View Full Version : LT1 Based Engine Tech
- problems help. NEED INFO.
- LT1FlaGuy(Adam Parsons) call me!!!
- Cam sheet
- Felpro Impala head gasket
- 1.6 r/r installs please help
- Guru's help! Car dies and Chevy clueless???
- How many bolts does a T56 have?
- How to get the motor and tranny out as one!!!! After a crash.
- Next mod??
- o2 sensor
- yet another hurdle how to fix ses code p133?
- New Accel ignition problems.. please help!
- Flush and fill or not?
- Ls1
- Which CAM???
- Help
- Here's a tip for you 96-97 guys with !cags that still have the light
- I was looking for Car Alarms.. this website offered me Corvette rims... WTF?
- attn" anyone about to do a t-top conversion
- Rear End Experts Traction System Help?
- 383 buildup
- Oil dripping from optispark
- BBK throttle body
- Dyno numbers
- New clip Of Exhaust...what u think??
- anyone seen the new ZEX air filter with nitrous injection?
- SES Light.. only when 140+mph
- Ses
- Opti Spark
- wow this is a change from 12mpg
- Water lines that go into the back of the heads. I need a question answered.
- My car sounds like it has a supercharger. Is it my belt?
- two flanges in back of intake manifold, one is EGR and other is what??
- Anyone in the NYC area???
- LT1 wheel well fit?
- can i run 12s now,or am i crazy
- Shoebox my problem is solved, but.....
- Gauge problem?
- squeaky wheels
- Got 32 code, replaced EGR valve, still get the same code?
- abs inop?
- CSI BOOOO! ...This website YEA.....
- People with aftermarket intake elbows question?
- solid motor mounts and poly trans mount, OK??
- Valve spring micrometer.
- 1.6rr???
- Changing my brake pads
- Who has dealt with Supersport Camaro Performance Specialists?
- Please help me! spark plug #1 popped out!
- Can someone check out my Datamaster file?
- anyone know of injector cleaning services
- 1996 M6 w/ 2000+ tremec syncros... will they work?
- LS1 SPEED (SPEED Inc. Shaumburg IL)
- think i may have fixed miss yaa!now need to get rid of surge what causes surging?
- Which tire?
- what is a normal temp readout for an A4 transmission?
- 1997 Firebird Formula Questions
- car won't start; possible fuel pump problem?
- AC Delco Platinum Plugs. yay or nay?
- Pictures of my Combination Motorsports Stage II heads
- Which Crank for 396 build up?
- Will i have to modify my vortech intake elbow for it to fit my fipk?
- Top speed
- Shifting Problems
- Dynatech Headers and Spark Plugs
- Oil pickup screen. Loss of Pressure at High G's
- Could a bad opti cause arcing wires?
- Excessive crankcase pressure ?
- Your oil pressure?
- unibody repair
- comp 305 cam with 600" lift valvesprings
- running the car on friday with nitrous, will it be safe?
- Longtube Install
- radiator replacement
- QTEC electric cutout for borla catback
- how to install 255 Walbro inline fuel pump??
- LS1 Brake Swap?
- experts, PLEASE come on in.. i NEED help
- what do i need to install GMPP 1.6rr's
- alternater
- tires / potenza
- Rear brake replacement? (quick question)
- Help me out!
- TPS error with 224/230?
- Who here has the free ram air mod?
- 94 transmission in a 96??
- Enlightenment please.
- 160 stat now hotter?
- Pontiac headlight problem...
- dash board part #
- gonna look at a 93 for sale tomorrow...
- jet hot longtube questions
- SPA duel gauges
- rounded off header bolt, help!
- Moser 12 bolt questions, free Heavy duty cover?
- Electrical Question!!!
- Did I do right or OVERDO it with mods??
- Best / cheapest relocation brackets
- Critical mistake during timing chain install?
- MSD Wiring Harness, Shoebox?
- White Residue On Spark Plug Tip (l-shaped Tip)?????
- Tranny Question (vettes)
- New product in PHR..."Plasma Booster"
- anyone with a trailer in chicago/ nw indiana
- Milodon Windage tray
- Intake manifold bolt treads
- Just bought a 1994 Z28!
- Trick Flow Elbow Problem... Plz Help!!
- Speedometer going up from revving engine???
- Door locks quit working.
- Difference between 93 and 94+ LT1
- Help! vented opti harness doesnt fit
- 99 LS1 gauges cluster in a 97 LT1?
- Lingenfelter CAI
- G-Load Brace
- Gear question and Help
- Who installed your SFC's?
- hesitation!
- Please HELP my friend, he posted this on the Impala Forum
- What can I fit?
- transmission gurus in here please....
- Fuel pump question
- A few Formula Questions
- body repair
- Is My LT1 Running Right
- Assorted LT1 Problems...
- Y pipe
- 4.10 Gear Swap Vibration Figured out... I think....
- I have no power when i turn the key on
- Annoying people again, LTs vs Gears?
- Failed smog, what to fix?
- Strange 12 bolt (bent axles)
- I got a big problem....
- what mufflers to use with duals
- 1 fog light turned off?
- car smokes after wot!!!!
- Finally got some times
- Will Stock Z06 Wheels fit on 4th-Gen?
- LT1 Head Gasket Replacment Questions....
- electric waterpump on a daily driver? specifically a 383?
- You gotta be ****ting me....stupid cam
- hmm, called jegs, ordered motor mounts they recomend, look on net, looks wrong??
- ATTN: Injuneer, turbo_Z, slopokrodrigez please help
- titanium retainers and 1.6 RR
- How do u get the coil out of its bracket??
- Warning to Long tube users
- Think i may have solved my problem could a intake elbow cause this??
- Weird Ignition Problem
- Coolant leaking from hole in bottom of waterpump. Is it history?
- Sounds like a knock but not sure??
- question about mufflex y-pipe!!
- Killed 2 coils
- can ZO6 parts help us pass emissions?
- changing motor mounts, big job??
- y-pipe for hooker lt's
- Weight of "T-tops"
- get computer scanned?
- Need help Bfg or E/t streets
- Help quiet my car down
- Question about back pressure!
- My TPS reads 100% before it's to the floor?
- Do I really need to mod my tune after head install?
- what year computer???
- Looking for long tube header pics....
- How do u test the cruise control module??
- LT1-Solid Roller conversion
- Lunati Hydraulic Lifters fit, work?
- ABS reluctor and Eaton posi???
- "Swoosh of air" sound from eng. bay when I hit the gas??
- Heater Core
- impala head gaskets: which side up?
- I got my street twin today!!!
- Did TB bypass- need to "burp" my cooling system???
- Injector relay code
- Car takes forever to start!
- lifter/valve lash question
- heating/cooling ducting problems
- THis is total BS, need to get this solved
- vacuum leak causing problems maybe? (hopefully)
- how to change regulator
- How much power would I gain n/a and be giving up on the juice? LSA Related
- TH400 swap questions
- Cracked dash from the sun, fixable??
- Autometer Electric Fuel pressure gauge install question
- How can I get more amps to my window motor?
- 78 RF SOlenoid Open or Short to Battery???What does it mean??
- which oil to use?
- alternator bolt lost, what type/size is it?
- Fuel pump probably dead but a question before replacement
- meaning of cam measurements
- 97ss Cai
- line lock for brakes
- DEBT.....3.73's, Tranny, Vigilante 2800 Stall, PCMFORLESS
- intake sucking air?????
- Hooker Cat Back
- Fuel Cells
- Hot cam questions?
- Underdrive Pullies?
- My opti expierience
- tires
- Brakes/Suspension Rebuild Easy???
- Loud squek
- electronic switch on borla catback exhuast
- gauge hook up
- 2800 midwest stall
- HELP Edelbrock Header Installation
- any other ideas on how to get my #2 plug out with jet hot lt's??
- how hard is it to install a coil?
- MAP sensor?
- air inlet tube
- Safety Switches
- water pump switch
- Question about ignition lock cylinders-M6 vs. A4
- Connectors for a 93 A4
- Z28 or Trans Am
- Anyone with Long Tubes & Starter Heat Sink?
- Getting new tranny and stall
- Thanks to all here that supplied help to me with head install..
- Got it!
- Is Water Wetter worth it?
- where to buy a fuel filter
- What is Max Valve Lift on Stock Heads?
- RR's
- how can i run cooler???
- will the lt4 knock mod work on 93?
- LS1 brake swap problems.
- 236/242 cam wont idle in gear...drill holes in TB plates?
- Stumble, running rich and plugs
- stroker cam question
- LT1 Vs. 5.0 302 Mustang GT
- AS&M or FLP headers???
- gears
- Chassis Mod
- borla or loudmouth
- Which to choose?
- Are the top injector O rings different from the bottoms?
- How do u take out the side mirrors?
- Vibration when accelerating an braking
- Seriously... Do LT1 Heads Suck?
- rear transmision seal questiton
- removing egr?
- Anyone make better cooling fans?
- Code 18??
- Can tire pressure cause alignment pull?
- What spark plugs to use with MSD?
- ls1 rearend swap
- Serious electrical problem with alternator
- Bad Muffler Affecting Starting?
- what do you get when you cross a gn motor with a f body
- service engine light on
