View Full Version : LT1 Based Engine Tech
- need a balencer!!!! this any good
- Which fuse is this?? (Picture)
- Help with dyno graph.....
- A question about Nittos..
- Newbie to LT1s...
- Under the Hood?
- ****! What is wrong with this damn car? Starting problems....
- Taylor Opti-Spark end terminal kit?
- Freescan & Schrader Valve Size
- Running Rich pics..
- How much does it cost to port & polish stock LT1 heads?
- Back from the strip w/ new headers
- Header decision - what do you guys think?
- engine dress up
- What Do LT1,LS1 & LT4 Heads Flow??
- Engine Missing
- 93 M6 Hypertech Chip Owners Inside
- Dead battery and Security light
- Doh!
- How Hard Is It To Replace Starter Motor????
- wheel hop?
- Knocking sounds in my back end Help!!
- Fuel Injectors arent firing
- lower front control am install?help
- Piston Rings?
- Rear brake shim install?
- If this is the oil pressure sending unit, then what is this?
- Thread sealent for Head Bolts?
- 02 bung/ oil pan leak
- THUMP THUMP THUMP under HARD accel..
- quick fuse question...
- Rear End ?????
- Jordon or anyone; part # for K-D LT1 hub installer
- High beams in low beam place
- Slick 50 and other oil additives ?
- Mac exhaust tick tick tick???
- Granatelli torque arm a good idea?
- fuel pump access door install in a conv??
- Heed help :) How to recognize is 1.6RR are to tight?
- oil pressure?
- Macs to Stock manifold swap
- whats the lowest price on 18" tires
- 99ss shifter
- pcv was unplugged
- pro comp r lifters
- A.I.R. Recall, WTF
- Can you Rebuilt a water pump?
- is there a way to verify a lifter is ticking?
- calling everyone with CRANE HI6-STR and TRC2 box
- LT4 KM Ques.
- O2 Sensor
- Does it mater where the sprockets are?
- Last minute prep for the track, help me out please!
- Any difference between 98' LS1 and 99' up LS1's
- Mobil 1 ATF
- LT1's problems
- Idiots guide to belt and spark plugs
- Help!! Car refuses to pass emissions
- I already tried this on the Nitrous forum, anyone?
- how to get speedo to work with th350???
- What's wrong with my car? Is my torque converter broken and hurting my power?
- reluctor ring/gear install question
- Roller Rockers and .600+ Lift?
- emissions/headers question
- Would low voltage alternator cause low fuel pressure?
- need to know differences between 94 rear and 97 rear
- Wheel Bearings Accessible?
- i need tires!!what should i get??
- Impala Head Gasket Question.
- Pushrod Lengh Question
- OK, got allottttta questions... please oblige me the best you can..
- Vortech elbow and air foil really smoothed out my engine
- SES light, egr valve question
- New Pro-Magnum rockers sound like a sewing machine?
- What should i do with my lt1.... heads and cam?
- Costs of DYNOS
- rim size confusion
- billet short stick noise solution
- doing opti plugs and wires this weekend anything else?
- Dyno result -
- LT1 edit question
- Is anyone using the Edelbrock torque arm?
- True Dual X-pipe question
- Valve Lash Problem See Inside PLEASE!
- Problem Code # 101
- Never Assume!! & Always go to basics!!
- Injectors
- Can you remove the Intake Silencer?
- Strange Electrical Problem...please help!!
- Hooker LTs
- 2800 Stall
- Eibach Drag Launch kit and now my rear is twisted.
- When I hit the brake gauges go wacko
- using alcohol to clean injectors!!
- Put on my hooker...
- CC 306 Running real rich....
- help, can somebody explain the PCV system to me?
- Dual cat SLP headers vs single cat SLP headers?
- a4 w/ Cutout and CAI Times/dyno results
- Car Wont Start!
- Best cam for carbed LT1
- Gauges
- lt4 knock module
- slp manual fan switch
- vented opti
- Re-upholstering seats.....
- Rebuilding a T56...I need help!!!!
- RAM heavy-duty clutch/PP, Part#88516
- Paging Shoebox(Trans Pan question)
- adjusting brakes after rotor/pad replacement
- Anybody have a spark plug that leaks and keeps coming loose after you tighten it???
- GOt some heads flowed, what do you think?
- What is this Part?
- Anyone running LT headers that have lowered their car?
- Can't pull error codes from connection under dash!!
- Hooker LT's on a Single Cat - I need a Y Pipe
- GM parts direct part no. please
- Which 1 of the TC do you suggest?
- New fuel pump causes tons of new problems
- I wanna take out my ac stuff, any advise??
- vented vs not
- gear Change
- Did anyone port there stock heads?
- weird problem when the z warms up...
- Is the HPPIII worth $250.
- New Rear ?'s
- Aftermarket Mass Airflow Sensor
- lt1 head gasket
- anyone who has fabricated a CAI...come in
- Will I be able to use S/A rockers with Crane 10308 springs?
- Anyone use conventional oil in their high mileage lt1?
- stutter on take off...???
- Fuel Filter/Opti?? Need Help!!
- Cutouts?
- Whats the price Jason Kromer sells the optis for ? I need help fast
- head experts, need help
- no oil pressure
- URGET...should I get heads or heaers?
- Engine turns over but will not start
- Clutch Questions
- Push rod
- Tech question about VATS
- Which mod
- First mods
- A/C delete Vac lines question
- RS Style Ground Effects.
- MAC or HOOKER
- OBD 2 in a 95 Z?
- where to get a CSI or meziere WP??
- 15X8 wheels
- Too late for heavier Mods ????
- Must... lure.... shoebox....
- McCleod clutch issues......
- What else is done to A4 to shift harder
- oil leak????
- Help!!! Big Piece Broken Off In Engine!!
- Will I see any gains going to AS&M from BBK
- symptoms of a loose MAP?
- Are NGK tr55 G-Power plugs any good
- Does the Taylor OVC wire set from thunder come with.....?
- Something is not right with this picture??? Shoebox??
- Leak between the...
- Stroker guys. Please post your timing tables.
- my POS is driving me insane! pt.2
- Hawk Racing Cranks
- Tuning
- quick cai question
- How many did the vent mod on their 93/94 style opti?
- Where to find GOOD TA seats?
- How to keep my motor/tranny alive for a loooong time?
- Think I missed a gear on spray, how can I check for any damage?
- Posi question??
- headers and y connect to stock cat
- NEED HELP...need ypipe and muffler install
- no more z
- PLug for O2 sensors?
- how much for header install
- I need help fast with my mom's car, thanks guys/gals
- What #s should I spect from "Combination Motorspots" heads
- Magnaflow goes ....
- Part # for Grand Sport Throttle Body?
- Best ignition for Nitrous or boost
- what the hell keeps happening to MY posts!
- problems with my inline fuel pump
- Is there a write up on pulling the 4l60E??
- How much is this Firehawk worth?
- Hot Car = Drives like crap (loss of power)
- Lifters for hotcam.
- MSG Ignition
- 2 questions for those that lowered theri cars......
- I Hate This Street Twin Clutch!!!!
- White smoke?
- Questions? Clutch, Ignition, Fuel
- A4 Tranny
- good muffler for LT's
- intake manifold gaskets
- People with the CC305
- Is it necessary to have a new flywheel and pressure plate balanced before install?
- Code 1642????
- 160 thermostat
- Best way to do exhaust
- LT1 1/4 times
- Quick question
- Fixing the manifold leak, question before i start
- Traction Mods & Stock LT1
- 383 questions
- Ghetto True Duals
- Kenny Brown SFCs & ASM Headers?
- starting issue-mechanic gave odd answer
- 3000 stall lockup conv
- Please Help!!! Whats causing my misfire??
- What To Do Next?
- Will a 93 bbk 52mm tb fit a 94
- RAM AIR or COLD AIR?
- Need help picking out a nitrous kit
- Best Heads for Hotcam
- Where to find gm part numbers
- Can't find some RPO codes
- $500 more to spend, but what mod next?
- 383 stroker rear end
- lighter, defrost, electrical probs. can they be related?
- Where can I get a new or used lt1 block
- Heads are off. Have a cleaning ?
- Magnaflow catback is SWEET!!!!
- overheat, AGAIN!!
- Slight humming/noise while driving in gear...
- What are BLM's and IAC?
- AFR 220's on a n/a 396?
- hardtop
- ARP Bolt/stud for main caps?
- Reprogrammed Chip?
- Raced a ?
- Fans coming on as soon as engine starts?
- HELP?????!!!!!!longtube install question
- Electric WP quetsions
- Tell me about LT1 Edit
- Help me decide, please!
- Water leaking into back seat HELP!!!
- 93 Z28 Mac headers install question (EGR related)
- Freescan
- Car suddenly won't start
- Pulling the tires?
- Head Gasket change
- my ecm gone?
- 93z28 vs 94z28?
- What is this hose that the altenator wore through? Hi pressure air escaping
- Startup Problems? Opti? HELP!
- ZR-1 engine in a camaro
- Guys, I REALLY need some help. I am out of ideas
- Replaced timing cover seals and gasket, now have oil leak. Help!
