View Full Version : LT1 Based Engine Tech
- vibration in 1st and 6th??
- Airbag removal?
- part # question...
- Knock Sensor Troubleshooting
- best plug wires for LTs
- jimmy 1995 lt1 engine no idle
- Anyone with a Spintech Muffler?
- Comp cams 987 Springs?
- New Eaton posi and 3.42 in today but..
- Why am I running lean after 2800-3k?
- 986 springs on LT-4 heads / standing height?
- Hello all :)
- Got a ?
- Water Pump Seal or Cam Seal???
- quick opti question
- What did I ruin? Starter ran 4 minutes straight!!!
- 9.60 @ 141.52 @ Bowling Green video is up!!!
- Torque Converter Vigilante or Yank
- FINALLY Fixed Front Cover Leak!!!
- Botched up threads about misfiring…[logistical rant]
- Need contact info for Dal or Jason
- help kertong identify this mystery part
- 383, Stock Radiator, Street Driving
- Tailpipes POP and fire is actually coming out!!??
- popping sound in the back
- LT1 hotter when AC is on...
- gains between long and short tube headers??
- Rattle
- Cam and heads pro install question?
- What Do You Guys Think About This Tool???
- Unhooked AIR for LT's, fans won't shut off
- Help! car wont idle
- God hates my car too!
- need help fast, miss or hesitation? bad o2's? how to tell?
- Bolt For A.I.R?
- Reliability of the opti when paired with an MSD box such as the 6AL or Digital 6
- How do you get the little black clips on the brake lines off?
- Throttle body bypass???
- brake pads
- did opti plugs and wires still stutters and surges?
- Need advice on car towing...
- taking out headlight motor
- starting problem
- New style turbo kit
- What to check for when buying LT1 car?
- Car runs like crap after rebuild/hotcam/headers/catback...
- doesn't start - no spark
- OBD-2 progam help please
- wipers won't work sometimes
- SPEC phone#? Does the stage 3 come with pilot bushing?
- How about this for exhaust flow?
- changed differential fluid...problem is still here.
- 3.42 or 3.73 on 383 stroker
- meziere water pump
- Guys Who Have Installed MACS - A few tips for me
- How accurate is it to tune off an EGT?
- Mustang guy inquiring about a WS6....
- Optispark ?
- Just got a catback.... is a cutout worth while?
- Major Problem Need Help (is it a mis??)
- Air Bag light will not go out!
- Max tire size '95 z28?
- Anyway of determining which version EGR valve my car has?
- Intake porting really required?
- MSD Digital 6+ plug for coil????
- fuse question please help
- Tranny Problems
- air/fuel gauge
- Beehive springs on LT1 heads
- Help me out....sway bar install
- 3.73 gears are the way to go you say?
- engine assembly tools
- Tired of ****ed up wires
- 224/236 cam head porting
- After timing cover seal replacement, distributor drive shaft seal leaks oil. Help!
- hotcam and RR ratio
- another tc question
- Injectors
- Anyone know proper procedures for flushing LT1 coolant
- The smartest thing to do when the engine is out??
- Longtube Question???
- stock cat or high flow... NEED OPINIONS
- LT1 Rebuild questions?
- Need Help....
- Different Plugs affecting gas milage?????
- How bad do gears affect gas mileage????
- Does a big block hood serve as cowl hood also?
- Valve float and dyno sheet...
- Trouble Installing 410 Pinion
- transmission problem???
- What suspension components do I need?
- My Z Tuned for Hot Cam but not Heads... What should I expect?
- Moser 12 bolt Yoke question, what series u-joint for standard yoke??
- HP mods that do not affect gas milage and are CHEAP
- GOD hates my car!
- Wiring
- Explain F-body check digit to me (VIN)
- LOUD noise comming from engine.
- cheapest place to buy LTs.
- Torque Converter ??
- NEED HELP:will these 4.10 gears fit??
- Look good to you?
- Help with install of LCA's and panhard bar.
- Is anyone running BF GOODRICH COM F-FORCE TA KDWS TIRES What do you think of them???
- Pushrod guide plates, are they created equal? Pushrods too...
- What ignition Crane/MSD
- Replaced Opti and Water Pump... What a difference indeed.
- Can I use Comp BBC 1.7 ratio rockers...
- Can tranny make speedo go wacky?!?!?
- Price of rockers that come with the LT4 hotcam kit?
- electrical problem somewhere??
- Here's a thinker for you (re: rearend)
- Summer Time is here and Need to keep engine cooler!
- what gears for a head & cam daily driver?
- Where to put cut-out?
- will the cc306 work 4 me
- Thank God For Superior Automotive In Anaheim Ca.
- 94 LT1 fuel injectors into a 93 ??
- SLP Loudmouth vs. Hooker Catback
- Alright, so what kind of engine coolant do you use?
- 10 bolt longevity
- Best suspension upgrade for street use?
- I have tried everything and Nothing Works!! Help with a 93.
- Super Quick Question!!!
- Got my flow numbers from Lloyd
- s
- buying first mod
- Any places sell a Complete top end kit??
- engine light
- free mods QUESTION?
- Removing A/C unit near firewall......
- Videos of the 383 at Idle and Revving...
- LT1 ignition probs
- Free Mods For Lt1
- Show me your engine bay with !AC !EGR etc..
- Will MAC headers fit stock I-Pipe?
- Hooker LTs and duals done
- HELP before I burn my car to the ground. (Long)
- Have a lifter tick, what to do??
- Speedo Recalibration
- Brakes after CC305
- Help Identify these valve springs
- Extreme Duty Timing Set Crucial?
- Brakes Dragging until brake petal hits floor
- new cam =blowen motor
- One wheel peel???
- Hatch speakers ... how are they wired up??
- Heaglight motor wont turn off
- New Maf???
- resevoir question
- Sensor on back of intake manifold??
- where is the brake booster?
- How does spark plug gap effect temperatur of the plug? AFR Heads
- Goin to the track for the first time tonight
- Winshied Fluid Nozzle/Window Motor Problems
- Help oildipstick
- What to do w/ EGR/AIR/sensors w/ Hooker LT's?
- Those with tunercat, what 2 files do I need?
- Why do you 1.6 rockers keep coming loose?
- Flowmaster Muffler Question
- is it safe to take this part off?
- Bocsh O2 extension ?
- mccleoud twin clutch info needed
- Stock weight of 97 T/A
- 3.73 shift points
- where else to mount gauges on a 93-97 camaro !?
- tranny problems - HELP!!!!!!
- Transmission Help Please Help Me
- Abs Inop????
- The waterpump debate, electric or stock.....
- cant decide
- installing 160 stat
- Requirements to swap 4l60e for 700R4...
- just tried out the drs on the street for the 1st time
- strut tower brace
- lt1 swap?
- Ordered CatBack
- should i ditch the 4.10's and go 3.73's???
- I went to the track tonight....
- whats a good scanner, and cheap too.
- Need help ASAP removing steering linkage!
- New here
- What's a 96 WS6 worth???
- 255/50-R16 BFGoodrich Comp T/A Drag Radials ?
- O2 sensors with leaded race gas. Which to use?
- Need the link for the TB bypass!
- Just got gear installed, supposed to whine at first?
- NEWB question on stall converters?
- LT Install Q? Also, anyone good in Eastern PA?
- Looking for Canadian MAC Exhaust distributor
- Header pics
- home made cai pic?
- Broke The Shift Cable
- C5 Wheel Question
- Transmission Dying....
- Leaky Fuel Injector--Now What?
- custom CAI
- 236/242 cam... some insight on what to expect.
- Fusable link wires?
- What kind converter for street tires?
- SA Rockers on 93
- Give The K&n Cai Air!!!!!!!!!!
- Is it the fuel pump? Your opinions please.
- 396 as apposed to a 383? any drawbacks?
- PLEASE HELP LT4 Conversion won't respond
- Help me pick between Flowmaster and Hooker.....
- Cam shopping
- JET fan switch install????????????????
- new clutch problems...
- need advice!
- What gear ratio for street/strip?
- Help!..SES light on when rains
- BIG problem... need your help!
- Intake silencer
- Doing cam swap with engine in, walk me through plz(or link to guide)
- What M6 tranny fluid to use?
- midwest torque converters
- 12 bolt abs question
- PPC Spark Plug Wires?
- Anyone using poly TA mount?
- 160 thermo. question
- header question
- Quench Zone
- What gear oil?
- How Can I find out what size Gears I have in my Rear End Differential?
- Got my programming done by madwolf
- Adjusting Rocker Arms??
- Head and cam install fees
- Torque Arm
- Wiring Question! Please Help!
- Abs Inop!!
- How much did your 355 or 383 cost you?
- Damnit Damnit
- Getting 4.10s installed
- What Size Transmission Cooler?
- need help quik!
- Looking for online store that sells Walbro fuel pumps.
- how to completely flush transmission?
- plug wires over valve covers?
- a/c compressor bypass question
- Gear Install Price Quotes??? How much? NEED HELP
- lt1-rebuild kit? !!
- replaced opti plugs and wires still have a small flutter??
- adjusting Lt1 rockers
- Electric Supercharger
- cheap forged crank?
- Rookie question about removing heads.....
- Water Pump?
- LT1 vs ls1
