View Full Version : LT1 Based Engine Tech
- 383 Clearancing
- Fuel Injection+LT1=Bad????
- What mods would you do if you were going to park your car?
- Shock/Struts Opinions?
- hatch speaker box
- LT1 fuel pump in '99 V-6
- Are 92 vette water pumps the same as 94-97 fbodies?
- Throttle cable.. How can I get it shortned
- Headders
- Size of thread needed for o2 sensor?
- strange problem with stereo system
- Head bolts must be "angle tightened"?
- Window Motor Question
- motor oil on transmission case?
- very confused bout air filter/CAI ???
- Best rain tires.... Need to take 600 RWHP
- Looking for 4th Gen Add-ons
- Questions about stumble
- How to check the oil pressure sending unit?
- Engine combinations with stock lower end in here?
- Part number for SVO 30lb injectors
- SES code help plz
- Popping still not fixed!!
- Another One Bites The Dust
- low rpm misfire...it was the optispark
- What universal joints
- Wipers go past drivers side pillar?
- Anyone have their alternator & bracket off the car for a while?
- When is it ready to replace the rack and pinion?
- SLP fan switch?
- Wheel hop......
- help with part #
- Need some help with setting spring heights (847)
- Only 5-10 RWHP from Dyno Tune????
- Best CAI???
- EX and Cloyes Double Chain Set
- Where does the grey wire on the MAP sensor go?
- what should i run with the new mods
- cam
- Sliding rear end in turns
- E-Brake
- Kooks LT1 Headers
- rear end setup question
- bbk headers ,y-pipe combo
- My car CANNOT be aligned. Need help and opinions
- I was in a car accident, airbag's???
- Ways to stop brake squeal
- a4 to m6 swap!!!!!!
- Blueprinting........
- installed fuel pump...
- Does anyone have the Lunati chain set?
- jet fan control switch
- homemade cold air intake?
- CSI or Meziere??????
- Camaro 94 issue
- Should i buy SLPs Fan Control Switch?
- Who stocks these 2 items?
- Gear noise from Tranny....
- 315's on stock ws6 rims? doable?
- Would a exhaust cutout leak when closed?
- Racing ticket for going 40 in a 35... no tires peeling
- Which waterpump seal??
- rear-end
- hows this Cam???
- new guy here... 1st post.... and i need a LOT of help!
- How to store transmission?
- this a good combo?
- something is hitting the bottom of my car hard
- Will it Fit?!!?
- Custom Dual exhaust down the passenger side?
- 94 z28 where to start???
- 3" in 2- 2.5" out muffler
- New dyno numbers...what do you think??
- Slave cylinder removal
- car doesn't shift right
- Still have darn high rpm miss.
- WOT question
- fuel pump compatability?
- fuel pump
- damage from overheating?
- Exhaust sound clips
- MSD 6al and MAF??
- Powerslide at 75 into median
- TPS volts.
- LT1 four bolt mains?
- Which Headers to buy???
- S&W roll bar
- Hooker muffler on stock pipes vs. Hooker Catback
- danger in having TOO big of injectors?
- Does anyone have an engine built by tpis or doug rippie motorsports in minnesota?
- Hard starting.
- What size bolts?
- Is my slave cylinder f'ed up? PIC INSIDE!
- Lt1 - SLP
- Weird smell... anything to worry about?
- anyway to disable the popup at park lights?
- what happened??
- Coil Springs!!!
- chirping noise from engine
- Battery Choice -- Red or Yellow
- Will 245/40/18 fit on a 9.5 wide rim?
- Billet or Plastic MAF Ends?
- im getting a TURBO!!!!!!!
- please help me problem....
- Is the Hypertech programmer and 160* thermostat worth it?
- What Should I Expect For The Track
- A couple questions about balanced 383.
- Need 12 bolt axle bearing/seals
- Can't get the tranny back in!
- Motive Gears
- 52mm vs 58mm tb
- Who has most miles?
- hpp III shift points
- easiest way to get the fuel pump out?
- What gains have people gotten from...
- block ????
- anyway to tell if fans are on high speed?
- Powder Coated or Ceramic Coated.
- How many miles after heads/cam before going to track?
- OBD1 conversion, anyway to pass IL emissions?
- Hollywood Mufflers
- Do i have to buy a wiring harness to make my MSD Dig. 6 work??
- HPP Tire Height?
- Jethot Prices?
- stock block on a 383 stroker?
- LT4 Hotcam
- Car running hot after Head/cam swap. Need Opinion
- ACA performance...Any good?
- Rattle
- will all ls1 injectors work on lt1's?
- Over Reved!
- best looking wheels...
- Gauge sweep on C5 and Cadillacs. Can f-bod do this?
- 1994 Z28 Wrecked $$$????
- A better Opti Spark?
- Help!
- Jackstands
- cv breather catch can
- cc306 Questions
- which drag wheels?
- pm rods
- Moroso Solid Motor Mounts??? Any Good?
- Finally!!! Heads/cam LT1 running right!
- '97 Camaro SS SLP Hood
- In-Line Fuel Pump Installation Q--Please Help!
- Squeeking noise from front left? tire?
- Is it worth losing your power steering just to replace the alternator?
- One of My New Favorite Mods (Borla E Cutout pics)
- wiper motor
- '96 TA: What O2 simm connector type do I need?
- Highway driving with a 396 Stroker
- Anyone read that 1.7 rocker thread?
- Jinxed myself...
- Low system voltage causing misfires?
- Question about BLM's and o2 millivolts...
- Need part # please ...
- Rectangularish shaped exhaust
- Stock LT1 idle speed?
- Electric Cutout?
- SES light?
- MSD Digital
- PCM for less
- Is there a smaller alternator I can use?
- experienced .several questions about 1.7 roller rockers..?
- whats the best programmable PCM
- six speed race shifting
- Part question
- My car has kind of a sweet smell when I get out
- Stock Z with like 10 MPG
- Re Tourqing the Knock Sensor
- DYNO # XE224/230 and lloyds heads
- anyone take the CC's out to 68cc? 72cc?
- is there a heaven for camaros?
- Oil galley ball
- Engine pull out the top w/o discharging a/c
- swoosh noise from fuel rails/line
- LT1 rocker studs vs lt4 studs
- hours? opti?
- Gear install kit, complete? or deluxe?
- Replacing top dash piece!!!!
- DR sizes
- Lopy idle and knocking
- Engine toast, maybe? What to do next
- Nos inline fuel pump
- Is my TH400 slipping, or is this about right w/in
- is $1800 a good price for a complete rebuild?
- ABS inop light?
- Leaking gas tank?
- Would this cause SES light?
- Anyone with poly seats?
- AC Delco T-stat How much?
- Hotcam and Idle Issue
- O2 Simulators
- Are 93 & 94 m-6s the same
- EGR question? Please help
- Finally!!!!!!!!
- plug wire question
- Exactly what do i ship to when having my PCM programmed?
- Member Went 11.02 125 With New Set Up
- 3.23 Rear Gears
- New Member And New Times With New Set Up
- Mufflers a little quieter than bullets
- 02 Sensor question
- Should i get these rims?
- Engine clatter ? on new 383
- Any good weight saving tips for a 95 Z28 convertible?
- is 93-97 steering rack different from 98-02?
- Car doesn't start, then it does, then it doesn't, help very confused
- 93Z With Opti problems
- Biggest tire in the back
- K-member install guide
- 6 speed growl
- stroke from 350 to 383...good idea?
- Need advice on guideplates....
- post your cam install mistakes
- Re-occuring Code 48, why??
- best pick of the two
- What do you think about buying a used cam.
- Odd problem - Possible Opti?
- Something Leaking in rear area...
- whats wrong with my window?
- Weight of car?
- Camaro Owner To Be
- Car will not strart???
- Weird Problem, help if ya can...
- msd ignition?
- anybody try the edelbrock performer lt1 heads yet?
- to many miles to mod?
- Porter screwed me on my heads, need best option for my built 383 combo
- intake CAI alternative fitting
- WHY did it not shift into 2nd.!?!?!?!
- Any info on Extrude Hone?
- Does adding trans cooler add fluid capacity
- Dynoed My '97 Z Last night... kinda depressed with my results... what do you think?
- Hard start after rain...sometimes smoke.
- Whats the best way to find an exhaust leak???
- small problem
- Car Hesitates To Start Sometimes
- A4 or M6
- Top Speed
- Slp clutch and billet flywheel installation
- New dyno numbers are in
- alternator's jacked...i think
- Do you bleed the ABS when bleeding the brakes
- How Fast Am I Looking At In The 1/4
- Oil in Intake Manifold
- throttle body bypass
- Replaced Opti, problem still
- Part # that I can't find in the manual
- dash to windshield panel replacement
