View Full Version : LT1 Based Engine Tech
- cooling problem 94
- Just installed Opti ... now car is screwed up - help!
- Oil Pump Replacment?
- Reasons for dropping oil pressure?
- Rear end whining?
- Temp guage stopped working?
- Black rubber strip that runs along bottom edge of window..
- 4 qts. of oil for 6spd...correct?
- G-tech Competition
- front control arm bushing?
- A/C Removal
- help on choosing a fuel pressure regulator
- Side mounting plug wires with AS&M Headers
- Should you use the stock gap on a worked engine?
- Avoid Canton Race Products At All Costs!!!!
- Need help, passing emissions!!!
- QUICK Help Please, Removing Oil Cooler?
- my car does have a 16 gallon tank right?
- Flow #s in....how are they?
- Compression question?
- Forged 327
- Coolant Magically Disapears ?
- Problem after cam install
- Those with lots of tire experience, help me choose?
- Replacing Valve seals.
- Wireing harness swap
- LT1 Cam Question
- ET Streets and the Highway
- which flow's better LS1 air lid or LT1 K&Nfipk
- Are MSD coils any good, or should I replace with stock?
- Best Nitrous Plug and Gap?
- lt1 dave
- Old school vs New school
- !!!!!!!!!!!all Camaro28 Members Please Read!!!!!!!!!!!!!!!!
- Programming..
- Need some RWHP predictions, Going to dyno tomorrow!
- 11s N/A for under 3.5K
- Good muffler shop in Chicago area?
- LT1 MAF eliminator kit???
- Guys running MAc headers, what kind of power increase?
- brake cylinder seals and dust boots
- Who needs a cutout?
- Subframe connectors
- 93 custom fan switch diagram????
- Cam install prices..What are you paying?
- what happen to the cadillac cam
- Before buying new opti
- eibach springs
- Has this been tried yet
- stupid spark plug wires.
- Type of fuel injectors on a LT4 96 Grand Sport corvette?
- Finding Valvetrain Geometry?
- xe 224/230 and lift number question
- Is the GM Hot Cam the hottest chevy makes as far as hydralic roller
- stumbling and pinging
- gear ratio question
- I have officially gotten 13.9
- Will a T-5 tremec work with the LT1?
- Do I need O2 Extenders for the fronts when I do MACs on my 96
- PCMforless?
- Need help
- the 383 LIVES!!! woot
- Will 94 shorty headers fit and hook up to a 93?
- Any 10 second heads/cam LT1s??
- What is ideal coolant temp range for a modded car?
- How to get oil and rust stains off...
- guys sorry bout another exhaust thread, changed my mind!!!
- a/c problem??
- Anyone heard any feedback on Edelbrock Coilovers?
- If I deck the block .025-.030, and Mill .006 off heads, What about the intake?
- Price and parts needed for LT install?
- flatspot when i get on the gas
- cam install question
- ! Please Help ! Hesitation
- Cam Questions
- good price on used Trans AM
- spark plug suggestions
- Where's the best place to buy header gaskets 1 3/4?
- VATS repair
- One problem fixed, now another.
- Anybody use these tires?
- what motor to go with?
- xe224/230 or cc306
- Racenet Heads-anyone use em?
- What kind of puller do I need?
- Front end alignment ?
- Got low oil pressure? I got the solution!!!!
- opinions on dyno numbers
- oil gage stays up at 80
- slp headers, will 3/4" bolts work?
- Part for K&N CAI missing...Suggestions?
- Is it possible to install factory theft deterrent system in a '95 T/A??
- Are 24" O2 extensions long enough for my Jet-Hot LT's?
- WHy won't 98+ steering column fit 93-97?
- need some help here...
- the hell???
- is it worht building a 355?
- Someone please tell me what this 112lsa means as far as cams go
- i need a few part numbers.
- Head Gasket Intructions
- Is it my imagination? Ground clearance!
- Need a new tranny, WHICH ONE SHOULD I BUY?
- Injector size question
- valve cover removal?
- Hot Cam/Heads....in here!!!
- How do you check what gears your car has?
- valve adjustment..
- Couple Questions on N20 vs Blower??
- selling my car... please read
- Anyone have a sound clip of a Borla?
- Jet-Hot Header review?
- Need help with Timing chain and/ or Egr valve?
- widest tire on stock rims?
- High output alternator for LT-1
- I mangled my brake line.
- Door coming apart...
- Popping At Idle
- 383 Engine and Exhaust Sound Files...
- SLP Fan Switch
- security light randomly comes on can't start until it goes off
- Brake or Bearing ?
- skip shift eliminator
- Settle this once and for all
- fuel rail schrader valve
- Does anyone use rotex brakepads
- Who has best prices on Spec Stage 3s?
- A stupid question...
- Might be buying used cam, questions inside
- SLP traction contorl switch
- hot cam and nitrous questions
- Help me push over 320 hp.
- miss under load at idle
- cheapest price youve seen on window motors?
- Link or phone # to cable from computer to car
- Possible Injector Problem when hot?
- car wont start, and shooting flames from the Y pipe after opti and waterpump install
- Loss of power...Please HELP!!!
- If I have a little bit of play in the steering wheel, what needs to be replaced?
- Any "gotcha's" on center console removal?
- AC questions
- can I change the waterpump seal with the timing cover still on
- Spring install - Open end towards front, or what?
- Question about light weight battery..
- Differences between SLP CAI and K@N FIPK ???
- Whats Engine Core required mean?
- throttle body problems
- What Tranny Do I Replace it with????
- Ls1 4l60e ??
- replacing torque arm bushing
- what would cause an alternator to ...
- is there a fuse or relay or fusible link for the...
- 61cc heads with 58.2cc pistons. What problems?
- What heads?
- My Tranny!!! Need urgent help !!! Belhousing
- thinking bout porting heads, who to choose?
- If I received a new "HOTCAM" that was ground...
- 97 Ss
- opinions on this cam please
- Abs Inop
- Code 29 eas electrical fault???
- Stock lifters
- Hooker catback people inside.
- Q-Tech headers. any one try them
- Had cat removed
- God i hate my car so much.
- Reverse pops out
- Do I really need 02 SENSORS
- 383 vs 396
- Rubber bushing grease, what type?
- Proform 1.6 rocker arms on ebay - $169. 00 - any good?
- hooker cat back of flowmaster american thunder catback??
- aftermarket optispark
- Autozone.....PFC Z Rated Pads
- 2 bolt or 4 bolt splayed caps?
- Will this work(224)
- I finally have the time and money to go out to the track.
- 94 #4 cyl misfire.. clueless
- How much does your shifter move?
- Here they are, some pics of my homeported heads!!
- Electrical/Ignition problem, PLEASE HELP!!
- A curiosity question for those with '97 Camaros
- important ? someone please respond
- Question about LTCC COIL setup
- Slave cylinder problem?
- how to tell apart sefl align rockers from none align
- Are all LT1 intakes the same?
- Is this worth buying??
- Pass-Key (VATS) question
- How to reach my goal...
- Why wont the car start now...
- How does everyone like their BMR K-member?
- Timing Chain in 93 LT1
- Removing Motor mounts?
- What's the best paint to use?
- PCMforless
- Having probs with highly mod'd 97'Z PLEASE HELP!!!!!
- ls1 guy needs help
- 1984 Corvette block work in 1995 Camaro???
- how many gallons of water/antifreeze do i need to fill after flush?
- Question about changin from 94 to 95+ timing cover
- How Do I Put LS-1 Ignition on Lt-1
- Helmet Requirements?
- New Tires And Valuable Info!!!!
- Flushing cooling system.. before it gets too dark hopefully!
- How much horsepower from
- line loc question
- Hot Tank & flow test heads. How much $$$
- Programming w/ hotcam or CC 305
- Do single cat headers on a Dual cat car remove all cats?
- Those who know about fans (ON/OFF) get in here!
- Stage 8 Locking Bolts or ARP Header Bolts?
- How To Get Slicks Rubber Off Fenders???
- Is this an opti-spark problem?????
- true duals or custom y-pipe?!?!
- 6-speed guys inside.
- trouble code 55: Fuel lean monitor
- 95 mass air motor to 93 speed density
- Do i need a new torque converter with my tranny rebuild?
- Low 12s.....in here!
- Need 400wrhp NA?
- new to board have some LT1 q's!!
- Gear whine and noise, any cure?
- Underdrive pulley? Good/bad? Why?
- Could i run my opti spark if i decided to carb my lt1?
- What redline is safe?
- How long is an off-road pipe? I think MAC screwed up!
- Accel DFI questions... speed density vs. mass air
- No Start on my freshly installed 383, inquire inside
- No Start on Nu-tek 383 after install and PCM tuning
- really need help with this
- Whats the redline on a 96 z28?
- help!
- Changing oil: Regular to Synthetic
- Hooker cat-back and K&N FIPK installed.
- stock wheel direction
- anyone ever used a DIY AC recharge kit?
- arp vs stage 8 vs oem header bolts?
- Quick question. How long is a MAC off-road pipe?
- How good are Howard's rods?
- will the vortech elbow work with slp cai and airfoil?
- Have you looked under your car lately?
- Madwolf is going places
- Help! Spec Stage1 Bad Chatter
- max lift for 1.5 stock rockers?
- Brake pads...
- fel-pro 1406 or percy's aluminum header gaskets?
- Coolant Sensor Question
- LS1 Brake Upgrade Spindle Question
- Has Anybody Done An 97+console Upgrade
- Trey are you around this morning???
