View Full Version : LT1 Based Engine Tech
- ignition switch problems
- changing wheel size?'s
- A/C repair
- how to get ford 9" into 95 camaro?
- Prothane motor mount install
- NEW DYNO #'S (still needs improvement)
- Car still will Not Run
- Car Runs Like %&#@ At WOT
- Factory Alarm Location
- a/c compressor
- LT1 headers in a 3rd gen
- Track times: CC306 and stock heads
- why isnt the performance shift mod working for me?
- 3.42
- Stereo question - please help
- Rebuilt trans + shift it = no reverse and slushy shifts?
- Eaton blower on 4th Gen. Firebird--Step by step
- Excessive tranny noise still....
- Has anyone installed an oil temperature gauge?
- I'm going to buy gears, what are the strongest ones?
- I have a question,....@ what compression ratio does a stock LT1 1994 5.7 L V8 run @?
- do i need a cutout?
- CAI and catback or headers
- Best shocks for Eibach Pro Kit
- How does air foil work?
- HAL/QA1 users!!!
- My buddy's Z needs help on next mod...
- look at these smoking reaction and 60ft times
- Now that the heads are off....
- changing m6 tranny fluid
- Nitrous vs blower vs turbo?
- Shoebox or anyone big problem help
- 60ft ?
- Nitrous Mastermind help
- PCMForless is OK!
- Ignition or fuel probs
- pcm woes
- Lloyd Elliot Heads
- Since I'm doing head gasket I'll go with 1.6 RR, but have valve cover ?
- A4 2 M6 Swap
- Oil reading still way off.
- scan tool for 93
- Need some 700R4 advice....
- ran car for first extended time in 4 months....
- Why is my car slower this year??
- AIR fittings
- POSI/Limited Slip or Lockers
- Shift rpm
- No Stored SES codes? WTF?
- Fuel Problems?
- Tomarrow trans coming out....
- cc305
- true duals or cat back?
- transmission/car done!!!!
- SES code 372 what is it???
- part number
- any gains w/ cam/ no headers??
- Roller Rocker?
- Okay what are ses codes 100 and 372 mean?
- Problems after cam install
- LT1 seems to be choking a little?
- Open headers and o2 sensors
- what all to remove before pulling motor?
- m6 tranny oil change has filter?
- Electric Water pumps...
- Borla + heads/cam + 383 + no cats + LTs? Rice?
- Cranking, not starting. What else could it be besides opti?
- Starting Issues
- what size cutout for a stock 94 z28????
- Please Help!!
- 1:6 rockers
- lt4 km on 93
- Engine running real rough
- Torque Arm install
- Weird fluctuations on oil press gauge. Mobile one oil filter the reason?
- seat belt light
- TDC & Different Head Gasket
- 1LE intake elbow part #
- Pulled intake manifold
- Where to get the Crank Balancer Bolts?
- Weld wheel question
- Moser 12 bolt and Drivershaft..
- Paging Shoebox!!!
- Ive tried everything i can think of...
- ..alternator accesory bracket question,..
- ABS problems. bad connection? Interference?
- Vented Opti Conversion Help ASAP!!!!
- ses code = shift sensor?
- Cleaning Combustion Chamber And More
- Level ten trannies?
- Anyone have Bilstein shocks with stock springs?
- Cammed LT1's?
- Centerline Telstars - longer studs?
- Throttle body bypass on a 94
- CC503 vs CC305
- how to "pop" start an m6 f-body
- Rotors/Pads - Whats good?
- panhard bar adjustments?
- shoebox
- Need some T56 related help
- overheathing with idle at1700rpm help
- HELP me fix my hesitation!!
- RWHP vs Flywheel HP
- Will 17x11's help or hurt me
- What the cheapest way to do good true duals???
- Torque specs for Eagle rods?
- Are stock plugs platinum?
- Weird motor behavior.....
- Does anyone have '93 A4 wiring diagrams?
- ses what code??
- Desktop Dyno LT1 file
- What are unported stock LT1 heads worth ?
- Titanium Retainers or Steel?
- Driver's window problem
- Bad hesitation problem
- went to get my new clutch installed and it died out on the way there
- Lost 28+ hp through stock cat-back, not good, what do I need?
- What is hypoy c gear oil?
- c5 vette seats
- Where to buy ring filing tool?
- What are signs of a bad torque converter?
- Does anyone know where the factory tach runs off of?
- A/C vents broken, how do I get inside?
- besides fasttrackperformance.com, where do i get...?
- Square or Tubular SFC's. Any real Difference?
- Shoebox, A TPS question
- LCA Relocation Brackets worth it without lowering?
- 94Z28 won't flash any codes???
- Fuel pump pressure
- Rod Selection
- would i get a code?
- Almost there.
- changed plugs
- RPM Idle Down Issue
- steering problem???
- For anyone whos HVAC fan slows down when accelerating
- Stock Tailpipe Size
- Some questions you could answer...
- Performance problems
- Need info on this off road pipe....
- noisy tranny
- Optispark and Spark Plug wiring
- lt1 to lt4 or 383?
- crazy tb idea????????
- posted hear because you are the smartest of all
- Optispark wiring
- 93-96 rear caliper bracket?
- Where to buy walbro255 in tank fuel pump?
- Question for all with outboard pump & sumped tank-
- How hard should it be to turn an engine out of the car?
- Biggest Cam and Still pass Emissions (ODBII)
- Opinion on this setup pls..
- Another cheer for MadZ28.com!!!!
- Step on it=hesitation?HELP!
- cutout or cat back exhaust system?
- AHH $800 for LT header,y-pipe
- need help in dismantle
- header question
- what gears do i have....
- Trouble Starting
- Any guides to removing bumper supports..
- 12 bolt and stock ds..pic inside..enough slack?
- Relocation brackets with 12 bolt?
- pple w/200amp alt. from beavco(ebay)
- loose hose
- Where to buy EGR blockoff plate?
- Weird noise
- a small leak at the head gasket.
- keyless entry
- Intake Manifold Gasket that covers everything?
- What is this connector under the console? shoebox?
- Drilling out the IAC passage in the TB?
- help/suggestions for 383 nitrous bottom end.
- Quick Corsa exhaust question
- Rear End Clunks After Changing Pinion Seal
- Difference between X-Pipe, H-Pipe, and Y-Pipe?
- Length of wire for fan switch.
- Help!!!!!!
- need help quick!!
- Ported intake question?
- Time for new tires! Need Suggestions.
- Best place to purchase SLP Headers
- quick question?
- PLEASE HELP Car takes long time to start and hesitates at low rpms.
- opti spark, installed 2 BRAND NEW GM units in 4 days!!! READ!
- LS1 in a LT1 car
- just mufflers or whole exhaust system..?
- Next Mod?
- Plug Wires
- Exhaust: Just mufflers or whole exhaust...?
- 1.5 to 1.6 rockers worth doing on 93z?
- Ok, let's have an oil filter discussion...
- Gear swap questions...
- Problem-- Read inside.
- changing the coolant
- Worth it to port match intake manifold?
- Part # for SVO 36# injectors.
- shakey idle
- Q-tec Question
- STUDS... wheel studs I mean.
- Weird Vibration after 12 bolt install.
- Tranny Cooling Lines
- Lakewood lower control arm bushings
- 383 top end job
- No power gained after cam install!
- 01 WS6 springs fit on 96 TA?
- computer or wiring problem?
- When to upgrade 24# injectors?
- car running like crap need help
- BEST guide for INTAKE LEAK FIX.....
- HAL QA1 front shocks/V6 springs??
- what could cause the speedo to run 5 mph slow?
- Relocating LT collectors to gain ground clearence?
- oil pressure @ 20psi at idle??
- custom doors
- Replacing Rotors
- Edelbrock exhaust ?
- Possible BIG problem...
- issues with fan switch mod
- Thinking seriously of A4 to M6 swap. Anything I should be prepeared for?
- High tranny temp?
- steering column
- Car Died, Need Help
- FelPro intake manifold gasket part #
- Car did a very strange thing today
- out of box AFR 190 dyno #'s
- Stripped Crank Snout Threads???
- tick tick tick under the hood,...what gives?
- smoked my clutch at the track, please help
- Magnaflow is quieter than flowmaster right?
- 354 LT1 Dyno video
- Best place to get Nitto NT 555's?
- LT-1 lifter bore size
- which tires
- Need Enlightment!! IAT Sensor Help!
- Need reccomendation for switch panel
- To all the have installed mac headers>>
- LTs or shorties?
- Can we adjust LT1 clutches?
- can I soak injectors in anything to clean them when out of car
- Speedometer and Tach problems
- What temp does fan come on
- throttle body and injectors?
- Info on CC306 Cam?
- Help Me Please, Headers!!!!!!!
- Adjustable shock settings for drag racing.
- Another Header ?
- why do lt1's sound so much crapper than a old v8?
- any words of advice?
- O2 Sensor Part #'s?
