View Full Version : LT1 Based Engine Tech
- Bets place to buy New wires for my headers and the S-Pipe
- Bad brakes after cutting brake line
- Part number for side window theft system sticker?
- 383 Questions...should I or not?
- Everybody with 93Z28's and Longtube headers
- In Need Of A New Engine
- How to on removing/installing driver's airbag?
- Anyone running an X-pipe setup?
- rebuilt tranny, how long to break in?
- MAC header people, what gaskets?
- High Speed Vibrations
- Cam. Is it too big?
- Can I pass emissions with this cam?
- Tighten Throttle Cable
- What need to be done to install intake LT4 intake manifold?
- stock clutch question, kinda advanced.
- Window Problems? Need help
- Help me I cant get my wheels off!!
- 383 Stroker Help/Questions.....
- Is the LT4 hotcam kit right for me....
- headers before tuning?!
- 4' WS6 Hood
- SLP Clutch owners inside.
- Wheel hop feeling still here....HELP PLZ.
- which did i break, clutch or t56?
- Nitto's or Eagle F1 GS D3
- power tuning module removal
- freak or not?
- 1le a/c delete bracket
- car shaking at higher speeds
- question on lt4 knock sensor
- Experts, please verify part #'s! Getting ready for headers!
- WS6 set up on Z28
- cutout questions
- 1st Gear free mod?
- Arcing
- True Dual Pics?
- Aluminum driveshaft or LCAs first? Your vote counts!
- CC306 Track results!
- what is cyliner fall off? is that bad
- GTP Stage 2 Flow #'s here on dirty heads.
- GTP Flow #'s? What is good?
- LT1 Head & Intake Port/Polisher Experts. I have a few questions.
- coolant temp sensors?
- Longtube exhaust suggestions!?
- 383 Guys, how did you keep your compression ratio down?!? Having trouble...
- Help with cold air intake installation-PLEASE HELP
- Cut-Out Pros/Cons
- Up and down bouncing of the shifter when dropping the clutch?
- gas mileage and mr MAF
- I hate my fuel gauge!!!!!!
- will 29.5 slicks work??
- How much louder will my exhaust be?
- Female plug broken off back of block...what is it?
- Preformance auto vs stick
- Help!
- How important is the right ratio?
- What i want to do for exhaust, suggestion
- Fel-Pro .041" Head Gasket Part # ?
- tranny mount installation
- car cover
- Tranny out, motor in car....can i replace the rear main seal??
- Using slightly dished pistons in an n/a and nitrous application
- window problem...
- Guy who have disabled the knock sensor - daily drivers?
- #1 Slip-In Primary Leak
- eibach drag launch springs, lower the car any??
- Deck my block? Quench will be .066 like this. How much affect on compression?
- Reassemble after heads/cam, what should I look for, opti, hub etc.
- Clutch,Tranny ?
- low trac sensor
- help with SES...I'm goin nuts!
- T56 Question
- Eibach Spring Q
- Bad O2 Sensor Symtoms
- LPE Z Conv's GM 847 cam video inside
- HELP!!!! P1441 Code Evaporative Emissions System???
- Power Window Motor Questions?
- Could it be the O2's ??????
- Quick question about Taylor OVC?
- What Material To Use For Sealing Intake?
- Driver's side window not secured
- Value Number- Car Key (help!)
- Toilet Paper: Not just for wiping butts. Pilot Bushing Removal - By Dave88LX
- Comp Cam XE 230/236 people... questions...
- Pics of BMR Boxed SFC's installed
- ses code 1136 see dealer whats that along with p0300 and po400car runs like sh1t
- Car Suddenly Developed A Stumble. Need Help.
- whatever happened to seafoam?
- Weird "clunk" sound. Help
- $$$$ to spend
- Dynatechs and lowering?
- Intake Manifold Gasket Re-use?
- CSI install?
- How do I remove valve springs?
- Mac Y-pipe clearance issues?
- another ? about 1.7 RR's
- Timing chain
- convertor clutch valve feed back fault.
- Easiest way to remove front bumper for paint work.
- Anyone running 1.5 rr's w/ the cc305 cam?
- Clutch for 700+hp
- Bad pressure plate?
- Hypertech PTM... need info
- Good atlanta machine shop / stuff :)
- Will thicker gear fluids allow for quieter operation?
- How do I support the tranny while i replace the mount?
- Strange VS Moser 12 Bolt???
- How to convert from 1 wire o2 sensors to 3 wire o2 sensors for long tube headers
- Which Radiator?
- cold air intake question
- Guy doing machine work says springs that come with HOTcam kit may not work??
- MAF Help
- Tranny mount quick question
- Which CAI is better?
- is my gm motive 373 gear for 2 series?
- lt1 block
- HELP! I cant get the automatic transmission filter seal out of the tranny!
- Alignment numbers-what do you run?
- Anyone with AN fuel lines?
- Burning smell...from headers? Please help!
- What is required to remove the oil cooler?
- Anyone try a crankcase evac mod?
- Which Suspension Pieces transfer from 10-bolt to 12-bolt and what doesn't
- need LT install guide and pics please
- Can alternator cooling fan cause knock retard?
- air bag removal
- Stupid Question about an air filter..
- I think i blew up my t-56! HELP!
- Saw an Odd Intake Setup on an Impala
- Dyno Graphs for Xe cams on a 110 Lobe Seperation?
- LT4 heads
- What egr block off kit should i need?
- slave cylinder poped apart what to do.
- I'm so confused what should i do for a y-pipe?
- 4.56 gears in 6 speed?
- wheels,suspention,gear question
- HPP issues
- do flowmaster mufflers make ur car worse???
- My Eradispeeds CAN'T be warped!!!
- anyone have this head/cam setup?
- How much WOT timing is ok to run?
- Head rebuilt help?? Quick Question!
- How much power can be made with normal aspiration?
- whats lobe?
- Gasket Port Matching?
- Relocated Battery to Trunk, Alternator not Charging
- A certain way to rotate your tires??
- just got my ss hood on
- flashing converter
- Rattling...still
- 6spd guys... i have a few questions concerning your oil pressure.
- Custom exhaust .... Opinions
- HELP...My car is too quiet!!!
- TRans pproblem
- NEW POST: Videos of Car Idling and Rev...
- M6???
- occasional ses light
- Cam Packages ?
- How do you remove these #$% Brake rotors.
- Anyone use a MAFT for tuning?
- someone convince me finally! electric or stock wp?
- my car is junk!!
- Im confused need HELP??
- Spohn VS BMR torque arm
- driveshaft wobble
- PLEASE Help with overheating problem!!
- Dumb Air Intake Question
- Help with a fan switch on 96
- running hot
- Will a Spec St. II from my Z fit a 66 Chevelle SS?
- quick rocker arm/valve lash question
- exhaust manifold leak
- Would this shift light work?
- was anyone in wildwood nj for the may car show?
- calling all CC306 owners
- Questions???????
- any thoughts on what this knocking may be???
- fuel rail leaking
- What shocks?
- How do you like your poly motor/tranny mounts?
- 5 speed Z28 convertible?
- Need Help: Car loses power after 4k rpm
- Few Header Install Questions
- can a bad tranny cause knock?
- most comprehensive spark plug guide?
- Zo6 or C5 rims?
- factory alarm question........help
- Problems to look for when buying a used LT1?
- Cam Swap.... DONE!
- Radiator Question
- tire rubbing problem!
- If I want to use a Double Roller do I need an Elec. WP???
- Clutch Swap: Pilot bushing or bearing?
- throttle body bypass now not starting?? Help!!
- LT's, exhaust, and lowering
- Shifter moves freely from P to 1st
- Heat transfer greese/dielectric greese
- Mezierre WP failed
- Will these rims and tires fit???
- How to test O2 sensor
- Bolt Pattern on Camaro?
- Maybe getting a LT4 intake and Hotcam
- looking for links
- Problem with Cloyes True Roller for 94 Z
- Dynatech Questions
- Motor Mount ?
- Uh oh! Oil!
- SLP Differential cover
- Ac Compressor
- Oil pressure low and tranny problems along with SES light...are they all related???
- AC delete fan belt
- 1995 TA i blew the motor i am replacing it with a 1994 motor what to do with opti
- Will 18's make me slower?
- Video Of My Hooker Catback and race w/cobra
- Engine Assembly
- For the most part I think I fixed one oil leak, now anoter is just pouring!
- part number
- What exactly are "Claimer" Rings, and should I use them?
- Good deal on a stall?
- Anybody with jet hot lt's have the mufflex y-pipe?
- Do you have to remove the dipstick on a longtube install?
- First post
- need a/c help
- 96-96 hpp III
- where to get o2 sensors??
- Going to be pulling heads, any tips, tricks, or ideas?
- What would cause my car to never go above 6375 rpm?
- which cam
- Running stock exhaust on a Stroker/Blown Camaro. Bad Idea?
- are Torco torque converters and these others OK?
- Exhaust tick
- The little shaft that drives the opti...
- Rattling coming from Rear Passenger Shock.
- oil pressure gauge
- installing edelbrock TES headers, which sparkplug wires to get?
- Secutiry Light won't go out
- Clutch is talking
- air dam with ground effects
- Turning Rotors ?
- Timing Chain Parts
- Will a 700R4 that was in a 77 350 truck fit up to my LT1.
- whirling and hesistation
- Arizona Auto Masters?
- security light will not go off
- FLP Long Tubes
- low fluid in clutch resivor
- Ok I am looking for a new motor, where and how much?
- New Tranny Mount
- Anyone using this HUD unit
