View Full Version : LT1 Based Engine Tech
- Going to the track,need to pick up a couple of tenths
- Question on O2 Sensor's
- After Market Oil Cooler Question
- Could i put chrome polish on my headers??
- Bat kitty?
- front rotors
- another thread about a header leak!!
- New Here....My Car w/ Pics and Dyno
- Ordering SLP 2OTL today....will it interfere with SFCs though?
- oil cooler removed, observations
- Post timing chain break........valves trashed and need opinions
- Ratchet Shifter
- Starter Clicks But No Start, Any Ideas?
- Latest mods...
- 3" exhaust cutout plates?
- Post you exhasust sound clips please!
- Change cap and rotor, yes or no.
- What Cat-back should i use???
- Coating on MAC headers...HTS???? quality????
- LT1 383 GP Going on
- Tune Up Help!!!!
- Where can I pull switched 12v power under the hood????
- How do you pull off the rear side panels?
- How often do u change spark plugs?
- Ever ran the same ET 4 times in one day
- Wrong stall converter?
- Headliner Price
- LS1 Brake Upgrade ???
- Chewed On Another Opti =)
- Call me crazy but...
- Is this the right cable to get my pcm tuned by pcmforless??
- third gen IROC 17in rims on fouth gen
- How long for Harlan shift light to come?
- LT4 heads and Hooker LTs
- Tubular K member install questions
- wtf!
- Where to buy an electric exhaust cut out (prefer 4")
- Which intake elbow is best?
- Tall Aftermarket Valve Covers PICS INSIDE
- length of axleshaft please
- back up lights
- biggest gains from heads and cam
- oil under intake manifold
- Header Bolt Help
- quick msd ignition ??
- WHat percent does the rev limiter kick in before the push rods bend?
- Tuning for 1.6RR's and stock cam??
- URGENT! What is the correct voltage for the TPS at idle?
- Oil Pan and Oil Pump
- starting problem
- Need bolt size for tranny mount.
- HELP SHOEBOX! Broke A.I.R. Diverter Valve
- Found a cut wire near tranny HELP!
- Help with fuel line disconnects?
- Okay everyone, list your low gear, 2k V-light throttle surging fixes
- i did a search
- Dissapointed with my heads/cam results. Any suggestions?
- 4l60e
- Intercooler Needed
- ported LT1 heads VS ported LT4 heads
- biggest slicks possible? And what brand to get?
- Intake manifold gaskets, put on dry or a spray on sealant?
- HELP: car dies as soon as hits 3k rpms?
- found this in the door panel...what is it?
- Hydralic Roller Lifters Vs. Solid Roller Lifters
- All those connectors on the T56 tranny?
- gears and rear end...come inside
- Anyone been able to take the clutch fork out "without" taking the 6sp trans down???
- Cooling fan Mod.
- can i take the heads off without takeing the intake off?
- Bad Lifters Or Not?
- Ive got anifreeze coming out when i drain the oil
- Knocking Sound
- 2 questions:smell gas while driving & car runs hot
- AC Bracket question
- Is there a torque seqence for the intake man. bolts?
- Guys with 230/236 on 6M...I need honesty.
- federal mogul.........
- More power with .600 lift cam?
- where the heck is the sensor for the evap system?
- I no longer have posi traction, how bad it that?
- What rims to get?!
- How correct is the HP Calculator
- Please help me with my bad idle problems
- Opinions before car gets worked on
- guys who did head swaps with motor in the car-
- belt for underdrives...small problem...
- CC306 on a 114 LSA
- How much is new egr valve from dealership?
- Got my jet hot lt's today got a ? about the drivers side?
- Running in Speed Density
- anyone with NO leakage or dipstick problems with a Canton pan?
- Quick Help !! EGR Line Broke off Manifold
- Regarding the SLP Linelock, for anyone who has it!
- rear end question. 2 problems.
- How do you degree your cam?
- Quick 12 bolt rear question....
- Torque arm mount bolts type
- Engine refresh versus rebuild
- stock LT1 specs
- Keyless programming
- Code P412, Fuse Blows, Mechanic said:
- Whats this Valve For
- Slow Acceleration
- Suspention
- push rod lenght for afr 210
- swaping from 4l60e to th 350
- How to get into the high 10s N/A?
- Will the SLP DS LOOP work with a 3.5" DS?
- Car wont start!?
- Anyone running the LPE 3.5" Alum. DS?
- Doing front alignment with string.
- Oil Coated inside of intake manifold, how to prevent it.
- HP loss from to running high octane fuel
- What's acceptable knock retard readings?
- New Spark Plugs
- any scanning freeware for OBDII?
- Best Street/Strip shock/spring combo?
- HELP!! misfiring on the freeway
- Scanmaster and LT1 Edit
- Idle Problems
- guys with camaro parts book- need part number
- At idle, car's rpms lower after a while and SES light comes on????
- AIR pump bracket bolt size
- car wont start, not battery or fuel pump
- electric cutout dying after 1 day?
- Car over revs
- Transmission wiring (m6-a4, 94-96)
- guide plates vs. self aligning rr's
- Transmission Mount Help!
- Knock sensor ses.
- Opti Contact vs cylinder
- Open loop/closed loop question:
- How long did it take you to swap converters (at home/no lift) - and torque specs
- Hypertech shift firmness
- wheres the fuel filter and how do you change it?
- plugs and gap with a 150 shot?
- Help! Please! Opti ?
- Need GM Part No. for 3.73:1 gear set.
- Why does this part # = a "valve kit"
- Transmission whine
- Need a part#
- car fells like it falls into neutral
- Anyone else have rattling in the back?
- dyno numbers are in and was hoping for more!!!!
- Drive Train Clunking driving me nuts
- opinions on Kieth Black pistons...
- A wet dog in my car?
- Injector Help on 96 Ram Air
- canton pan fitment problems!
- Going to Get heads today Quick Question
- Swap
- Running Rich, flooding while driving
- Has anyone tried this
- Exhaust question on headers/catback
- just when u thought a question couldnt be dumber
- Late Night Help -please-!!!
- 1.6 magnum question.
- Stage 1 or STage 2 heads?
- Hollow clunk
- cc 305 guys inside please
- Will this O2 Idea work
- crumpling tin cans sound
- help!...please
- My Z28 stalled in the middle of nowhere
- edelbrock shorties with off road pipe + dynomax muffler = cop magnet??
- smoging in cali
- Whats this noise when its shifts?
- Front Camber ?
- Valve-Springs, Lifters, Pushrods
- Nedd step/step install info on trans cooler
- camber prob on rear? wtf?
- loud *click* after i let off the gas?
- Need Help with plug/wire install
- What to expect with jet hot lt's??
- Need Help Car Still Wont Start
- Air/Fuel gauge..useful or eye candy?
- Factor freak?
- Having problems with idle after 58 mm TB install.
- Centerline Telstars
- Gains with just heads?
- What fuel pump hose are you guys running with your Walbros?
- LT4 Conversion
- Radiator Help
- elec. W/P seal Q:
- need new brakes, pads/rotors
- Need Help!! Used Stock Clutch Disk. Asap
- Brakes squeeking, driving me nuts
- tire questions
- ignition switch gremlins
- New Cam and aweful smell
- car ran fine a few minutes ago, now won't start...
- Need step by step directions for springs
- console
- New pics of my ride!
- Part # for opti cover when going carb???
- finding tdc and water pump shaft seal
- A4 tranny bounces off rev limiter before it shifts after programming?
- Doesnt happen often?? Here is another one for you all!! Heavy duty replacement???
- dyno on friday
- Will JB Weld hold uo to gas?
- BMR Trak Pak Torque Arm....Check this check out what i broke.
- which throwout bearing to get?
- Is my timing advanced too much?
- What Would Cause Start Hesitation?
- LPE DS and Spohn TA a little problem
- Torque Convert to Flywheel Gap Problem
- 97 heads.... I heard they wont bolt up to 96 and earlier intakes. WTF?!
- quick question
- Motor Mounts: Poly vs Rubber... questions inside
- What's a good price to pay for a 6-Speed and LT1?
- Fuel Injector Wiring Help---Please!!
- noisy fuelpump
- Hitting Rev-Limiter after stall & tune??
- Has anyone swapped an LS1 into their LT1 car?
- Replacing Strut Mounting Plates?
- Testing for a bad opti
- Tranny/Speedo question
- Anyone with a SPEC Clutch inside
- m6-a4 wiring
- best and cheapest place to get LS1 aluminum driveshaft
- Help!!! car running chitty.
- Checking for leaky injector(s) question
- How to find a vaccum leak
- How do you make the louvers functional on a stock Camaro Hood?
- Headliner
- high-temp copper gasket maker to seal AIR fitting?
- Painting intake...most effective way to remove fuel rail covers/injectors?
- Where and how did you mount your MONSTER TACH???
- Question about Draglite Wheels
- this might be a stupid question?
- My car is a POS...any knowledgeable ones please read on...
- .029 GM head gasket(which side goes up)
- Injuneer Fred!!!
- Blowing oil after 100k miles
- Where is the alignment mark on a Spec?
- Need help. Car is backfiring and running poorly. Check Engine Light on also.
- Getting more power to our sh*tty window motors
- increasing the tranny pressure is a good thing??
- Where can I pull 12V+ Ignition Switched power????
- cheap scan tools?
- Problems adjusting rocker arms
- Strut Tower Brace... Does it REALLY do anything?
- Exhaust Questions
- Clutch install(in the middle right now), cant find the mark on the clutch to align
- Easiest 1.6RR valve adjustment procedure?
- Is a 95 OBD I or OBD II PCM??
- Who Has A Stroker From Agostino?
- Are discussions saved permanently, or must download them?
- Lowering vehicle w/ 11's
