View Full Version : LT1 Based Engine Tech
- i need some help!!!
- Position of MAF censor?
- Just for fun, 10sec with 383
- Injectors and over 80% DC
- EGR on or off
- 94 TA Hoods
- 150mph speedo in a v6???
- Granatelli MAF
- Exhaust ?
- Why does my car do this? (weird)
- Needing a good mechanic
- high lift or milled heads.
- Sensors on brake pedals
- OVC People, is this correct?
- I burnt my fuel pump up
- fuel injector size
- not an LT1?...?'s about Jeep 4.0L
- Back from the Dead..So to speak
- Lost on what to do.
- Supercharger-type whining noise coming from my car at over 3500rpm's...
- LT1 Engine Cleaning/Degreasing
- How to quiet her down a lil.???
- "Tuning out" cam surge?
- My hooker Y pipe doesn't quite fit
- valve adjustment with hotcam??
- Dyno today high A/F (NEED HELP)
- am i getting bad gas mileage?
- hotcam tuning ??
- Home Intake Porting
- cc306 in a daily driver?
- Burnt wire.......now what?
- ******New Videos of the 396!!!!!******
- Good decision???
- Stainless steel CAI elbow from SLP
- Could use some help in making a purchase
- Fuel pump problems
- Mail order or Dyno tune/programming
- 96 SS wheels on a 94... problem
- Need advise BAD
- Dual cut-outs on non-custom Y pipe?
- part number
- Catalytic Ineffiencecy
- Where to find an offroad stainless 3 Inch Y pipe for 97 camaro
- Emissions Guru's inside please
- Wheel Hub?
- Question about head studs...
- Running rich (what to do first)
- What size tires...
- Spring question.......
- Steering linkage dust cover with hooker LTs?
- Best Price on a CSI W/P?
- Spin your front wheel....
- People with SS's inside!!! stupid question....
- is this a good deal?
- QTP or DMH cutout?
- Those With Wolfe Cages/Bars, Inside Please...
- how to preserve block now that heads are off
- how fast are these cars stock?
- Just finished installing 233/239....
- 3.42 to 3.73 on 6M...I can tell a difference
- My transmission perform button works!
- radiator removal question
- valve spring installation height.....
- How much (grams) do the stock pistons weigh?
- 5 points and stock belts, how to have both
- True Duals w/ Twisters
- when someone gets programming for 93 octane, what is changed?
- Whats a Good Torque Wrench???
- Brent94z so you still sell headlight gears?
- How long are our shocks supposed to last?
- LS1 Aluminum driveshaft on 97 LT1...
- longtubes vs shorties vs midlengths
- What is a REV KIT?
- Dynaspark user's inside
- hot cam parts with cc306?
- are springs wore out at 100k?
- What 1.6 RR's add the most HP?
- A4 with t-tops
- window crank removal
- 1LE driveshaft
- Gears
- Electric fan and Service engine light??
- Adjusting Idle?
- Much of a difference?
- Anyone who has/had a slipping clutch
- What do you consider a "factory freak"?
- motor gasket kit & plugs
- Comp XE Users Inside
- Motor Oil & Filter, Trans. Fluid, Rear End Fluid
- Borla Y-Pipe, Exhaust, Straight Pipe
- Hypertech Programer
- Eldebrock Heads
- clutch still not right
- Intake manifold was torqued but never ran, can I reuse gasket??
- master brake cyl
- i want pics of chrome ZR1s on a T/A
- New cam with an Auto?
- My horn doesnt work
- SSBC brake kit with spindles included?
- fog light blackouts??
- Does this sound like a bad computer?
- Heat core hoses leaking...anyway to fix other than replacing?
- plugs and wires install
- 383 sound/vid clips
- New to the lt1 world..
- Tall Valve covers?
- 4l60e questions
- Where to get 1 plug wire?
- Real quick valve cover question
- Do I NEED 02 Sims?????
- taking apart plugs again -- shoebox
- Will this be too loud for everyday driving?
- do my ttops have vin numbers?
- Rod length
- Roller tip rockers
- Homemade CAI???
- where can i find the cheapest 3" cutout?
- Most common reason for engine miss????
- 1LE Elbow Question???
- Need help with exhaust.
- Which headers are the best?
- 350ci LT1 times in 1/4mile with bolt ons/ headers..?
- fuel delivery and pressure regulator questions..
- hows this sound for exhaust?
- Recomendation on tires.
- Quick help: removing the Crankshaft pulley
- Lowered Z28 exhaust options?
- Hooker Shories better then stock?
- help removing passenger side cylinder head
- Lt4 Heads and stock exhaust manifold
- gmmg question.
- why do i have the old gauges?
- Resurfacing an LT1 flywheel ? Good or not so good ?
- Rattles from jethot Longtubes
- What fuse for keyless entry?
- xe 230/236
- Timing Chain Set?
- lg motorsports g2 brake upgrade info
- eastcoastsupercharging or stage1performance?
- New; sqeaky brakes
- hotcam m6 guys what are you idleing at?
- spun bearing+blown rings.. what are my options? help :(
- Why are some of my rockers/pushrods not moving??
- C5 brakes & Baer GT+Brakes
- Praise Combination Motorsports!!!
- 1995 Obd1
- are BFG comp ta tires anygood?
- Is it okay to use stock pushrods for 2-3 days with guideplates???
- Thoughts on a Dual Exhaust set up?
- LT1 Leaks
- ASM headers with what y-pipe?
- EGR valve??
- Rough idle after coil install
- custom Y-pipe
- Double Diamond VS. Tubular Subframe Connectors HELP!!!
- mixing oils
- Unusual Starter Behavior (will not crank)
- Magnets on the oil filter and drain plug
- 0-60 Gear Shift
- simple question about an oil change
- Torque Specs on headders
- What size slicks for 15x10 wheels?
- Engine Suggestions
- Subframe Connectors, I found these..what do you think????
- electric water pump question??
- clutch vibration at 85mph +
- So why doesn't my cruise control work?
- Failed Smog!
- Reasons not to get 17x11's?
- Anyone run Combination Motorsports heads?
- Ticking noise.
- Turn Signals
- trouble...im tryin to put my moroso CAI on and
- Help! Grinding going into 2nd gear?
- Roller Rockers? Non SA or SA
- Questions about SFC install (BMR)
- High Idle???
- will these fuel injectors work for us?
- Oil Leak after Opti install
- Rear brakes... don't work.
- 5/8" Vacuum cap
- 100 shot and stock timing??
- Second Guessing valve adjustment, stupid question inside
- Performance meters
- new winter oil?
- Direct Hits Ignition? By Tbyrne
- Polished intake elbow by SLP???
- $400 maybe a little more, WHAT TO GET FOR MOST HP?
- How long to c/o H2O pump?
- New Sound clip
- O2 part numbers
- brakes and rotors
- LT4 Knock module
- took the crank hub off, without the arrow pointing up
- what's a K-Member?
- where can i find...
- why use a thermostat?
- Will 30# svo injectors be good for xe 230/236, ported heads, occasional n2o?
- HELP FAST! Car won't start after cam install...
- anybody from southeast missouri area?!?!
- Will these axles work on this car???
- Anyone one in...
- Is it possible to swap out only the odometer from the cluster??
- need some help please???
- any way to calibrate tach?
- STOCK Timing...how much and all in by?
- Attn All Aftermarket Tb/cam People!!!
- Help Me Out Here Plz!
- Cheap 02 Sensors
- How should this engine be balanced?
- Coil replace?
- what is this??
- Are LT1 and LS1 sensors the same?
- new z28 owner
- How do you bleed Clutch Master Cylinder?
- Millitec.....
- 10w30 oil?
- Anyone know the MPH shift points on an A4?
- ordered a DYNASPARK today!!!
- Need Help Diagnosing Car from DataMaster Files
- body harness through firewall
- Aerospace or Pro Street brake kits
- Weird Problem with the Z.........getting worse!
- Part Number
- Hawk rotors on Ebay.
- Anyone ever attempt an LT5 conversion?
- Bleeding CLutch Master Cylinder?
- scanning obdi conversion car
- Power steering removal
- HELP! SES code P0157
- Spark Plugs and SLP CAI in...
- guy with lowered cars and longtubes - need advise
- Used Hotcam, buy it or not?!?!
- Is this possible?
- Rough Cold Idle
- 1.6 rr's=higher rev
- Wilwood 6 piston Front Brake kit
- is it necessary to remove rockers/pushrods before removing heads?
- odd sounds from passanger side
- Steering colomn removal!!!!
- stock bottom end/HUGE HR cam
- O2 Sensor Wiring?
- Installed hooker catback
- Dying opti???
- 95 T/A coefficient of drag
- Replaced EGR...
- Distributor ruin cause of oil help!!
- are lt1 vette heads interchangeable with fbody lt1s? and LT1 Bare Head Part Number?
- 3.23 to 3.42s
- firebird trouble
