View Full Version : LT1 Based Engine Tech
- Seals sweating.. Problems to come??
- Ticking sound? What is it?
- need help
- Hotcam 1/4 Mile times - Stock Motor
- Would a Local Auto Parts store have exhaust manifold bolts?
- ?? Adjustable Lower Control Arms ??
- Need Clutch Advice (did a search)...
- optispark question
- need help troubleshooting A/C clutch compressor hook up
- i want to run 11s
- headers and stock y-pipe quesiton
- Changing Auto into Stick
- It's almost alive.. questions inside
- Big Problems with McLeod S/T, NEED EXPERTS!
- Wiring diagrams
- just killed 2 opti's in less than 150 miles (long, but please help)
- best way to screw up a TC
- pressure problems
- Roll Bar
- roller rockers
- 1:6 Roller Tip Steel Rockers
- did some 180's now steering is stiff..?
- Newbie needs more info...
- Cam in a 93 ??
- looking for an lt1 edit guru
- Questions about Competition Motorsports!
- ignition problem?
- those with 320-340rwhp inside. Post your times...
- i need a a muffler for my wide open exhaust cause i think i lost power which one?
- need part #
- headers
- attn: everyone who has weld prostar 15x8 rims please help what is the right backspace
- Torque on thermostat bolts?
- LT1 Tuners??
- Need help ASAP alternator related
- Lose Tranny Mount?
- Help with pics please!!!
- What the bad part about having 3.73s
- stall, cam, fluctuating rpms?
- Stroker noise and RPM questions
- Banks Power Systems exhaust
- how much can elevation hurt ETs?
- Ignition problem? Help...
- got engine codes
- Troubleshooting Fans and Starting problems Guide
- clutch question?
- Best Cam for my setup?
- Removable tube on Hooker LTs?
- Can someone prove to me that longtube headers are better than shortys??
- Fuel Ran Low...Gonna have fuel pump problems?
- FTFORCE.com a.k.a. - Racenetone.com sucks!! (LONG RANT)
- need something...
- VP and car getting lean
- Gains from 1.6 rr and headers
- Where can I get Mac-True fit headers?
- Pushrod questions
- my electric fans run all the time on LOW...
- caprice MAF same as Camaro?
- Getting after market SLAVE CYLINDER
- Can someone put me on a weight loss plan??
- xe 218/224
- Differential Cover
- What are my stock rear gears?
- LS1 brake upgrade...where can I get one?
- How do I check the pinion angle?
- Which 58mm throttle body
- where to buy manual fan switch?
- Why dont I get a 3d face instead of these ;)
- Your opinion on the XE 224/230 cam
- $399 Headers
- Is XE 224/230 good for daily driving?
- o2 sensor replacement
- Best Spark Plugs/Plug Wires
- as&m or slp headers
- Spark Plug & Wire Installation Help
- Whats the Best Muffler to use if you don't have cats that will sound good!
- ET streets vs ET drags
- How hard to install tranny (auto)
- trans am front end conversion
- Replace just belt tensioner pulley or the whole tensioner?
- Changing oil pan
- why are my blocklearns 115?
- 96 Convertible to 98 conversion.
- MSD Ignition Control
- LT-4 Knock Module
- Umm.. WTF whats the world comming too?
- My diff is noisy after 4.11 install
- ET Streets for 16" rim, any tired them?
- cost for cam swap gaskets
- ZZ-9 idle clip?
- My Hotcam Dyno #'s
- FLP Long Tubes
- Tuning- When?
- broke engine? bad gears? broken tranny?
- Ported and polished MAF ends, will they help?
- Where to get cage for a convertible?
- LS6 in 1994 camaro?
- They old what should i run thread
- pro 5.0 and stock shift knob ?
- Use AIR as vacuum pump?
- SLP CAI filter question
- Where to buy Torx driver for hatch struts?
- Fuel Rail Covers
- Got this in a good deal
- Quick header install/EGR question
- rev limiter?
- car shoots blue flame
- Wet outside...car misses badly..opti?
- First races with new set up..do these times suck??
- odd noise when i shut off my car...
- High Temp after Cam install
- Best place to get GOOD tie rods and ball joints?
- OBD-2 TRICOM help fast......
- Those with rollbars/cages within!
- Trans, please help
- OPTI question attn Engineer & Shoebox
- Did Pep Boys Screw Me?
- Does anyone know?
- how can i tell if it's a PM rod
- buying lt4 conversion kit but want more power
- what are "baskets"? relating to brakes
- Whats this I hear about OBDII not being able to use a Double Roller???
- Trip odometer
- 1/4 mile times with 3.73's
- What valve springs are you running with your high lift cams?
- Watching out for dead outta the box optisparks
- Next mod, and which brand
- '97 SS info. needed
- clicking noise
- Will 20X10.5 rims fit on the rear of my car?
- POPING Noise coming from Pass. side!!
- What should my next mod be?
- scanned codes. got code 32 egr system fault.
- Anyone have a how to guide on pulling the motor out the bottom?
- Panhard rod
- plugs and plug wires
- hooker catback with catco cat size question
- What year heads will work on my 93?
- Anyone ever have their air compressor go?
- Can custom cam make 450+rwhp w.AFR heads
- Y-Pipe Question
- changing shifter
- McLeod clutch help !
- Hesitation under acceleration
- 19 Degrees Of Knock Retard
- Rims Wont Fit!!!
- Camshaft Install$$$$
- Should I increase my stall with my set up?
- What’s that metal piece that bolts between the two frame rails?
- header bolts on lt1
- Cmotorsports Heads, Questions
- summer is back, car runs hot again
- oh yeah...she's grumbling now :)
- Anybody have this cold air kit?
- Shifter bounces and moves when shifted hard
- Skip Shift Eliminator: Where is white connector?
- How should I work this? (Upgrade path advice..)
- can't get motor to come loose!
- dual exhaust with long bullet mufflers?
- New to 4th gens, a little help please
- To all with jet hot headers
- Ford 9"
- Accel 300+ wires?
- Ignition Problem PLEASE HELP!!!!!
- Ring and Pinion - How long to break in?
- Download 93-97 Firebird / Transam parts manual
- How To Make An ADJ Fuel Pressure Regulator
- loose header bolts, any ideas?
- Where?
- How are Probe pistons? (Come with the SCAT kit)...
- Tierod question threads/degree
- Stock Wheel Offset/Backspacing
- dead tranny? broken engine??
- Anyone make a guage/switch panel that goes over the tape holder
- What's the difference between mini starters and normal starters?
- bump-stop modification with 17x11s
- Where can I buy HI-6trc wiring harness??
- Any thoughts on why my oil pressure is reading higher?
- Installing Stall Converter
- My inner door panel is broke. Who has fixed this>??
- About to buy BBk Headers
- TEA Heads
- Largest Intake Gasket
- what to gap plugs on and off nitrous??
- suspect air in cooling system
- I found my clatter!!!!!!!!
- Where did you guys get your Walbro pump?
- Electronic vs. Thermal Flasher?
- Lifters? Self aligning or not?
- LT1 Valve Lash Question
- mufflex y-pipe for hooker longtubes
- Electric Water Pump woes
- Engine Wont Rev Help!
- New Best STREET TIRE MPH and E.T. - Videos
- When hooking up a boost gauge, what sensor does it read from?
- (Video INSIDE)
- lt1 bin file
- Moroso solid motor mounts: HELP!
- Custom CAI Pics (Finally)
- Anyone with Ed Wright Stage 2 Fastchip on 1993 LT1?
- Cutout Louder Then LM?
- ft-lbs on diff cover?
- Silly Question: Jet Hot Longtubes built by Jet Hot?
- speed governor
- Hook me up with some help here
- Where to run OVC wires
- th350 install- SES light on
- Computer Tuning help!!
- If you don't know what 02 sims do,you might be
- thumbs up for pcmforless!!!
- Fuel rail covers
- F.a.s.t.
- what headers should I go with... 383...
- porportioning valve leaks at the back side of it...
- Swapping from 4l60e to Turbo 350?
- Run a colder plug with an agressive heads/cam car...??
- How can i pick up .2 ?
- A.c.&p/s Delete???
- FLP LT Guys. What bolts?
- Opinions on madz28.com needed....
- Installing BBK headers tommorow
- what to do with $800?
- Some Q's on some things.
- Taking Heads off. Need Help Please.
- Drag racing.
- Hooker LT dyno sheets..
- Batttery in trunk not working! HELP!
- No Intake Leak=Very Special???
- sad sad sad
- Which heads
- Weird noise after new shocks/springs
- Heating problem....
- Header bolts...
- ABS Exciter Ring, Press Fitted?
- question about hpp III
- Anyone know the name or part number of those headlight gears?
- PCM?- ODB2-ODB1 conversion Which pins are 21&22?
- 94 Z28 Dilema. Please Read
- Speedautomotive
- bypass TB just for summer?
- How accurate is the stock oil pressure gauge?
- edelbrock lt1 heads
- Opti Spark & wire ?
- 97 mac headers-94 car
- SS hood scoop
- Weird oil leak. Why?
- rear-end fluid
- Anyone wanna look at my autotap log?
- Summit rebuild kit
- what size tires?
