View Full Version : LT1 Based Engine Tech
- what mods?
- true dual exhaust
- "ABS INOP" light is on
- Scanmaster
- What is doing this??
- Cam Gurus Inside Please! Mind34game, Bret, etc.
- 12 Disc Magazine
- PA K Members?
- Cooling/Computer Help
- Decision heads or heads and cam
- Replacement Brembo Brakes???
- What is my car's problem?? HELP!
- dipstick problems with new motor (main caps or pan are in the way)
- what to do next?
- How to lubricate window
- throttle problem i think...come inside
- i cant get traction, and i'm stock! Help!
- LT1 Problems?
- Trans Dipstick Tube
- Changing optispark drive oil seal, how hard? Install guides?
- Hows the change to a 3rd gen rear sway bar???
- optispark change in progress...need help
- roller rockers
- Can the stock oil pan be used with a 396
- LT1 cars
- Cruise intermittently not working?
- how do i know what gears my car has?
- HELP! security light comes on and car doesnt start
- Front cover oil leak -- need advice
- Heads to go with CC305 cam....
- My AC is going out
- Tapping noise under low throttle
- optispark problem
- what causes backfiring, popping sounds...
- Driving without in-tank fuel filter??
- Anyone running 236/244 Cam?
- rear axle swap?
- What kind of lube for pilot bushing?
- Stock fuel pump and injectors handle 375RWHP??
- How can I tell if it is a real lt4?
- LM + LT + Cats
- What should oil pressure gauge do at WOT?
- Another LT4 KM Question??
- What would be some signs of bad EGR valve?
- Last Minute advise..
- lifter swap?
- code 44 where to start
- Steering Binding...
- This noise is driving me crazy, please help.
- What is the part # for a Mobil 1 oil filter?
- Getting transgo shift kit and new torque converter, do I need reprogramming?
- Hotchkis lower control arm
- valve / lifter tapping diagnosis - please help!
- Max effort LT1 Cam with stock bottom end
- PS delete Without Skinnies?
- Trans, rear end, or suspension? plez help me pick
- Where to mount MSD Digital 6
- Which fuel line goes from the filter to the tank?
- Those with Black camaros....Whats your paint code?
- Stock LS1 MAF, will it work on an LT1?
- do '93's take platinum plugs?
- anyone heard of gm performance exhaust??
- CC's on stock heads
- Bolt on 400HP+....How???
- is it normal to run this cool after !AIR and !EGR?
- Headers banging on floorboard...remedies?
- p&p heads
- Coolant light
- my passenger side fog light went dead!!!
- Where to get a pigtail for 94-95 coil?
- Hey guys will this engine work with my car?
- 4L60-E running to red line before 3-4 shift
- Is the Z28 LT-1 2 or 4 bolt main block
- plug gap ??
- Idle gets choppy after about 1 minute of running!!
- stock sounding cam?
- Cutting Out MAF Sensor Screens?
- Delayed start, any ideas?
- Msd Opti Replacement
- Cheap gas by miskate?
- Morning Backfires.
- tire size
- Tunnel Brace
- where do i get these parts??
- Differences Between '93 and '97 LT1s?
- LT4 Intake Manifold In Summit Catalog???
- Do the cooling system on the LT1's suck? Yes they do
- LT1 Dave
- I don't think it's the intake leaking after all...
- Can a breather hurt?
- Everyones take on the huge tach shift lite subject.
- Need amber bulb part number for front clear corners on '94 Z!
- Car still aint starting, no spark
- Someone wanted a gear poll...
- Bad machine job
- Rods
- Jet-Hot LT install.......done!!!
- LS1 intake swap...
- Gear Question
- Comp 875-16 Lifters & valve lash question
- Where can I buy a relay?
- Need Ideas For my next Mod?????
- what do I need to do a 2500 mile trip or so?
- help
- Electronic B&M shift kit just as good as a real shift kit?
- Lakewood Lower Control Arms and Panhard rod
- Z06 Maf?
- EGR p/n?
- Do T56's tend to slip out of gear.
- Just bought an LT1... let me know what you think (pics inside)
- Clutch alighment tool specs
- Throttle body difference???
- testing the coil with a multimeter or something
- What can I use to clean EGR VALVE???
- Noise after i let off the clutch?
- Production mubers
- Firebird to Trans Am
- Will I be ok with 2 different types of wires?
- Just fired up my Z with the GTP's for the first time & have a RR ?...
- Scanmaster mounting???
- Q's about new Torque converter and mail order tune??
- 93 LT1 mods question
- LT4 Knock Module ???
- Strange vibration after I let off throttle?
- Need help with TC terminology
- Shrader valve??
- Broken Bolt in my head :( help?
- confused... how do you bleed the coolant system?
- Easy fan switch question
- Opti vaccuum hose ?
- 93 LT1 Chips
- codes 13 and 63..
- Which 2 intake bolts are used to mount cruise unit over valve cover
- New cyclinder heads
- Does anyone have, or know where to get, just a starter solenoid?
- R/R bearings in drivetrain??
- alternator problem?
- Is it hard to change the EGR value??
- what info from scanner should i post for everyone to figure out my problem?
- OBD1 Manual Fan Switch?
- Need help with Diagnostic codes!!!!!
- Stroker is finally ALIVE!
- Manifold bolt/nut?
- 95 Lowering Kit
- 3.42 & 3.73 A4 people inside please!
- Intermittent starter problem…
- What do you guys recommend for a ring gap?
- wiring 95car to a 98+door
- Problem - Please Help
- How do you hook up emissions on passenger side LT?
- Gear Swappers question
- Exhaust manifold studs
- Need p/n for mass air wire harness pigtail?
- My New Z
- Has anyone used Cottman transmissions before?
- Overheating Problem Please HELP!!!!!
- LT4 valve covers
- T56 upgrades?
- Overdrive on auto tranny
- SLP header install?
- 700 R4?
- Tbryne CNC heads?
- Want to remove PS,AC and heater core
- Can't find last bolt to take tranny out!
- Will 0.19 Amps draw be enough to kill the battery in a few days?
- Oil pump swap in garage on jackstands, how hard??
- how much HP do you loose if you race with the A/C on?
- Anyone have there dash lights go out? not a fuse
- Codes 32 and, what the heck is 77?
- Quick question- These are SVO injectors right?
- engine light comes on when a/c is on
- I am buying new Heads, cams, headers.. WHICH DO I GET?
- Yes, im a dipstick, i need help with my dipstick...
- Air Intake Duct
- Where can I get pilot bushing (not bearing)?
- CSI elec wp wiring question
- yall prob know more about this tranny than i do
- Hp loss with 7' knock retard?
- 160° Stat require new chip/program?
- SOS GOD HELP ME!!! (just came from garage)
- How do i know if rotors are warped?
- Sawtooth dyno graph
- pulling motor, need ideas
- A/C Compressor Install / Uninstall Results
- Argh Wipers
- my car seems to be slightly rattling, details inside
- xe224/230 at 111 LSA
- typical price for heads and cam
- 2.25 Wheel Spacer
- Tubular okay or go with boxed SFC's?
- LT1 crankshaft difference between manual/auto tranny?
- Rear end advice
- Monsoon Stereo
- 6-speed Question
- Paging shoebox (or anyone else that knows everything)
- Whats the low down on flywheels?
- Cheapest price on hotcam??
- Part # for upper shifter boot?
- How do I install the windshield wiper blade?
- Need help reading my Datamaster File
- Where to get a t-56?
- Vacumn leak
- Auto Shift Points RPM Range
- Found a cheap T56, but it needs two parts...
- What The Hells Do I Do With This???
- Shocks or Springs, which is better?
- M6 tranny not going into gear
- Valve Job and Reliability
- Anyone ever get a horrible sound from the A/C compressor?
- Drilled/Slotted Rotors..is 200 bucks a good price?(LINK)
- Guys with LT's how are you routing #7 plug wire?
- DMS motorsports
- where to purchase modifications??
- WTF is wrong with my brakes?
- overheating problem
- 2nd gen z askin for some input
- 383 help
- Anybody know how to adjust the winshield washer nozzels??
- Where can I get one MSD plug wire....
- Is it possible to mount n2o system here?
- New intake and Oil Pressure Question ??
- Trans question
- Anyone install and poly tranny mount???
- lowering kit
- Rear end ?s
- SES on non-stop for months. Now off due to better gas?
- What do these symptoms mean??
- manual fan switch??
- Does the HVAC fan slow down when accelerating? or am I crazy
- Car won't start, problem?
- TB top plate gasket - part #??
- Please HELP
- need help with removing LCA's
- What are the symptoms of a bad torque converter?
- Power door lock problem, HELP
- Need A Link
- powere ant
- Help with AC!
- ???Hot Cam Kit???
- Car starts, but then SHUTS OFF!! Whats the deal?
- anyone pass a roller emmission w/ open cutout?
- Is a cutout a worthwhile purchase?
- 17in rims to 18in rims how did it affect your 1/4 mile times??
- Is this a scan master???
- Ignition box needed?
- 95 Lt-1 Alternater
- Whats the Fastest Bolt on LT1 on Nitrous?
- anyone tango with a code16 yet?
- Security Problem no start! 96 Z
- rough running
