View Full Version : LT1 Based Engine Tech
- LT1 performance questions?
- Alternator Cutoff
- Fastest car w/ stock heads/cam/manifolds/converter?
- coil bad?
- heat in car not hot.
- z28 weak performance
- Tranny slipping?
- Cracked the accessory bracket
- 1.6 RR Install w/ Comp 987 springs, what torque setting?
- .596 lift cam on a .600 spring?....
- What removes carbon buildup?
- What The #$*@!!
- High Mileage check in! How many miles with what mods?
- cam question?????
- Help please, trying to fix squeaking sound after wreck.
- dyno #'s and 1/4 time- people w/ heads +cam
- AIR pump removal - relay needed?
- Normal transmission temps (4l60-e) ??
- if i didnt delete tranny tables...
- anybody with gmmg in chicagoland?
- Hotcam with blower guys
- I need Help
- Fuel smell
- 355 build up ; Engine wizzards, please look
- How to tell if starter is dead
- Ok, what cooling hose/metal line is this?
- Limitations of stock lifters???
- pvc system
- Oil Recommedations
- Help!!
- when raising the roof...
- LT1 intake porting & welding
- nobody sells 94 6spd consoles?
- Carrier Shims !!! ARGHHH !!
- Correct Cam Dowel Pin lengths??
- Push Fans worth it?
- Lt1 Uprgades? Your opinion!
- Hooker super comp supposed to be broke???
- Can you wack a plug without actually wacking a plug?
- wheels spin, whole car shakes...?
- will loose rockers cause engine breakup at 6K?
- Something has to be done!
- Doing Clutch this weekend...Any Tips?
- Couple Of Questions
- All TH350/400 Guys, Come In Please...
- Big cam and stock exhaust manifolds. What to expect?
- Round headlight conversion...
- Does anyone from the bay area program their own 93
- Header gaskets.. Percy's or Earl's?
- Were to buy Headlight Motor
- Keyed balancer hub
- All guys who had their engines rebuilt or machined......
- just wanted to say
- Holley TB Peeps.....
- Anybody runing a ZEX kit?
- Cold air is a tight fit and seems a bit to long. Help plz
- contact info for ACA Performance or MCLEOUD
- Rebuild Kit...
- Free Mods
- offroad pipe, elec. cutout?
- BBK TB, Need to repositioin the TPS?
- newly Rebuilt LT1 Sputtering and popping
- PLEASE HELP!! My new 97 WS6 won't start!
- Gas tank lid, new o-ring
- DIY Engine Pre-Oiler
- come in if you're running weld wheels
- MAF Ends and Roller Rockers
- Code 16 Lo-Res Failure???
- Misfire cause rich condition??
- Summit sells Opti's for $279!
- spring question
- LT1 transplant problems
- E5 Torx wrench
- Speedo ? (no, not the swimtrunks!)
- Free online service manual
- standalone pcm for 4l60e?????
- What's my compression ratio?
- 396, cc306, GTP s2, what rwhp?
- mid 12's on a street tire- whats it gonna take
- Is my thermostat going bad???
- Should i order this cam on a 110 or 112 LSA?
- Price for rear rebuild?
- quick disconnect steering wheel?
- Installing OPTI...
- Datamaster/Freescan help
- Will I be able to beat my friend's Cobra??
- Good clutch for daily driver with fair amounts of power?
- Best option for ignition upgrade
- want low 13's or even better high 12's with LT1....
- LT4 for a 93?
- electric cutouts: problems?
- Fans
- TunerCat A/F Ratio Spreadsheet
- Need ASAP help with CAI
- LTCC / Bob Bailey - great product / great service
- EGR Question...again :)
- Flow Master Cat Back
- Need some suggestions, please help
- Do I need a new oil pan for a 396 strkr
- did a new clutch and makin werd noise?
- Does anyone know the jet size for 125hp shot on a NX kit?
- Got a noob question bout 1-2 gear
- Long tubes with Subframes
- keyless entry problem
- Gain
- windshield heat spots
- problem with clutch (centerforce dual friction)
- Opti Conversion Non-Vent to Vented
- Bad results with LPE CAI
- Cheapest place for CSI WP, Cloyes Double Roller, and 2 piece front cover???
- Weird Coolant Leak!please Help!
- Do you have to drop the oil pan to replace the rear main seal?
- Tire sizes please help
- Headers!?!
- Question about Cams? I know Nothing about them!!!
- steering wheel removal
- ? on 1.6 rr
- MAC Mid's Owners
- Drops of coolant all on the front side of my engine...
- C clip eliminators
- stock cam #'s?? and what cam is best for me?
- next mod
- Anyone know the guy who made the metal headlight gears for firebirds?
- JetHot LT's VS. Hooker Coated LT's??
- Are o2 sims sold by the pair?
- Eaton Posi
- air box
- Auto Zone Opti Spark 95 Z28 Camaro
- Driving on a Broken Tranny Mount
- Airbag Delete, any links or picks to remove.
- What should I tell this guy?
- Accel Ignition
- Anyone Running the 227/233 Cam??
- DYNO results with HOTCAM!!
- to reuse stall and cooler in 94 4l60e
- Plug that goes into the opti
- Sometimes my car just clicks! and no start
- Go with OEM cat or hi-flow cat?You decide
- Wiered Problem Never Heard of This
- Lt1 to Lt4 Conversion!?
- those with moroso solid motor mounts..
- welding in egr fitting into LT headers
- Teflon Tape & RTV???
- MAF problem.NEED HELP QUICK
- Results from scanning car with SNAP ON SCANNER
- Does #1 have to be at TDC when Opti is Installed???
- Crane Hi-6 Ignition
- Headlight Making Noises???
- DIY O2 simulators?
- need some help with my other car this time.. :)
- Supercharger
- Weird sound from gas tank?
- Stupid Skip Shift Light.. and HELP!
- What intake manifold is this?!
- anything i should know before installing new (used) injectors?
- Duals + BMR Trakpak=possible?
- wont start after Heads and cam
- Obd-1 Obd-2
- New tires , what pressure?
- Who builds the STRONGEST 4L60E's out there??
- porting heads question
- 160 thermo question
- Got some Dynatech lts now what??
- shift light install on 1994 z
- Canton Oil Pan...
- what are the avg gear swap gains in 1/4
- eibach launch springs
- Okay Guys! I'm really Stumped now!
- Fan Switch ????
- pics of dual exhaust on passenger side
- How far from mid/low 12s??
- Comp 1.7 rockers
- window motor replacement question..
- need some suggestions for mods in my situation
- moving battery to the back..any advice
- A4 dead. Cooler and stall reusable?
- Nitto 555R vs 450 Extreme
- e-brake question
- Will my Spec stage III ever stop shaking my car on engagement?
- oil viscosity
- injector questions
- new oil pump after a spun bearing?
- bilstien shock install?
- 98z cluster in a 97z????
- EX Components Timing Chain
- probably a stupid question
- Catalytic Converter and Canister Purge Valve questions...
- Error Code 1659 on a 96 Z28
- How much hp gain from some exhaust mods
- does this sound like I need a engine rebuilt?
- try twice to start?
- Running 1.7 rockers with 211/219 .530/.560 on 112 lobe with ported heads?
- wires to the starter which go where
- Bad Fuel Pump
- this winters project...gm847
- Slipping clutch
- what to get for 50 bux :P
- Do I need a new Clutch Master cylinder???
- air/fuel guage???
- My friend with the 455 goat makeing fun of my trans am, Help Please!!!
- Oil Gauge
- tranny cooler question
- Autozone's window motors are $75?
- test drove a 92 stealth twin turbo
- Carfax Please
- Friend got a 96 cobra how does it compare to a lt1?
- Slp Header Installation
- Coolant dye with a blacklight..where to get dye?
- 1994 1le car
- Wiring question (technical)
- trans am worth it?
- Options after lowering (Exhaust)
- Clutch question..about flywheel
- car wont start
- Gauge Plastic Cleaning
- how much N20 can i run????
- Anybody running the Combination Motorsports budget 383 kit??
- Couple questions about Jet-Hot LTs
- 3:73's or 4:10's
- free weight reduction ?
- harmonic balancer bolt question,..
- LOW OIL light comes on and off
- at what NA hp level would one change to a bigger TB?
- Stupid water pump install question...
- Anyone do any business with Diabolical Performance?
- what gauge cable should i use to relocate the battery to the trunk?
- moser 12 bolt questions, help asap please
- Rust on rocker arms?
- dyno tune
- How many cfm fan?
- i set a goal. Help me get there
- cheapest longtube headers
- is it ok to...
- intake port staining
- Lt4 conversion
- Overheating
- Summit OffRoad y-pipe for dual cat cars. Opinions?
- Should my car be blowing out some smoke at WOT from tailpipes?
- OVC wires and 94-95 MAC headers
- where should i get a new opti?
- Can I replace the header to Y-pipe bolts?
- Best plugs and wires
- Price for loyd elliot to port heads?
- Anyone have an engine built by Combination Motorsports?
- TEA Intake Review
- spark advance and knock...
- 81mph on the 1/8 track= to what on the 1/4 mile?
- Power steering failure, need advice.
- should i change my opti while the engine is out?
- Y-Pipe
