View Full Version : LT1 Based Engine Tech
- Rk Sport Hood Grill Wont Come Out!!
- Cheapest Way To Hit 12
- 3:23's to 3:73's A4's
- need more power in the low and mid ranges
- question about air intake
- 94z tripps out after about 20-30 minutes
- What do you think?
- what now!
- stock lifters and high spring pressure
- Anyone running an AFR headed LT1?
- Hypercrap power stat
- Time to pass emmissions, need opinions on high flow cats plz.
- Puralator Breather!
- throttle response
- possible Bad PCM?
- Opti question about broken piece
- F.A.S.T. Users
- rattle, rattle, squeak, squeak, squeak...make it stop!
- EGR bolt size?
- Power antenna question.
- low dyno numbers?
- HELP! How to remove coil from ICM??
- White Sludge?
- aftermarket shifters: whats the best?
- Car looks like it's been raised?!
- 1.6-1.7 ratio roller rockers, Hooker lt's, CAI, Magnaflow
- Thoughts on Stainless Works y-pipe
- Ram air for stock 97 formula hood?
- PST products
- AC Compressor clutch replacement
- Water Pump Install Help...Quick
- Home made CAI tips/suggestions/websites?
- I got 1.7's!!!!
- Cruise control Help.
- dirt and junk got on block during heads/cam removal.. what to do?
- Smooth Bellows For T/A or Birds
- Spring pressure and stock lifters
- Best and lightest damper available for the LT1
- 30th z with LT4 ?s
- battery - insufficient power
- Aluminum Driveshaft Strength?
- Why does my clutch not grab when the car is dead cold???
- unpluged injector for emissions
- Installed HEaders...
- Suggestions and Recommendations On Cat
- synthetics vs mineral oils for diff and tranny
- borla louder than loudmouth??????
- 4" Cut out
- Canister Removal
- Need a part number
- Q's about some headers.
- mobil 1 syn. tranny fluid?
- How do you think this will sound??
- Jet-hot headers installed today lots of problems
- Place to buy parts?
- Airbox Setup on SS hood
- Why do people have such a woody for SLP headers?
- Not rockers, not pusrods, not lifters, ....so what is this ticking sound??
- Coil is arcing between the 2 plugs
- Traction in reference to 1/4 mile time?
- Ecm/pcm
- Easy one for you guys.
- Anyone ever relocated their lighter/vert top switch?
- People with the LT4 Hotcam kit...question
- tranmission woes
- HELP balancer problem
- What pumps the tranny fluid
- Opinions please...
- Possible bent valve?
- Underdrive pulleys
- What sealer?
- Does this sound like a computer problem?
- manley valves .100 longer... where can i buy them.
- Will this timing chain work?
- Heater Hoses - What would you suggest?
- TCI=poor customer service
- MILKSHAKE COLOR OIL CAP NEED help
- how do i get my door panel off?
- Website?
- Got a Loud Mouth!!!
- Can’t feel any difference after subframe connectors. Why??
- Camshaft Question.
- Oil Pressure goes DOWN at WOT
- why is my Borla so loud
- high performance heads
- Need part #s! Help!
- AFR angle plug heads vs LT headers
- Who's Siped Their Tires For Winter
- Let's talk about valves
- HATE Lt1's, grrrrrrrrrrrrrrrrrrrrrrrr.................
- New Battery
- please help,a/f ratio gauge wire
- whats needed to rebuild calipers?
- Clutch slave cylinder
- If not Custom Duals then how about.....?
- Roller lifter question
- i broke something....
- Temp problems
- how long to change lifters?
- 1LE elbow P/N 96-97
- Places to rent gear install tools?
- I might buy a 93 pace car, $11,000 need advise...
- 50# injectors for ATI D1SC OBDII to OBDI
- Cam/valvetrain breakin procedure...
- Anyone have pix of Kenny Brown DD subframes installed?
- Looking for wiring schematics for 94 lt1
- Those who port heads, come inside!
- Lexan?
- Part number, valve cover gasket
- Racenet Stage II LT1 Heads?
- Swarbar Removed....(RESULTS INSIDE)
- Question SES
- what hp/tq gains do jethot LT's add usualy?
- weird leak
- FUEL questions (383 injectors)
- Thanks to LTCC Bob!
- changing springs with heads on
- Whats with 55mph???
- Comp Cam Guys Inside..........
- Someone please enlighten me: How do heads and a cam work?
- Question about Intake on Ebay
- If not heater core that what?????
- Anyone have a "bolton" shaft setup on LT1 castings
- 847 or 230/236???
- What kind of times can I get???
- Torque Pattern
- Need help FAST on spindle install
- look and maybe learn
- I thought this was funny.
- Stock lt1 cam specs
- SES Light
- Got 450$..whats the next mod?
- LCA question
- Z71 Z28 similar tranny?
- Hotcam Question
- EGR delete.....
- My take on the 3.73 gears...
- Callaway ground effects kit for 94 Z
- AC Line and Headers
- Waiting for tires to cool down...
- What tells the shifter that the brake is in, and lets you shift from park? (SHOEBOX?)
- Possible leak areas??????
- Just a quick Question
- Height and length of a Wolf race craft 6-point cage?
- Is it better to city drive in 3rd or drive?
- Arcing, but unknown cause. HELP!!!
- umm why wont my shifter ball/knob come off?
- Hard on brakes coming off exit ramp, got LOW TRAC light???
- Which is better bewteen Hooker aerochamber and Spintech ?
- total hp loss in 3rd gear?
- Problems with shifter moving out of PARK! (Has to do with brake pedal I think!)
- where did you relocate your iat to?
- hooker catback and T-top
- Eagle, Scat, or Callies???
- Losing coolant - having trouble diagnosing
- Question about lowering
- Rods
- Opti
- cam install
- Roll bar for convertibles?
- Backfire and miss at idle?!?!?!
- I need help choosing a cam. Any suggestions???
- Emissions test in Illinois
- Is this a real car?
- vibration
- Low RPM stumble/pinging when warmed up
- Flood?
- Coolant flush question
- Misfire cause a PO133 code?
- Key and resistor chip question, how to wire
- lt1 thermo
- Rearend whine?
- Installing SS hood
- Edelbrock Heads
- Mezziere electric water pump
- just ordered my jet hot longtubes :)
- Heater problems?
- driveshaft tears off from rear end wtf!!!
- 96 LT1 z28 ... what should it idle at?
- Convertible subframe connector questions??
- So, I have a header bolt kinda stripped
- New muffler on and now WOW!
- whats a f1 camaro?
- What do 17x11's weigh?
- where are HOT cam owners revving???
- Sparks flying, car wouldn't stop- what happened?
- Looking for downsides to an OBD1 conversion
- Headliner question - Need updated info
- Timing Chain
- What's wrong now?
- no 2nd gear but...
- Dashboard !!!!!
- HELP broken oil sending unit
- how hard to fix a windsheild wiper??
- Flywheel Resurfacing????
- Was up with the 3k breakin before synthetic??
- Special tool for doing plugs?
- ECM Part Number.
- wires and pullys?
- Lots of Road Noise....Is there a way to silence?
- Heads, cam, lt's install ?
- Less then 3/8 tank = hard start???
- Jet Hot LT question
- Need insight to performance woes. (sorta long.)
- My Heater gives off a FOUL odor sometimes?!?
- Why are my Wipers sitting straight up when off?
- anybody,everbody need your $0.02
- Can someone with an MSD retard box do me a favor?
- Exhaust Question
- head bolt & intake bolt torque
- real bad miss fire after cam swap? please help
- Safe to lift front of body off K-member by a Strut Tower Brace?
- Coil/Bracker Arcing
- best shocks and springs for comfortable ride
- Going with Heads and Cam... WHAT ELSE???
- CAGS install Q????
- anyone ever wrap there M6 trans with dynamat?
- BMR K-Member: w/ Motor Mounts vs/ without...???
- This is what my car sounds like from inside.
- Anyones A4 ever leaked from around the SPEEDO sensor?
- 1 3/4 mid vs 1 3/4 LT header
- O2 sensor have 3 or 4 wires? Ordering one off summit
- Remove the front sway bar, yes or no
- What kind of Bearing Puller?
- A/C problems....
- Is 35/25 front/rear sway bars a good combo? Respond fast please! =)
- 11.5" ET Street on salad shooter?
- Need some advice. Please help
- Desktop dyno File
- Will 18's fit my Z?
- transmission fluid
- Swapping rear ends....
- TB spacer?
- those with Accel 300+ ignition
- How to stop header leak on slip in primary???
- I Dont Get This!!
- Heater Core, Im cold :(
- where to find the comp fuse...
- OK explain to me this...
- trany problems
- I give up... LTs SUCK
- renting scanners?
- Right turn signal dont work
- LPE Supertube
- Please Help!!!
- Does the LT4 Conversion put out 425+
- Hooker LT gasket ?
- Cheapest place for slp cai
- Holley TB Opens to far
- Dynatech opti and MSD 6A
