View Full Version : LT1 Based Engine Tech
- Vats Security light ?
- Realistically, what does it cost...?
- Question on Catalytic Converters
- high flow cat
- A4's with 3.73's inside.
- Clutch won't disengage?!?!
- Intake gaskets - dry or use sealant??
- What is this?
- what fuel pressure
- *pics of spark plug tips*.....these look ok?
- hmm... someone help me out on this one..
- alternator problem
- Does the Opti include the cap and rotor?
- TDC question
- can someone direct me
- what header bolt lenght w/ hooker shorties
- replaced clutch and it still rattles... WTF!?
- AC Delete question
- 380+ hp w/ 8.3:1 compression, what octane fuel?
- How much power differenve between??
- This should be my last jet hot lt install?
- Roller Rocker Poly locks backing out Help!
- moroso intake is amazing
- im hard of hearing and need advice
- 18mm Thread
- What's involved in replacing the seal on the oil cooler?
- Battery Dying after a few days of not driving...
- Synthetics
- tranny install
- ASR install?
- LT1 to LS1 or maybe LS6
- shattering noise that happens occasionally
- help with jethot LT install
- Does anyone have the part number for the power window switch LEDs?
- Royal Purple or Amsoil ??? What's the best ???
- Cant get opti boots on
- 4.10s and Drag Radials?
- Tc?
- Which wheels?
- anyone own a 30th LT4 SS?
- How To Fix A Flaired Cam Dowl........????????
- well quickly figuring out total new motor will have to wait. Are heads/cam a waste!
- How to break in a clutch?
- i ran a 115 trap today, et??
- getting extremely frustrated
- is a 50gph t rex inline and a stock pump good enough?
- Dipstick tube and kick down cable for TH350 swap
- Think I got a bad load of gas... few q's
- Which motor oil?
- 6 liter LT1 STOCK?
- could bad/old plugs/wires cause engine damage?
- Almost Threw Longtube Through Windshield
- dowel pin length on 95-97 LT1 cam
- Coolant Air Bleed Pipe....HELP!
- Z28--------to-------->SS
- Help with code 34, MAP sensor.
- running rich...
- wires have been arching...........did i possibly damage anything?
- new motor - vibration :(
- Does wheel hop cause damage?
- HELP Heater Hose ?'s ...
- 218/230 114 inside
- Does a gasket exist?
- Anyone using this TB?
- name this part please read?
- how many hours to do rocker swap?
- Cleaning Injectors the right way
- Camaro vs Mustang
- opti idea
- Trani Swap
- you have $2000 for a blew tranny, what would you do?
- cost to get machine work for bigger valves?
- ?'s for guys runnin skinnies
- Help me with Changing Fuel Filter please.
- Manifold porting advice...
- Is the aluminum driveshaft really worth the $$
- 315 Nitto Drag Radials. What best psi to run them on the street?
- No power steering...please help!
- harland shift light
- how can i get more traction.., sugestions?
- Fuel System Q's
- Newbie in the Mod Department. Few Questions.
- F.S.- 1995 red trans am rebuilt everything
- FNG with car problems. Pls help (long)
- LT4 roller rockers and valve cover part #'s
- Amazing thing happened today...
- Quick newbie question
- come inside & guess Dyno #'s!!!
- 95 a4 tranny problems
- All people with DMS springs please
- Before you go and replace your MAP
- 1LE suspension
- little throttle response
- does this sound like blown rings?
- 60' Times
- Need ideas
- Shoebox or just any body please help!!!!
- Exhuast too quiet..suggestions
- throttle body fuel smell
- 4:10 gears whinning
- Tranny Help
- 3.42 gears
- Is my tranny slipping?
- Look at all the passages in the LT1 INTAKE MANIFOLD!
- confused by my car
- T56 or 4L60E
- Is it ok to re use rings?
- Seized Fuel Filter
- What FP are you guys running
- what and where is the icm ?
- Aluminum Driveshaft
- Who is selling GM Motive 3.73s right now.
- Wheels and Tires
- What is part # 22128877, and do I need it?
- fuel filter change?
- 94Z A4 transmission slips @ WOT 2/3 rd gear shift
- Oil pressure GAUGE drop.
- How to remove back seat, pass seat and frnt sway bar
- Where can I get a map sensor
- need caliper hex bolt size
- Lunati LT1 Timing Chain??? Anyone got any info on this thing???
- What is the most power you can make with stock heads?
- The IAC passage in the intake goes where?
- California Drivers with SLP LoudMouth
- After 2 years, same problem...ideas?
- EGR going bad?
- How loud are the rollers supposed to be?
- brand new dyno numbers
- Need engine help!
- Oil pressure sending switch ?
- My car makes a funny noise when I take off.
- Question about NGK's?
- Which camaros have LT1's?
- Where to buy LT1 Engine?
- Anyone have a second to explain to me what cam surge is?
- This would be easier if I had a torch
- This is funny
- Front shock "top hat"
- Will these gears fit my car...
- Removing stem seals
- Big day ! Opti / H2o Pump Install, anything I need to becarefull of ?
- How can i clean my Throttle Body??????
- Crap!!! Need Emergency Help!!!!
- headers
- heads and cam help
- Steering gear, torn boot.
- Transmission preform button
- Anyone replaced p/s pump seals?
- mounting pro ratchet shifter
- XE 224/230 good enough to blow tranny on 1st day
- Rotors
- How Can I tell if My Car Is Hestitating
- SIMPLE question about pcm... please help, please?
- Finally went to track tonight, are these good #'s?
- Lt-1 Motor Rebuild
- Vigilante converter? Need feedback so I can order it!
- DRL Install
- Are shocks a good mod?
- Why do i have a popping sound from my exhaust?
- code 62 air bag help!!
- Anyone with Hotchkin's lowering springs?
- Just bought 95 T/A, have a couple ?'s?
- transmission swap
- Just did Over The Valve wires from Thunder..
- what do these wires go to
- gettin tranny rebuilt...wut kit should i throw in?
- I live in the city and I've got "crickets" under the hood...HELP!!
- Mushy throttle at low RPM's
- Manual Fan Switch Help ASAP
- Can anyone take a guess why my pedal vibrates?
- need some torque specs please
- car wont run NEED HELP!!!
- fuel injector o-rings
- I very interesting Cooling problem NEED HELP FROM THE EXPERTS!
- If the 10-bolt doesn't break...
- Lt1 Engine Overheating
- 402.3 RWHP on stock bottom end.
- GP on spec clutches...what do you guys think???
- 3.42's alright with 2800 stall?
- 600+ hp. 3.42 or 4.10 gears in M6?
- Cam question
- How wide of a tire will fit a15x8 rim
- Removing Entire EMISIONS from car
- Clutch bites hard..
- rear axle fluid change
- new clutch, synchros, flywheel... Opinions?
- motor mounts
- Remove crank pulley for doing wires?
- How to test Oil Pressure Gauge??
- How to check for a fouled plug
- Wheel Hop
- Help me decide..
- Is a 700R4 just as strong as a 4L60E
- Low Coolant Light
- Question about clutch and tranny
- Do I remove front Radiator when removing AC???
- part-throttle hesitation
- What PSI for street tires at the track?
- Crane Gold 1.6 3/8 self-align
- Stroker kits ???
- Car spudders and back fires from intake
- muffler part# for duel exhaust
- Fuel System Problem - Need Help
- SLP header install question
- Any Tricks to yanking the alternator pulley?
- parking brake
- 18 inch rims all around?
- ATTN: Everyone who had problems the same day they used seafom...
- A/C fuse buster
- How many runs on a bottle of NOS?
- Clutch fork slipping off when installing slave cylinder
- Bmr Relocating Brackets
- did many 97 camaros come with aluminum driveshafts?
- 1.7 ratio on an LT1?
- Red line
- a/c clutch?
- OEM vs. Aftermarket Fuel Pump
- Throttle response and hesitation bad
- Shift light
- Just found out that my blown head gasket is perfectly fine!!!!!! WTF
- Wha is the best shop for T-56 tranny work??
- electric waterpump install question
- 396 Stroker GP packages added
- serpentine belt (help please, quick)
- did i get screwed?
- opti spark ?
- knock module ?
- map sensor part #
- Things to know before buying a 9"
- All with Stall Converter!!!!
- Looking for Rims....Please help!
- Question about A4 transmission.
- cowl hood
- Car Won't Start, Help!
- Shoebox ??
- Canton Oil Pan # 15-244T (vs) 15-242T
- are my headers leaking??
- good setup for not spinning?
- Plugging EGR vacuum lines?
- Turn Signal problem
- Is a MSD 6A worth the money?
- Anyone run straight h2o and water wetter in the summer?
- anyone have pics of their car lowered?
- Where to get cheap 02's.
- Corvette fuel rain covers and traction control....
- AS&M Install Question?
- Why do they make adj. LCAs?
- Car options.
- hey shorbox... have a picture of this part #?
