View Full Version : LT1 Based Engine Tech
- aluminum paneling after stripping interior?
- Do Mac headers come with hardware?
- Does spec clutch cause "jolting" starts?
- 315/35-17's?
- people with an EGT gauge
- Omg
- How did you plug the air tube on jet hot LT's
- Mcleod street twin PP vs. LT4 PP
- hesitation/stumbling from idle
- 97 M6 dynoed today!!
- Pic of my Custom CAI
- Homemade CAI
- Can't get fuel line disconnected.
- tranny only shift under 30% throttle, WTF??
- How can i balance a 383? Also will stock oil pan work?
- who is this
- OK, Changed my window motor, now have a slight bang. Please help with any suggestion
- what is this
- 1.5 or 1.6 RR's
- T/A cover stud broke..where to get one?
- car idles high when coasting to a stop
- What is you normal operating voltage?
- What is this????
- Clutch question
- where to get one or two lug nuts
- dyno today..tell me what you think
- flow numbers on new edelbrock heads??
- Weld draglite
- Need some cheap head porting. Who can do it?
- Cleaning the injectors
- got some $$$, what should i do?? (cam people inside)
- Will all the Gen1 1 piece rear main cranks fit the LT1?
- putting on new pads
- LS1 Speed Inc is top notch!
- how in the x#$@ do you get the tranny back in with the street twin????????
- Low Coolant Light still on!! What Now?
- Diagnosis Murder.
- 60' Times ?? please read
- Cleaning your LT1
- Is this necessary??
- More LT1 products available
- push starting
- car starts fine 5 times in 4 hours....suddenly won't?
- Anothe Gas Gauge Question
- Size injectors for a N/A 396
- 306 or Custom Cam?
- Headers were installed last week and now ONE plug wire is arching.... H E L P
- gasoline
- TCS removal?
- guys with 3.23 want 3.73 look first
- oil pan
- does anyone here know anything about true duals and x pipe please help
- Diagnostic test first or just replace optispark???
- which cam???
- Cam is in....
- Super ram on Lt1
- build too loud 3" true dual exaust
- Chirp when you let off of acceleration?
- where can i get a line lock
- Transmission 700R4
- Best shock to run with Sportlines?
- Slp Cai...
- Rag joint eliminator kit installed
- which mod to choose
- part numbers
- Need to find a place that sells the center console gauge pod...
- slp cai
- reducing knock sensitivity on a 93
- Stock Rockers studs and guideplates
- Z06 85mm MAF worth it?
- Use of NPT Fittings instead of metal lines for head coolant?
- EGR valve removal, how to?
- Car dies while driving and hard to start...
- Weird Valvetrain problem
- How to inspect lifters, have car appart need help
- squeek comming from the hood?
- what's your oil pressure at???
- LT1 PLug Wire Length
- 93 keyless entry
- worse gas mileage after programming
- Are lightweight driveshafts worth the $
- Getting heads now what cam
- Don't laugh........SNEAKY PETE
- Disabled VATS, now can I...
- 95' TA... Lack of power and backfiring
- How to make first gear selectable A4
- seat belt
- im not sure
- Anybody got a good scan file I see to compare my freescan log?
- EGR Code Help
- State Vehicle Inspections - help
- Are Comp r lifters a must when swapping to an aftermarket cam?
- DEI HT Silicone Coating for headers
- Advice For Mods Needed
- Any way to adjust idle?
- need people w/ a 94 or 95 z28 m6 and 3.42s
- just got back from the dyno!!
- FUEL FILTER from JEGS, wrong one?
- My car died going 35mph in 3rd. absolutely no warning
- has annyone put dual cat exausht on a single cat car???
- bleeding brakes??
- th400 conversion
- Removed egr , now car is having trouble starting
- Clutch Fluid?? Flush??
- Belt squeek/Chirp
- Lean in Bank 2
- Baer rear brake install?
- That's all she wrote!
- Pulling oil pan!!!
- LS1 vs. LT1 spark plug wires, very important!
- Stupid question, how to unplug the oil leve sensor?
- change a4 to m6
- took some pics
- Advice... help?
- SPEC clutch install help...
- what oil should i use
- Funny things happen when you unplug the MAF
- Coolant in oil again!!!
- fuel pump...
- Dip Sticks
- 4"-connector K&N filter for CAI location
- Quick...need advice
- Just got a cutout, is this normal?
- m6 from a 93
- what size pipes to replace cats?
- Need 304 sound file
- I think I found my heads!
- throttle body sensor mod
- "Turning" your exhaust into a catback
- can I test a cat (cloged or not) off the car-found one in garage
- 58mm TB is not too big!
- Fan Switch
- Camaro waterpump different from Corvette waterpump???
- ls1 superiority?
- need question answered about window and headlight motors
- My car backfires at low rpms!
- 1LE Intake Tube has been installed
- Throwin a code (26) on my '93
- CC306 is in!!
- I know this is a dumb question but could someone help me out here?
- No Dampner on Underdrive Crank Pulley?
- Code 67.....
- open/closed loop question
- bored TB's...any imput?
- Where to mount gauges in Camaro interior?
- whats the best pulley(s) set?
- anybody used the jet IAT relocator?
- Edelbrock Tubular Headers?
- Starts and dies after sitting for a few minutes, 2nd try fires right up
- Need lifter retainer part number
- Electric water pump wiring question
- Head work quote I got today.
- Just had my Nittos installed, thoughts within...
- Will removing airpump throw ses?
- are there any gains fro swaping stock injectors for 24#'s?
- Pushrod length question
- Pushrod Length?
- No Power TO Radio 94 TA Lt1
- Rebuild a water pump?
- keyless entry
- brakes from 94 vette
- Spark plugs backing themselves out?
- broken water pump or just a gasket?
- Does anyone know what kind of Ypipe this is ?
- self aligning roller rockers?
- Portland area mechanics
- EGR deleted, ok remove solenoid & vac. lines?
- Would like to do a Heads and Cam combo write up, everyone that did it come with in!!
- Cam recommendation
- Anyone have Part #s For LS1 brake Conv.
- Grinding when engaging clutch...
- How long are coated Hooker long tubes lasting?
- dumb question,are salad shooters aluminum??
- Auto Trans Fluid in an M6
- converter/trans question
- All my problems are fixed after cam install! Opti...
- Spayed Main Caps- Which ones?
- How crappy are BBK shoty headers?
- tire pressure??
- are the 700r4 and 4l60e the same thing?
- Car leaning
- T_top conversion ? anybody?
- what trans fluid do you guys recommend
- Know any good tricks to get a rotor off?
- quick question: CFM?
- Popping out of 1st gear
- what headers
- Anyone with Eibach springs, HELP. Having probs with my struts!
- port quest.
- Rocker stud diameter question????
- New....
- plug wire locations affectng performance?
- SLP SHORTY HEADER problem
- 2 Questions, why is my keyless remote range so limited? and.....
- pcm service number
- Cheapest place for a set of lifters??
- Which are the better plugs?
- How often do you do Brakes?
- locking or not locking (axel) that is the question.....
- What are the differences between these two LCA's?
- Retard Roomates lol
- OK, my clutch is toast, what should I buy??
- getting headers on friday
- 4.10 Question!
- Low coolant light.
- 1st gear grind.. what could it be?
- Where can I get a 2OTL silencer cone?
- Rev Limit/shift point suggestions for my setup
- PLEASE help, car just shut off...
- how to "gut" the cat?
- Best way to fix front dash?
- Broken poly trans mount?
- what could be wrong with my car?
- How is the SLP 2400 Stall converter?
- bare block weight
- To anyone that has changed window motor
- AFR 190cc heads ported
- 285 horse
- injector size
- SLP's take off tires
- tuning problems....
- opened my optispark
- What tools needed to remove seats
- about to rebuild lt-1
- Anyone have problems putting on timing chain?
- need some advice on rebuild of lt1/a4le80 built
- Pulleys or 4.10s?
- Will a high performance clutch last???
- headers
- Are the Trans Am's really under rated?
- Transmission mount
- What do you guys think of these mods??
- Bearing on the spider of the driveshaft...
- $400 to spend, help me go broke
- What would cause tranny to not shift into OD automatically, but will manually
- weird crank
- How Much Is The Z Worth
- 1LE Intake Elbow
- bottle brackets
- Combination Motorsports stage 1/1X....
- my wounded stock rear finally broke teeth...
- denting valve covers for alternator
- trouble code P1416
- Who here passed the sniffer test with no cats?
- p/n for trans cooler line on 95Z
- blac3rdgen complete gasket set
- Last minute tips, advice, etc before starting new motor...
- Does rear end differential cover have gasket underneath?
- Question about true duals...
- TB bypass kit
