View Full Version : LT1 Based Engine Tech
- first camaro
- ALDL Cable?
- HELP!!! Car wont start...
- vibration at speeds 90 and above
- Anyone running HAL shocks in here please!
- heads up display
- Gearing Question
- Jet Hot LT Guys
- Replacing 93-97 Firebird popup headlights with flush mount headlights
- Stalling in drive WTF
- how the hell do you get teh driveshaft off?
- Cam surge and random misfire code
- Broken Rocker Arms
- What is the best way to clean intake/exhaust valves?
- SUSPENSION Questions??????
- What should i get?
- Noise from rear
- Is this okay to use in my differential?
- Question about oil filter for 97 SS
- What Parts for a clutch?
- getting the cc306 need advice
- Water pump HAAALLLLPPPP!!!
- Lt1 Rebuild
- Tire size question
- Sodium Filled Exhaust Valves
- Fog Light
- BAD.....6th gear vibration
- LS1 catback on '96 LT1
- Ah Crap..........
- Heads/Cam Gaskets
- Ratchet Shifter for 4L60E?
- broken exhaust manifolds stud
- Resetting is back, different now but back
- Lights in steering wheel not working: any ideas?
- Leaky T-Tops
- Questions for a LT1 newbie
- exhaust popping while cold
- Headers ON!
- Can fuel lines be disconnected?
- Tranny on ebay?.... safe?
- t56 tranny swap questions
- Water Pump Driveshaft Removal???
- Dude with EGR block of plates!!
- Header and Y-Pipe questions
- Part number for.....
- i have knock....need help with source
- How do these LCAs look? Good price?
- What would cause these ignition problems?
- How off would my MPH be???
- Where are the front o2s on a 96 LT1?
- spec stage 3 with stock flywheel?
- Jet Hots are ready to go on, Y pipe?
- Problem with stock brakes..Help
- Payam
- Need opinions on Idle problem.....
- Line lock sticks in rain
- Convertible owners, anyone had their top replaced?
- What can you guys tell me about these valve springs?
- would i hook up?
- timing chain conversion
- Loud noise...help me please.
- A/C DELETE? Can you on LT1
- RearEnd
- Stock exhaust tip question
- resevoir?
- Speedo-cable ?
- windage tray
- Is it oil in my trottle body?
- ls1 maf
- oil pump pressure questions
- Throttle Position Voltage Question
- How to remove !air?
- Bailey Engineering LTCC setup
- underbody ram air
- Damn, this rebuild is going to KILL me! I'm over $1000 budget already...
- easy question...
- Whats that smell?
- Which Plug Wires Will Fit Stock Looms?
- low coolant light on, but its full
- Car bon in exhust
- Vig vs. Yank the battle of the converters
- What improvement should I expect?
- Need Anything Else to Install 3.73's?
- help me get my hydrocarbons down!
- what times should i be posting
- A/C Compressor price
- thinking of getting 3.73's
- 2:73 without posi?
- GM 845, Crane 2033, GM ZZ3
- What's your experience with CSI electric water pumps?
- GM 846 cam question>>
- question about cai?
- throwing a code (sensor related), help please...
- Switching Opti question....
- Running too HOT!! - Newbie needs advice
- Make up my mind!!! (headers)
- rubbing sound from rear end?
- changing 02 sensors
- Common causes of speaker intefernce... MSD???
- Transmission
- Parts list for a NSA 1.6 install. (Besides the obvious)
- i ordered my t56 kit
- Problem found... need advice..
- Oil Cooler Removal
- ?? Timing gears
- Acceptable fuel psi bleeddown?
- Coolant sensor!
- coolant ?
- Do the LT1's hold 5 quarts of oil?
- head qasket
- Need help passing emissions!!!
- Solid lifters w/1.7 RR?
- Need help on buying headgaskets. GM part #?
- rwhp gain with longtubes?
- DEXRON-III MERCON or DEXRON-III ATF
- ARP header bolts?
- parking lights....
- Finding that Exhaust Leak
- Found the Problem!
- Borla band clamps
- Guess what, another mysterious coolant question!
- Cutout = Burnt Valves?!?!
- Plug Wire Opinions
- Done a search, need 1LE tranny mount Part #
- Detonation prob solved !
- Drivetrain problems
- What Drive Shaft??
- WOT miss?
- What procedure did you use for your headers? I've searced the archives
- Problems with Pro 5.0 shifter.
- Well, found out why my car wouldn't start....
- 94 LT1 exhaust manifold leak
- Moser Fluids
- Need help with datamaster file...Look inside
- Fuel System and Engine Management for low 10's n/a
- BIG cubed LT1 + solid roller cam = Knock sensor go crazy?
- Gas Mileage...
- URGENT:Need U-joint P/N for Lingenfelter drive shaft.
- what causes the engine to run rich?
- Recommend a converter for a 383
- Just got car back from Speed Inc.....
- Translator for n/a and nitrous applications
- Combination Motorsports is an Awesome company!!!
- Poly mount on Torque arm. How does it feel
- Lingenfelter Adj. FPR's any good?
- anyone heard of a cramaro
- Motor Mounts?
- LT install help, ASAP
- HOTcam people, tell me what you run!
- Electric waterpumps
- Rotating after shutdown
- How to install the hub corretly
- Spohn TA mount, will old ta work with new mount
- Cruise control problem
- O2 questions
- High mileage cam install
- Hot Cam emission
- differences in lt1 blocks?
- Electric Superchargers on Ebay??
- Part #'s for wiper blades and Wheel Speed sensor
- very strange thing happend to my car tonight!
- lt4 intake
- Need a gasket set list
- Different headlight problem
- What LCAs should I buy?
- Can I tune this to pass emissions
- B&M Supercooler Installed
- LT4 Knock Module Needed?
- having problems please help!!
- Does a 2001 rear end fit my car.....please help
- Torque Ft lbs on LT1 Pan bolts?
- Are AS&M headers Legal in Ca.?
- Ram Clutch?
- Help i think my trans just went
- slp Torque Converter
- How can I determine if my MAF is bad or not...
- Exhaust size?
- Are LCAs worth it?
- running the car without a battery?
- LT1 burning oil?
- Having trouble with reverse lockout...
- !egr ?
- Anyone want to help with Clutch install
- Stupid tranny mount install question.
- Dropping the motor out the bottom....
- exhaust question
- 1.6rr, oil cooler and gears=13's
- How to clean EGR, and will it last?
- I know its been covered but 306 or 230/236?
- Flow #'s
- what do you guys think about the Power Stop Rotors?
- making the passenger window auto
- Header Time Check List
- Didn't put gm differential additive am i in trouble?
- LS1 Intermediate pipe
- Stock LT4 flow numbers?
- where is the rear o2 sensor on a 97 z/28 drivers side?
- need auto transport
- Transmission
- Comp Cam XE 224/230 on stock heads!
- how does aftermarket shifter install w/ reverse lockout?
- New top end question
- o2 sensor issues.. HELP!
- Evap system removal
- AS&M headers
- Help me choose the right plug wires
- Missing? Rough Idle...
- Still dont get it...
- clutch\transmission problems
- Question about OVC Kit: Crimping Tool?
- Are there any bad gas stations?
- johnson rods are breaking, should i use the black mambas???
- Will this setup fit?
- what gas?
- what years are the best lt1s ta buy used...
- I think my valaetrain is timebomb!
- Replaced Cap and Rotor No Help
- help with electrical
- Power window motor
- Paging Any Convertable Owners With Sub Fram Connectors Installed
- VERY! wierd prob, smoke from underhood and no start (long)
- Car has a weird wheel hop?
- Camaro>>Corvette accessory swap
- installed rear, now i have a clunk only under certain cinditions, help
- how to replace coolant sensor
- 96 LT4 Corvette M6
- Header question?
- She's missing!!!!
- Anything else?
- Blinker Won't Blink?
- mac headers
- RK Sport FX5 adjustable shocks any good?
- Over camming?
- Header install questions
- Confused about this cam
- FLP headers any good
- Is this a Lifter Tick? *Video Clip available*
- mod's
- Anybody willing to help me do a transmission/engine install in Dallas, TX?
- **Transmission parts on floor, not in car**
- New tranny and same problem...help!
- Where can I find ceramic coated 1-5/8 Hooker LTs?
- EGR intake question
- Platinum plugs with MSD?
- Steering wheel volume/cd lights don't work
- 94-95 intake manifold different from 96-97?
- Hydrolocked Motor - Do I have a leg to stand on?
- Seatbelt light will not go off!!!!
- Went to the track, kinda happy
- I don't speak obd-II,can you translate
