View Full Version : LT1 Based Engine Tech
- what header gasket to get, and where??
- What do I need for a
- Help!!
- Next Problem::::
- pcm
- What do you think about these tires?
- Does the PCM use 02's if SES is tripped?
- Why am I blowing out coolant
- what clutch to use
- Need part #
- Serious header question...anyone with SLP headers please help!
- is there a way to verify an opti is going bad?
- Re use heat shields on plug change?
- crappy tranz
- alternator question
- How much play should there be in clutch fork?
- Dex Cool
- o2 sensor dilemma.....
- Ignition wires
- How cold is everyones A/C?
- CMotorsports Stage II Heads/Cam package ? ?
- Just blew up my star stage 3 clutch.what now?
- pushrod broke through rocker arm, curious questions
- what are the chances of a blown headgasket if you don't have mixed oil/coolant?
- manual Fan Swithch Questions
- oil on spark plugs?
- What all attaches to intake manifold studs?
- What forged pistons (part #'s) have you guys used for 355 and Nitrous?
- break in period for new gears?
- ? on Record RWHP on a stock bottom LT1 N/A, Hows 452!
- Autozone opti does not include cap and rotor
- Torque specs for diff cover nuts?
- Exhaust options
- How is my car going to sound with jet hot lt's and a hooker catback??
- Operating temps with electric WP
- where to buy ZR1 replica wheels?
- Weight difference between Ttop cars the coupes
- Car died magically overnight?
- Thanks Shoebox!!!!!!!!!!!!
- Valve adjustment
- lt4 EGR Block off plate part number
- Best clutch for cheap
- ARP intake manifold bolts on LT1?
- Glovebox not closing tight. Question and pic....
- The New guess the motor output *reward*
- AustinZ28 future buy
- Aftermarket starters?
- Code 300 after oil change
- 3:73's or 3:42's????????
- Alternator
- ? about underhood relays and fan operation..
- Would SFCs be in the way when I go to do headers?
- Smalled tire for 9.5"???
- fuel pump discussion (standard 255 vs. racetronix 255)
- LT1 swap update (II)....still wont start
- Lambert Salvage
- Tranny Prob in a 67' w/ LT1
- tire pics
- Anybody ever changed....
- Is it true that 100lbs equals a full car length in racing?
- cc305 or cc306?
- transmission linkage???
- Rocker arm question
- Borl+LTs=ricey tone
- Suspension/tires help with 400rwhp?
- TB Bypass Intallation Question
- Part number
- Head Break in Period?
- SLP Fan Switch Install Question.
- strange idle
- Midwest Converters
- throttle cable pulled through...
- Stock LT1 combustion chamber size?
- 17" et streets
- Cheapest place to buy EBC Greenstuff pads
- Is this worth the $
- Help!!!!!!!!!!!
- What is involved in "stroking"?
- ABS and smaller front tires
- Anyone know what the 230/236 Revs to?
- Are the oil pressure senders different on the 94 and 96 LT1's??
- low on cash, need mods
- Clutches
- Need help kinda fast got to pass inspection
- Possibly louder?
- Low Fuel
- This require a break in time??
- These tranny cooler lines are REALLY STARTING TO GET ON my nerves
- Got some lights coming on, please help
- A4ers, Something I've Noticed
- With 255/50-16's make you 2 mph off????
- Opti died?
- stud replacement
- where can i buy this?
- Cats
- 236/242 cam...stock 1.5rr's capable of handling Comp 918springs?
- Do i have to bleed all 4 brakes?
- Complete LT checklist....
- How Many Times Can You Mill Heads???
- ZO6 MAF....Worth it?
- stall converters are $750?
- Hesitation up top. opti??
- Drag radials or tq converter
- cutout question
- as&m headers
- What did you do about your altenator when installing lt's??
- Will this work?
- 94" Corvette gear ratio?
- low oil press, knocking sound..HELP, long
- Can I run open headers for about 25 miles?
- melling stock volume oil pump pick up ???
- Big cam, stock heads...What problems can it cause???
- ?? for those with digital h2o Temp Gauges?
- MSD wires question
- SLP Clutch...Clutch Chatter??
- quick question!
- I need help on fixing this problem
- Please tell me what the fuel canister purge tube is and how t
- Need help hooking up oil & water temp, keeping s..
- window motor questions
- Can anyone help me interpret a 1/4 mi scan and diagnose why my car lacks power?
- SES light on after getting into it hard!!
- shifter cable and two cooler lines... simple q's.. if you've dealt with either before
- O2 Extender Question
- cooling fan mod, getting SES code
- Best times and HP/TQ wih 230/236 cam
- which notch on opti drive
- Service Engine Light after coil reinstall?
- How to hook up guages and keep stock guages?
- this clutch install could not have been worse*please someone help me*
- 700r4
- Would a skinny fit on a space saver spare??
- Where to get COMP R Llifters??
- I need to win-----please look>>>>>
- wheels on a T/A
- oxygen sensors
- Cam selection for some hot heads?
- Will a vortech S trim F-body kit work on a B-body?
- Headliner messed up
- Car almost cuts off with new cam!
- Are these any good?
- Starter
- 14.3 @ 96 mph Please look inside, is this slow?
- noisy power steering pump
- cooling fans not coming on, any ideas???
- camaro z28 mods
- Exhaust is on!!!
- What is the best clutch for the lt1
- factory alarm stopped working, Shoebox?
- Lt4 components
- deleting cat = hurting engine?
- Does this sound like the fuel pump?
- Corsa CatBack sounds Bitchin! Hear for your self Inside
- Best brake pads
- high rpm miss ,roughness?
- Which Mods? What order?
- What mark should the clutch fluid be at?
- Some LT1 Myths/Misconceptions
- popping sound
- oil pick up tube info.
- did tune up after opti went bad and it know misses all on one side?
- A-Pillar install
- How do I bleed the clutch system??
- starting probs
- Fuel delivery problem
- My left side taillights are dimmer than my rigt side. How do I fix it?
- Car has trouble barking tires on 1-2 shift?
- Is there any trick to getting a brake hose off?
- Will this cam pass emissions?
- How much does spray hurt an LT1?
- best pushrods?
- help with clutch install, pics inside
- Clutch install, now very hard to shift with car running!!
- Eliminating Pollution Control!?!?
- Location of Schraeder valve, also coil reinstallation question?
- LT1 seized?
- aftermarket opti???
- Creader obdII scanner
- scanning tool-worth the money
- n/a no longer- turbo or centrifugal?
- Which CAI?
- Lower Oil Pressure since Synthetic switch...
- Milling heads and compression
- Are these headers/exhaust good?
- please! please, help me pick a gear!
- T56 swap done... but the starter won't work... dash lights come on... please help
- Where to start Diagnosing Missing Power? (Recently dyno'd Solid Roller 392).
- I need Knock Sensor part# for 95 Z
- Please help me pick the right gear!
- Solid Roller Stroker Peaking Too Early?
- new turbo motor break-in?
- Piston to valve clearance
- Ok, did a search, still confused...
- need help quick!
- HP with CC306 cam ???
- Installed my Spohn rear LCA's yesterday
- Question about cam install!
- Torque Converter Shims
- Which motor oil weight to use?
- maf gasket??
- Intermitten start problem. Help.
- Electronic Spark Control, Anyone ever use it?
- Which RTv is best for all?
- BMR Boxed SFCs'
- PCM tuning
- Accel Shortie Plugs Anyone have a part #?
- Best spark plugs for LT1????
- Mechanical or electric Autometer, which do you prefer?
- How easy it is to change the tranny's 5th gear?
- any good launching tips for a4 lt1 Z??
- what are some indicators of a bad opti?
- Ha another cut out question
- Alternator wire/plug
- Jumping in and out of closed loop, split BLMs, and more fun stuff
- TPS Question
- WANTED - mjcent922
- Knock count and PCM learning
- Poll: 245/50-16's or 255/50-16's?
- Oiling problem
- 302 camaro??
- Longer length valves will result in what?
- What exhaust.. Post all Exhaust Clips here plzz
- I need an EGR solenoid....
- Bigges diameter valves that I can use on 190 LT1 AFR Heads?
- Pound rating for stock springs?
- SS Ram air intake VS Cold air intake
- 97 z rims on a 92 jimmy 4x4 ?
- Exhaust Question. Catback vs Muffler?
- Granatelli? or just port the maf?
- rewiring help!!!!
- Were to buy a 383 short block?
- anyone else have a rattling clutch?
- Fuel Line leaking ?
- I need part Number.......
- speed limiter
- Occasional SES light and code 34
- What do you use to add tranny oil to M6?
- Tried to install headers today and it couldnt have went worse!!!!
- ***urgent*** need help with this clutch please help
- Gtech Pro .... Good or garbage?
- Trans shot
- Edelbrock CHs again
- My plans, what kinda numbers?
- Camshaft Questions
- Need opinions with the "hidden" shift kit
- oil primeing question
- tire size
- 450RWHP LT1... How much?
- Dielectric grease
- T56 w/ problems... fork or syncros?
