View Full Version : LT1 Based Engine Tech
- $650 for the Fuel Pump?!
- 95 single cat exhaust for my 96??
- How much suspension travel???
- CC306 w/ stock LT1 heads
- Wipers won't shut off
- how do you adjust speedo?
- Two wacky questions!!
- Pulling Harmonic Balancer, Neep a bit of help!
- a4+3.23's guys in here
- Engine Temperature???
- LT4 knock modules, what year are they from?
- Mallory 685 ignition box
- AC blowing warm air??
- Power Window Switch
- Passkey problems
- Which set-up would be louder?
- pcv valve
- my blinker is borked...
- Safe RPM levels
- Doesn't run will in the rain
- Getting drilled rotors turned
- Tranny Help!
- Burning Rubber Smell???
- HELP! Are these lifters collapsed?
- 95 z no spark
- 5.7 to 6.0 rod
- o2 sensors
- knock module
- Torque specs for flywheel, tranny, etc.
- Vacuum Diagram
- Bad Injector ? What do you think
- Par for the course.
- Hot Cam + Hypertech = ????
- looking for some advice only
- Will an alternator from a '95 TA fit my '96 Formula?
- Patman, or anyone that knows about oil and filters
- SC cam without the sc
- Heads & Cam
- Electric Cut Out with borla exhaust?
- Tranny tech
- Does anyone run 4:56's
- Anyone ever had to add fuel to their car to get the right mixture going?
- Help with Heads????
- 1996 LT4 Hotcam programming and codes....
- SS intake setup and OVTC wires?!?!?!
- s-10 or corvette TC's
- problem keeping the k&n cai filter on
- Lowered my 95 TA and now cat hits HARD
- dynaspark
- steering problems
- installing hooker long tubes
- Hot cam kit rocker arms??
- Getting 2 codes, think it might be O2?
- A4 tranny feels like it is double clutching?
- Should we have springs mounts on the rear spring? Lower and upper?????
- FRED OR ANYBODY THAT KNOWS... how do you remove the ram air rain baffles????
- check guages light has been fixed!!
- Track times: XE cams vs. Hotcam, CC305,CC306
- Cat trick?
- 402 Stroker
- Loudmouth Guys Step In Please
- Advice and knowledge needed!
- Squealing noise... tranny or engine?
- th350 swap
- Clutch???
- nine inch bearings.
- Backfire
- Carbureted LT1
- Kinda skeptical about getting a torque converter...
- sputtering feeling on acceleration...sticky TB blades?
- electrical problem
- will a b body oil pan work on a f body?
- So I burnt 2 Taylor Sprio Pro plug wires... what should I replace them with?
- Impala head gaskets?
- What happens when I unplug the O2s?
- GMMG catback with Longtubes or even stock manifolds people inside.......any vids?
- 4.10 too high for street use?
- moroso mufflers
- 3.42s in a a4.... worth it or not.
- Why isnt there an T56/tranny tech section?
- Headers or Gears first?
- Egr
- Anyone else have a SERIOUS vibration after installing a star spec clutch?
- In the middle of clutch install! torque spec?
- BAD Brakes
- Who here has removed EGR/AIR w/ stock manifolds
- All you guys with headers...Where'd you buy um
- Odometer problem
- Vibrations
- Question
- How or what to use to clean top of pistons?
- new track numbers, good??
- Update on motor
- quick auto trans. removal question
- Ground-control to Major Tom! Come in, Tom!
- Reprogramming Remotes......
- broke motor mount bolt
- How do you clean the carbon build up off a intake??
- A note about aluminum flywheels and balancing!!!
- stock sound systerm
- A/C Removal questions
- Can headers cause hesitation??
- Where to start working on my LT1
- Rear end recipe
- LT1 oil cap for Vette VCs?
- Changed Water Pump now overheats
- should I start this engine??
- Will mail order tune give me HP? (PCM4Less, MadZ28)
- Anyone have an oil leak through the crank position sensor bolt?
- How Loud Should my roller rockers be?
- Highest HP with stock cam
- What fuel pump to buy.
- So I'm on the phone with AFR about heads ...
- Will this T/O Bearing work?
- Thinking about some exhaust work, but I need advice on this one.
- Can the bearing go bad in the opti?
- keyless entry question
- How to get into 12's
- water damage to z28
- Jason Cromer's contact info?
- Trouble Code #26 What is it???
- ??? about o2 readings...
- question about fuel injectors????
- specialty tools required
- new o2s car runs horrible, need a AFPR?
- oil pan during cam install
- Need an LT1edit file ASAP!!!
- Low Vaccum! What is the cause?
- How to check the bottom end?
- Which headers to get?
- R LT 1 heads from a Corvette interchangeable with Z28 LT 1 heads?
- Window Motor replacement.. HELP!!!!
- what series carrier do have
- Need help with Gears, Clunking, damage, install
- Will 3000 vig.,new 3.42's,and LT's satisfy me for awhile?
- Cali-Legal Cats...
- LT1 Performance Sites
- 410's good in an lt1 m6???
- Raise my stall higher? Or install gears?
- What kinda numbers?
- 224/230 and converter (Help me please)
- Water Temp gauge probs
- Polished Vortech elbows
- Cooling fan
- symptoms of a bad pcv valve
- quick please
- best price on an alternator?
- Hot Cam Kit.......dumb question.
- Stainless Works Y Pipe Without Cats
- Where to get Series 3 Carrier?
- Had Goodyear Eagle F1 GS-D3's put on....WOW!
- cut out guys-where did you place yours?
- optispark vacuum leak
- how do i get better gears?
- Losing coolant slowly...
- if htere was only 1 mod u were giong to do what would it be
- When do you actually need a larger throttle body
- Droping oil pan 1 inch with trans in
- whats the difference?
- Hoods, weight of stock and aftermarket
- How do I know if my opti. is gone?
- Help Rear-end Noise (clunk Not Whine)
- replacing AIR metal pipes with rubber hose
- Just called the chevy dealership...
- 3 channel vs. 4 channel ABS
- Tranny Q?
- LT1 "refresh process",..
- Rearend noise? Is this bad?
- Full CAI install
- Stock LT1 valve sizes?
- gm fast burn heads
- Removing Shifter And Console
- Security Light + No Start????
- someone please help...
- what is the best tire for traction and so on and price
- 12 bolt vs 9"
- Casting Numbers for LT4 HEADS?
- A/C vacuum leak - shoebox?
- converting to badass small block chevy heads?
- How to disable car so it will not start.
- Whats the 0-60 time on stock LT1 Z28 ?
- Optispark Upgrade gone bad?
- HUGE Oil Leak =(
- Let's try to solve my 2+ yr alignment problem...
- locking header bolts
- Car's running weak. Suggestions?
- Where can I get injectors cheap ?
- rear end gears
- where can i get a power window motor?
- Listen to this
- exhaust
- The LT1 motor gremlins got another bolt!
- Hey 383 peps gimme some luv
- where did you mount your ignition?
- rear end cover ??
- flywheel question
- gauge install
- vig stall converter
- Shocks
- Oil Leak I need your opinions
- Dip in airflow around 5000-5200RPM
- Need Help Fast!!!
- Flywheels
- Question on rearends
- Stainless Y Pipe
- How do I drive this thing?
- is cc306 big enough for my new motor
- Is My Waterpump History?
- offroad pipe and people without a cat or cats please come in
- what headers are CARB legal in CA
- Lug nut thread specs?
- here we go again, cam help please :(
- Crank Pulley
- Are Jason Cromer's prices for real!?!?
- I love a Loudmouth, but I'm in love with a Hooker
- ? dyno's & tuning
- Power steering gone??????
- LT4 knock module
- I need a bigger cam, Suggestions Please
- FLP guys where to get replacement clamps?
- 350 question
- 93 hotcam/ported heads/pcmforless users, please read.
- oil leaking from low oil sensor?
- What is this??
- Carsound Cats?
- Deciding on tires
- FLP Headers...
- problem after 230/236 install
- Where's the best deal on o2 sensors and extenders?
- Recharging my A/C (Repl Compressor)
- Widening wheels...
- Help, my radiator blew!!!
- SS intake + CAI?
- where can I get a good fuel filter?
- If My Spark Plugs Are Bad...
- shorten my driveshaft?
- stainless works y-pipe from sumitt :(
- New Starter
- Whats this trouble code mean?
- Total rebuild......what do you guys think?
- Rear turnsignal wont work.
- Borla Flow Control Plates, Few quick questions...
- Changing Lifters????
- hp #'s
- dynomax bullet or high flow cat?
- Clutch slipping, all parts that i need include?
- SES Light, OPTI maybe?
- Exhaust leak??
- Visa 245/50/16 tires (model VK-50G) tires
- Optispark upgrade questions...
