View Full Version : LT1 Based Engine Tech
- Those with DMS springs inside please
- hooker long tubes??
- Leaking SLP shorties
- Bump stops?
- Quick! My bellhousing wont detach from my block (T56)
- Got Vigilante, Stall question
- is it necessary ......
- Spark plug gapping???
- WHAT REAR GEAR DOES MY CAR HAVE
- URGENT is it okay to put the DEX cool in my car??
- Hooker sortie header owners inside
- what should i expect from 3.73's
- Does anyone else have problems with thier...........
- Which stall to get?
- Cam question
- Valve cover questions...
- Cam gear runout and wobble?
- The Bunny is about to die!
- Help
- More than a few questions inside..
- ??? for FLP Owners
- How does the PCM determine WOT?
- Rear Brakes
- Fastest N/A LT1 in a 4th gen?
- Comparable plug to the TR55?
- Quick Coil Replacement Q
- will LS1 eibachs work on a LT1???
- O2 Voltage
- question about getting the air and egr programmed out??
- Quick one, weight of tire, tire & rim, stock 16" salad shooter
- Big cam guys with stock lifters?
- what could cause low idile???
- How much for custom Y-Pipe?
- Best header bolts
- dead spot on starter
- Is it OK to use sandpaper on a flywheel?
- Bolt size on tranny inspection shield? Rob?
- LS1 Brakes
- How long do you go before you wash your K&N filter?
- 3.73's or TC?
- auto to manual swap
- High idle
- Wet or Dry?
- EGR and AIR
- are 1993 computers similar to previous computers?
- Hesitation patch.. EGR easy to clean?
- is the code stored if ses came on then went off?
- lug pattern on 95 z28?
- Quick question about changing coolent?
- Trans wont shift into 3 or 4, sometimes it does. HELP
- Going to the track
- Question about the LT4 conversion kit.
- No start, no spark.... im buying module today.
- For those who bypassed stock trans cooler
- How much will be ET improve going from 2.73s to 3.42s?
- Best plug wires and easiest way to change?
- MagnaCore wires? Where?
- Best bang for buck CAI ???
- LT1 ported heads, with LT4 hotcam kit and summit forged kit --> 400HP N/A??
- Why TB bypass and EGR block off?
- 97 Y-Pipe Removal
- Real LT1 SS owners inside
- Default KR settings?....Injuneer?
- Wiring Schematic Needed
- New Here
- Aftermarket Valve Seal question...
- offroad y-pipe for 96-97?
- XE 230/236 and LT4 Heads
- can this happen?
- Rear end not centered?
- Woo hoo! I think I found my Problem!
- Who's running a custom cam in their 350?
- Too big for CA smog?
- A/C Compressor (I've Searched)
- How to make sure your rear isn't bent (without driving it)
- Starter Failure?
- intake gasket or rear main?
- adjusting valves
- How to measure pinion angle?
- Best tires for stock tire size?
- Torque Converter
- Next mod?
- Waterpump rigging...
- charger all done!
- How to fix certain things on my car
- Has anyone removed the solenoids from pass side of intake?
- How good are you? Tell me what this sound is coming from...
- oil change
- McCord Cutout
- headlight hostility
- steam pocket in the block
- Hooker LT question
- Where to get C4 valve covers for our LT1's??
- cc306 and 3.42's???
- Help with disc brake install
- speedo correction?!?
- Name that driveline noise
- Exhaust Gas Temps - This is What I Did
- Cutting hole in Ram Air hood?
- rear view mirror
- Side door panel guard things!!
- ABS light... help
- Unbelievable! LT1 owners inside.
- Questions about 3-4 upshift module?
- Could I do a Cam and parts for the same price as a $600 n20 kit??
- Need Help with high rpm Miss
- Question about coolant crossover tube
- Front turn signal/marker acting funny?
- Accel 300+ & Timing Retard Problem
- Does it hurt to run w/ just manifolds?
- intake elbow
- Qeust on water pump and thermostat
- tell me what this is??
- exhaust rattle
- question about posi-traction
- brake bleeding question
- ? Re. Torque Arm Bushing
- Would I benifit from computer tuning?
- Opti Woes Theory
- $400 bucks, what to do?
- Lt 4
- Clutch Fluid Reservoir Question
- PowerMax 2050
- PLEASE HELP, problem with g-friends car
- Do you have weatherstripping all the way around your rear glass?
- Manual Fan Switch problem.
- Need emissions/programming help BADLY
- Do all LT1's have the same smog pump?
- oil light sensor
- K&N VS Cool Blue
- CLUTCH INSTALL PRICE... this good?
- Stock MAF
- Trans cooler question
- On the fuel rails, which connector is for the feed line and which is the return line
- engine seals
- LTCC user, a question on spark wires.
- Best short throw shifter?
- Is there any way to remove the traction control box, but retain ABS?
- Hypertech Thermostat
- Jumping on the dyno. Any last minute tips?
- Few ??? about LT1's??
- True duals with Flowmaster race mufflers?
- Trans temp gauge...Pressure port??
- Kennedy's Dynotune - Buffalo, NY
- Door Window Trim
- Changing rear gear... Please Answer These Q's
- Is this ok on a new clutch?
- noisy power steering pump anyone tried Seafoam TransTune?
- Forced Induction
- Cracking
- Troubleshooting the Great Low RPM stumble
- Anyone else's oil drain plug leak?
- looking for a suspension package. where?
- Pilot Bushing Part #
- So I switched to synthetic oil and...
- $10 to whoever figures this out.......T56 probs
- how to check cracks on the heads??
- How to hollow out the cat?
- to go w/ TransGo or something else...or nothin at all
- Posi breakaway torque?
- Back from track
- How does the PCM sense the AIR?
- MAC dual CAT
- race gas?
- jet hot lt headers
- Header Suggestions Please
- Exhaust clips
- Jet Hot / Hooker Long Tubes owners.
- LT1 scanmaster
- Another oil leak question...
- clutch pedal problems
- Exciter wire from alternator HELP PLEASE
- How common is intake oil leak?
- !! overheating !!
- wire arcing to header
- top end stumble
- car idiles at 400 wtf?
- Replacement Clutch
- Swapping to OBD-ll because of stall , what is needed??
- What kind of rotating assem for 1000hp
- CC305 question
- Why is my off road pipe too short...!!??
- ASR and Alarm
- Changed chip, now exhaust leak???
- Winter project? Need ideas!
- A/C not coming on, LP switch or PCM?
- HELP! Jet Hot install problems...
- What is all needed to go !air
- Put the 93Z on scanner, need some info
- OBD I Palm scan...
- Why does my car sound like it's MISSING??
- ? tuner cat
- Where can I get a Dash Pad without paying big bucks??
- Why is my car sound like it's Missing???
- now what?
- reverse cooled radiator?
- sparks and smoke after intake leak fix
- Coolant Fan Mod
- Car is starving for fuel ... Help ASAP
- i need a part # for the tension pulley...
- set my valves almost every way and still make noise!!!!!
- clutches
- Crank Pulley Wobbling bad!
- Why the hell is my 95 Z28 Vert an OBD 2 ?
- What to do with my extra money?
- i need a little more detailed info on the egr and air delete for 96 z
- ? about deleting charcoal canister
- Quick question
- what the hell???
- Auburn Posi vs. Zexel-Torsen posi
- !AIR people, what did you use to plug the hole in the intake?
- s10 or 3rd gen wheels on 4th gen
- Driveshaft length
- purple wire
- WTF is up with this??
- Maiden voyage after heads and LT install
- random tecnology y-pipe for dual cat cars??
- I need a starting/charging wiring diagram...shoebox?
- Are pushrods down when cylinder is at tdc?
- installed headers and car dies??????????
- 383 price
- Temperature Rising
- Freaky "stuff"!!!!! (edited by moderator)
- Need help guys..engine is screwed up..diagnosis?? big problem..
- Car Is Driving Me Crazy
- Ignition fuse keeps blowing!
- Cruise Control Removal on a '97
- Just bought a Z-28 and have a couple questions
- Just dyno'd the car with GTP's & Hot Cam
- Line Lock question.
- what clutch to get?
- Useable HP and TQ for the street
- Bad feul problem please help
- Can I Remove All Retard & Live???
- Install ? elect water pump
- about the ex 224/230
- Need radiator hose(s) part numbers...
- Can someone quickly confirm that...
- timing gears?
- Help choosing next mod...
- Can the differental be rebuit??
- Nasty oil leak, rear main or dipstick tube possibly?
- Howling Noise??
- part # for switch blank. ex:fog light switch
- Walbro making noise
- LS! MAF on an LT1?
- I think my PCM is messed up can I use my friends pcm on my car?
- Dumb question about 4th gens and clutches and where they grab...adjusting?
- check gauge light
- Misfire/Won't go after 4k-4.5k rpm in '93 LT1...knock retard? what else can it be?
