View Full Version : LT1 Based Engine Tech
- What should my O2 readins look like?
- Tailshaft bushing on T56, need help ASAP
- scanmaster on a 96, will it work??
- if you have SLP headers..
- What will I run!!!!!!!!!
- Quiet Exhaust
- Anyone make 10mm x 3/8'studs to use LT4 RR on a sbc?
- Sealant on Head Gasket?
- Electrical Issue
- Review: MSD Wires/Looms
- over heating problem
- Turbo in the rear of car??? WTF???
- Please help Finished LT install today noticed MAJOR problem
- lt1 edit work w/ Mac?
- Paging Brent94Z
- War story of my own
- Who's builds STRONG 4L60E's for cheap?
- Is this stroker kit good??
- WTB v6 coil springs?
- Exhaust Cutout
- Tires...what do u have?
- Help me turn off this warning light!!
- CC 306 Cam with Stock Heads?
- Cam for me?
- Steel or Chromoly LCAs?
- Exhaust Suggestions please
- Balance the 383? external or internal?
- what should my times be
- Hooker longtubes over the hooker shorties i have now??
- Those of you with Lou's short stick...
- changing oil pump with motor in car
- Mixing [distilled] water with coolant
- Who has had this problem??????
- Automatic Tranny Problems, changed fluid and now it slips!
- Hesitation gone: replaced fuel pump
- Where to purchase TCI stall?
- Head Games
- Squeeky brakes
- Drag Launch kit and poly bushing ?s
- engine swap tips
- Wiring in a Qtec?
- What Heads go best with a CC305 cam????
- need scatter shield for 6spd lt1
- O.E. Concepts replica wheels?
- Question on LT1 edit
- AC refill
- Anyone with underdrive pulleys on LT1
- Reprogramming the computer
- People with CC 218/224
- whats a good price for mac install?
- I think my 4L60E is taking a dump...any ideas?
- Roller Rockers
- help!!! Whats wrong????
- Can a 4L60E harness be spliced / soldered to work with a T56?
- auto to a 5 speed swap
- Need A Tune Up, Bang/Buck Best etc...?
- Help clutch promblems !!!!!!
- What to do with $1,000???
- How many miles per tank are you getting on your 95-96 Lt1
- cheapest place to get a scanmaster for my 96??
- Tailshaft bushing T56, need help ASAP
- any of the vendors make a guage pod where your cassete tapes would go
- Gas Milage
- Replacing the WP driveshaft?
- low oil presure
- Need part numbers for ARP driveline bolts
- secondary air injection system malfunction
- PPL with a forged 355 inside pls...
- Name that wiring connector!
- Turn on the radiator fans using a switch on an OBD1 car while the car is not on?
- Valve lift question?
- Adapter to hook tubing together for gauges?
- Head Lights
- cam package... gp... good idea???
- well can you imagine that.............stumbling/hesitation FIXED!
- will a 98+ hatch fit a 93-7 t/a?
- 1&2 synchro
- V6 Springs???
- The truth about the motor.
- Mufflex Y-pipe?? Yes? No?
- 1 5/8 or 1 3/4 primaries
- rebuild kit for t56
- Should I run an aftermarket coil with my ignition box and N20?
- Do gears help 1/4mile times?
- wiper arms
- Will a 4L60E from a 94 bolt right up to my..
- Exhaust leak..Please HELP!!
- Need advice on buying a used engine....
- ABS INOP light and charging issues
- Removing T56
- lights flicker??? help
- Sound proofing undercoating. Anyone try it?
- non vented opti question
- LT1 "interchanging" with a 400 small block
- Has anyone bought an engine from Golen's?
- Order of intake bolts
- How do you clean the MAF?
- @!#*)@ lower a-arm bolt won't come off, need help
- Looking for good brake pads
- out of balance rims
- Will any Pontiac Key FOB work?
- Can't get crank pulley/hub off, what am I doing wrong?
- how do you put fuel pump back into tank
- anybody with the gm 847 cam ported heads and stock bottom end with auto inside please
- Which stall?
- White plugs.... possible causes?
- 95 lt1 in a c1500 pickup
- long tubes?
- seat belt light.....
- Dip Stick Leaking, How to fix? Please!
- What do you think i will run?
- Wiper arm removal...help!
- Is my alternator done???
- Anyone with PA tubular A-Arms...
- Getting rid of traction control....
- Single plane intake for LT1...
- Lower control arm bolt sizes, quick question.
- aerochamber vs. 80 series
- New opti seal with new opti?
- Headers aint worth a "darn" (edited by moderator)
- How much pressure should gauge read at fuel rail?
- For those of you with the CC306
- coating on RK Sport headers
- 95 vented opti drawing alot of moisture?
- I know it's been asked, but what parts do I need for a TB bypass on a 97?
- What gaskets are needed to do cam install?
- Magnaflow exhaust pics
- Taller Tires on the Back?
- Hooker or Jet Hot Lt's??
- somebody please, why is my car still missing
- What's the homepage for the company that makes "Strange Gears"?
- Whats wrong with my suspension/rear end
- If you have done a headswap in car, question for you!
- Clutch Chatter driving me crazy. help
- Do you have to get the cpu programmed when doing lt's??
- Pic's of my new headers.
- Installed Hooker Cat Back
- If you have installed headers help me.
- true duals quieter than cutout?!?
- Bad wires? or ?????????
- Ignition woes
- POLL: LT1 - C5 Brake Conversion ...
- suspension
- How long does it take to find out you have a head gasket leak?
- Left turn signal does not blink????
- Stumbling?
- Help...Banging noise coming from rear of car
- ran out of gas now..
- New Z28 owner..have few questions
- 396c.i. LT4 parts list update
- huge..huge.. dilemma
- how to store a motor???
- Rims?
- 94 1LE LT1??
- Don tlike how the cars fron lifts up when you punch it!
- is it time to replace my clutch
- How many MAFs have you blown up???
- Where did you guys mount your tranny cooler?
- is it a big deal using tap water compared to distilled in the radiator??
- whats louder, lt1 or ls1?
- Ignition question?
- Interesting find when changing rear end oil
- Dex-cool or not ?
- Seperating the tranny from the motor questions
- 1993 Corvette LT-1 Help!
- lights on in interior wont go off
- Do the front calipers slide on the guide pins?
- porting MAF?
- is there a way to check for messed up lifters?
- Can I remove these?
- **HELP** Opti just went out - car screwed up, need price list for parts!
- Increased shift firmness bad or good?
- Swapping to LS1 brakes, how to remove steering knuckle?
- Feeling vibration in throttle
- Clunking when I shift into first when not moving?
- How hard is a gear install...
- water plugs
- Intake and stock TB question
- Ported heads
- where to buy an LT1 Rebuild kit ONLINE?
- Any problems with D&D's customer service?
- THATS IT! ive had it........someone come blow up my car
- What roller rockers w/lt4 hotcam
- Where to get stock replacement fog light for 1994 Camaro?k
- CC305 Dyno Numbers
- MAF ends vs. granatelli MAF???
- my car died at the track!!! help please!!
- how to tell if you have an exhaust leak?
- I can't believe my eyes!!
- rear gears stock sizew
- 3000 Rpms @ 65mph w/ cutout n cai
- lt 1 randonly overheating
- Info on removal of Emissions systems....
- Best place to buy the LT4 knock module????
- Mechanix Gloves review!
- What is the difference between a throttle body for a '93 as a '97?
- Maintence on an LT1, everyone inside?
- Dang...pissed...
- Knock Sensor problems
- gear brands question...
- CSI waterpump
- Reliability... (both lightly modded/heavily modded)
- Automatic or Manual?
- Need brake help ASAP
- broke into 13's last night
- Whining new fuel pump? like as loud as some superchargers
- middle hose coming out of charcoal canister?
- need help, those who downloaded parts book
- Best Clutch/short throw shifter
- how to change pass side o2?
- roller rocker ?
- how hot do headers really get?!??!
- Com. Motorsports Email?
- Anyone in NYC area w/ LT1 Edit???
- MADZ28.com
- difference between lt1 ss and z28??
- Easy question----do LT1's and LS1's have 4 bolt main caps?
- Hooker Cat Back installed
- Something Strange
- looking to step up from 306
- Need help fast, pilot bearings which way in?
- Need some gear advice and info needed.
- What do i do with the master/slave cylinder when dropping the t56?
- dyno tuning
- Any table to help diagnose my car?
- after opti change
- oil leak HELP!
- Pictures of installed SLP CAI
- How do I make a front clip?
- Hook up Freescan?
- Tips on installing a Hooker exhaust???
- SLP Cold Air
- Problem??? (adjustijg 1.6rr)
- How do MAC mufflers flow compared to...
- Buying used cam?
- Stuck left turn signal
- Valve cover breather install...
- New "How-to" page for LT1s
- External trans cooler, through the radiator first?
- Replacement Catalytic
- Driveshaft and Rearend ???'s
- Why do a TB bypass?
- Hello All, brand new and have a few questions
- Lifter explosion??
- 4L60e and some tunercat
- Headers Install Question
- Just a few Loudmouth questions...
- squeaking noise at wheels and it's not Brakes
- Anything to look for when buying Lt1?
- how easy to jack up motor for LT install???
