View Full Version : LT1 Based Engine Tech
- ported heads and fuel question
- 93 m29 vs 94+ M6 should I trade?
- Honest opinions on Nitrous
- HELP ???? ON ORDERING 02`s WTF
- Part number for revised Canton oilpan?
- attn madwolf
- switching 93 to 94 pcm and wirring harness
- what track times?
- Heads need machining for CC 987 springs?
- dynotech dynaspark
- Short throw handle on ebay
- OK. Last few questions before header install.
- A few questions?
- roller rockers????
- Let's say you were going to swap in a first gen block??
- What would cause one spark plug to be worse than other 7?
- help
- BF Goodwrich Drag Radials
- another exhaust question...
- Cam Noob Needs Help
- oil pan gasket
- HELP!! Car idle is horrible!
- Need help about Z28 speedo
- time guestimate
- what bushings to change out?
- Bearing choices
- A/C delete, options to the 1LE pulley?
- Crane 10308-1 springs fit with no machining?
- What's the average life of a lt-1 fuel pump?
- 96 SS air intake
- how does this cam converter combo look to you
- Go with true duals or cutout??
- Can I shave a full second off with this?
- when to change shocks?
- belt pulley??
- Electric water pump- Great at Bleeding coolant
- got my cats taken off for cheap!
- i bypassed the throttle body bypass
- madcat pcm tune help
- What's needed to put a Ford 9" under my Z?
- Mallory Ignition
- Best ignition for an LT1
- Cut-out, to LOUD for street?
- Valve question
- Will a LS1 inake fit on a LT1
- Longtube Header Install question
- Do you have over 150k on your original engine?
- who should i contact for a custom grind solid roller
- LT1 block and Heads
- Hardtop Different than a Convert?
- Fix It Questions
- ahhhhhhhhhhhhhhhhhhhhhh yes jet hots on--fired her up
- Back to the dilemma.
- Dual cat catback fit on a single cat y pipe?
- ok to mix up 5w30 and 10w30?
- matching jet hot long tubes to y pipe...
- Side of lifter has a hole in it. What is this for?
- Little black box to run fans and electric water pump with the key off???
- what would be my best option to go fast?
- Dead Battery Woes
- Heads or Cam?
- Cold power steering pump not working?
- gauge install help
- Can this happen to us?? see inside
- H/C swap parts list check....
- o2 sensors at work?
- What bushings to replace with shock and springs
- summit turbo mufflers for duals
- gasket set Q??
- Where to buy engine kits?
- Ceramic or Jet Hot, difference??
- What is LSA on a Cam ??
- Valve cover gasket leak, possible?
- Question 2 for the day...
- Stroker Kit?
- Where is a good place online to buy.......
- Oil pressure question?
- Intake oil leak.
- Lokar or Milodon
- Cams & Rockers
- can you throw a DTC:48 MAF SYSTEM MALFUNCTION without setting off the SES light?
- What the Fudgens?
- Lokar Dipstick, Sealant in the oil
- cheapest place to buy spec stageIII? What material?
- Cam install write up?
- bad starter right?
- spark plug ?
- where to shift???
- another lt1 vs lt4 question
- cylinder compression test
- LT4 questions, again.
- fuel pump
- Dead animal stuck to exhaust thread...
- LT1-LT4 conversion kit
- HoRsEpOwEr/ ToRqE questions..
- I need another GM part number....
- 275/40R-17 Ventus HRII H405
- Anybody gonna buy a cc306?
- Easiest way to get stock program?
- SES light after alarm install
- Pick one of these 2
- BLMs for PCMforless CC305 program....
- TPiS long tubes with Prokit or Sportsline?
- Attn: Guys with 4.10s
- Header leak and O2 sensor need to be
- Does ACDelco wire set include coil wire?
- Im getting new gears, which do you prefer
- Hooker LT/X-pipe question
- Just bought a Dremel...how can I use it on my car?
- Alternator Wine?
- which fluid is this leaking? brake vs. power steering
- Dirtiest front cover ever?
- M6 daily driver cam
- TB Bypass 93 LT1
- Anyone have an XE230/236 sound clip?
- Anyone With This Cam?????
- Which Muffler Flows more
- How determine what is ticking?
- Exhaust cutouts
- what cam is best for daily driver??
- carpet sound deadner
- LT's and a cutout...
- Need part number
- No start up???
- What sort of performance gains from these fix ups
- stall to match XE 230/236
- how far should the cam dowel pin protrude from th e cam gear??
- Do brass brake fittings wear out?
- Heads and Cam question
- Head Gasket
- MAC header owners unite....
- Opti goin out?
- Taylor Over the valve cover
- DirectHits Ignition
- flushed heater core heat still not HOTT
- High IAC Counts and High MAP
- best place to get gears and install kit for 3:73
- Any way to check the coil?
- Anyone running a Spohn TA with FLP Long Tubes?
- exhaust flow charateristics post?
- Part # for front upper shock mounts
- Anyone have iforged pics of......
- Best O2 Sensors, Bosch or GM?
- lifter guides question
- dyno results 224/230
- How to change?
- Fulda Tires
- Pics of Hooker Cat-back...
- 10 bolt rearend
- Quaker State Oil Filters
- k-motion springs whos runnin em?
- cam question
- i need help finding a link
- LT1 going into '57, need help
- how long is 93-95 converter
- ? for the WS6 guys
- does all fbodys have the same rear carrier?
- Full Exhaust setup?
- 97 heads on a 93 and other ?'s
- Anyone running GTPs cams
- LT4 conversion/AFR Heads/FLP LTs/!cat/Borla revving video
- Cuts out on full throttle
- benifits of K-member
- 93 LT1 owners
- Can someone post a small video for me please ?
- GM 847 Idle + Rev video
- Question about factory speedometer
- air feul gauge
- How do i???
- Left 02 Lean and BLM of 160 all the time
- ASP pulley/balancer weight
- Piston slap in GM Motors
- Cam question
- Your opinon of this cam choice...
- Dyno tuning
- 1.6 with GM847??
- HELP!! i think water got in my motor
- Gm Performance LT4 conversion kit ?
- brass bushing in an auto?????
- 94Z has a spun main. need advice.
- new camaro owner
- advise on a mcleod clutch?
- Need Help Diagnosing Car from Log Files
- LT-1 Edit
- Idle Problems.
- Guage difference between 93 and 94?
- Headlight Covers & Best RPM/MPG
- Cam question
- Mid 11's with xe224/230 and ported stock heads?
- Left 02 Lean only at Idle.... Any clues??
- have flow numbers for LPE LT4's?
- Dual cat y-pipe
- Fuel Pump?
- How to identify PM rods?
- Supplemental vaccum pump, anyone do this?
- Putting It Together
- Where are u guys buying your Nittos from????
- Dart heads?
- Snapped a bolt conecting the Y-Pipe... can I replace it?
- CC306 vs. XE 230/236??
- screeching noise
- long tubes
- what is the most lift that you can run with a stock hyd. roller lifter?
- shift kit
- hppIII
- Interior light problem
- rear end?
- Window rattle, what should I look for?
- what is the biggest valves you can put in a lt1 head ?
- PCM4Less and Smog
- How are these mods?
- A couple more header install ???
- how to make a hooker louder?
- Ordering Bare AFRs
- Ordering a new Coil..which one should I get?
- Sagging rear suspension
- Ignition Coil???
- Hmm MSD Coil has rust on the terminal...
- Temp gauge reading too hot after LT header install...
- OptiSpark - Optical Side.
- How difficult is it to replace the steering rack??
- Post for people wanting a cheap awseme CAI
- OK..now can someone tell me what is wrong with my heater!
- Routing Plug Wires
- SS and Firehawk rear springs
- 93 Z28 No spark situation
- Oil everywhere??
- High temp. tape instead of Jet Hot Coating???
- Tell Me A Story About Lloyd Elliott LT1 Heads...
- 93 Z28 Harmonic Balancer
- hmmm i think i just messed up big time..jethot slipfit tube...read
- So I have 918 springs for my LT1. ???
- Installing Studs??
- Antenna question
- I need Help with Stock 95Z28 MAF sensor readings
- 93 Z, has fuel, no spark. Even changed opti
- 93 balancer, No key, shed some light?
- How many pounds for the air conditioner??
- Should I get new injectors???
- Won't Go Into Reverse Sometimes??
- pictures of my porting, am I on the right track at least?
- What cam are you running in your stroker?
- 98 & up T/A M6 center console fit my 95 T/A M6??
- chassis twist??
- New cam install??
- Finally fixed my car....or thought it was fixed!
- LSU wins the National Championship!!!
- Hooker LT - Emissions - GMMG catback?
- Why always these 2???
- Do you bleed ABS with the car running?
