View Full Version : LT1 Based Engine Tech
- Question? Newbie
- A4 help needed.
- ported heads
- EGR Valve Check - How Hard should it be?
- 4.10 gears with heads and cam car
- Cleaning LT1 Engine
- chug chug chug....
- Play in the driveshaft...Is this normal?
- Tunercat Question
- trailer width...
- coolant
- can you buy front wheel bearings
- Where to get tranny cooler zip ties or what to replace them with?
- Spark plug guidelines.
- Wiring Question?
- Who knows of a great spark plug reading site I can go to?
- Is a strut tower brace a good mod for drag racing or only for cornering
- leaky intake elbow?!?!
- do they make a 15x 10' rim
- injector o-ring missing???
- dam oil pan gasket!
- fuel questions with cam
- Best Heads.........
- Decided to throw a cam my Z
- how do i remove the hatch of my TA
- '01 GT Vert vs '95 LT1 results
- Homemade 1le elbow
- Need Help W/ Jet Hot Install Asap*
- 285/40 onthe front???
- Guys with B&M shorties inside
- tuning and cc306?
- Were to get oil filter magnet?
- why does no one make an aftermarket lt1 intake manifold?
- need an opinnion on 3.5" catback systems
- Need a new clutch...suggestions please!
- Right rear brake scrapping
- A.I.R. Hose Pops Off??
- egr system????
- what can a cracked spark plug do?
- If my headers r leaking?
- oil on spark?
- What are the symptoms of a broken tranny mount?
- I think I got hosed.
- Need torque specs for rocker studs....
- Z having a few problems, need help!!!
- Fuel Filter? Which one should I buy?
- Factory computer limit of 93 computer? 7K??
- New to Mod-ding
- possible to reroute A/C Vent? Not actual vents...
- A/C Compressor Clutch squeak!
- A4 removal and reinstall time?
- Worth it to try to make a bulletproof 4L60E???
- Will a 4L80 work in an F-body?
- engine work
- Control Arms
- Mail order tune?
- Homemade Octane Booster... How safe is it?
- Abs Inop.
- Cc 306,305,lt4 Hot, What Mods We Need
- under a load
- Do any of you have a gas light?
- O2 sensors or O2sims with Jethots on OBD1
- Ls1 coil convertion
- Spark plug wires
- Ordered the wrong length wires...that sucks
- Having trouble....93' to 95+' OPTI Swap...
- Need Help
- Is a 383 stroker really worth the $$$
- Fan switch mod trouble(not an SES code)
- Exhaust Popping?
- 3rd gen vsLT1?
- fuel filter and coil replacement in driveway? how hard..
- Need a comp 305 cam sound clip
- Anyone daily drive w/o ABS?
- How Fast do you think i could do the quarter?
- Transmission Problems??
- Help, questions on oil additives, need answers/opinions soon please.
- Anyone Running A ZZ4 or ZZ3 Cam?
- SCAM artist on ebay, look out
- Catalytic Deletion
- Tranny or Clutch problems...PLEASE HELP!!
- Abs Inop....
- Performance chips...
- Strong gas smell coming from my car?
- Need help with rear!
- Preferred Motor Oil
- louthmouth with longtubes?
- How the hell do I get the plugs off the driver side of opti?
- how to remove cat?
- air box for my new hood
- Clogged Cat? you tell me
- service engine light
- Quickest times for N/A LT1's with shorties, or mid lengths
- Anyone have problems w/ double roller and cover?
- Will my car drive ok without the speedo calibrated?
- 95 Corvette LT1 OBD1 or OBD2?
- Rear Bumper Cover
- In the 1/8 mile, do you usually hit the 2-3 shift in an A4?
- Made a Street rip, really camming, pass side plugs Dark, 110 octane, 02s wacked?
- vss connection
- What color are the speedo gears for 3.73s?
- Hp on a budget? if thats possible
- horrible brakes after abs removal
- horrible gas mileage
- Blasted Z28 Won't Turn over!!!!
- a/c cuts out after 2-5min
- (inches of lash)/(turn of nut)
- Do any header coatings really last
- I Need Help Asap!!!!
- Boy I'am ****** Now.
- HRV need some help.
- Rough Idle and SES Light!
- could this be a spun bearing?
- Stock converter causing problems with CC306?
- car trys to start when i plug my battery back in.. quick help needed
- XE 227/233 cam is in (stock heads)
- Rebuild a4?
- Scanning My Car
- Suggestion on plugs and wires
- TPS and Fuel pump Q's
- stock 94 trans am a4 times?
- bottom end
- Weird Feeling at startup!!!
- Found the source of my LT header noise
- Edelbrock Elite valve covers
- Cheap throttle body inlet elbow replacements?
- Need help with ford rearend identification
- Not getting oil to the heads after cam swap!!!
- LT1 Hesitation (RPM Specific)
- Monsoon in T/a 93 ??
- Whats the P/N for the serpentine belt?
- Why does my car backfire sometimes when I'm off the gas???
- Now this is a messed up pushrod
- where get a new lt1?
- ABS problem here as well
- This the engine we all have and love?
- ported heads and cams
- How to get to the CAI filter from below?
- whats the proper BS for an 8" wheel ?
- Will you fail smog visual inspection with a cutout???
- TB Bypass question
- Engine harness
- Webpage to help with plugs/wires installation?
- anyone have this cutout?
- Dyno #`s
- $115 tune up??
- Lightshow causing rough idle?
- Anyone have a Crane Fireball coil / ignition ? ?
- TPIS Longtubes
- How much lift can stock valve covers support?
- Hey guys since I was on the subject of programmers.
- Z has more of a "lope" to its idle now? more shakey too..any ideas? plug gone?
- After market tach question? I have researched by the way...
- elec. VS mech. Fuel pressure gauge
- Any trouble with autolite plugs?
- Keyless Entry Problem/Question
- Cam time soon, come on in, I need your opinion
- weird brake light problems
- gasket maching
- Strange Firebird Headlight Problem -> Brass Gear Replacement
- Fastest cars on 17inch wheels
- Fastest cars on 17inch wheels??
- Do SLP headers need a custom y pipe?
- It looks like I have no spark..Please Help, I am scared.
- How to tell if the cam was ground incorrectly?
- Best posi unt?
- Which would be best?
- Why does car vibrate.
- Chris @ Jet-Hot
- cam springs for the 224/230 duration cam???
- FLywheel bolts reusable??
- Minor Issues
- ---- When you think you know all about LT1s..... What is wrong with my car??
- ABS problems
- LCA bolt size?
- PLESE HELP, Cooling system problem!
- GMMG Muffler Sold Separetly?
- Need experienced plug help guys!
- Do bad 02's cause problems at WOT also?
- Gain perdiciments? (sp?)
- headers or a gear?
- Valve spring P/N
- New best track times with hotcam...
- Bassani exhaust?
- How To Check For Vaccum Leaks ?
- Part # please
- Help With Buying Rotors!!!!
- KYB shocks
- LT1 to Lt4 Conversion: 425+ Hp Proven Kit
- Do any "mods" improve reliability?
- Will an LS1 10 bolt rear work in a 97 LT1 car?
- Weird bump when tranny shifts at redline
- Next problem w/ mods...
- camotion's phone number
- Benefits of MSD 6a on a 97 Z
- horrible miss under 2000rpm
- I have a cutout,but need the electric part
- ABS Lights after cam install???
- Any way to check coil?
- Rough Idle And Burnin Rich
- weight reduction ideas?
- How do you remove a convertabile top frame?
- pulling a motor?????
- Fastest N/A LT1?
- fuel delivery problem?..or is it mr.optispark?
- Double roller chain with NON-vented opti?
- Cut-Out or SLP Loudmouth?
- Exhaust ORP Question
- auto trans 2.73/ 1st gear blocker shifter question.
- MSD Digital 6+ Vibration Mounts???
- best exhaust with headers and !cat
- max compression for pump gas?
- Any way to improve stock WP?
- JetHot LTs knocking against brake line shield???
- AC was not charged for a year, is it bad
- damage
- Got back from maple grove ... is my engine dying?
- A/C Issues, Low coolant light? Help!
- 600 dollar install high?
- Best Pressure for Street Tires
- Car wont FIRE UP???
- Front End Squels
- What part number is o2 Sensor and belt?
- PLEASE HELP w/ mod problems - LONG
- Low gas mileage?
- Problems w/ mods, PLEASE HELP!!-LONG
- Smooth Bellows?
- how much for a '97 z-28
- Would ported heads on a stock cam hurt anything???
- Stock A4 1/4 times?
- Did anyone gain traction from moving the battery to the trunk?
- Electric Cutout - Which one/Where from?
- stock I-pipe outlet size
- Is this thing kind of like a Hypertech Programer?
- stock pistons
- Need part number
- 14.887@95.25 Analyze my slip.
- WHY Synthetic????
- water leak
- problems with new motor
- Header gaskets gone?? (Pics)
- My reading lamps never turn off?
- Loosing Fuel Pressure on "RUN" Position?
- tri state f-bod association
- Help: runs good for about 15 minutes, then like crap!
- wierd track results?
- Serious problem with Z28
