View Full Version : LT1 Based Engine Tech
- SBC motor mounts 4 fourth Gen.
- Cheapest fuel pressure regulator??
- stock heads,stock manifolds, bigger cam
- passed emmissions
- Bottomed out... Whats wrong??
- Heads and cam question
- How do you pull the codes on a '94?
- What The **** ASR off and ABS INOP!!
- ls1 brake install
- Hard starting.
- Opti swap = very easy job...
- Where should I put my sensors....here or there.
- Airbag sensor comes on??
- intake leak and hp loss?
- Help, Anyone know the size of the bolt for the Pan Hard Rod (PHR)? SHOEBOX?
- hurst shifter option
- Bought some used Edelbrock Shorties, what hardware do I need to install?
- engine vibrates loud... mounts?
- Adjusting parking brake?
- I need some serious help.....car is acting up and a ses light is on help please!!
- Anybody running jegs short torque arm?
- Dyno #'s and Opti ???'s!
- Radiator HELP please!!
- Camaro Chat at Yahoo Messenger Tonight
- ABS INOP after dyno??
- Need some valvetrain advice (847)
- Are KYB AGX Adjustable Shocks Any good?
- series 2 or 3 carrier?
- radiator flush
- #4 intake push rod....
- How much are Comp R lifters?
- Purpose of the Fuel Pressure Regulator Vacum Hose?
- got a couple questions
- starter stuck on
- This doesnt look normal...
- do iron lt1 heads mate up to an lt4 intake?
- New Radiator or fix old one?
- Breaking in a new motor
- Rough Idle? Cause?
- Rpm w/ 4:10
- Fuel Pump Problems...Need Help!!!!
- Where to buy aftermarket fans? and which to get?
- Squeal from rear what is it?
- Benifits of a Cutout and Nitrous?
- New Numbers
- BeCool and stock
- signs of bad IAC
- how much lift?
- Problem with idle and bucking while in gear
- Hooker Aerochamber vs. Spintech muffler
- who has the best price on the racetronix fuel pump
- Elec. WaterP. guys, how did you get the old impeller out?
- Stock Battery Guage reading 12-11amps Alternator Problem?
- MAP Trouble
- How did you get the crank hub back on???
- re-adjusting rr's for clicking
- speed density????
- What do you think causes my car to make a squeaking sound hitting the gas pedal?
- 111mph
- Aftermarket tach that doesnt go to 10k?
- rearend is leaking???
- Bouncing Off Rev Limiter
- Becool Radiator questions
- Wide Band Dyno
- Steering rack info, Part #s
- Need coil help fast...please
- Bad opti??????
- climate control
- Code 32 EGR system fault
- Broke/bent ALL 16 pushrods
- Seafoam - Hydrolocking?
- Help with cooling problems
- SLP line lock questions...
- program my 94 trans am
- Fogging Windshield/Weird AC Sound
- Failed emissions
- overheating except when ac is on
- Jumping tach?
- How much would it take for a pre 96 Z28 LT1 to beat a 2002 SS LS1.
- how do i found out what color paint i have?
- low rpm miss under load?
- major play in steering, poor college student needs help
- Zirgo electric fans
- Heater not working could it be the controls?
- Best way to tap into dimmer wire
- Need help with WEIRD RPO CODES
- Knock sensor question
- Trick on bottom back seats to get them to stay put
- Diverters leaking.. Bad ?
- Hatch Door Lock
- Just a reminder about how much ass the LT1 kicks.
- Slp Shorty Owners
- 4l60e
- Why do my legs heat up when i drive? tranny overheating?
- Transmission Temp. sender......
- Optis definatly goin out, how long will it last me?
- z28 is making weird noise, but running fine?
- CAIs
- Yet another SFC question...
- to cam or not to cam
- I can see spark, pics inside
- h/c + n2o stock bottom end LT1 with 141k miles.. dyno results
- probably stupid questions
- Motor oil and Trans oil temp???
- Throttle Body BYpass
- Flat Tires are Evil why can't they foam fill
- Cheapest Mod to start out the list
- Need 95 T/A wiring info?????????
- V6 vs V8
- 224/236 cam, egr delete = bad brakes?
- Is it possible...
- Bay Area Dyno...
- Have Shocks need springs that won't lower the car much
- Is it possible...
- help me squeeze more out of my lt1
- Steering shaft hitting header
- Ok to bleed brakes with ABS light on?
- Voltmeter drop with acceleration
- 3" Tailpipe?
- Help Me With my Setup Opinions Wanted
- 416.8 Hp 437.5 Ft/p
- BIG PROBLEM WITH CAR, PLZ HELP. IM SO STUMPTED. Shoebox, Injuneer inside
- car wont start
- AC compressor
- Can the intake manifold leak air?
- Where is it?!!?!? dumb question
- estimated 0-60 / 1/4 mile after...
- Show me your jet-hot LT Headers!
- Pleased give me suggestions on body aero kit
- Attn: Folks With Headers.
- Opinions wanted!!!!
- How to determine spring code???
- Lt4 Kit
- re-installing stock valve covers after 1.6 install...
- One for the experts Coolant bubbling out filler neck
- t-56 popping out of First HELP
- cooling
- Got times finally.
- 383 and Engine rebuild guys in here ASAP.
- question about bearings, kinda advanced
- What could cause this?!?!
- What Flywheel with Mcleod clutch?
- What this all about???
- Use this Head bolts? + where to get cheap head gasket set
- fly wheel??? what should i buy
- Can my csi pump have an internal short? Won't stop blowing fuses!
- MSD 8.5 wire Installation.
- Installation Hardware for 5pt harness?
- Stock Gears
- Please Help Experts
- Dry shot 73 Jet, what does that = for HP!
- where to buy GM 847 or 234/242 ?
- how much does the back seat weigh?
- will a '97 hypertech work on a '96 LT1?
- panhard rod...does what?
- Will i like the sound of my CC306???
- What the difference between pressed pin,and floated pistons
- Once again another Ebay Scumbag
- coolant dripping on the passanger side floor
- DAMN fault code #16!
- Car Bogs/jumps Why??
- 4L60E Rebuild
- What is the widest tire a stock wheel can hold?
- questions about lowering.
- will these mods help?
- anybody change out a heater core yet?
- zo6 gauges
- Ordered my 1.7RR's.
- what should i put in my trans???
- Shift light installation
- someone help me design my new motor (355 LT1)
- A4 1st gear mod
- STS Turbo kits
- Nu-Tek short block back,what you think?Power guesses?
- EGR Simulator Help Needed!
- Anyone make "stock" looking 93-97 TA fiberglass hood?
- How do you remove the oil pump shaft??
- Anyone use header wrap?
- Spec clutch questions...
- Heads and cam questions....
- Mcleod Clutch break in time?
- What causes smoke to come out front of intake?
- adjusting speedo after gear change
- ATI Intercooled Procharger for LT1???
- Security Light
- Exhaust rattle (heat shield loose)
- Break In Period On Motor?
- Caps for SLP shorties....
- Rebuild Questions??
- .35 plug gap curred my stumble but why?
- All of my plug wires are arcing??
- cometic MLS gaskets?
- Valve Covers for 1.6RRs????
- lt1 vavle covers
- Rough idle?
- Very odd tranny problem (help!)
- Where's the leak?
- What will a miss sound like?
- 93-95 and 96-97 plug wires the same?
- broke another engine mount in 6 months
- Scanmaster install location?
- k&n air filter
- How to cheat emmissions 101! Hopefully
- Racing my auto lt1 some question on overdrive and stuff?
- Where do most people screw up lt1 heads?
- Tranny Broke again
- Timing Cover Torque Specs
- Going to save up for a tranny next summer any ideas?
- Effects of plug gap....
- Did third gens have 1le driveshafts standard.?
- Is vigilanete worth the bucks or should just buy cheaper stall??
- changed fuel filter..still hard starts
- what happens when you unplug the IAC? Idle goes down or up??
- quarter mile time??
- Fuel Pressure Regulator and SES code
- 93-94 Headers.
- Car stutters need help!
- Why does the car only miss in 3rd and 4th gear
- 180-190 miles to empty in my 95 Z ?
- My Car Is Falling On Its Face
- How are these dyno #'s??
- How Much HP?
- Help! fuel question
- Anybody have an inline fuel pump??
- SideExit
- What's needed for LS1 brake upgrade
- ok i am confused
- Need answer quick concerning low temp fan kit
- Could I get into the 12s for $1500???
- LT,Off RD pipe,muffler or no muffler sound clips for LT1???
- no bolt on power steering pulley
- Should I have the rev limiter raised?
- Security light fix
- where does the air pump plug in?? need help fast
- New rims..now what size tire??
- Stroker Kit
- what is this
- HELP!!!...flashing SES light after head/cam install.
- Error Code P0140...help!
- Tube From Back of Intake to Exhaust???
- Charcoal Canister Removal
- EGR Removal
- Where to get Factory Service Manual
- water temp sensor
- Keep car in open cycle? can i?
- Dragging engine on the ground
- Oil leaking out of Oil level sensor....
- repair broken dowel pin/cam
- car stalled 3 times while trying to start this morning
- Engine noise
