View Full Version : LT1 Based Engine Tech
- Tired of this coolant smell, especially since I can pinpoint when I'll smell it
- clutch for high power lt1
- Snapring tool for T56?
- Few questions about pcmforless???
- "DeCarbon Take-Off Shocks" are these any good? better then stock?
- think my car is running bad, but i beat a sc cobra
- Can I swap lifters with the heads still on?
- high performance o2 sensors
- Is My Timing Off?
- LT4 hotcam kit installed by dealer?
- Can a 3rd gen rear fit a 4th gen?
- Firebird trouble 2
- Any of you got this problem?
- How do you change a throttle cable on a 94Z?
- Dependable parts, reasonable prices
- WTF!!! Fel-Pro oil pan gasket Is retarded and im pissed off *PICS*
- plug wires touching?
- Idle surge
- Exhaust Comparo
- Headers are going on, what should i know?
- Safe MPH downshifts for each gear?
- How to get the A4 shifter knob off?
- How much can a 2bolt block handle?
- a4 to th350
- EGR valve, need pic and help, SHOEBOX pic please????
- Wheel Bearing's.....WTF??????????
- Down shifting
- What are the best shift kit and headers??
- *Update* Hard Starting Problems
- LT parts list... again.
- who can get new 93-97 oem fog lights for $27????
- MSD Ignition
- When do you need to upgrade your fuel sytem??
- coolant light STAYS ON help any1
- o2 sensors, where to buy??
- Tall Centerbolt Valve Covers for LT1?
- How to host video
- Need Help With TH350 install
- What should I expect?
- SES related with MAF sensor, please help.
- people with Ball joint failures??
- 12:1 compression....
- Help ASAP
- cc305 with hotcam springs?
- Will this work?
- 93' Z-28 Help?!?!?!
- RPMs with 3.42s on 4l60E and stock height tires
- Cam/Stall Question
- negative effects of bypassing heater core...
- Who Has Had Problems With 6 Speed?
- Blown head gasket and on a budget.
- Inflateable Lumbar leaks
- need exhaust clips of LT and 3" exhaust
- aftermarket lower a arm weight?
- Bad water pump take out the OPTI?
- Where do I start?
- Can someone help me decide on an exhaust combo?
- Do cammed Lt1's have any engine longevity problems?
- RIP, my camaro
- Can exhaust leaks cause a low end hesitation???
- The shop says it's a bad lifter..... that sound right????
- just ordered stall but haveing second thoughts.
- What's the absolute best way to flush coolant??? HELP???
- Which TC??
- computer question
- As the world turns...
- What should i do to my car ...
- What size stall?
- Rough Idle
- Sold the 5.0, bought an LT1, Q's!
- Why????/ AC Comp
- my track times: WTF
- Teach me some basics of Cam #'s and selection ...
- What type of oil do I use for my A/C????
- Where to get an LT4 Knock Module?
- A/C Delete Pulley?
- 97 Stock SS Specs?
- anyone know how to take the drivers side window out?
- Driveshafts
- Pacesetter Headers
- XE 224/230 guys... where are you shifting at?
- Opened up the Opti Spark
- gears
- Anyone Using Hays Clutch?
- How loud should a Comp Pro Magnum valvetrain be?
- what valves to run with a supercharger.
- car lurches when speedo hits 115...
- Dual/single Cat Headers
- What Motor Is This
- which stall is better?
- Can I tell the difference between lt1 and lt4 heads by look?
- Removing 3-4 shift fork...
- best fowing heads
- msd 6
- Jet Stage 1
- How to remove front seat belts?
- 2.73 vs. 3.23
- twin disc need spec
- what should i get my boyfriend
- Rear Main Seal
- I just opened the gates to hell
- i need a part number...shoebox?
- Switched from 2.73 to 3.73 A4! Question
- ? about hood pins
- stud girdle
- Need ideas for cousin's LT1
- Do Street Twins wear out?
- Buying a '95 Trans Am
- burnt valves
- what's needed for clutch job
- Hotcam VS CC304
- Is 3500 too much stall
- more lt4 conversion questions
- Overheating problem
- Where can i get scanning software?
- street twin FW balanced??
- Where to place O2 sensors?
- What is the best cam for a daily driver??
- over filled trans, what do i do?
- How do I
- best deal for parts...o2 sensor, etc.
- LT's effect lowered cars???
- fan mod
- How do you port a TB?
- OPTISPARK??? Whats the symtoms
- misfires and some knock
- 230/242 problems???
- Jet Hot LTs and O2 Extensions???
- Cheapest place for a Throwout Bearing?
- Poltergeist Car
- gm t56......
- guys with duals, what mufflers are you using
- another EGR question
- 95 Z, 2 series or 3 series???
- Having A Hard Time Starting
- anyone have problems with A/C??????
- Are there any visible signs of a bad opti??
- Serious Engine Problem
- Best clutch -nonSpec
- How much vaccum should i have after cc305 install?
- T56 Clutch Disc
- Hey guys, I just bought an LT1...
- HELP ME! its gonna rain soon... (pictures inside)
- Street or Drag Radials?
- torque specs on valve covers bolts
- Which set up flows better ...
- 3.42
- Backlighting aftermarket gauges...
- Quaker state high performance oil any good?
- Delco tape deck losing pitch?
- What year lt1 should I look for?
- Shoebox I need your help with vats again
- Stock '95 Z28, what should they run in the 1/4?
- Diff between ASP and March pullies ?
- PLEASE HELP car keeps turning off
- Am I getting Raped?
- Crate or Rebuild????
- ls1 motorsports can suck it
- hot cam dowel
- URGENT!!! Pistons and Lift
- copper intake gaskets
- Couple T56 questions...
- how would i do this??
- Exhaust component discussion..
- recommended rear fluid?
- is my engine running too cold after 160stat?
- removing stock exhaust manifolds
- How's the SPEC 6 puck stage 3 holdup?
- SFC's...Kenny Brown or SLP???
- Clutch Compatibility
- 2800 stall and 3.73s on stock LT1...
- Book time for this?
- pinging problem between 1k-2krpm under load
- airplane spoiler
- To all on here : Thank You (MY car is now a beasat thanks ALL your help)
- I think I may have figured out my extreme tranny noise, please help
- combination motorsports springs...
- Exhaust and Headers help...ASAP
- Ignition swap
- OBD code 26
- T-56 Swap
- Getting clutch info straight...
- In car wideband, any of them good?
- Zr28
- Wire routing
- LS1 air intake on LT1?
- 95' Y pipe in a 97?
- Trans-go install problem, please help.
- How to install opti???
- Power (underdrive) Pulley question.
- Do NO stores carry the pulley I need or what??
- Lighting Problem ...
- Nitrous-Hall A$$ or Horror Story!!!
- M6 Rebuild questions for those who Upgraded
- Volts from Alt? Original from my '94..
- Weird cruise control problem
- cam change question..
- F body experts needed on questions?
- Ever read this?
- Help with car. Help me figure out my problem.
- How long is your hooker catback lasting?
- Does GM have a 1 year warranty on ALL parts including the performance parts?
- Mobil One made my car leak oil...
- eibach vs. slp springs
- 94 Z Blowing 15amp courtesy fuse
- What different on a 94 as opposed to other lt1s?
- e-brake handle flies up
- Suspension to make my car hook up?
- low oil indicator sending unit, can it be deleted
- M6
- dependability of STRANGE 12 bolt and mcleod clutch?
- clunk
- electrical problem?
- 400+ CI LS1s are everywhere why are there no big inch LT1s
- best place online to buy shocks for my new eibach set-up?
- Brake fitting sizes..............?
- MPH @ 5800 rpm with 3.73s?
- need torque specs for header flange to y-pipe
- springs
- How to bypass Neutral Safter Switch?
- Difference between long and short block
- LT1 Edit worth it?
- ball and socket exhaust
- water on air filter
- Different type of O2 sensor needed w/ my setup??
- How much RWHP?
- Everyone take a look I need it (esp. pros)
- Is it possible for a clogged fuel filter to make you run lean?
- annoying whistle??
- Physical difference between SA and NSA rocker arms
- How fast does Jason Cromer reply
- Have clutch question
- Headers for a 97 formula???
- I need help pease I am on my last leg!!
- Surge/Stumble Part 2
- mobile 1 vs. redline
- Harmonic Balancer removal...HELP!!
- Offroad Y Pipe
- need help please
- Strange 12-bolt
- Harder install clutch or headers
- supercharged
- street twin in, observations/concerns..
- Those of you who have gone from mildly blown to n/a
- o2 problem?
- What do you think i should do? (f'd up rebuild)
- I dont understand this light....Water pump install Schematic question
- Where To Buy CSI Water Pump
- How much of a difference can an opti make b/c the shop says....
- starts and then dies
