View Full Version : LT1 Based Engine Tech
- What are symptoms of a psychotic MAP Sensor?
- WS6 or a clone, how can I tell?
- After Cam Swap Dyno Numbers!
- muffler diamter
- How happy are you with your NGK Plugs?
- Just dynoed my 97 Ws6.
- Need help with lights ASAP
- Horsepower/torqe Am I Making?
- trans vibration
- Brake Pads???
- help new owner
- need help w/freescan ver 2.07
- "pink" rods factory in '93 LT1
- VERY bad gas milage, and a whoosing/sucking sound on acceleration
- dynomax ultraflow
- 8k rpm???
- cam packages
- Thump when I stop hard????
- another hp estimation
- t-56 rebuild question
- A4 to M6 How much $$$ we talking
- LT1 running rich
- Noob tranny questions
- SS Replacement Rotors
- oversized valves in stock heads
- How to strengthen the rear end?
- Low Fuel Pressure
- quick stereo Q's
- Here's a tip when trying to change 02 sensors.
- went to dragstrip today and bad things happened need ideas!!!!!!!
- pin hole leaks... OMG
- Anyone Get Their Rotors Zinc Washed Recently??
- Fuel Pump Not Humming!
- Best Gaskets For MAC Headers?
- computer chip?
- LT4 knock modual
- Swapping from 93 PCM to 94 PCM?????
- How good do flowmasters sound?
- STB install probs
- how many Horse powers?????
- Lt1 Dave
- slp 2otl exhaust whistle? would a cutout be worth it?
- zero lash?
- Where to get Transmission Yoke for LS1 aluminum Driveshaft?
- 2 ????? I did a search but didn't get the answer I was looking 4
- Shoebox, HELP
- Please help me with an electrical problem! QUICK!
- Where do I get this from?
- 1.45" Diamater sprgins.. which ones are the best and which valves?
- where to find dash cover94z(the big plastic one w/vent for defrost)
- Getting rid of REAL Knock Retard???
- What timing cover neededto run 94 crank hub and 95+ style Opti?
- Best Header+Exhaust Combo?
- Tranny pressure problems...
- For those who have pulled an A4
- Transmission trouble
- Header Question
- cc306 cam for sale on ebay..
- fuel pressure?
- crank/ hub problem
- firing order
- Help! Broke a wheel stud...Need help with replacement!
- AAHHH! What the "heck" is that? (SES Light) (edited by moderator)
- Car is on the road after HOT cam install!
- Used Power Programmer
- BFG DRs
- where to put cutout on my z?
- Hesitation and backfire, only when cold
- Slow.....WHY?
- Heads, Cam, Blower or N2O. Anyone running on stock bottom end?
- what next
- cool tip for trans cooler install
- transgo kit
- Rear spring suggestions
- True Duals on Stock Motor. Torque Loss/Power Loss??
- Coolant leak by starter? Help!!!
- Jet Hot Long tubes finally installed!!!! (pics)
- what ory
- Car lower on pass.side,and fishtailing fixed.
- Tight Valve Covers
- Best exhaust for 93 Z: Borla or Corsa?
- 98 Rearend in my 96
- any ideas for new mods?
- oil pump ?
- Noisy rockers?
- What to spray exhaust with to keep from rusting??
- Could 93 octane cause this??
- 94-95 Y-pipe on a 97???
- About This Lunati TIMING SET Summit Is Carying Now?
- Our Side Mirrors...
- 94 Z M6 7 1/2 1/16/3/4" ring gear?
- Any 400rwhp or close to it running stock ignition?
- Rhino Ramp Clearance
- First time at the track.....
- electrical problem
- Completely lost in the sauce on this one
- Throttle Position Sensor
- Heres the wheephole "safe the opti" mod *pics*
- epoxy on port floors?
- What is wrong with my car????
- 383 Balancing ?'s inside...DON'T WANT MALLORY! Please advise...already searched
- Another fuel pressure question.. Does FP drop or rise when you rev?
- Speedo gear change in a 93, in car?
- Tire size question?
- torque for head bolts?
- car pulling?
- security light on while driving
- 93 and 95 valve covers???
- did a tune up
- AHH can't decide!!!
- shoebox would you happen to know??
- opti apart, shows signs of arcing
- will LS1 flowmaster fit LT1?
- it has been a horrible night... there is a lifetime warranty on opti's, right?
- Just put in my K&N FIPK
- Rear end gears/differential- How hard to install for first timer?
- optispark
- Frustrated
- Will I pass smog?
- OEM SS Part number 93 97
- Cam Install
- pic of my destroyed rear end!!
- Can I buy single ARP head bolts ?
- Installed new comp cam, now the exhaust valve is hitting the piston!
- Drive Shaft Questions???
- 95 camaro z28
- Is this opti symptoms
- MSD 32129 (OTVC) Coil Wire ?
- buy new or rebuilt??
- What size Cut-out?
- Engine quits at random times and wont start up again for an hour...
- Best place to get stock parts online
- ZZ4 Cam Identification
- billet vs cast cam
- How to clean tb??
- AV Gas
- 1LE intake elbow
- grinding 2nd ...........what's the deal
- Rollbar install complete...Interior reinstall ???'s
- Part # for 1LE intake elbow?
- I need a part number
- Cam goes in, Rear end goes out- Need advice
- People with Mods in here
- TEA heads
- OPTI rebuild kit ~ does it exist?
- A few part #'s needed
- Should i do a 383 stroker or not?
- Need of relocation brackets on lowered M6, quick question??
- Mutherfrikin hoses
- Piston rings, what are we running here with strokers??
- MAP Sensor Questions (relating to my starting issues)
- removing air pump
- Question about longtubes and OBD2
- Horse power question??
- Bullet mufflers and Loudmouth
- underdrive pulley wont come off
- werid ?
- Rough idle, high iac counts, rich, hesitation
- Stock valvespring seat thickness?
- Roller Rockers
- Upping the Ante
- Need to find 14 sec civic post
- High Octane Fuel and Performance (or lack thereof)
- Transmission Question
- LT1 reliability...(both drivetrain and interior)
- Installation on new vented Opti....PLEASE HELP
- Gas Cap
- Things I'd like to do while heads are off
- Part numbers for front 02 sensors?
- Fuel Pump removal through trunk!?
- 355 vs 350
- Those that removed the splash guard inside
- I got my old opti out! Im almost positive this was my problem!
- Online Tire Dealers
- Part # for LT4 KM?
- accel dfi system
- Please Help. Procedure for filling up on coolant.
- What Clutch to buy?
- Sounds like marbles in the trans case??
- Falken GR Beta FK-451
- Timing gears?
- Quick help needed, car won't start
- Unregulated Fuel Pressure??
- Looking for a clutch part.
- Porting heads by yourself?
- Fuel pressure question.
- Tornado performance
- HOT Cam folks, How loud are your Rockers??
- AC will not blow???
- stock fuel system till???
- MAC hi-flow cat and 3" i-pipe? hiflow cat owners inside please
- How hard is it to remove the front sway bar?
- Lt1
- theoretically..
- Hard start and stumbling problems, please help
- OBDII Programming Released.
- Pice of crap tranney...........
- Radiator Fill Runthrough, (need someone to read through this)
- ATI mod
- car crapped up on dyno....need help
- Weep hole tube?
- K-member bent! Where to get new one?
- Car wont start
- Leaking tranny
- Car wont Start!!!
- Lean condition with new Cam?
- finally completed v6-lt1 swap
- 160* stat... worth the install?
- Quick SES question
- Brodix-headed monster came to life!
- How much hose do i need w/tranny cooler?
- Got a problem with a Z28 at a friends speed shop. Need your opions
- Opinions on Nitto 555 Extreme
- Anyone ever replace a window REGULATOR or sping before??
- Where can I find fittings for a Rad?
- How can I calculate what spring height I need for my new cam?
- Do lifter need to be "pumped up" when setting valve lash?
- Putting a used engine in anything I should do....
- Check out my airbox...
- Anyone got pics of welds or centerlines on their cars?
- where do I buy seafoam from???
- Buying a camaro, bit of help
- Having a hard time getting cam dowl out????
- If I block off the EGR on the intake...will I pass emissions?
- anyone who knows about o2 extensions and simms please help
- anyone with true duals please help
- T-56 gurus please come in and help me out......
- Can I use this block?
- Movie - XE230/236 cam & GMMG Idle
- Fuel Pressure low
- Serious Help - Rebuilding My Engine!
- Low top end power, rough idle
- Plugs and Wires
- Hypertech PP3 Deprogramming?
- Car died on way home today! Help.
- Pulling My Lt1
- Free mods for C4's??
- Manifold leak(?)
- Performance Trans Mode
- Guys who port heads
- performance shift button stuck?
- How to install Taylor Opti ends on Accel wires???
- BFG Drag radials- What PSI on the street??
- Turn motor half a revolution then stops, whats up?
- MAGNAFLOW exhaust systems. Comments Fellas...
- Car Is Acting Crazy!!!
- OMG HELP, this is really bad. A4 Trans Related.
- Rear hatch rattle, help!
- Jason Cromer's Contact Info
- Accel Ignition Questions
