View Full Version : LT1 Based Engine Tech
- 1 wheel peel cause? Low gear oil possibly?
- anyone with 3.73's on the stock 10 bolt?
- Changing radiator, green coolant? Few questions.
- anyone think this would be too loud?
- Lazy start after 50# msd injector install
- 1995 Z28 Coil and Coil Wire...
- has any one used lock washers with stock header bolts?
- What's up with ultimatefbody.com?? Anyone else having problems??
- Head removal, please help
- I found some killer heads for my street combo....a little pricey though...
- 1.5 or 1.6 rr with xe 230/236 cam?
- has anyone attempted to have their steel d/s balanced?
- how are LT1's??
- Cc-305 Cam
- Could MSD box be causing problems?
- 4 " Glasstek Cowl hood????
- Tranny clean, now what? ***PICS***
- Hooker v.s. magnaflow
- need advice on true duel set up
- center console question
- Horsepower numbers low?
- Should I get a Scanmaster?
- Will exhaust leak cause me to fail emissions?
- LT1 Long Tube Headers
- What connector is this??
- Question about clutch install...
- I may have ruined my heads porting them, HELP!
- Bad motor mounts?
- ABS and TCS should not be on a M6
- How many plates behind the door striker plate?
- any moderators
- What are these hoses?
- Pice of crap tranney part 2
- msd question
- OK, just got $3,500...
- Need help fast!! custom length wires!!!
- Torque Arm question
- I think I have a spring problem
- tb bypass
- anyone want to trade wheels?
- Finally got to race a LS1 ram air TA
- How many HP after those upgrates?
- cam/RR vs N2O
- 1/4 mile times / dyno #s
- Jet-Hot coat y-pipe or not?
- Real bad stumbling, rough idle, Please Help
- Old gasket baked on to rearend diff. cover. What will get it off?
- Cat Question
- fpr setting
- another tranny problem
- why is obd1 better?
- Gears: Series 2 or 3 Carrier
- Is my tranny bad?
- Suspension
- Easy Rebuild Question...Shoebox?
- 96 z28 tranny
- Spinnin' My Tires
- why is 95 opti better
- Polished factory rims....
- tranny
- Radio stays on all the time?
- HELP!! Runs bad when warm
- fuel pressure at 35 psi??????? i need help
- Problem with Holley TB's?
- Volt gauge on dash....
- Found oil leak....
- If im selling my car, is it worth it to take my Hooker LT's off?
- Quick Mac header and offroad pipe install question
- Intsalling Impy head gasket...which side is up?
- High Idle/Rough Idle & High Oil Pressure
- Passenger's Side Air Bar Removal Assistance
- Removing AIR pump
- corvette heads?????
- Weight loss going to headers?? what is weight of stock catback to aftermarkets??
- Flowmaster sound problems
- What spark plugs do you use when running n20?
- LT4 Conversion
- Okay, so I broke my timing chain....
- jet hot headers for LT1s..in here
- best tire pressure?
- Holley Stealth ram manifold
- Gears whining after Diff fluid change.
- warped heads
- Injectors
- a few questions about headers
- Using teflon tape on spark plug???
- Weird Clunk!!! Clutch? Tranny? Rearend? Help!!
- ohm's of my injectors?
- question about part numbers
- List for cam install
- Whats the extra cam lobe for?
- Carb'd LT1
- question about the fan
- is my ps pump saying bye?(did search already)
- Car running rough. Any ideas?
- Whats the stock rev limiter?
- Hit a curb w/rear wheel Brakes rubbing and axle messed up? HELP!
- Can I switch my shift knob with a Trans Am one?
- The good and bad of Torco torque converters for a 93 4L60??
- reinstalling PCM?
- This is the right Part # Correct?
- Need suggestion
- Roller rocker ratio selection as it realates to a single pattern cam..HELP
- ? for those running LT4 hot cam on stock heads??
- HELP....cant get plug in all the way???
- 1996 trans am inconsistant performance
- Lowering the Z
- Guys With SLP LM Considering A Muffler- Here's What I Did....
- pcmforless question
- Should i use a High volume oil pump or not?
- Where can I get a driveshaft for cheap
- Turn Signal Problem
- refinishing stock T/A wheels?
- Will Replacing Wiper Motor Fix...
- 1rst gear
- anyone with a 93-97 T-56 step in..
- Lt4 question??
- Msd 6al
- ? About the WS9 RPO code
- HVAC removal: a HowTo
- Need help ASAP
- Brake line questions
- After markett PCM`s and scan tools
- cc305 vs xe230/236
- Found my leak.....Doesnt look good
- Attention shoebox, or anybody that knows wiring
- Where to get EGR block off plates?
- are shorties worth it (temporarily)?
- ECT or knock or injectors? Where did pcm4less set your fans on point at?
- Cam dowel pin length on replacement cams
- BOSE CD Player question, is this where it goes?
- Anything I can do to save my tranny?
- Is it safe to pressure wash a tranny?
- Anybody with 4.10s on 10 bolt
- I'm Tired Of My Brake Problem, Someone Help Me!
- OPINIONS needed - LT1 headers MAC or HOOKER
- Still looking for noise
- Clutch Problem- stuck in neutral! HELP!!
- Handling
- New LT1 Power Packages available!
- Taylor OVC setup can really test a persons patience.
- Help, courtesy fuse keeps blowing
- Finally got word back on my broken tranny
- MAC question
- Hedders-Fac. warranty
- Slight idle problem after Hot Cam install.
- A/C line burst...
- Need help with Torque Arm bushing....PLEASE!
- 12 Bolt or 9 Inch??
- part # for lt4 km
- lt4hotcam or cc305
- 12 bolt question
- cheapest optispark?
- Drive light conversion on a 94
- where to find automatic headlight conversion
- highest flowing air intake...
- Why do Bosch O2 sensors suck?
- Anyone in MA run Long Tubes and pass emssions ?
- SES code????
- 11.84:1 Safe on 91??
- Yet again another optispark problem maybe?
- 3rd gen strange 12 bolt in 4th gen?
- Torque spec for oil filter adapter...
- fogs ok but not headlights in auto mode
- Anyone make an aluminum Block LT1/LT4?
- tunning after cam instal?
- MAC headers, 95 Z28, AIR & 02 problems
- black smoke?
- please help me decide!!!!!!!!!!
- i did it now
- Thinking of changing cam..110LSA?
- Where do I get a AC delete pullie??
- MODS i need your help
- looking for a write up for removing the engine
- Dip stick tube broke off
- Blown Head Gasket Cause Top End Noise???
- anyone burn plugs wires running uncoated LTs?
- How can you tell if your car is running lean?
- cam question( Crane 210/224)
- moser 12 bolt now grinding over bumps??
- mounting unbolted exhaust
- Removing injectors from fuel rail
- Solved the opti-spark conspiracy
- Emergency...cmon Guys I Need Help Like Yesterday!!!!!
- Finding exhaust leak.....Midas????
- Help w/ Removing PS Pump
- help me with my tranny pleaseeeeeeeeeeeee
- Firewall seal
- Wiper Motor gone bad?
- $5000 to spend- mods or upgrade?
- HELP! Need Reply Fast
- What the He!! is the problem?
- Recommendations?
- 4.10 gears
- How do yoy remove the air pump with out throwind codes?
- Compression ratio and 91 octane fuel
- Is there any advantage of blocking the egr?
- Huge Problem....please Look....fan Trouble
- Mysterious oil leaking problem
- 1995 Camaro Z28 Maintanence HELP
- Evaporative Emission Control System Malfunction
- Best Clutch package on the Market
- Removing ASR and keeping ABS... did a search, no info
- extending o2 sensors
- Squealing brake... what are brake shims?
- What size bolts for tranny brace?
- 2.73 to 3.73?
- adj. FPR with xe cams
- installing headers soon, any tips?
- manual cutout
- headers
- Car broke down 200 miles away, need wheel base measurements
- Would this be my pulleys making noise?
- Tire Opinions / Advice
- Goin for the dynomouth... what size bullet muffler do I need?
- Did you say yes or no the the power tuning on your hpp3?
- Which rockers to adjust when?
- Ignition won't turn over????
- Opinions on Collector Inserts
- 115 speedo??
- Best Heads
- obd check
- SLP Loudmouth vs Hooker Cat Back
- Is my tranny going bad?
- Thunder Racing Complete Gear Package??
- fuel pressure?
- Only when its hot
- How hard to R&R Slave Cylinder/MC
- G2 sway bars...Worth it?
- Can I use a Autometer Oil Pressure guage and keep my stock gague too.
- All guys with Headers....
- abs inop, no idea???
- Does anybody have a pic. of the speed sensor rotor installed in a TH400?
- Fixing to order exhaust
- 4.10 question...please help
- Will 4th Gen PHR fit 3rd Gen?
- Please!! help with oil leak..Im at my wits end.
- engine coolant light goes on and off!
- Where to get rebuild kit for Eaton Posi?
- SES light on. Code 32- EGR recirculation?
- 58mm TB or not?
- Engine Sensor Fuse Keeps Blowing???
- Ram clutch info/ Novel inside
- Vaccuum Line Problem? (Please Help)
- Long tubes vs Mid lenths
- Power steering problems
- TB bypass- barbed connector from Pep Boys?
- What size AN hose for fuel pressure guage?
- Installing a Tach
- T-56 output shaft bushing
