View Full Version : LT1 Based Engine Tech
- please help me fix my A/C...I'm this |...| close
- camshaft help please!
- oh my god... im about to jump off a bridge
- Hot cam and emissions/smog test
- Advantages of using LT1 Edit on an OBD2 VS and OBD1?
- PoPiNg at 80
- For those who need programming for their 93 LT1....
- brand new AC Delco part went bad ... can i return it to any GM dealer?
- I haven't talked to anyone who hasnt broke their MAP harness!
- What is it?
- Argument over what MPH i should TRAP??
- homeade cai?
- fuel ???
- m6 transmission noises..........wtf
- Fuel Injector Install
- Installed Headers, Now bad idle/ low RPM Stumble
- is snapping the rear a REAL concern with the xe 230/236?
- DTC 65 - oxygen sensor location
- Suspension suggestions??
- 2000 Corevette Help
- Long Tubes= loss of torq?
- what would happen
- low oil sensor
- Cheapest place to get ac delco 02 sensor online?
- cheapest 15x10 rims
- anyone have bigger injectors for the 224 xe?
- Not too impressed with pcm4less
- best cut out size for stock 94z (getting hooker soon though!
- Oil leak
- Who has used pcmforless.com?
- what clutch
- loss of power
- best mufflers for dual exaust setup
- Less Power w/ Cutout? and Exhaust Question
- finally broke 14's...
- What happened to my power?
- trick to installing a stock or 1LE intake elbow
- JBA headers
- Where can I get 2" / 1.56" valves?
- Cam install Help Please!
- Lt1 TB bypass and coolant line problem INfo needed
- Break-up at 6000rpm! Is it MSD BTM TIME?
- pulled intake cant see obvious bad lifter
- Dumb auto tranny question
- any loss with leaving cutouts closed?
- thermostat gasket?
- Stall/Rockers or stall/gears?
- gear change
- Whats the cheapest way to run 13.0s
- Loud pop and car died going down throughway.
- Drive shaft weight???
- Whats the cheapest way for me to run 13.0?
- Cam experts inside (396 Solid Roller)!
- Are the AIR fittings different from 95-96?
- Tan Leather
- Little help please, starting issues
- Just installed the slp LM today have one ?
- Some feedback please
- Solid roller lifter question
- URGENT: RE: JetHot header AIR fittings
- bolt torque on belt tensioner
- Will a 4th gen exh. fit a 3rd gen
- 1le intake elbow
- 93 icm compared to 94-97 (shoebox)
- another EXHAUST question
- Electrical problem! Please help
- What are the fastest 60' times you've gotten on stock radials?
- passanger side plug wires?
- May have a fuel problem, can someone help me on this one?
- Power Programmer Plus
- #2 Carrier Gears??
- Engine installation
- Low Trac Light
- How hard is it to?
- just dynoed car- questions
- stumble what do you think
- Rear main seal, hard?
- Heads gasket
- Made In Mexico.......
- LT1 intake a 2-peice intake?
- maf mod, is it worth it?
- Annoying Noise! (Shoebox??)
- Any drawbacks from removing AC system?
- What mod should I do next
- Cat Removal?
- How & where to get a LT1 shortblock (without cam or timing chain) for under $2,000 ?
- BMR Drag-Race X-treme Duty Sway-Bar on the Street?
- Automatic gears getting mixed up
- my chances against a 2003 mustang gt?
- Is the LT1 Hot cam kit the same thing as LT4 hot cam kit?
- Second time this code has appeared!
- Gas: 87 vs 89 vs 92
- How often should the Fuel Filter be changed?
- If you run rich, can that ruin performance?
- FLP headers - Rattle?
- fuel pump going, what to replace it with and from where.
- Would I be able to take my buddies '99 trans am?
- does porting ur intake do any thing
- Clutch Price Rip Off?
- if i just added.....what kinda gains am i lookin at?
- Annoying
- How fast should my modified car go
- Header Studs ? How tight?
- door wiring harness
- slp cai
- Bad weekend :(
- 383 stroker, low output, need suggestions
- 4-bolt main
- Starter Solenoid...where can I get one?
- quick question
- Throttle body Differences
- First time at track, very pleased
- LT1 Edit or Autotap or??? OBDII
- Is 14.0 possible on street tires?
- What does the new Hemi Dodge run?
- What is it worth - 94 TA?
- What would it take for mid 12's
- Heads/cam problems Freescan results
- How Do I Remove Dash about Gauges?
- Intake Heatsink? CPU Style
- Lack Starting power...?????
- clutch
- Raptor2x 2800 PATC(box says Midwest)ANYGOOD?
- Best Clutch for mid-high 11s
- Will Hooker LT's clear BMR K-member?
- Will this work???
- Slp Totl
- Fuel Filter
- G12 327 what does that mean?
- SES Light
- Looking for pic of stock clutch vs spec...
- can i do low 12's
- Does this wear look normal? (PIC)
- Two different map sensors listed for '97 LT1...??
- smoke after cam install
- Mac Torque Arm source?
- Mechanics In Decatur Illinois
- Transmission Cooler Install for M6 to A4
- K&n Fipk
- What should I do first? 1.6 RRs or the MAC Headers, I have them both here
- Can I ditch my power windows?
- fuel injector harness clips? Can they be bought separately?
- SLP LM's ?
- headlights are possesed
- Best way to store crank?
- Foot pounds to inch pounds of torque help??
- Valve Lash Adjustment
- How about this?
- What do you think about these LCAs?
- How do I get 330-350rwhp cheap?? Cam, headers??
- leaky oil filter
- How much hp with rr
- True Duel exhaust pics inside
- Smoke Coming Out Of New Value Cover Breather!
- hotcam
- A4 to M6 SWAP ???
- lt4 question
- Where can i get steering wheel cover? (the centre section that blows with ur airbag)
- comp ratio and spark plugs (heat range)
- A4 guys, how much MPH did you gain from your cam install..
- Mac headers
- 16 inch or 17 inch wheels???
- what happens when rockers are too tight??
- How much torque can a T-56 Hold?? Any difference in a LS1 T-56??
- flex plate
- ?'s about Vacuum hoses to opti.
- Racetronix LT1 Fuel System Improvments
- EGR anything to worry about?
- What do you think about those hearers?
- Slight vibration in steering wheel when I turn at low RPM
- MAF Cleaning?
- Differences between Tremec and Borg Warner Trannies
- ShoeBox...need a part number for MAF Screen :)
- question about the B&M ShiftPlus Elect.Shift Improver
- Where to find replacement bellhousing???
- Moser 12 bolt gears
- Has anyone had a #1 primary slip fit throw off o2 readings?
- rear springs
- small problem...need help
- MSD question
- 52mm or 58mm TB with CC306?
- Adjusting Rockers with large cams
- new to LT1's, been hangin around ford's too much, what to do first
- K&N Fipk info
- cali emissions? differance?
- Vette wheel hubs on a Camaro?
- Worth anything?
- This is what I'm doing...few ?s
- Advise please - cross-member ?
- thread chasers, coarse or fine?
- Do 93s have different rear rotors than 94-97?
- lt1 cam bearing question
- Cutout
- Does this 4.10 look OK to install?
- hissing from under the hood? its driving me nuts!
- build me a low cost 383
- Okay... iy finally got me... loose converter and OBD1...
- Magstar wires...ever heard of them?
- 52mm throttle body on a stock motor???
- ET Street Tire Size for 15" Rims
- Clutch pedal switch
- Throttle Body Question
- gutting my pass side cat
- Getting 12volts on the distributor reference low wire
- lt1 tuning
- What is the stock rear gear ratio?
- MSD help, ASAP!
- Dumb question but have to ask...
- TPIS Heads: who has 'em?
- Dielectric / Heat Transfer grease
- Where to get colored vacuum tubes?
- Anyone who has ever blowen a POWER STEERING pump or spun a DONUT, inside please....
- Miles on a mostly stock car???
- abs light, security light, HELP
- Calipers
- unvented to vented opti. conversion?
- Did a search....Part # for MSD wire to do Over the Valve cover
- How much coolant do I need to drain?
- Gauge overlays -year/model?
- Welding axle tubes
- People with Walbro Fuel Pump INSIDE PLEASE
- How to install Air/Fuel Guage?
- Best gear choice 3:73 or 4:10
- header leak....
- Re-use original head bolts after doiong head gaskets?
- Fuel injector cleaner and other additives....
- Torque Converter rattle?
- Don't buy por-15!!!!
- Jason Cromer
- Fresh 383 install, few problems please help! IDLES at 2000!! also, ABS inop light
- exhaust manifold gasket - how difficult to replace
- AFR 210cc LT4 Race Ready heads
- coolant light
- Anyone running Bilstiens?
- Super Weird Plug Fouling Problem w/in ---->
- Is there a way to reset the computer?
- Throw out bearing and input bearing?
- Rplaced opti, now no start
- Clutch Question
- Good place to buy Bilsteins
- TDC Help For Rebuilding LT-1
- Help!! I think I blew my new motor
- need advice on new problems
- Ignition fuse keeps blowing...
- 11s on stock heads?
- Help me build the ultimate LT1 top end set up
- Blue box under dash
- Whats quieter?
- Loudmouth
- brakes are squeaking a clicking!
