrade
- Fog lights / Aux lights
- Odd Window Motor Question
- What do you say is the ideal lift on a solid roller cam for a 396 stroker?
- Jack Stands - Where is Safe????
- How to check if my EGR valve is bad?
- Anyone know how to use FreeScan?
- T5 vs T56 Transmission... what's the difference?
- lt1 intake elbow/ air duct
- Vaccum leak that can't be found, Please Help?
- Anyone running a 3.5" shaft and the SLP DS Loop?
- what size bolt on back of head for coolant line
- fog lamps
- any help?? ovc install...
- Just a heads up...Comp R's are now available straight from Comp.
- is the air pump needed to keep the cats alive, some say yes, others no?
- How hard to change pads and rotors???
- Stock LT1 track times
- door window outer felt guides questions (shoebox??)
- Any info on Dynospark optis would be appreciated!
- What gauges are important?
- What to do next?
- Car died, was jumped, ran like crap!!
- Another question about pulling/installing the heads..
- 93 Z-28 just shut off going down road.
- lifter recommendations?
- how much for salad shooters
- AIR fittings on Hooker LT's
- Quick question about pulling the heads...
- LT4 starter bolt into LT1?
- Fuell pump going out again
- Installed MSD 50# and now car is mega lean offsets???
- hmm
- Dual exhaust... OUT THE BACK!! Everyone inside!
- whats wrong with my times?
- will i feel a difference with HOTCAM???
- Cam Motions?
- Gasket needed for EGR block off??
- Where to go for fuel systems?
- Cai hp?
- fuel pressure?
- What else is needed to install gauges?
- Where can I get a cable and freescan for a laptop?
- LT1 Polished Alum Valve covers??
- 98ls1/94lt1/004.6
- Power Loss at high RPM
- Chips: Is Jet the best one out there?
- What timing chain in an ODB II setup.
- LT1 Head weight?
- STUMBLE/SPUTTER fixed!!
- installing the electrical oil pressure guage
- Hmmm
- If you could
- 94z heads and 97z heads questoin
- ATI TH350 Owners !!
- Next mods....
- what transmission oil do you guys use in M6?
- Anyone know the felpro part number for a full gasket set?
- Would bad tuning make your car misfire?
- Well ran my first 12 on motor
- NO!! what's wrong with my car??
- Why did I pick up 14 whp with cutout?
- installing cats for true duals/longtubes soundcats best to use for clearance
- Guys w/ BMR K-member...Need tips ASAP
- symptoms of a clogged cat??
- 3200 stall TC
- Need Help....blinker won't work!?!
- Drop Top Rattles
- rps with 4.11 m6
- B+M Shift kit opions?and install?
- Mechanical or Electrical Oil Pressure Guage?
- K&N FIPK VS K&N FIPK Generation II
- Wow is pulling the heads ever a pain!
- Some please help me with accessory bracket.
- Removing ASR
- Stuttering? need help
- b&m ripper shifter
- I need opinions!!! Please help!
- Talking about the ThunderChicken Formula
- Shift points for 224/230 112 LSA cam..
- little help!!!
- What is that noise when you shut off you car?
- Looking to buy Exhaust tips for a 97 TA need opinions and places to get them...
- Non F-Body Help (1996 Aurora)
- Not LT1 Related...but need help ASAP!! I almost blew my truck up!
- How much timing retard with 100 shot??
- Fuel line clips?? part number??
- Installing valvespring
- Help me Find the Corvette servo
- 94 cam in 95 car... possible?
- Did I block the EGR the right way?
- what does a 97 Z28 dyno at bone stock?
- bolt on car question
- What O2's
- squeaky rotor
- Help me out with my idea...
- How can I tell if I need flat or square connector for O2 sims?
- Tips for removing driver's side drain plug?
- GMHTP LT1 Vortech install issue?
- New ET's w/ Lloyds Heads
- cc305 cam question + valve springs
- Help ! LT1 stalling - EGR ?
- Hooker catback?
- stuttering?
- What is the rectangular metal piece under the intake manifold?
- Where's my cat?
- heads
- Wheel Question?
- Hit a sort of wall while accelerating through lower gears
- How much RWHP will this set up make and what should it run down the 1/4
- Shoebox part # please!!!
- Backfiring through intake.
- cai
- Help
- bad idle
- POLL...10 bolt failure record?
- slave/master cylinder and lines all come together
- suncoast creations ram air hood
- Post your dyno graph of your hotcam please.
- 93 z28
- Anyone put and LT4 block in an F-body?
- Flex plate wobble?
- can i put control traction on a 94 z?
- What type of fluid does the T56 use?
- corbeau seats
- Flywheel - buy new or resurface old?
- 17"x10" rear wheel. what tire?
- Question about functional Ram Air Hood??
- bell housing
- compression #'s??
- Which gears are the best in your opinions?
- What mods to do with the engine pulled... ? ?
- Where to mount tranny cooler?
- ignition gremlins killed
- How many splines does a 4l60e have?
- Front end feels loose
- fuel injector o-rings
- Taylor Fire Sleeves help ASAP
- Tip - Gasket Removal
- Header bolt thread size
- rain
- Brake Pads
- Need cam part number!
- ? - Using self aligning rocker with guide plates?
- can i re ring and install new mains on my LT1
- LT-1 Problem
- what clutch disc/LT4 PP combos work?
- Valves 16/32/8 ?
- 14mpg???
- Engine Miss-Fire
- exhaust question
- NEED HELP with a power window motor!
- GTP-6 cam or similar questions.
- companies for 92'ECM reprogramming ?
- Where can I find a bolt/rod to install crank hub.
- DOT approved aftermarket driving/fog lights?
- Pacesetter Shorties? Good or Bad?
- filters
- How Are My Numbers?
- True duals 2 1/2 or 3 inch pipes?
- Clutch/Flywheel zero balanced?
- Bypassing Oil tube that goes from Valve Cover to TB?
- Cant Hit Reverse
- Hooking Up The "Harlan" Shiftlight Question
- what is involved with changing pistons, rods, and crank?
- question about practicality of re programming
- New Spark Plugs - 3rd Time!!! Argh... this can't be normal! Misfire???
- Stupid guage question...
- rear seal is leaking on t 56!!!
- ? about Lt1 Mods
- [Engine Pulling] Your preffered method? Drop bottom or out the top?
- 16" T/A Chrome Center Caps
- 6 Speed = atf trans fluid??!?
- Oil Pressure
- FluidDamper dampner or ATI Dampner?
- header hardware questions??
- strange noise from spec stage 3 clutch...
- Question on jegs rad. hoses.
- What's the best radiator for autos?
- throttle body help
- LT1 Slight stumble/and stalling problem--any ideas??
- do you have to bore the block for a 355?
- Valve spring question.....
- Want to "wash" engine, what besides Opti to be careful around?
- those that have removed AC evaperator and/or heater core>>
- Spohn TA and LPE DS
- Not your typical header gasket ?
- Are all replica wheels the same?
- Too much play in steering wheel
- What causes a spun bearing?
- Shoebox! Can I get a part number????
- What to expect w/ my new mods
- tpis longtubes
- Questions On 383 Stroker Parts!!!
- Brake Inquiry
- Clutch Noise - Help
- Will a 4th gen sending unit fit 3rd gen tank?
- went to town with armor all
- Need a ZR1 17x11 repaired - slightly bent
- Switching to OBDI - Which fan mod to use?
