View Full Version : LT1 Based Engine Tech
- can this cause detonation?
- Porting the intake
- Will Crane Gold 1.6 rr work with XE 224/230 cam
- Car won't go over 112
- Heads on Ebay:BS?
- Why am I having clearancing issues with the CSI waterpump???
- white faces gauges.. 150 over 110?
- High volume oil pump
- cigarette lighter doesnt work.
- Torque specs for Pro 5.0 shifter bolts?
- Brake Issues
- True Dual w/cats
- Ive been tricked. quick question.
- car wont start after radiator install..
- Wrong Pump???
- gm torqe conv.??????
- Need Help Removing Intake ASAP
- Optispark
- Fuel Flow ?
- reverse lockout solenoid
- T-top conversion
- On a 396 engine, where do you put the timing mark on the harmonic balancer?
- I have noticed that ARP head bolts have a bevelled side on their washers!
- Can I launch any better with???
- 1le or not?
- Stupid Question (Wipers)
- 16x8 2002 firebird wheels don't fit 96 Z28? WTF?
- injector question??
- Update - Engine Rebuild
- Tire help
- 95 Z28 Wiring Problems ... Anyone with Pictures ?
- Auburn rears
- Overheating Problem
- Who sells stock length high flow y pipe?
- First LT1 with experimental muffler :)
- Heads/Cam A4 vs M6 Cammed Car
- Electric Whirring Noise?
- Starting problem. Need advise.
- 4.56 too high?
- BMR, great customer service!
- intake oil leak question...
- Machine work required?
- window/door switch question
- Alternator Making a funny noise?
- 30lb's or 37lb's
- Diagrams, dimensions, or drawings...
- 700r4
- Best spring/shock combo for a street/strip car?
- where to get exhaust
- What is wrong with my wipers
- lt1 ls1 differences
- FLP headers on a 93?
- crankshaft question
- What are you guys using for lifters these days...
- what would a procharger 3 core intercooled go 4
- Shoulda listened
- Ok guys, i really need your help/advice on this one...
- I know I'm gonna kick myself when i find out
- What hole in the back of the opti should I put the cam dowel pin in?
- Mods
- drivable cam with A4
- Emissions in the state of georgia... Some help plz
- 4 bolt mains?
- AIR/FUEL ratio gauge helps and tips maybe inside ~~~~>
- t56 hard to shift only when running HELP!!
- Clutch Problem
- Getting Spark Retard. Bad Knock Sensor?
- Washer fluid squarter thing
- Making the Wheels Wider!
- most insane cam you would consider "streetable"
- ls1 brakes on moser rear
- Quiet Exhaust?
- Spark Plug Wires
- 1 LE 4th Gen people, I need your help
- Belt keeps getting chewed up
- SLP Loudmouth or gmmg
- Wiper motor replacement/tools?
- Did anyone make it so their A4 will hold 1st gear?
- Whats this?? se pic
- Are all M6's the same?
- Anyone else shred belts?
- keyless entry FCC #
- Z05 Brake Conversion for rear brakes - possible?
- SLP 2OTL custom idea
- name that connector
- Another XE Cam question...
- lt1forum.com
- i have 1500 to port my heads, what else should i do?
- SD to MAF conversion
- where can i buy the conversion?
- Any problems with roller rockers and stock springs?
- So what are the latest, greatest, and most popular LT1 cams today?
- Aluminum flywheel?
- Burning Metal Smell???
- What is the difference between the LT1 hotcam and LT4 hotcam
- other oil thread reminded me.
- Will I gain anything?
- Difference in single pattern and dual pattern cams?
- Is my starter suppossed to be like this?
- Magnaflow for cheap!!!
- Felpro
- MAC header users (and other ?)
- No More Cats
- shift bumpers
- Help me pick a Cam for this set up.
- 3600 Stall killing me at the traps.
- Alright Everyone They're almost done.... Custom LED/Clear Bird Tails
- SES Light when in 6th gear for 30 minutes or more
- electric cutouts
- Srt4
- Crankshaft Position Sensor Help!!!
- custom exhaust question
- t56 grinds goin into reverse just swaped from auto
- Unhooking AIR??????
- Line Lock & "Brake" light on Dash on again.
- LT1 Scanmaster Users In Here Please
- are RR's worth it?
- csi waterpump
- Those that consider themselves a cam "guru" please come on in for a discussion...
- OBDII to OBDI?
- Video of my 224/230 112 - Hooker LT's - Idle/WOT
- Crane VS. LT4 rockers
- Exhaust Question
- Slippage after tranny rebuild? Help
- 93' Hooker Shorty's
- Proform Valve Covers for 97 Z28
- performance chip problem
- Clicking after MAC header install....
- 383 stroker build up suggestions
- Throttle Body bolt Thread/size?
- Planning on changing Tranny fluid... few Oil questions..
- CSI electric waterpump keeps blowing fuse???
- Valve Covers
- Need some help with brakes
- Roller Rockers
- Dual Exhaust Pictures
- Crane 1.6 Rollers ROckers on stock LT1???
- HELP, Car wont Start, Backfires, Smoke out the Intake
- I have searched and looked....need somemore help.
- MACs are here!! Single cat ones for my 96
- crank hub bolt stuck in crank
- Going to change OPTI and lifters tomorrow, need some advice
- Procedures/Parts needed for axel swap
- Should I update my ignition?
- Tach wire??? for shift light???
- engine upgrade
- Best price on Hooker Catback??
- Why the hell does my car jerk at 120???
- How's my custom CAI look?
- Need Full LT1 Gasket Set?
- Help me cleanup / 're-decorate' my engine bay...
- What is the strongest Pinion Bearing?
- LT4 Intake Part # ????
- What is the duration when using 1.6 RR's on the XE 224/230 and 230/236?
- Put engine back togother w/ a stainles ALLEN head bolt kit?
- best exhaust!!!
- midwest converter gains?
- Gauge Cluster Light Bulb P/N for 94 Cam
- Unknown gear change before I got the car?
- Opinions on a clutch
- NEED HELP!! Terrible noise from passanger rear wheel!!!
- HELP! Car won't start suddenly!!
- 95 opti harness
- Valve Cover Gaskets
- Oil Wizards: is the new Mobil1 15w 50 ok?
- ICM cooling mod results
- JetHot LTs & dual 3" after collector cutouts
- Post a pic of your ECM PLEASE!
- Help me spend $300....
- 15x10??
- LT1 head porters near Dartmouth, MA area
- ultra flow muffler
- Accel 9000 Extreme Wires
- vented opti conversion question
- stumbling question
- What should I look for on scanning my Z?
- Cam Question
- Cutting my cats out 97 z28????
- new track times
- Getting wheels narrowed
- rear gears
- underdrive pulleys
- JBA headers
- Went to the track, what do you guys think?
- 93 harness to computer hookups different
- Rear Brakes squeek ALL THE TIME
- OK i need a tranny rebuild
- M6 is making noise, help!
- LT1 heads and cam parts info
- Shift Points and A4 Tuning
- st count, o2s, and duty cycle all messed up.
- My 95 TA has six speakers??
- Can I remove the heads without taking the intake off?
- will the Richomond siix speed fit on a lt1 car?
- bmr suspention or hooker catback?
- does anyone know the part# for the corvette cover pins?
- theft deterant relay
- Eaton or Zexel
- why is hub such a PAIN to get back on?!?!?
- N20 and Hotcam
- Installing an AutoMeter A/F ratio gauge. which wire to connect to 0xygen sensor?
- ? for those with Strange 12 bolts.
- Which Clutch to Buy?
- Axel part number
- Tuning Program questions
- Wiggle the connector and my car starts ?
- which hose goes where?!?!
- airfoil has nothing to screw into?
- Max effort street strip Hydraulic Roller?
- ECU Programming
- Shift kit install
- Is it ok for my cooling fan to be on all times?
- Solid roller valvespring recommendations?
- Feedback on JBA headers?
- new springs?? or what?
- 9 degrees of knock from t56, need to disable the knck sensor for a while
- Goodyear hi-miler hose kit for 94?
- Please recomend a good cam for my combo.
- LS1 rear in LT1 car?
- What are some good pistons for nitrous?
- About removing cylinder heads
- Dielectric Grease on opti ends?
- Catco Catalytic Converter?
- KR at idle?
- Evolution fast?
- 2 Release bearings in 10K miles?
- Quick question on where to put boosta pump.
- Fuel pump not turning on!
- 36# inj. on stock motor w/ stock programing?
- Do I need alignment after springs swap?
- Throttle body idle screw question
- Need firebird headlight help...
- Brake light stays lit on dash...
- Daily Stupid Question
- distributor from postive of battery,can i use it?thanks
- bad gas = white smoke
- Damned Muffler...
- Problem after header install
- Doing DMS springs, follow the haynes way or someone else's?
- Best place to find exhaust clips??
- e-brake questions..
- SLP loudmouth or Flowmasters?
- 93-97 brakes for moser 12 bolt
- LT1 Catback/Muffler
- non Z rated tires.....
- shift light help
- valve cover made by profrom
- 95' Computer
- this winters mods finally done
- Quick question timing ? from new guy.
