View Full Version : LT1 Based Engine Tech
- Very Confused....HELP!!! (header guys inside)
- Why wont my car hold a charge?
- 224/230 XE Track Results (Crappy day for the track..)
- tail light
- Dynomax Race Magnum?
- best cai
- whats the dif?
- red light thingy
- newtimes with slp's
- Bay area mechanics
- PS Fluid
- Help with torque arm bracket
- High Idle with long tubes
- Our stock rear ends are 7 1/2 or 7 5/8? Right part no. for rear diff. cover gasket?
- gunned it in first at about 7mph and she back fired
- Tech Help Headers on almost stock lt1 What size?
- autometer FP gauge has a crack face...
- Clutch Experts - Please help!
- camshaft surface rust
- Heads/cam problems UPDATE :-)
- Block problem?
- Pics of mini-tubbing and Impala SS for 18x12 with 335/35-18
- Replacing Pushrods??
- Fans not coming on...
- lt1 motor swap to a 87 corvette. need a little help
- Quick Tech- What size headers for almost stock lt1 street
- removing the egr valve
- Traction/Performance Buttons on 95 T/A, CAN THESE BE BYPASSED?
- diff cams which one is the best
- ABS inop , Low trac ???
- Aluminum drive shaft ls1 on lt1?
- 12bolt/9'' do it yourself conversions
- FT Force - If you work at this location in houston tx - cantact me!
- 18 inch rims
- What spark plugs does everyone run?
- Please Help
- Are those SBC CHEVY VORTEC ROLLER TIP ROCKER ARMS any good for LT1?
- need a new alternator
- True Duals
- Where to buy 315/35R17 nitto drag radials cheap??
- squeking sound from engine bay..
- unvented opti conversion to vented how???
- LS1 conversion question
- stupid, stupid, simple question!!
- does bad opti feel like no fuel?
- headers
- Please help...fixed opti now it overheats.
- Help with tranny dropping
- Strange sound after Hooker cat-back install.
- Changing valve springs and cam?
- throw out bearing
- OMG!! Headers and cutout install
- Check Me On This Plez
- What's the biggest size valves you can use on an AFR 190cc heads?
- "brake" light on
- Exhaust question?
- Car wont start, don't hear fuel pump pressureize system
- Foglights not working.
- exhaust
- 1/4 mile times
- which brand of brake pads?
- Question About High-Flow Cats, CA emissions, and more
- Can you get the engine out with the cast iron manifolds on?
- Any dyno sheets from before/after 224xe or similar cam or ASM/Mac headers or both??
- How hard is it (really) to rebuild an engine?
- how many miles on your rebuild
- Just took the swaybar out, what to expect at the track tomorrow...12's?
- another cam ? need to know asap
- will this setup work with hotcam
- motor mounts
- header install questions
- What Next????
- OOOPs, need help identifiying broken part!
- Yokohoma AVS Intermmediate tires best bang for buck?
- Spec Stage II or SLP clutch??
- good price
- Gettin me a camaro
- I think I know why I blew head gaskets
- ProForm Roller Rockers?
- 52mm Throttle Body?
- be careful in the rain!
- Granelli MAF... worthwhile or not?
- Seals for AC system...
- Do I need to change lifters with Hot Cam kit?
- aftercooler ?
- Problem!!! Fuel Pump???
- M6 Bell Housing Removal Please HELP!
- Water pump died, I think it took the opti too. What do you think?
- Found a Good Intake / Header Cleaner
- KB Hyper pistons OK for 125 shot
- High Octane burning valves??? My old man is scaring me.
- Converter Question
- What crank bearings and rod bearings are people running?
- How good are the stock connecting rods?
- Removing motor mount
- Muffler with offroad??
- parts list for opti conversion???
- High RPM Stumble, Need some advise inside!
- Burning Coolant - Blown head gasket?
- getting my first z28
- How hard is it to take a 4L60E out by yourself?
- Fuel help ASAP please
- before i waste my time money and effort, has anyone made brake ducts yet?
- Why does my oil pressure drop slightly at 5k and then back to normal???
- 14mm or 15mm ?
- Valve covers
- Flow numbers (strange)
- Just got 97 z28, bone stock - what mods to do first?
- What is my next mod?
- Whats a good piston for 383 and 150 shot?
- Cam for Autocross I need opinions
- What Passkey system in a 95 Z28?
- opti/CSI install(crank hub)
- OBD1 Cable
- Finished grinding down dowel pin and installing opti
- Need Advice on Spark Plug Wires/Plugs!
- Here's a good head-scratcher
- Changing Fuel Filter.......
- i changed my front right wheel bearing assembly
- anyone run ECSTA 711'S?(tires)
- cleaning n checking the idel air control modual
- 93 blowing air pump fuse
- Do those 1.6 rr fit to Lt1?
- Misfire SES. does it pull timing at all?
- Whats the cheapest place to but 1.6rr?
- Ok to run without O2 simulators??
- need quick help
- WHat on earth does this code mean?!?
- tranny cooler install, how long did it take you??
- Dyno Results are in.
- could a faulty fuel filter cause...
- Please Help Error Code 16
- How is PCMFORLESS.COM
- 11.5:1 on 93 octane?
- CAT cranks not SCAT
- exhaust
- accel adj fuel regulator
- 383 and stock throttle body
- hypertech pp3 need help with shift points
- 1.5 to 1.6 rockers
- just got back from the track
- opti
- clips on stock injectors
- speedo recallibration
- Throttle body sizing
- what cam????
- Hooker LT header install on an LT1/EGR block off paltes
- What to do while K-member is out?
- Should I do a relash on a 130k engine??
- rocker arm studs
- Shifter
- anybody interested in a GMMG?
- Installing Intake, have part left over, help ASAP
- LT1 to Bellhousing ?
- shop says i might have messed up my car!!! please help!!
- help lost drive + overdrive
- What can be causing this???
- hypertech power programer. anyone used one b4?
- What will i Run tomorrow
- Need Help ASAP with Head install
- Need Help Fast! (Shoebox)?
- Head gaskets
- Desensitizing Knock Sensor?
- Huge power difference between open loop and closed loop?
- M6 question
- opinions on 1/4 ets
- lt1 intake only good to 6000rpm
- Airbag Question
- Weird problem on 95Z, ignition switch?? Help plz
- MAF Translator
- need help in replacing ac hard line
- Do those main/rod bearings fit to LT1 engine?
- Lubricating bushings, will it help the weird sound I get when going over bumps?
- How do I know if I have a MISS???
- What kind of clutch is this? (Twin Disc)
- 93-94 and 95-97 Difference in Starters? Its showing 2 Diff Numbers
- what size (thread pitch & diameter) for AIR plugs?
- Help! car won't shif into park
- Do headers and a cam justify a 52mm TB?
- 94-97 opti-gurus
- Need some help guys (Temperature Gauge)
- Voltage boost for fuel pump?
- high mileage LT1
- Driver side window moving around
- How do you remove injectors
- High flow cat--flanged or not flanged
- how much hp estimated?
- high miss w/ cutout open!
- I can use stock rods/ pistons with a 383 crank right?
- can't get the car to cool off
- Ram Air or CAI?? Whats Better?
- Hot cam in 94 with newer opti ?
- how do you know if you have bad motor mounts? and how to install new ones?
- Can the Street Twin be rebuilt?
- *PICS* Undercoating car with Por-15
- Help me understand my O2 readings and BLM's
- How do I get the Windshield Wipers off the arms?
- need help with fuel pump install
- Horsepower
- Possible transmission problem
- Is there adjustment that can be made in the rack?
- suspension build-up
- will paint hold to rusting ceramic-coated headers?
- Tire Size?
- 383 rotating assemblies
- Exhaust Option?
- Timing chain questions
- URGENT!!! Stuck while pulling tranny from bellhousing, NEED HELP!
- Need to decide on 4.10!!
- Will a 98+ dash pad fit a 95 T/A?
- Torque Specs for bolts????
- 4L60/700R4 Operating Temps?
- Best guide for replacing opti?
- exhaust manifold leak, whats more common?
- Is something wrong with my tranny?
- 2 questions Brakes and muffler
- Clutch pedal softer now
- Could my A4 be starting to go?
- cc 306 and 1'6 rooler rockers
- Stupid vortech elbow question.
- When the A/C is ON, the car heats up a bit
- AC compressor differences?
- first opti install tonight any tips
- What are 30# SVO injectors?
- Cleaning T/B, need new gasket??
- Anybody use these wires?
- new lt1 crate 383 in summit?
- Who has the best prices on McCleod Street Twins?
- BMR K-member question
- Questions about some parts
- Odd location for a Coolant Leak
- Head Gasket Question
- O2 simulator?
- Fuel Line replacement
- complete LT1 rebuild
- Rear end experts, need suggestions really badly!
- Pulling T56 from T/A tomorrow, everyone give their 2 cents!!
- Racenet Intake Manifold
- Will a 95 tranny work with a 97 engine?
- 3.73s and stall....How much can I expect it to knock off my 1/8th et?
- '93 Guys with hypertech chip...take that POS out
- @WOT - Do O2 Sensors come into play ?
- converter size
- Screw the Lt1 or not?
- custom cai?
- just out of curiosity
- #2 Carrier Motives??
- clunk
- Need part number for oil level sensor..
- glaze on windshield
