View Full Version : LT1 Based Engine Tech
- Just changed wires and have got a ?
- Anybody who's swapped to AGX/Struts:
- roll cage questions
- Do I have to actually remove the stock sxhaust manifolds, or can I just unbolt them ?
- LT1 intake with Throttle Body
- Broken teath on rear gears???
- Out of control brake dust
- Torque converter...whats the best one??
- LT1 and a rockcrusher??
- Finally got true duals!!!!!
- Rebuild $$$
- WHOO HOOO ! ! ! Intake is off.,., Now what ?
- Fuel line
- ? on pushrod and lifter install
- LT-1 Srock Rotating Assembly, External or Internal Balanced?
- High Mileage Oil Change
- compression ?.....12:1 stock? yea, come inside please
- Ok, how many of you have done your spring change without an air hold fitting?
- What fixed my low rpm stumble....
- Car is running right...Finally!!!
- Brake pads...
- BMR torque arm vs Jegsters torque arm
- How do you balance the brakes
- Ran N20 for the first time today.....does this sound right??
- Body Kit For 95'?
- car starts and dies and power door lock/dome light dont work..
- accell shortie plugs
- What can I expect from this....
- Car Runs like a p.o.s. UNTIL the S.E.S light comes on..WTF!!
- 4 valve reliefs?
- To everyone who has taken their Camaro instrument cluster appart....
- Suspension Question
- Need Cylinder Compression #'s For a Healthy LT1
- Good Traction=Broken Trans Mount??
- stall?
- brake questions
- Are the TTS headers good? What is the best set?
- Knock Sensor Torque Specs.??
- Max ported heads and a STOCK cam? anyone ever do this?
- GMPP CAI part #?
- LT1 Hesistation, The Sage Cont'd
- Formula Taillights leak?
- Catalytic Convertor Removal
- Ok, Tell me what you guys think I will run?
- Just bought a 95 Trans Am Convertible
- Running Lights
- Automatic Tranny Fluid Change
- muffler or no?
- Car moves in park...
- high rpm miss... help:)
- Need help with uninstalling an alarm system...
- Lightup Spark Wires
- SS Hoods Conversion
- Stage 8 Locking Bolts
- Need a Dyno tune
- first track times
- Engine Fans
- need help with gear ratios
- I keep KILLING o2 sensors
- Help A4 guys
- starting after long sitting periods
- Waterpump help please
- My Dyno Numbers...
- Valves!
- Causes for hard starting
- GM Part#....Shoebox?
- Two different plug wires how bad.
- comp cam xe 224/230 112lsa
- Need a part number
- Something is hitting floor board, driving me nuts!
- just finished my lt4 springs and rr install...
- mods to reach 13.2
- Crankshaft Postion Sensor
- Need ignition switched power source under dash
- Stock LT1 Head's CC
- Starter Question
- New Volvo/LT1 web page
- OverHeat? Coolant mixture?
- Camaro vrs Firebird?
- Lightweight driveshat questions
- '96 SS "Optional Performance Exhaust System"
- Need Some Education On LT1 Headers
- How much $ to replace all the hoses?
- Whats this part called? I need a new rocker arm bolt/stud.
- Fuel Delivery Problem
- what will my times be?
- LT1 Oil Questions
- rear main seal housing gasket
- Who's gone from short to long tube headers...
- How's the LT1 driveshaft come out?
- Areomotive AFPR are they repairable? Mine is Leaking out the vaccum port.
- 94 FireBird Formula, Which upgrades are legal?
- High end miss?
- I found another oil leak!!
- Cam To Rod Clearance?
- New ET's from Lloyd Elliot heads & 224/230 XE cam
- Quick before I get off work (Head related)
- Low RPM stumble
- sidemarkers??
- my car is leaning, need help!!!!
- Long tube header questions
- Yellow tape on hotcam?
- opinions on what might be holding me back
- Calling Shoebox
- Oil Leak at waterpump drive seal
- Removing the Intake. Am I taking the fuel rails off?
- help quickly w/ electrical neon light problem
- Auto XRay NO Codes =? Useless?
- reocurring problem
- Shifting into third?
- '95 vs. '96 Clutch Difference?
- What is this thing, what does it do, and is it worth $400?
- Checking for a bad lifter...
- Timing the eninge when doin a cam swap
- Rear Swaybar Size ??
- Rearend size
- oops... didn't realize the A4 tranny will shift into 2ed at 100mph
- Maryland/DC/Virginia F-Body owners inside
- Head work being done, What springs do I use ?
- hotcam track times
- Got the z28
- IAT part number for a 96 car...
- Why would one O2 be fouled and the other not?
- Can buying diffrent gas from diffrent gas companys give you better gas mileage?
- LS1 Intake tract on LT1
- Are 4L60E and 4L60 converters interchangeable?
- AC just stopped working?!?!
- Reuse stock PP and install aftermarket Disc?
- Found out why I can't hook. Need advice
- Update on Running Lean on Right side
- Any gains from a cutout on a catback?
- powerdyne 4.5
- had to put leaded gas in, few q's
- Cheapest place to get Felpro 1074?
- AMERIACAN racing wheels-torq-thrust 2
- Unstoppable high idle
- Anyone broke timing chain?
- Do you need an extra trans cooler????
- What kind of spark plugs and wires do you use?
- Brakes
- Building a 383, little help
- LT HEaders
- Cam Spring Combo
- Slp Air Lid
- Is this website true? (Power Gains?)
- Front suspension bushings, poly or not?
- What after market gauges you run?
- stock fuel pumps or aftermarket fuel pumps
- Reverse lock out connector on trans
- HELP car wont start
- hot cam kit?
- in the middle of adjusting valves..help!!
- Heads & Cam packages available
- LT1 Rebuild Kit
- trouble with a pulley, need some advice
- Best CAI?
- NE1 got installed pics of the new Y-pipes by stainless works or hooker??
- CAM Question
- Shoebox help me what plug wire set should i order?(for ovc wires?)
- A4 Shifter
- peolpe with RR's, in need of answers ASAP
- 18 degree heads?
- Need help fixing my arcing problem??(like quick/permanent fixes)
- How do you install the bulb in the fog lights?
- Cam duration - Advertised vs. @ 0.50
- 1LE springs
- stock gears vs 3.73
- fixed my rough idle, thanks guys!
- Wrong Tstat in my car, question need awsnered
- Cruising in 1st gear in an A4
- Ion is the man!!!
- Running a Cam without a Tune??
- GM's LT1 carb. intake
- vaccum modulator hook up
- Which cam is for me?
- fuel pump bucket
- rough start
- convertible top resistance
- BBK headers to fit
- Cooling fan problem, Please help
- need help
- Car run ok w/ out cat's?
- someone with downloaded parts book
- LCA's
- ignition problems, key doesn't turn
- high idle after a cold start? help me out please!
- MSD, overrated or worth the money?
- another cutout ?
- Best Header & Exhaust Combo????
- All you T56 users, GET AN AFTERMARKET SHIFTER!
- I failed emissions. Help please
- 94 LT1 Spark knock 2000 rpm
- Quickest LT4 Topend w/LT4HC Car (N/A)?
- Best 60' Mods besides DR's
- Need Help Fast!! Please Answer!!
- LT1 Rebuild Kit
- Any help????.....
- Cryogenics?
- Supercharge or headers/wheels..need input.
- Bouncing off the rev limiter?
- New best bolt-on times!
- stroker oil rings
- AC delete w/o removing heater core?
- Brake question
- Does anyone have any pics of LT4 Heads?
- headliner removal get off coat hanger screws
- Latest track times w/video
- Fuel Pressure Gauge.......
- Mother of all swaps...4thgen guts into thirdgen?
- Anyone know whats the problem??
- solid roller
- Think my clutch is toast! What shall i get?
- 1.6 with the CC306
- biggest valve size for LT1 heads?
- Baby LT1
- how to get seatbelts off???
- How do i stop arching??(need help fast)
- CC305/ported head track results
- Internal Mods...NEED HELP...
- Finally Fixed Hestiation/Surge at Idle
- Wanted: 4th gen Camaro owners, Pls post engine numbers
- New Battery?
- Please help! Worried about the Z
- CC502 track results
- Integrated underdrive pulley/harmonic balancer
- I think I lost some low end torque
- The Z is Scream'n fast tonight... Have a Nitto Traction Question.
- ls1 style exhaust
- Engine Rebuild Kit
- Any easy way to tell if an A4 has been rebuilt?
- Quietest muffler?
- Compression question???
- heads
- T56 trans
- How do us 93 guys get data logs of our cars. Like autotap logs and such? I need one!
- My Harmonic Balancer Fell Off - Help!
- which is the intake valve and which is the exhaust valve?
- Is there a way to tell if an egr valve is bad with it being off the car?
- Anyone using a Lokar throttle cable?
- Need help! 93 fresh 383 barely runs????
- 2 bolt engine vs 4 bolt
- Engine Rebuild
- Egr Blockoff
- Wish me luck on my Tranny service!
- Front suspension bushings?
- Good Place To Get Some Ported Heads...
- Has anybody noticed a loss of low end torque after installing the Borla 2 3/4 Y pipe
- Are aftermarket y-pipes worth the $$$$
- 93Z IAC removal
