View Full Version : LT1 Based Engine Tech
- '93 LT1--Best way to 12's
- 918's with cc306???
- How do I make my exhaust really quiet???
- question about tunercat
- Enhancing Performance
- Problems with the pro5.0 shifter
- rod's for 95 lt1
- New cam dowel pin. Cut or push in?
- whats the deal with the SLP short throm shifter
- Gear ratio of a M6 z-28???
- Are Pushrods Supposed to be Parallel???
- AS&M headers with BMR K-Member
- Tach and Speedo gone wacked.. need help
- quick help
- True dual Prices and pics
- LS1 catback on LT1?
- 2 Different EGR Valves
- Any stroker guys using Hotcam...
- Mac Header install
- Motive Gears...
- Gas milage with the CC305, CC502, or Hotcam?
- 847 on a 110lsa what do you think
- abreviations
- In a flash...thanks for the help all...
- Help! Clogged Cat/Exhaust options for '97 Car?
- Choking problem..(shoebox anybody???)
- Accel Gen 7 DFI users....
- SLP headers -- Only option for stock Y pipe?
- Jet Hot LTs REALLY woke up my car!
- Missing about 2 cups of coolant?!!?
- exhaust leak - damage to valve seals?
- How can you tell Comp R lifters by looking at them?
- H-pipe vs. X-pipe?
- improving trap speed
- New best hotcam/stock heads
- WS6 owners, Firehawk owners and anyone who put Ram Air on their car need help.
- fender lips
- Is this possible?
- Installed long tubes now both 02 sensors dont work?!?!?!?
- Short Somewhere?
- Need Help Urgent
- 1/4 mile times with Mods Listed (383 Stroker)...Discussion...
- Honda or Redline ATF for m6?
- 3rd gen exhaust setup on a 4th gen
- Wich shortie headers?
- 4.10's??
- Oil pan leak causing shifting problems?!?!?!?!
- Does the STB(Strut Tower Bar) hurt 1/4Mile Times?
- Will these work?
- Hydra-Rev Kit & 1.7 rr's
- Speedo With Th350???
- Do I have to use the spacer that came with the crank hub bolt???
- How Hard is LCA Install?!?! 1 to 10?
- Does the starter on my car stay engaged??
- Anyone knows if our starter stays engaged???
- Quick Q
- have carfax account for 1 month, if anybody needs a check
- tb swap
- Car Alarm
- had problems starting
- What????
- ABS Inop light after LS1 brake install
- 1994 Z28 4L60E Tranny Problem
- Dexcool to Regular Anti-Freeze conversion.
- Do I need these sensors????
- Tips, Hints, Tricks on swapping rearend?
- open loop"?
- pull the motor for heads/cam install?
- Felp! Fuel leaking badly at fuel rail.
- K&N FIPK Intake w/ traction control
- does anyone have a list of tools needed to remove an auto trans from a 93 Z28?
- Should i take out the front sway bar?
- Map + Maf
- Had to hammer that stupid crank hub on...
- Where did my rough idle go??
- The Mods I made Absolutely DESTROYED my A4 ! !
- after airbags deployed and I put new ones in, what should I do
- Up for CA emmisons, few quick questions
- put new complete steering column in, how to make it work
- Success on LTs install!
- Zexel Torsen T/O differential
- Bogging engine/power loss
- new best!
- Oil Leak
- Does lingenfelter have a payment plan??
- Bolt in or weld in re-location brackets?
- Head dilema for my 383...AFR bare castings, full head, ported LT1's etc...
- can someone tell me
- MAF Size
- next mod???
- Pro 5.0 Vibration problem...
- m6 aftermarket shifter ?s
- A little disapointed in performance
- Fuel line quick connects
- Anyone using Prothane motor mounts?
- Is there a snag to this?
- please help
- my heater sucks, please help
- Power loses after 1.6 RR's
- Leaky power steering bushings or just new dust covers?
- NEW BEST!!! Let me know what you guys think.
- exhaust hangers
- Tips before installing SLP clutch...
- Injector plug question
- gotomy subframe connectors and rlc brackets installed.....
- How to remove the crank timing gear?
- Taking apart electrical connectors
- Tire sizes on a stock 94'camaro z-28 with rims not hubcaps.
- flow80 vs. cutout
- Skipped a tooth on timing chain? Newbie has lots of questions
- exhaust on longtubes clearing trans crossmember
- Gutting the cat????
- What compression does a stock 94'z-28 come with?
- Ignition wires and plugs a power adder?
- guys with LT's and dual exhaust
- self aligning roller rockers or not?
- LT1 heads ported to a LT4 intake
- hard starting cold
- Air pump..where do you stop???
- which head gaskets?
- starter installation guidelines
- Spark Wire Routing?
- Windheild replaced now wipers don't down
- Rough idle after washing
- Silent Muffler
- 93 Formula + Moroso + Loudmouth + Free mods = 13.1 @ 105.7!
- Help me i threw a code
- Help Please fresh 383 running like sh-t
- thanks madwolf
- new best lloyds heads/xe224/230
- Putting motor back in 97 Z-28
- heater flush success...and one unrelated question
- lookin at draining the coolant
- What should I do?
- acceleration isn't good
- Exhaust manifold bolt broken.
- 93 Z28 with bad O2 sensors? Weird voltage being reported
- just replaced EGR gasket... not problem
- It got Deleted... but the 1st performance install pics are back!
- heater core or thermostat...?
- ALMOST 11's w/ STOCK heads and 4l60e!!!!
- Opti, Wire, or Plugs??
- CC306, stock heads.... How to tune??
- Don't know what else it could be
- Car rake for drag racing
- Vette Seats in an F-Body??
- Adjusting rocker arms on high milage stock motor?
- video's or sounds
- cam
- fan switch help
- Where to get M22 oil drain plug & 5/8" capoff?
- Egr Pintle!?!?!?!?!
- CM Silicone hose couplings?
- Anybody's Z running just one muffler under the car?
- LT1 Edit Installation Disk
- what springs
- What do you think of my new times?
- Heater valve
- new header suggestions
- if u have 1.6rr come in here please
- Such thing as a quiet exhaust on a cammed engine?
- Vigilante Stall Converter
- Jet Hot LT's installed PICS inside!
- What relay for csi electric WP??
- engine bogging bad and hesitating at WOT and Idle!!
- Stock TB flow?? Why upgrade?
- Do the cam sprocket bolts need loctite???
- suspension squeak!
- Front wheels hard to turn...
- Need help getting new motor
- Winter Mod List, Help Please
- Plug wires coming loose...anyone else have this problem ?!?!
- Is This the EGR?
- MAF sensor voltage??
- Have 315's should stay 3:73 or go 4:10
- Quick EGR? Doing project tonight.
- SLP shorties guys....
- Missfire,tried everything!
- Dip stick and 1.6 rr clearance....
- Stock lifter has failed at 44K ....recommend new ones please
- rear end noise???
- Crank hub threads are shot to hell!!!
- tensioner pulley
- Clogged cat?
- Drag radial users please
- Cutouts Dangerous
- Help! TC P1415 - "Secondary Air Injection System"
- Compression ratio
- rough idle/stall goes away when MAF unplugged ?!
- Brake Master cylender
- New best, 11s stock heads :)
- Help ASAP! questions about installing Long tubes
- smog/cc306
- Heads and cam....
- project82lt1 first track times... cam sugg?
- Trick Flow Engine Kits 350-445 Hp
- Got an SES light last night..
- New Dyno Numbers, but pissed about dyno RPM
- what size tire on a 16*10 wheel
- Holy crap...just got my true dual Bullets...
- can someone tell me what this bolt does... (LT install)
- Water Pump Help
- fuel filter able to freeze??
- coolant leak
- How much material do I need to take off the timing cover to fit a double roller???
- Bad Vibration over 90mph. Could it be this?
- What would be the difference...
- a question about hotcam/headers install
- Another question.
- Need help picking out injectors of new build up?
- How often do you guys adjust your rockers?
- how to remove dust boot
- Timing cover gasket.... dry or rtv??
- Question about headligt problem??
- 2.73 to 3.73 (? on required parts)
- where can i look at the gtp cams
- Whats the difference between shorties and LT
- Any idea if a 95 or 96 Firebird factory radio will fit a 94 TA ?
- MAF Problem?
- How much noise do 1.6 RR's make?
- Strange Problem 95 Z28
- how to get spark in?
- skip shift question
- Battery loses charge after sitting a few days. Normal?
- Leaking lots of water?
- Are my comp non-sa 1.6rr's going to rub the valve cover???
- somebody help me with my taillight problem... shoebox?
- Wanted: 9 or more people to go in with me on a run of custom Mahle NOS Pistons
- Anyone in the......
- Tranny Question, Please help!
- EXTREMLY bad vibration when i turn...Please Help.
- Little help with my Jet-Hot LT's please...
- ICM question
- OBD1 Conversion Question
- Safe to drive my car?
- After a long struggle I finally got my LCAs on, thoughts within...
- Stripped 2 threads on crank hub bolt...
- emissions
- SpeedPro Powerforged Pistons....AWESOME!
- What's wrong with my car? Please help.
- Electric Cutouts
- Temp not as low as usual? WTF?
- headers
- Quick Question
- Mid -Lengths out do Longtubes!!!
- What are the odds of the optispark seal leaking?
- HELP!!! Can't budge bolt on LCA!
- Clevite Rod& main bearings off ebay??
- Dumb electrical systems in LT1's
- Where to get Dyno Tune in Bay Area
