View Full Version : LT1 Based Engine Tech
- Veh. spec tag missing... where to find out specs?
- BMR LCA relocation brackets
- How is my air fuel ratio?
- any "how to" do the a cheap manual fan switch??
- how much wieght can our rims handle?
- Who sells MAC headers?
- HOW MUCH smaller of a belt for Delete A/C pulley
- Weird starting problem...help me out
- Front End Squeals/Squeaks-No glove box data tag
- Cam Question
- bent spindle?
- Tranny going south?
- What is up with my plug wires?
- Gauge install...drilling firewall
- starting engine without tranny?
- 02 question (good reading)
- something not expected
- How restrictive is the stock exhaust?
- SLP headers and O2s
- brakes
- will crossed plug wires throw codes?
- T56 to TH350 swap
- removing back seats
- Overfilled Gastank
- jet hot lt headers
- Pics of my clutch... what's wrong???
- What happens when your fuel pump begins to die?
- I hate the " please guess posts" but..
- help with trouble codes shoebox and ne one else
- test plug wires with ohm meter?
- Lt1 weight
- Quick oil pressure question: is something wrong??
- POLL: Which Headers ??? Also, How insight on the install ?
- need pic of 4" single out and dual 3" dumps ASAP
- Part number needed please
- Hey 383 people!!!
- LT1 Valve ?'s
- Weird AC Charge Problem
- What rpm should my A4 be shifting at?
- WTF no SES??
- What Did I "mess" Up ? (edited by moderator)
- Pic of subframe connectors please??
- Non ASR throttle cable...
- Got $350, what to buy
- PCMFORLESS questions
- Do I need a new console for A4-M6 conversion in a 97 fbody?
- A4 and M6 driveshafts the same length?
- 1le bushings
- Rhoads lifters?
- NOS it or not???
- negative 22 degrees timing??!!??
- Noisy Lifter
- Knocking noise from rear...
- Rod or Lifter Knock
- How do I get the water pump drive out?
- Arcing msd wires & every other problem....
- fuel leak
- a/f gauge
- how much will this drop my ET?
- Do I need to machine for valve springs?
- optispark upgrade
- 1le bushings
- 1le bushings
- When do headers become a requirement?
- why wouldn't my car start in the rain?
- Dummy Light For Brake
- Problems with K&N Cold Air
- Which Headers???
- Special spark plug socket... Is this for real?
- What else can I do to help me hook?
- A4 --> M6 swappers
- need an opinion
- New best times and questions to go with them
- Doing Doughnuts...Something broke.
- rear end help!!!!!!
- fuel line??????
- !ABS/Brake booster ?s
- Why my driver side window wont raise up?? Help?
- !egr, !air
- 95 t/a vs 2003 srt
- Over doing Top end?
- Headers
- Fuel Pressure
- Stock Oil cooler or aftermarket?
- Anyone upgrade your brakes? Either w/Baer or LS1?
- Hesitation cured Thanx PontiacX2
- Cam install
- parts list
- Steering shaft question
- Where to find a 2 into 1 Y-collector (3")???
- Gears or Suspension?
- Light Weight Capret for LT1's???
- help needed badly!!!
- 3.73's Worth It????
- Anyone ever deal with or hear of advanced dyno technology?
- LTCC Users
- if you had 100 bucks, would you get LCA's or reloc. brakcets???
- Opti Spark Alternatives
- What does it take to get 300hp?
- Fixed my over-rich problem
- speedo problem
- high oil pressure and rpms.??
- ANYONE know how I can fix this stupid nut?
- Bad miss upon acceleration ?
- Borg-Warner sparkplug wires any good?
- my 93 has traction control....???
- Oil In Hose Going To Throttle Body.
- under drive pulley [ebay]
- could i have installed my fuel filter wrong?
- Can bad IAT cause crazy idle when hot?
- Double roller timing chain install
- Could my MAF have been damaged?
- Heads and cam Auto dyno #'s?
- Hooker LT's and Pro kit- How much clearance do YOU have?
- Car doesn't properly drop down to idle from a rev
- Master Cylinder Problem
- rear end drippin
- O2 Sensor
- Alternator "squealing"
- Screwed up. Need help.
- over cover wires??
- how much for a clutch bearing
- is this a bad water pump, a bad sensor, or LT1 cooling system just suck??
- aftermarket tachometer
- Hub position in relation to keyway?
- front shocks
- 15.1 in a 1/4
- Will a cutout cause this error code?
- Right Bank = Which Side?
- Removing Jounce Bumper spacer?
- Anyone running Jet-Hot Y pipe?
- No power - clicking from near front bumper
- too much tension from new springs?
- copper header gasket leaking
- Multiple Cylinder Misfire
- Taylor OVC wires installed!
- Is my car falling apart?
- Opti Problem, please help asap
- which tires to go with 17x9.5 front and 17x11 back?
- How much does a new gauge cluster cost?
- MAF= Tranny Problems
- is bbk a good brand for a TB?
- chevy 9 bolt work w/a 4th gen
- calipers
- LS1 exhaust
- rotors
- which gears are best for me
- Who here is running Mobil 1 15w50?
- best muffler?
- Oil leaking from valve covers?
- head gasket or two
- fuel pump
- lt4 cam compared to CC306
- cam change
- Why does my car run smooth one day and not another?
- hey shoebox
- What kind of gains will i get with these small mods??
- what causes awful gas mileage??
- scanning question
- where to buy front bumper cover for 93 to 97 trans am
- LT1 to LT4 ?
- would a obd1 scanner work on a 95 if
- False KR(long)
- Recalibrating Speedometer?
- How much gain from a tune
- What could be wrong with my car?
- Old input shaft ?? What did you align cluth with. Aligment tool with clutch won't do
- Detonation problems (need help)
- engine missing after new plugs and wires
- Making this Camaro consistent
- Anybody using this for an exhaust??
- head porting and sound
- Fuel shootong out of headers, it it a leaking injector??
- Anyone able to get longer studs in the back axles?
- High RPM Miss (long, please help)
- Air Bag
- LT-1 takeout
- T56 Output Shaft
- Scanning the Car... HELP
- Hard starting FIXED!!
- WTF cant get slp y pipe back on???? HELP ASAP
- What exactly fails when the optispark gets wet?
- I think my oil intake pick-up fell off??
- question bout timing chain,gears,opti install
- Window motor help
- Low profile jack suggestions?
- Is it safe to drive with a Code 16?
- HELP! ? about welding relocation brackets
- so here are my goals. would shorties do?
- Craftsman bolt extracter Bravo!
- What does getting the valves lapped mean?
- What makes an off road pipe different from a regualr pipe?
- cc304 vs. stock
- taking off a4 shifter
- free mod question
- got a error code 048, whats up?
- 1/4 with slicks & stock rear???
- Ram Air on a '94 camaro?
- wheres my turn signal flasher at
- Priming the Oil Pump
- need some help
- Anyone have pics of a ported and polished LT1 intake?
- 3440 # convertible BS or what
- Driveshaft Loop Questions.......
- Need guidance on my next set of mods.
- where to manuals
- not enuff fuel?
- shifting help...
- 1/4 mile time difference w/ 4.10s???
- CC305 with LT4 Springs
- Best spark plug?
- LT1 Wiring Harness in S10
- It's alive!!!
- heads
- '94 dual cat. conversion
- heads and cam questions
- acurate a/f guage and fuel pressure quetion
- I need this clamp! Shoebox??
- Would I be an idiot...?
- OBD2 codes?
- Worth building bottom end for boost without heads?
- Whats the BIGGEST SLick for the Rear??
- limit on stock lifters?
- cadillac converter
- ?'s for Mufflex y-pipe owner
- Why doesnt my a/c work??
- Horn & Cigarette lighter not working?
- What should my Fuel Pressure be set at?
- hub install
- Custom Y-Pipe or wait for JetHot Y-Pipe for JetHot LTs
- Y-pipe
- torque pounds?
- XE 224/230 power OUTPUT
- Installing traction control unit
- What exactly is involved in >>>>
- wtf is wrong with my car?p;z help
- how is the opti numbered on the passenger side from top to bottom?
- All you self port and polish dudes in here..
- t56 rebuilder in kc
- replacing fuel filter
- can a bad opti cause Backfiring(?)
- Bigger TB or not??????
- Fuel rail bolt problem?
- 95 z lt1 will not start
- Dyno #'s..
- Just got done doing heads and cam, car runs super hot!!!No fans!!
- car died, won't start, black smoke while trying to start
- Is there a way to mount the brakes from a 82 Corvette on a 94 Camaro?
- changing valve springs, but locks wont come off
