View Full Version : LT1 Based Engine Tech
- Noise coming from driver side engine???
- How much to get TTops re-keyed???
- Who says LT1's aren't strong....
- Whats the best head and cam combo for low 11's ?
- Headers, whats their advantage?
- Weird Things Happening All at Once
- Anyone else w/ a soft gas pedal?
- Ignition going??? HELP!
- newb needs header help
- Anyone have any idea what brand stall this one is?
- Can i cut the dip stick tube?
- how good is Flo-Pro exhaust?
- will these springs work with the cc306 cam?
- 383 stroker labor costs?
- Jump in on a Scanmaster GP
- How low can they go?
- who would you take your motor to for a Stroker rebuild????
- new computer
- Mcleod Softlok
- why reprogram a4 after installing a 52 mm tb??
- Still down on power...
- Need Help Or Opinion
- Problem that won't go away(Long).
- Cheat and Easy Mods
- Guys who change injectors.........
- 02 Sensor Question? And What Types Of Headers Does Everyone Run Here On There Cars ?
- speed calibration
- Ignition/Tranny problem
- Dual cat SLP headers, what to do with heater hose?
- header install
- High idle..any ideas?
- best location for tranny cooler
- What parts make a car a specific car?
- Pistons
- Abs Inop?
- Help -- dash lights OUT - need help asap
- darn it
- LT4 Fel Pro Intake manifold gasket PN?!?
- 95 Z28 Spacer For The Front Rims
- 1LE intake elbow
- AIR BAG light
- Magnaflow Catback bolt right up to 95-97 dual cat cars?
- easyest year lt1 to mod
- worth it to go from 3.23's to 3.42's
- where to bu MAC headers
- Is it time for a PCM tune?
- The bird died
- Long vs Mid vs Short
- Coating LT1 Intake?
- 3.42's a good choice?
- What is this? (PIC)
- car running rich when warm
- p/n for Limited Slip Additive
- Help after electrical fire...
- good cam for my 383 w/heads flowing 270 at .500 intake and 185 at .500 exhaust
- i dont think i can use the cam i just bought
- HELP! Yet another car that won't start
- removal of water pump
- How would the car behave with stock front swaybar and 24 mm rear swaybar???
- Finally took pics of my true duals.
- Removing rear bumper support.
- Rear Brake Problem
- O2 Sensor Questions
- will an ignition miss throw code? (95 Z28)
- cutout
- Port my stock Throttlebody?
- cant figure out this miss!
- lights on the steering wheel buttons
- intake gasket
- Y pipe
- MAF question
- Anyone have the XE 227/233 cam?
- spark plugs
- Who fixed thier idle surge/low rpm hesistation?
- Reason for ABS light?
- mufflers
- AFR and APR problems
- Who's done the 98+ center console???
- New best times on XE 224/230 cam :)
- PLEASE HELP....SO STUCK!!!!!reply
- Datamaster problem?
- quick question
- What can cause injectors 5 and 7 not to fire correctly?
- power window???
- rotors
- Need help with security sytem install(my car has keyless entry)
- cutout
- best price on lt4 hot cam kit
- 96 z28 m6 transmission noise
- Catalytic Converter
- Repairing Intake Elbow... TAPE?
- LT4 conversion kit, what else do i need for it?
- anybody chew up pushrods using gmpp guideplates,or any guideplates for that matter?
- Tranny cooler install kit (sticky pads) question...
- Does E.G.R./A.I.R. removal throw any codes?
- LT1 OIL pan
- please advise on idle problem
- Catback exhaust reccomendations?
- 30# injectors enough for this 383
- MSD 8982 install question...
- 1.6 roller rockers
- hose question
- will a 94 air pump fit in a 93?
- Dynomax Super Turbo
- need help with wiring on electric window switches.
- tachometer installation
- Upper RPM vibration in LT1
- Fired up 383 1st time WOW!
- A/C question
- Question about Power Steering Pulley Bolt
- Mass Air vs. Speed Density
- What are my options for a broken fuel injector wire?
- torque intake bolts
- Low WOT MAP & knock w/ stock timing
- spark advance dropping to zero?
- Dealer question
- Pcm
- where to get fuel rail for 94 Z?
- Where to get bracket that holds Air pump, coil and Ignition module?
- Coil Relocation Page Now Up
- B&M leather shifter knob
- my tranny mount broke :(
- Anyone have problems with SPec billit steel flywheel?
- Program after head swap?
- 383 Dyno Tune Result
- What are the best Long Tubes....
- Could wrong wires in gauges wiring harness cause car not to start?
- GAY IGNITION??? please HELP!!!
- camber/caster is adjutable right??
- fuel pump relay
- Should i drive the car, with a blown clutch?
- Need some Gm parts number help!
- how to check vacuum pressure
- New problem that i thought i fixed...car wont start
- Werent all m6 96 vettes LT4s?
- getting rid of smog crap?
- Comp Cam 230/236 xe, high miles?
- stuffing a grand national motor
- new guy needs help please
- Inline Fuel Pump, What wire to tap into the Fuelpump Harness for Power?
- Plug wires for Edelbrock shorties, OVC or not???
- Failed emissions
- will lt1 heads work on a standard small block chevy block?
- New best, smoked clutch
- cutout wont help?
- What would cause a cat to glow red?
- not connected hose?
- Need help on modding a 93 Z28
- Need Help...look in here..:)
- Need help with part # Please help
- 230/236 Comp Cam XE
- Cheap Fix ups
- Overheating
- Gauges are Acting up!!!!!!!!
- is the Z06 MAF physically the same size as a stocker, length and width?
- Rearend feels Loose After Removing...
- Dead spot in stearing??
- Guys running a McLeod street twin, What is up with balancing it????
- Compression Ratio
- Track results
- Anyone have Proform RRs?
- hotcam install questions...bear with me...
- help here---Is my tranny?
- Bad MPG?
- proof that water wetter works!
- Grade 8 bolt Snapped, any suggestions???
- The grapes of wrath project
- New track times 1/8 just got back
- GTP Head Owners... Valve Stem Seal Question?
- Is my engine cradle alignment messed up? (A4)
- Going to track tomorrow, any last minute tuning suggestions
- fixed hard starting problem
- Power window motors dying.. best brand to get?
- My Air conditioner fan is acting crazy... within
- Finally tested my car's potential after installing Jet Hot LT's...wow.
- Lock cylinder
- HotCam - Wowee
- Fuel pumps?
- Grinding noise from shifter after new clutch install!
- 383 new engine breakin?
- electrical problems, car will not start...
- New best times
- Buying a new"Pawl"
- Dyno results for ProjectTranzAm!
- HELP - electrical problem
- PCM Location?
- What does everybody think about the SLP CAI?
- anyone have any info or experience with the crane cam 234\242?
- Exhaust runs hotter, engine runs cooler after O2 sensor replacement
- LS1 exhaust on LT1 Camaro?
- Right turn signal/brake light.
- fuel in ports and oil
- BBK or AS&M TB?
- Ebay auction ss airbox?
- the tranny is slipping when it does what??
- Intake manifold and water pump bolt sizes?
- Signs of a failing coil or ignition ?
- PCM fuse keeps blowing
- SS Hood Vs CAIs?
- Symptoms of a bad pressure plate??
- Washing your camaro...
- got error codes 16 and 48
- Couple of interesting questions.....
- Swapping out 95 Camao dash to 97+ style??
- 94 shorty headers on a 97?any probs?
- Vented vs. Non-Vented Opti Internals?
- Which Ones?
- Taking aprat the center console for A4's????
- Dyno of the Firehawk, A/F questions
- Combination Motorsports recommended this...
- Worth paying for GM additive with Torsen diff?
- Primaries 6 and 8 glowing red please help, been working on it for 3 days
- Dtc 64
- Can a stock MAF go bad gradually??? Z06 MAF???
- Ebay LT1 intake
- ?? about fuel needs for 370RWHP
- SLP muffler
- Any way to disable the Anti Theft device on a 1995 Z28?
- O2 sensors
- Who has had their intake manifold coated???
- Heater doesn't get hot?
- Security Light on car wont start
- SPEC stage III issues! are these things CRAP?
- What else should i buy for my clutch install?
- Rotor Replacement Suggestion
- Help - Service Engine Soon Light
- water is coming out of my overflow lid!!!!!
- Best way to clean fuel injectors?
- Big Problem with my new SLP clutch
- Paging Madwolf
- Cold Air Intake Temp.
- After H/C install "no" heat
- Exhaust opinion SLP LM with or without cats
- Cam install where do i shift
- building 383 - whats the best for the $?
- Locktite the same as thread sealant?
- heads and cam? (for a 383 kit)
- need firing order and help ASAP
- are these flow #'s any good?
- hydralic to solid roller conversion, whats it take
- Where is the factory keyless entry brain at????????
- Can hydra rev be installed wrong?
- Ram air Firbird pn needed.
- Need OVC pics and install
- What idle speed and RPM shut-off for 230/236?
- PCM Forless and AKM cables........
- o2 sensors...
- power loss with 114 LSA over 112
- Will STEEL FORGED crank out of truck engine fit an LT1?
- where is the oil pres sending unit
