View Full Version : LT1 Based Engine Tech
- Torque difference on Hotcam; c305; 224/230
- Cleaned MAF, IAC, IAT, TB, and installed Holley Airfoil!
- ltcc?
- Possible vacc leak around pcv...
- Remote Quit now horn beeps
- Electric WP
- No more mobil one oil filter for me. Help
- best place to buy a Strange 12 bolt
- 383 stroker kit
- cooling fan wiring
- What is everyone using to monitor their engines?
- Security Light
- snap! timing chain
- VA Emmissions with cats
- Can you put dual valve springs on stock heads?
- DTC code Question
- Interior question
- What would cause water to drip (really fast) out of tailpipes?
- Header Coatings...What do they do and do I have to get my MACs coated?
- Getting new Longtubes
- Whats happening to my oil?
- Help with no motor!
- Throttle body mods?
- How restrictive are cats?
- stupid question
- What cam to do over winter with stock heads?
- quick hotcam related question
- Questions about my new to me 95Z
- Extreme 230/236
- 52mm Throttle Body won't idle right
- I did a wheelie!
- anyone smog their LT1 on the new CA smog2?
- weird hesitation / power surges
- Part #\where to buy speed pro forged pistons
- New to the board and am looking for input
- 2bolt vs 4 bolt main
- Any "how-to's" on heater core replacement.
- Opinions and ?'s on torq thrust 2's for my z
- Water pump
- rockers hitting dual valve springs !! Help?
- Do I have everything needed for my LT install?
- whit smoke from exhaust/rich gas smell, and SES light after opti install
- Car fires up and dies in cold
- Washing my engine
- loss of hp??wtf???
- cam shaft,fuel rail covers
- Exhaust popping when I give it gas
- ...cause water in intake?
- Tie rod ends
- Car misfiring at 1500-4000 RPMs
- Vacuum
- Stumbling during acceleration
- GMMG group purchase
- O2 Simulators
- Hooker Longtubes
- autometer transtemp install, quick question...
- ? about removing heads
- cam?
- Are these lt4 heads??
- Name this Hose!?
- Who has locking lugnuts that can accept the stock lugnut covers?
- Hooked up LT1 Edit Diognostic Tool, What should KNOCK COUNT be?
- how much hp is safe
- Cat with 2 bolt Flange on each end? Anyone?
- BF Goodrich Comp T/A Drag Radial
- Will a 97 optispark work on a 95 LT1?
- Starter lasted 9 months, no warranty?!?!
- URGENT Starter problems continue!
- Longtube Headers
- ES poly tranny mount or stock(help fast)
- Used 100 octane, now the knock is gone. What do I do?
- Clutch Slave Cylinder
- CAI which makes the most HP ?
- Jamex lowering springs
- NOT to Happy with DMH Cutout...
- Belt Size w/ pulleys???
- Rewiring my 94 Z28.
- Cam lesson 101
- Oil everywhere...
- heater core replacement
- SLP Clutch/PP = AWESOME
- new timing chain by lunati
- ET with new mods ...
- I keep breaking wheel studs....
- Anybody elses header do this .....
- Good price needed
- Where to buy Lugs?
- Replace new extreme duty set?
- Dumb? 2 bolt vs 4 bolt main
- what should I get next? Have about $400 to spend
- 3/4" or 1" header bolts
- Anyone have Pictures of Clutch Master Cylinder Installed?
- how much will this cost?
- leaking fluids
- keep blowing fuse?
- slp ultra z ram air hood? worthless?
- Car won't start
- A4 To M6 Swap
- Using cc 943 spring on a XE230?
- My heater sux, help!
- whats wrong with my rear end?
- 6speed conversion question
- 224/230 vs 230/236 vs cc306
- White Smoke after timing chain install???
- is it normal-49 psi fuel pressure without vaccum
- Reprograming??
- 383 or 396 dolar for dollar which one.
- A Friend Died Today
- Scanmaster on a '96
- The power of a tune up
- eveything bought except timing chain
- Pics fo your engine bay
- miss again
- People with Aeromotive FPR inside..
- Sway Bar Brackets
- FYI: To everyone with stock injectors and 340+ RWHP
- 58mm or 52mm TB???
- Anyone change torque arm bushing?
- cc306 cam number questions
- 94-95 headers on a96
- Ebay Subframe Connectors?
- Exhaust tones AFTER LT's and/or Cam..
- axel removal to replace wheel studs?
- Ok NOW WHAT!
- found this on ebay, is it worth it?
- Z06 MAF vs. Granatelli MAF
- Use 2.02 Intake Valve = Change in Valve Spring Height???
- Cracked header WTF!
- Possible Mod conflicts?
- Urgent Brake Help!!!
- ls1 maf work in place of a lt1 maf?
- Where does this go?
- 700R4 questions
- Is Left O2 sensor the Driver side one?
- scraping sound from back right
- Quick Fuel Question
- MAf connector.
- Ordering LT4 Starter
- So What's Next?
- amsoil better than mobile 1 ?
- cutout sounds
- Front brakes.
- i need the exact location of the ground for driver side turn signal
- BFG Drag Radials
- Junked parts
- LS1Speed : Reccomends this setup! Yes or No?
- How and how often????
- Front brakes dragging
- Question Concerning 93 O2 Sensors
- My Next Mods HP/TQ Thoughts
- Part # for 12-pt ARP header bolts?
- DMH E-Cutout
- First freeze, and now grinding.
- Who has had good luck with Centerforce
- Frozen Doors
- Buying New Car... LT1 Vs LS1!
- Can ls1 catback (gmmg) fit on lt1?
- LT1 to LS1 Swap Out
- What a POS!!!!
- Anyone here with JetHots w/air +egr fittings?
- Where did you put your Cut Out???
- Underdrive pulley spacers?? Which goes where?
- Fog light bolts
- What exhaust?
- smoke from the shift boot
- smoke comin from the shift area
- SFC question, did I do any permanent damage?
- Ls1 vs. Lt1
- Loudmouth with No Cats
- AS&M Headers?
- Another Seafoam? Just look!
- 233/239 Dyno Results!
- Gears
- Eibach Drag Launch Spring ???
- hmm...any1 know of a good cable controled cut out?
- Best cat back for long tubes?
- roller lifter ?
- Proper Valves?
- Any way to repair electric cutout? Help please.
- Wierd Noise from Tranny
- 15'' wheels on f-body
- neeeeeeeeed replies QUICK
- Rag Joint, Question?
- does a g-tech pro really work?
- New best with 3.73's and my 224/230 setup :)
- Searched, but can't find dyno numbers from MAC mid length headers.
- How long is the dowel pin come out with timing set on?
- Anyone here using a "Dyna-Batt Batterie"
- 400sb w/lt1 heads?
- tires?
- Post your Vid or Sound files here
- 95 heads part #...what is it.
- Car smoking like crazy, any ideas? Ready to push car off cliff.
- T.b ?
- SLP Short header install suprises ( very long)
- Pics of LT's and Purple Hornies (or simmilar mufflers)
- hard starting
- howling from the rear ?
- Sudden Stop And Asr/tcs Function Turns On!
- Anyone still scan SES for free?
- freescan question
- Racemaster Crank
- Turn Signal flasher....or no?
- best spark plugs and wires?
- Prices on N2O refills???
- Clearance with my LT's and a 1.75 drop...
- Need size of tranny mount nut
- How to tell if LT1 KM or LT4 KM
- What do you guys think?
- Advertised duration... cam experts help me out.
- Where to get SOCKETS for the tail lights,for cheap
- how do you remove abs
- Turn signals
- Nu-tek Motorsports
- 93 Z28 Question concerning transmission
- Cheap Modded Dyno Numbers!
- frozen starter?!?!
- how about a 4" stroke 408?
- Poly mounts ?
- Something broke!
- EGR trouble
- you won't believe this...
- Which scanner to buy??
- cutout question
- Anyone ever try something like this with their exhaust?
- Magnaflow cat back for Z28
- OptiSpark Fudging up
- How did I break this
- 306 cam on my 97 lt1?
- Borla with DMH E-Cutout...HP increase?
- STOCK Radio on a 95 same as 94??
- how thin is to thin on......
- Checkin the coil??
- @#$^%#$% Broken Intake
- AC affecting our 1/4 mile???!!!
- cut out...before the overtheaxle or...
- where can I get a cheap cat?
- tb bypass without a kit
- what are the best spark plugs to get if im gna run 100 shot
- LT4 Hotcam - how will it affect gas mileage?
- parts for true duals
- Poly Motor Mounts
- cant find last 2 bolts in water pump removal
- Granatelli 2
- New motor smoking
- Play in front steering
- Car won't start, Please Help
- Rear Seal, how hard to replace ?
- SFC install question
- quick question
