View Full Version : LT1 Based Engine Tech
- Quick Easy Question
- Infamous Surge/sputter
- Schrader valve on A/C leaking...possible to tighten?
- is there a gasket for the TAIL LIGHTS??? Shoebox???
- Horsepower estimate
- How come nobody sells stock LT1 crate engines?
- how many people own 93 z28
- Why did my cam gear eat itself?
- Can you drop a stock LS1 into a 1993?
- Need new clutch, what should i get?
- Oil pressure fluctuation at WOT! help
- Does anybody know a good shop in southern IL?
- How Do I Do a Compression Check?
- header install
- Does J. Cromier (sp) still offer parts? I need a valvetrain kit
- A/C Delete/ Heater Only Question!
- New here, need some help!
- No Cats
- Why so many spinning bearings with new cams?
- Spec Stage II + N2O + ET Streets - will it hold?
- Where should my friend be shifting at? (Dyno sheet)
- E-brake cable hitting DS yoke in rear. Anyone have this before?
- Zero Gas Milage
- Hybrid fuel system
- People with SLP headers and stock y-pipe inside please
- 230/236 cam gas mileage info
- Wheel hop bad
- Lower Gears = Higher Top Speed?!?!
- Lowering question
- How hard is installing new injectors?
- goofy problem with fans drawing too much juice...
- Th400 Help!
- Can bad opti cause really bad low end hesitation?
- Good Deal?
- Quick Brake install ?
- Mods to beat almost stock LS1's
- What are some good settings to play with in TUNERCAT ?
- My car got flooded out.
- Just Curious, which rear gears does my car have?
- Video clips after the headers
- will a high stall torque converter help me besides just from a stop??
- Speedometer acting funny?
- running too rich?
- asr
- Rocker Part Number
- new gears?
- Catalytic converter code 0420
- gears on a 93
- Adverse effects of removing tunnel brace?
- goodyear f1 gs-d3 tires, any comments?
- Monroe Sensa trac
- 93Z Speedo/ High RPM Problem
- tb bypass on a 93 z
- 4L60E Question?
- Wierd horn issues
- Cam Swap
- Strange vibration
- Welding the car
- Who has done true duals with cats ?
- 1994 Tru 1996
- Did I lose power with my off road pipe ?
- Track problems, please help?
- big problem need help!
- shift light ???
- What combo are people runnin to get 12.0s
- The Ultimate Question......
- BIG idling problem...
- what mods should I get?
- Installed Gale Banks cat-back....i love it!
- Code 61 A/C Performance ????
- guys with cams on stock bottom end....in here
- Taylor OVC and SLP shorties
- bad idle, tried to fix, now need help
- Cheapest place to get Mac headers for a 93 LT1?
- Would a LT install be easier with the tranny out?
- This is my 3rd post on this subject (really need help!)
- Capabilities of stock block with forged internals
- has anyone gained power going form FLP Ypipe to true duals?
- 3000 vig. should I get a custome tune?
- What exactly is the purpose of traction control button?
- Is this a decent cam, Compucam 210/224?
- Humming noise from rear of 6 spd
- Auto drivetrain loss not as bad as people say
- opti from autozone $165,... not a good idea???
- SS Ram Air vs. Aftmkt CAI
- need some pricing help here
- 4l60e question
- Stock bottom end @ 6500RPM?
- anyone want longtubes?
- LT1 Swap
- Breaking up is hard to do
- so longtubes are a pain???
- Msd digi 6 went dead???
- Plugs and wires, whats best?
- Timing chain for cam install?
- Anyone running Total Engine Airflow heads?
- SLP 2OTL catback and "cone of silence"
- possible misfire
- will this get me 20 rwhp??
- Scorpion rocker arms, ever heard of them?
- Turbo Kits
- How important is an AFPR???
- Tuning a 93 LT1
- whats up with my SLP dual-cat shorties?
- I need a part # for.......
- Lt-1 vs. LT-4
- Dyno #s - Where is my bottleneck?
- M6 tranny fliud.......synthetic????
- what is the best cam
- adjusting speedo?
- wires and abs?
- Losing Fuel pressure while sitting parked
- car missing....
- A few pics of some new stuff
- MSD Retard box WTF!! ADVANCED!!!
- 97 and 01 M6 shift boot ?
- New plugs, wires, opti, coil, ICM and still a hesitation when cold at low rpms??
- lock-up or non lock-up converter??
- stuffing a 96 LT-1 in a 89 camaro
- what rearend gear?
- Help! Can't Pull LT4 Timing Set! No Slack!
- My car feels a bit sluggish... will gears do it?
- '95 fuel lines diagram.
- anyone seen a yellow ta better than this?
- MAFT...yes or no??
- So Cal Wideband Dyno?
- Trans Question
- What kind of numbers are people getting with this combo
- leaking trans HELP
- loudmouth or flowmaster
- Just got some money! What do I do? haha
- pilot bushing???
- Fuel pressure = zero psi?
- Traction Control on 97 ws6
- Question about timing chain!
- BIG problem filing rings!
- Over-heating now, no fluid or noise...
- Lunati, Cloyes, or Edelbrock?
- windows rolling!
- Any problem with bigger injectors...
- Reverse gear continued....
- mod performance links
- Need help fast! TH700R4 related
- need power window motor help - stumped
- did tb bypass and homeade cai
- Its Sunday - Power window switch dies.
- Cheapest price on opti
- Distance between ground and quarter panel
- R&R Battery - now chime sounds & car won't start
- LPE cam...How good is it?
- Ahh going crazy, what could this ticking noise be??
- hypertech?
- which Honda ATF do I need for M6 dealer says type for auto or for manual trans
- changed head gasket.. now I have low oil pressure, groaning, stalling, etc.. wth?
- O2's good or bad???
- Car turns over but doesn't start...
- Might be saying good bye to LT1 for LS1 or 6 if I hold out a little longer.
- Help just got Dyno results, not good!
- New LM and the law...
- Header gasket fix?
- Parking brake not releasing
- SLP takeoff shocks - questions within...
- Question on changing heads, power gained?
- Any Suggestions to Fix High Rpm Miss??
- How much does it cost to get a rear end narrowed?
- what is my car worth
- Rear Brakes Question
- im about to put some $ into my car whats best time improver i should go with?
- How to store an A/C Compressor?
- need help with shifter
- I need some help guys.
- Do flywheel bolts use washers? Quickly :)
- OIL PRESSURE SENDING UNIT--94Z-which one?
- Autozone Opti?
- No sealant on head bolts among other things...
- no compression
- last minute header question
- Hypertech power pulley coming off,is it the only one?
- Cleaning under the hood
- How to remove the IAC?
- Part # for headlight and brake light.
- Identify this part!
- Slotted rotors
- firebird trouble
- where to find....
- Headers
- Moser 12 bolt owners PLEASE HELP, check out this pic....
- Damn Brakes...ANyone else stumped on a Low to almost NO pedal?
- Knock retard...Real or not how to tell.
- Lt4 conv., Speed Inc. dyno #'s
- TB bypass? Good or bad?
- Stock LT1
- those w/ jet hot lts what y-pipe did you use?
- Who turned out the lights??????????
- 3200-3400 stahl too much for LT1???
- Voltage drop
- 550 hp on 383
- LT1 rebuild options since motor will be out...
- LT1 Guru's inside ... Need Help ASAP
- Well I think I found the problem inside my tranny *pics*
- What brand tires are you guys running?
- How much for this TA
- Page For Shoebox
- Is it possible to find out the stahl of a converter before it's installed?
- Please help with BAD low end hesitation w. new engine
- Rethinking cam selection..........any advice?
- noticable diff between modded exhaust & cutout?
- Please..Help me decide...100shot or CC306??? *POLL*
- how much would an average LT1 go for?
- installing a shift light in a '93
- durability: LT1 vs LS1
- check guages light has issues!!
- What Y-pipe and gaskets to use with Jet Hot LT's???
- Using tq to yeild head bolts have a ?'s
- emmision and o2 question
- Not turning over
- Got a new ignition box, and I think I've found the best bang for the buck box
- o2 sims '95
- what are the best swap in gears?
- idle in drive is horrible!!! The IAC steps count shoot up to 140's
- Thanks for the help guys!!
- LT4 Cam swap
- Hooker LT's or Jet Hot LT's???
- Degreeing the Cam
- Autozone Wires?
- Changing O2 Sensors
- just bought exhaust system
- Quick A/F Question
- WS6 "smooth bellows" scam on eBay
- which radiator hose is this....?
- what kind of headers?
- big stall ~ little gears
- Need cam (new to camaro's)
- Went to track, couldnt be more pissed off
- stumble solved?
- which heads are the best?
- Coolant Light is on for no reason!
- BMR Trak-Pak
- Smog Pass
- Spark plug change.....try this
- new pilot bushing looks different than old one, is this normal?
- Running W/ No muffler..will it gain HP??
- Standstill...How bad for brakes?
- M6's w/4:10's...
- Any stand alone shift lights?
- posible misfire????
- What the heck is this???
- I want to run 13's What will it take? not to much blow...
- O2 Sensor Question....
- Car Dieing Problem. Random....
