View Full Version : LT1 Based Engine Tech
- 11.7-12.2 volts when cranked (Max)
- Slot car racing LCAs and PHB
- GM or Fel-Pro rear main seal?
- Service Manual on CD any good?
- what clutch should i get?
- Driveability Question
- Are speed pro forged pistons pretty good?
- XE 224/230 Cam Questions
- engine bogs
- TPIS heads???
- Atkins diet for my car?
- Chilton's or Haynes, that is the question
- best heads cam setup
- where can i get a/c delete pulley?
- Ok last try, anyone with Crane Hi6 come inside. PLS
- What makes a lowered car not handle bumps well???
- Still not in the 12's yet
- Vented gas cap after removing EVAP system??
- Worth replacing 110K mi Opti since it's already off?
- Adjusting the timing gears...no chain
- Wideband O2 Tuning After the Cat Possible?
- Dyno numbers for Bauer 383
- Looking for feedback on 1LE/LS1 driveshaft
- Is someone on that can help
- Old question...but i'm a newbie
- 3.73 Install what fluid to use?
- Spark plugs with heads/cam
- another quick question
- Clutch woes...Take a look.
- CC 306 Video's inside
- Rocker Arms
- 3.73 on a stock rear?
- What to do with $600
- differential cover/ girdle
- Prob stupid question
- lowering the car...
- coolant question
- thermostatic switch for electric water pump???
- clutch pedal had different feel
- New Exhaust???
- WARNING about LT4 KM
- Anyone used the ypipe from summit for the hooker LT's?
- Cheapest subframe connectors
- Engine Eating Oil
- Oil Pressure sending unit
- My starter is going out
- which elbows fit slp cai?
- Part number for oil filter bracket
- Brakes
- shift knob removal?
- Best SFC?
- vented opti conversion
- Is Master Cylinder Mated To Slave Cylinder
- Dynotuning in bay area???
- What to buy with $200?
- another thumbs up to lloyd-numbers inside
- short block
- How does everyone like their HAL setup or Koni/Bilstein Setup?
- Will 3.73 work better with CC306?
- Does the Magnaflow sound like the hooker catback?
- solid motor mounts
- Weight Reduction
- Will this rotating asembly work?
- help me....
- LT1 with LS1 Heads?
- Retaining ABS on ASR Delete
- Beep Beep Beep - ARGH!
- May be moved butt.... Ford motorsport wheels on 94 TA????!!w/in....
- Troubleshooting A/C system, please help.
- Which Head Bolts go through the water jacket?
- nasty vibration
- Air Pump Fluttering Noise
- Kevlar or Carbon Disk on SPEC STAGE 3 LT1 Clutch Kit
- Post your STOCK dyno sheets...
- Offroad pipe or something similar for a 97' Z28
- Royal Purple... interesting real life data within...
- Nasty hesitation/stumble in closed loop...
- what size rocker arm studs go into LT4 heads??
- LT4 Intake Swap ?
- Is It possible???
- heater bypass poll
- Long Tube question
- Street Twin work with stock flywheel?
- Help! Fans Won't Come On
- Real bad miss
- Best Bang for the buck?!?! "SLP Clutch Kit or stock OEM"
- lca
- What mods next?
- best way to wire a csi electric waterpump, I see several.
- For those w/ Xtreme Torque Arms
- Engine Swap advice --- LT1 rebuilding
- Synthetic ATF in Auto; What's the Final Word?
- Need to drop oil pan, should I add HV oil pump now?
- Free scantool for OBD2?
- need help with LT's
- 383 or 396
- What can i expect?!?!?
- can a water pump leak for a bit and stop
- Crane HI 6R install problem with in. PLS HELP with the white wire.
- What are some good sized sway bars to buy???
- I need help bad!
- ? on Trouble Codes
- Pushrods. What size are they???
- Intake gasket, what about oil press. sender?
- monkeys at gm dealership or not?
- NGK TR6 part #
- putting engine back in: have a few q's!
- Converting ODBII to ODBI Speed Density
- Relocating the alt. but keeping PS and AC
- What's the point of a windage tray?
- Those with Nitto DR's that drive Street please
- TB and Filter give 25 HP on HP TV
- Spare tire rims as skinnys
- Muffler/exaust preferences
- stock rev limiter for m6, 5800 or 6200???
- longtubes
- Any write ups on Crane HI6R ignition hook up?
- Will The 26x11.5x16 Et Streets Fit In Fender???
- problem with intake install, need help
- LT1 Block
- ARP Main Studs location question w / Windage Tray
- Opti's and timing sets
- MSD Placement
- Exhaust
- Key FOB
- can someone look under their hood for me?
- Clutch question
- 85mm ZO6 MAF conversion???
- Which heads and cam combo for 383
- Canton Oil Pan
- lt4 knock sensor=bad?
- Used automatic tranny adding a shift kit
- Can I use an LS1 clutch with an LT1?
- Would like your experince with the following engine ideas
- camaro z28 mods
- Chrome Emblems
- How long to do a T56 swap
- Buy used rear with brakes vs new brake hardware and gear install later?details inside
- T-56
- flow numbers on well ported AFR LT1/4 castings?
- No change in ET after H/C install?
- Pushrod Length?
- Solid roller guys
- Cam and Lifter Choice
- tire question
- how do I test the knock sensor?
- Longtubes on a lowered car?
- Question 'bout Oil leak
- Holley Air Foil?
- Hypertech 160 Thermostat?
- hot cam kit and what else?
- Question about trouble codes
- dynotune prices???
- Those of you who got WOT (only WOT) dyno tuning....
- Lot of difference between 245 & 255 on 8" wheel?
- Knock Retard Woes...
- Porting Intake
- Longer exhaust valves....setting lash???
- Would like a part # off a GM schematic
- Relocating IAT(incoming air temp. sensor)?
- How much HP are Scat 4340 Forged I-Beam rods good to?
- How much of difference would a Ported Intake Manifold make?
- link to site black z28 with nascar exhaust?
- Can someone please help me find the correct part #'s?
- dynaspark replacement for optisark
- Is there an unused power wire somwhere?
- does anyone have sound clips of this???
- BBK TB Gaines???
- Is nitrous SAFE???
- Cam endplay ???
- keyless entry alarm question
- would this work?
- HELP FAST PLZ with my ES tranny mount.
- Problem with Brent's SKIP SHIFt mod, no GRAY WIRE!
- Coil ??????
- How to disconnect this battery? PICS!
- Couple of questions before header install. Need some help locating part #'s
- Almost Blew Up Motor
- msd or accel coil?
- Can I rebuild my starter or am I screwed?
- Beating up the cam question some more
- LT4 conversion. 425HP
- Mac headers+offroad pipe = lots of rattles
- Has anyone else had trouble with Eagle?
- Rotating Assembly is HERE!!!!! WOO HOO! Pics inside!!!
- durability tips?
- Is RockAuto.com a crediable source?
- Strange Cooling Problem (Please Read)
- Bad EGR symptoms???
- Low O2s/ 1/4 times down Please help
- Big Problem!!!!!!! NEED HELP!!!!!!!! PLEASE!!!!!
- O2 sensor removal issues
- Car stumbles, bogs, then takes off like a rocket!?!
- Knocking, pinging, detonating, preignition, whatever...
- Emissions: Shorties vs. LT's
- Exhaust and Header Help
- Tranny Question
- Now what do I do?
- the teeth on the gears broke on my car, what needs changing???
- Service Engine Soon light
- Vacuum Hose Replacement?
- Emissions numbers for stock engine
- ignition problem
- Pro 5.0 or SFC's???
- Problem with keyless entry transmitter!!!!
- How important is the LT4 knock sensor to get?
- car misses, smell gas please help
- Check out the before and after (Head Work)
- poly/rubber LCAs.. quick question about install
- Backspacing on skinnies
- car only starts after long time and oil pressure
- anyone with TPIS long tubes?
- Time For PCM tune yet?
- Rear control arms
- Is this the right Part # for GM Header Gaskets?
- I need your opinion on a problem guy's
- car still runs like crap please help to list any and all causes.
- IAC number all over the place after installing TNT plate...
- Weird dents... should I be concerned?
- Ltcc Help!!!!!
- Going to build a 9", need some advice.
- Can't find just the Walbro 255lph pump (not w/wire kit) online?
- What kind of 02 sensors
- what should i replace?
- Breaking in a new clutch??
- Holley TB worth The $$ on a ported Intake?
- Failed Emmisions
- MAF probelm HELP! shoebox?
- Reading Rims
- Does anybody have this color touch up paint??
- IAT sensor
- Where can I get rubber sealing washers?
- Tips on Rebuilding/Upgrading a '96 up to 600 HP
- 94' trans problem....not downshifting right
- Dont know what mod to do next?
- Heads and cam or 12 bolt
- Blew head gasket, going to do all gaskets in motor, help me decide
- keys stuck!
- wheel sites
- Just had an engine rebuilt, seems like there's problems
- Heads and cam are in, my thoughts and a few ??s.
- code 44
- SES Light came on in my 97 Z today...what to expect???
- anyone have instructions for power window motor R&R???? shoebox??
- can I shim my rotors myself
- What gear to dyno in?
- did my heater bypass yesterday, and have some questions
- Battery bolt size?
- Track gains?
- Front Lower control arm bushings
