View Full Version : LT1 Based Engine Tech
- Cheap alternatives to stock timing chain for 96+ LT1 z28?
- How do you know if you have a vented opti?
- Tubular K member?
- Whats it take to swap to a vented Opti
- Jack points...
- Quick borla question
- Need Help with Ignition Key Cylinder
- should i get....
- X pipe???
- I need a windshield
- Should I go for it??????
- Opti-Spark replacement
- Plugs and Wires
- Best Place to Purchase 383 SHortblock
- Heads question
- Starter giving me trouble after LT install
- Guys with Jet Hot LTs and Hooker Y, how does it SOUND?
- options for tuning a 97??
- will an overheating car....
- Horrible stumble only at 100% throttle ??
- air foil and themostat
- before I proceed any further with an opti swap..
- Hi, I have a fan/service engine related problem
- Dual exhaust mufflers?
- Which side of a Percy's Aluminum gasket faces the head?
- ANSWER ASAP Does it matter if my tank is full to install a fuel pump???
- different lights
- Random Catz.....
- What cam should i get ?
- Dynamat inside valve covers... hear me out, I'm not stupid =)
- SS and Ram Air owners: What happens when it rains?
- Where to buy lt1 edit and the cable?
- What am i looking at in RWHP??
- true duals?
- I think my opti's going bad.. HELP!!
- ? Havin some troubling engine problems?
- cc306 on stock tuning?
- Problems interchanging Engine wiring harnesses
- True duals and conflicts with suspension parts?
- Best sfc
- Could this be the master cylinder....
- ZZ-9 and Jot Hot Longies over winter?
- good cheap intake?
- smoke out tailpipe / fouled plugs
- weird sound on start up
- Seperate Timing issue
- Lifters collasped or timing waaaaaayyy off
- Any guide to keep fuel bucket with Walbro 340?
- Tranny not down shifting..
- fan switch purchase
- Dash lights for swap
- Suspension mods.....
- arcing between the the boot and block WHY!!
- Little lights above window switches/door locks...
- descreening MAF
- What mods should I do now??
- why did my timing chain break?
- Vert owners with !CATS..Need advice.
- got my DMH electric cutout installed
- What can I get for my whole front clip? Its a 97 Maro
- ok question for those out there
- Anyone want to help me with a ttop conversion in Oklahoma
- What keeps killing my battery!!!!!
- Well, thats why the belt went!
- Those with FLP headers
- Thrust bearing shot already
- ABS INOP light on??
- Spark plug diagnosis needed please.
- Idea for True Dual set up
- Alarm question
- grille insert
- will this hurt anything?
- Need some important info: Possible collapsed lifter
- Egr tube or Air Tube Noise
- Looking to buy an LT1, have some Questions...
- Tires and what?
- Heater performance problems
- To much back fire?
- P.i.t.a!!!!!
- air/fuel ratio
- Are Stainless Steel Brake lines worth it?
- HP/TQ Numbers......
- What is VATS
- Valve seals - brass, teflon...???
- 97 header issue
- Help me pass SMOG.......
- E-Cutout
- opinions wanted on T-top conversion on a true 30th camaro
- my autoxray is showing -12 degrees for start up!
- Where to find used/cheap LT1 interior parts?
- Quite down exhaust please.
- Metal Gears for headlight motors? Who makes Them?
- Exhaust Vibration
- Exhaust rasp cause?
- some1 with AIM read --need help
- mac mids or jet hot lt's
- My temp gauge is moving all over the place??? HELP
- stock crank and rods???
- what is this?
- New Jet Hot LT Photographic Install Guide!
- cam
- cold weather vs timing
- Mac Midlengths! Help What is NECESSARY FOR INSTALL?
- Aeromotive FRP
- Need diagnostic tools!!!!
- Steering wheel radio button?
- Running Rich...How can i fix?
- Does your lt1 do the same thing...pissing me off
- set of 8 - 25lb/hr fuel injectors NEW - $99.95
- Making HP
- Impala Performance
- who makes the aluminum intake bellow
- My new car.....
- Gear Question
- What size is stock Y pipe
- cam purchasing help
- Why not B&M?
- LT1 Engine Identification?
- flowmaster muffler
- intake elbow 4 sale
- What's your 60' times and what gears you run???
- What happened to the HP (67->95)
- 95 double roller w/stock WP
- Steering lock-up???
- Dyna Spark!!?? Any one have Good/Bad things to say about them
- Is your exhaust too loud???
- 94 computer part# for m-6
- Question about LT4 springs.
- do you need the A/C bracket to delete ac?
- Getting ready to fire up my new stroker, but have ????
- Roller Rockers Revisited
- 502 max hp? from an Impala guy
- O2 sensor question
- PCM qs
- Whoooooooooo these Jet-Hot LT's are sexy! Got some up-close pics...
- umm question about dual exhaust
- what needs to be replaced? (pic)
- New some advice...
- Random Technology Issues
- Pushrod help needed
- Stupid Window! Moves Back And Forth!
- lt4 hot cam Horsepower and videos
- Bulb
- SES light, rough idle, please help!
- Jason Cromer
- what first; headers, gears, or stall and shift kit?
- Break-in engine
- stock headers on 93 z28?
- cheapest place to buy cc306 online?
- flowmaster - dual outlet - drivers side
- Someone Help please...
- can any 3rd gen parts be used on a 4th gen?
- lingenfelter camshafts???
- How many O2 sensors?
- oil gauge going to zero...
- changing O2 sensor
- 98-02 ss spoiler on a 96-97?
- art carr transmission is installed!
- Need help finding correct exhaust manifolds *NON LT1*
- legal nitrous??
- Quick/easy question...
- crankcase vent hose part number?
- Cam too small?
- Next Mod?
- borla or flowmaster
- exaust dump
- LPE Cold Air Intake Installation question!
- Need Jason Crommers PH #?? Help
- need a new opti....what's the ABSOLUTE CHEAPEST place to get?
- what is your compression?
- Anyone have experience or opinions on Super Trapp mufflers?
- leaking valve covers
- LT4 conversion people...
- Where can I find Impala combustion chamber pictures?
- Will these rockers fit?
- Best $2500 I can spend on a 96 Z
- any links to jet hot install step by step?
- Fuel system with LT4 Hotcam kit?????
- Help with replacing fuel pressure regulator
- Very Bad Shaking...Please Help.
- coated LT's in the winter?
- I need suspension help
- Anyone know of inexpensive places for o2s?
- rear end removal
- Lt4 KM with LT4 Extream timing chain
- price of new opti?
- Bad Dyno troubles/issues....CC306..
- ? for those who have shipped LT1 heads...
- LT1/LT4 Valve Covers
- Jet Hot LT Sound. Disappointed? (long)
- Moroso Blue MAx
- How much $$$ for 3.73's?
- Line Bored Timing Chain???
- jegs roll cages
- Cc306
- Best Street Head/Cam Package
- AFS wheels
- is it realy necessary to gap plugs??
- ram air question
- head machining
- Remote starter
- Bolt Ons: Best Bang for the buck?
- Lost my clutch and opti at the same time
- what should this combo be good for??
- help!, how to get rusted bolts out?
- Is this my belt slipping?
- PBR's on 1996?
- For hp estimate experts....
- CSI questions
- TCS Wiring / Cutout
- Is This Going To Work??? Help
- Can I do a cam and head work this winter for under $700
- Diff between 95 & 97 lt1
- heads
- after market ignition?
- CID of my motor????
- Decent cheap 383 stroker kit??? Check it out!
- Idle around 1800rpms!
- Questions about summit
- cam swap ?
- go with the catback or just keep the muffler?
- random questions
- Black soot and some liquid out exhaust
- Spring (EX-612) question......
- Anyway to make my car run leaner?
- Backfire?? causes??
- Why doesn't anybody use lock washers on their header bolts??
- Re-torquing head bolts.....
- 95 ta no spark HELP!!!
- limited edition 1996 SS
- Is There A Kit To Put Alt. Where Air Comp. Goes
- Mysterious misfire
- HELP ON Lt1
- How to quiet it down???
- Can a dynomax Ultraflow fit on the I pipe? Not lowered
- CC306 vs xe 230/236 112lsa sound
- can the ABS module be rebuilt?
- clunking noise?
- what could cause this?
- Real Quick!!!!
- ram air baffles.................
- what is this computer in the front driver side of the car?
- replaced everything brake releated in the front of the car, still pulls hard left
- hot cam sound clip
- Noise in Engine...Exhaust Leak?
- Mounts
- How to remove the Passenger side exhaust manifold?
- Is she safe to drive?
- Bent Rods? How To Tell?
- where to get metal gaskets?
