View Full Version : LT1 Based Engine Tech
- What are these heads worth ???
- valve springs
- My battery is draining,how do I find the problem
- stock lt1 heads....?
- Anyone make a 12 bolt support brace?
- How do these corrected times sound?
- i need to change my elbow in the tb and trans mount!help!
- Shoebox wiring?
- How hard to change plug wires on lt1?
- Need help with jethot install ASAP
- 350LT1 Tech
- What could cause lean condition?
- Vote for my next mod please.
- Cam and Headers ???
- Intake elbow
- Radiator needed for 96- LT-1
- Anyone with an SLP CAI
- Exhaust Leak
- Driver Side Window
- Brakes and Rotors
- The same header bolt is lose??
- backfiring? or what?
- My car is eating IAC's?!
- What is the power difference between shortys and long tubes?
- AC line to back of compressor?
- Please help, car runs horribly!
- finally got the SFC welded in!
- RPO Code Help Please
- Jet Hot Install: THE Passenger side
- Questions about LT1 to LS1 rearend swap. Help please?
- How to Remove Rusty Rotors?
- Installed the LTCC setup today!! WOW!!
- *Possible* Mystery hesitation fix
- need 5 minutes from ANY LT1 owner ASAP
- Poly torque arm mount, need help!!
- Seized Motor
- Part Numbers
- Hesitation still there!!(Part 2)
- My turn for new opti. odd ?s inside
- Jacking up engine...need help soon!
- First time track results!!!....what should my next mod(s) be??
- Oil Pressure
- RKsport airbox?
- Are these Pro Mag Rockers Fugged up? Pic
- Fixing the problems UPDATE:
- So if you bleed down a lifter when the car is off...
- More Trouble Codes ???
- headlights shaking
- best way to change #1 wire
- adjusting rocker arms
- Intermittant starting/electrical problem - Please help
- MAP sensor issues - wiring experts needed
- Headlights
- Springs: On their way
- Q about installing new lifters?
- can i use universal plug wires?
- DYNO PULLs???
- after cam install will car start????
- car beeping?
- Removed ram air box vanes...looking good
- loss of power
- What Air Filter Is This
- when i put springs/shocks on do i want to put LCA's at the same time?
- Gains from AC Delete
- Anyone here purchase one of these???
- LT1 swap wont start. PLEASE HELP!
- Lt1 Tpi?????
- So I think I got one of Jet-Hot's "test" headers
- TB Question
- Air/Fuel Gauge?
- 314/292 Rwhp/tq
- 2 weak cyls.
- Car STUCK in OPEN LOOP!
- Brakes Are Pissin Me Off!
- Good drag strips in cincinnati
- LTCC users!! What wire do I hook my MSD window switch to?
- NEWBIE here...Fill me in on these LT1s
- spark plug/wire replacement method
- BMR Torque Arm Install ?...Lowered & Moser 12 Bolt
- Spark Plug accident
- how many quarts of trans fluid?
- Anyone want an LS!?
- way to bypass compressor? quick!!!!
- Question on ABS idiot light for GM Techs here
- somebody school me on heads!
- 02 question
- TPS Bad?
- Need help with header install ASAP
- Speedometer recalibrate for 3.73
- Preventative maintenence on AC system.
- Can i use the stock retainers and locks on CC 983-16 Valve Springs?
- fan switch
- How much does fully loaded 95 T/A weigh?
- Snapped a bolt trying to remove the cats
- Timing Chain choice....
- $1,300 to fix my A/C????
- edelbrock head and cam package
- My car just gets slower...
- best heads
- My steering wheel shakes/vibrates a bit....
- Would the egr cause.....
- Jet-hot LT parts list
- Do the Cometic head gaskets require sealer?
- Ever since I got the car tuned it has felt sick...
- Cam Breakin???
- Problems with mounting Lakewood D/S safety loop.....
- Backfire between shifts
- why change to OBDI??
- How much $$ for a shop to change valve seals?
- '93 rough idle when cold
- dynaspark??
- Shorty headers for 93. Will they bolt up to the stock y pipe?
- Smoke from dipstick and oilfiller cap??
- Changing my rear but staying with the 10 bolt
- o2 Simms Pre-96?
- 5% more power with fuel additive?
- how much should i tighten the stock rocker arm to? ASAP
- Where is the best place on the body to jack up your f-body??
- Gear choice for auto: once and for all, 3.42 vs 3.73
- Electronic Spark Timing
- Quick question on trouble codes
- Just go my PCM back!
- Any idea on prices??
- How much does a K member usually cost?
- Map sensor volts and spark advance readings
- TB Bypass on 97Z
- Coolant Passages in Intake?
- Lifters for LT1/LS1
- Hmm wtf Density altitude is messing with my head, Please help!
- Bad vibrations at 3000-4000rpms.
- If it's not one @%@#$$% thing it's another.
- engine light
- Help car does not want to start
- Anyone know what the wheel stud size and thread is?
- need help changing blinkers and side markers!!!
- Scaned SES Codes
- Engine stalls from time to time
- Revalving necessary for DMS springs ?
- how to get 400 rwhp ?
- Ordering Tires today nitto or yokohama?
- Important Info on lashing out the rockers
- What Exactly is a lean Condition?
- What does "knock" sound like?
- How to Change Pinion Seal?
- New Borla sounds awesome!!!!!!
- Swapping thermostat?
- Vibration problems - You will ABSOLUTLY NOT believe this!!!
- I hate bench racing but....
- part #...
- Track tommorow! What will I run?
- oh my god went to track last night 13.5 at 100 please come in cant be!!
- MAS direction important
- Fuel Injectors
- Another Wheel Question
- Blew my rear. Does anyone make re-build 12 bolts? Or am I looking at $2K for a Mosier
- Hooker shorty header install this weekend....Need suggestions.
- Any Ideas
- Suspension Q's. What's the differences? Lowering, etc.
- How do you figure correct 1/4times for diff. elevations?
- Oil Pressure Drops on hole shots.........?
- LS1/LS6 into a 93 f-body?
- Vented opti conversion,... what do i need?
- Need ft/lb ratings...
- Will I have PTVC Trouble with my Heads Decked .030 a .039 Gasket and this cam?
- Something is draining the battery...
- Anyone read the info tech section of this month's GMHTP...?
- what voltage for maf?
- Question on wheels
- accurate stock LT1 in Desktop Dyno?
- What size is an oil pan bolt?
- dual cat MAC ORP?
- MAC or Hooker LT Headers???
- car died, wont start, no spark please advise
- Let me know what TC you have or had...
- Nitorious LT1 stumble, whatcha think?
- 160 thermostat
- noisy injectors or bad lifter?
- Need part no.
- Dowel pins necessary?
- Electric W/P o-ring pn??
- Question on lifter retainers so lifters dont fall during cam install
- Which oil pump pick-up to use?
- Felpros Website shows same part # for Camaro and Impy Head Gaskets!!!! HELP!!
- Taylor OVC wires and stock manifolds?
- guess my time w/ my mods
- Any of you Mufflex catback guys have soundclips??
- Possible Opti problem, please help!
- Question about exhaust manifolds.
- SES and OBDII...
- Took off valve cover..FOUND THE PROBLEM..what does this mean?
- what should i do?
- Any good shops that know LT1's in CT?
- Here is a link to some LT1 info.....
- VIN Scanning? Need Help ASAP!!!!
- Fuel Pump Question
- Looking for some HP, what next...
- multi misfire/p300 code problem solved
- Mac offroad pipe fitment?
- Rear suspension squeak... I know it's vague, just read inside.
- need advice and help
- Gear swap=computer issues?
- anyone with a A4 and 4:10s?
- Pro Charger Fuel Pump?
- Holy Hot Dang!!!!! Woo hoo!
- Low-Profile cats?
- AFR 220 heads and valve covers, need help ASAP!
- is MSD coil worth it??
- Header Help
- Any Quick A/F guage install tips?
- Quick oil pan ?
- Power booster gone?
- fans dont go on by themselves
- Tranny wont go in!
- 3rd time a lifter has failed, are there any that are good?
- what the **** is wrong with my car?!
- for shoebox or anyone else that knows
- camaro SS egr question
- ACPT Driveshaft... Worth it?
- IMPORTANT, Need Advice Really Quick
- Need advice on rear end, 12 bolt? 10 bolt? HELP please
- A few small issue
- physical difference between LT1 and LT4 KM?
- lt1 to lt4 swap
- Oil pump or possibly coil?
- Failed VA Emmissions Twice, Please Help!
- Effects of cracked intake elbow??????
- Hotcam or CC306 for bolt on LT1?
- Broken Spring or Lifter rod
- Quick O2 sensor question
- Auto shop still tearing apart car to find problem.
- Cleaned my TB and MAF
- Spun bearing...Just my luck? after cam install
- Gear whine from 60-40mph only??
- Hesitation/Stumbling
- Only got 2 runs in...
- Car is running Rich Ideas???
- Are all Header gaskets the same?
- Can a hotcam'ed car run out of gas?
- Idle
- SFCs welded in......now a weird clunk in the rear?
- Start car and rpm's shot to about 3 grand
- engine hesitate
- What is the definitive difference between.....
- 1LE Elbows come with the IAT?
- I need to determine which stereo system I have. Please help!
- headers or cam???
- Whats involved in removing a radiator?
- What would a loud clicking noise be? Whats piston slap sound like?
- Help quick please
- quick help
